BSOD during Battlefield 3. Please help.
Please go to the third post as it is in the correct format.
Trouble
Noob Whisperer
Hello and welcome to the forum.
Please read the first post in this sticky thread here How to ask for help with a BSOD problem
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Good luck
Randy
Hi, I have been experiencing blue screen errors when running the game in Ultra mode. The game runs fine, super smooth, but i have had 5 blue screen errors and have since switched to high settings. If anybody can help me figure this out i would really appreciate it.
Just so you know, I have never encountered a blue screen error before this. Only BF3 is giving me trouble. When running on ultra settings, it runs fine, even in multiplayer. All of a sudden it will go to BSOD without any real pattern.
If there is anything else I need to add to get a response please let me know.
Elmer
Hi TheBDU and Welcome to The Forum.
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Device driver.
Your latest dump file lists dxgmms1.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
Your dumps are mainly graphics related though.
As a Priority:
Reset your graphics driver set up.
AMD Graphics Drivers
  • Download and install DriverSweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
Drivers with Updates:
bcmwlhigh664.sys Fri Nov 06 00:27:07 2009 bcwl664, Wiki Drivers (01/03/2011).
Rt64win7.sys Tue Sep 27 15:50:33 2011 Realtek PCIe GBE Family Controller v7.050 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
BugCheck D1, {9c, 2, 1, fffff8800480be7d}
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiProfilePerformanceTick+6f1 )
Followup: MachineOwner
Drivers:
fffff880`011b3000 fffff880`011f1000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f52000 fffff880`00fa9000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`0400c000 fffff880`04095000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04512000 fffff880`04528000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01038000 fffff880`01043000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0855e000 fffff880`08569000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00c3c000 fffff880`00c45000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0100e000 fffff880`01038000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`05b31000 fffff880`05b4b000   AtihdW76 AtihdW76.sys Tue Oct 18 08:09:49 2011 (4E9D263D)
fffff880`04883000 fffff880`052e9000   atikmdag atikmdag.sys Thu Nov 10 02:52:46 2011 (4EBB3C7E)
fffff880`04200000 fffff880`04255000   atikmpag atikmpag.sys Thu Nov 10 02:12:44 2011 (4EBB331C)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
fffff880`07229000 fffff880`072f9000   bcmwlhigh664 bcmwlhigh664.sys Fri Nov 06 00:27:07 2009 (4AF36D5B)
fffff880`01609000 fffff880`01610000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04376000 fffff880`04387000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`07dc5000 fffff880`07de3000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`006b0000 fffff960`006d7000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`019ce000 fffff880`019f8000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d0b000 fffff880`00dcb000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01968000 fffff880`01998000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cad000 fffff880`00d0b000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01101000 fffff880`01173000   cng      cng.sys      Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`04502000 fffff880`04512000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`06d09000 fffff880`06d17000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`042d5000 fffff880`04358000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`04358000 fffff880`04376000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`041e2000 fffff880`041f1000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01952000 fffff880`01968000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05b88000 fffff880`05baa000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`06d23000 fffff880`06d2c000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06d17000 fffff880`06d23000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06d2c000 fffff880`06d3f000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07306000 fffff880`07312000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`052e9000 fffff880`053dd000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0108f000 fffff880`010a3000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01043000 fffff880`0108f000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01918000 fffff880`01952000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01815000 fffff880`0185f000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`03207000 fffff800`03250000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0486a000 fffff880`0487b000   HECIx64  HECIx64.sys  Thu Sep 22 17:38:44 2011 (4E7B6494)
fffff880`06d4d000 fffff880`06d66000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06d66000 fffff880`06d6e080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06d3f000 fffff880`06d4d000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`07cfc000 fffff880`07dc5000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0190f000 fffff880`01918000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`044ec000 fffff880`04502000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`045e8000 fffff880`045f7000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0733c000 fffff880`0734a000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00ba7000 fffff800`00bb1000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`05a39000 fffff880`05a7c000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013e4000 fffff880`013ff000   ksecdd   ksecdd.sys   Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`05baa000 fffff880`05baf200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`084ed000 fffff880`0854f800   ladfGSCamd64 ladfGSCamd64.sys Mon Apr 11 19:41:01 2011 (4DA34B3D)
fffff880`0858a000 fffff880`085dbd00   ladfGSRamd64 ladfGSRamd64.sys Mon Apr 11 19:41:07 2011 (4DA34B43)
fffff880`05a7c000 fffff880`05a7fd80   LGBusEnum LGBusEnum.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`08569000 fffff880`0856b480   LGVirHid LGVirHid.sys Tue Nov 24 01:36:48 2009 (4B0B38B0)
fffff880`0737b000 fffff880`07390000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07358000 fffff880`0737b000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`06cfb000 fffff880`06d09000   MBfilt64 MBfilt64.sys Fri Jul 31 04:40:32 2009 (4A7267B0)
fffff880`00c4a000 fffff880`00c99000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`0734a000 fffff880`07358000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04400000 fffff880`0440f000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0732f000 fffff880`0733c000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00dcb000 fffff880`00de5000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0142b000 fffff880`0145c000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`080c7000 fffff880`080d7000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`07de3000 fffff880`07dfb000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`07c00000 fffff880`07c2d000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`07c2d000 fffff880`07c7b000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`07c7b000 fffff880`07c9f000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`0122d000 fffff880`01238000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fb2000 fffff880`00fbc000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010a3000 fffff880`01101000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`041d7000 fffff880`041e2000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`018fd000 fffff880`0190f000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014ac000 fffff880`0159f000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0454c000 fffff880`04558000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`073e3000 fffff880`073f6000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04558000 fffff880`04587000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`05b1c000 fffff880`05b31000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`0411f000 fffff880`0412e000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04095000 fffff880`040da000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0159f000 fffff880`015ff000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`084d5000 fffff880`084ed000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`01173000 fffff880`01184000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`041cb000 fffff880`041d7000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c1e000 fffff800`03207000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01241000 fffff880`013e4000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01600000 fffff880`01609000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`05b03000 fffff880`05b1c000   nusb3hub nusb3hub.sys Thu Feb 10 05:52:32 2011 (4D537D20)
fffff880`043ad000 fffff880`043de000   nusb3xhc nusb3xhc.sys Thu Feb 10 05:52:33 2011 (4D537D21)
fffff880`07390000 fffff880`073e3000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`040e3000 fffff880`04109000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00e00000 fffff880`00e15000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fbc000 fffff880`00fef000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e86000 fffff880`00e8d000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e8d000 fffff880`00e9d000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`08021000 fffff880`080c7000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05b4b000 fffff880`05b88000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c99000 fffff880`00cad000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04528000 fffff880`0454c000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04587000 fffff880`045a2000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`045a2000 fffff880`045c3000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`045c3000 fffff880`045dd000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0417a000 fffff880`041cb000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`045dd000 fffff880`045e8000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`0149f000 fffff880`014a8000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0121b000 fffff880`01224000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01224000 fffff880`0122d000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018c3000 fffff880`018fd000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`07200000 fffff880`07218000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04437000 fffff880`044d7000   Rt64win7 Rt64win7.sys Tue Sep 27 15:50:33 2011 (4E81E2B9)
fffff880`0687d000 fffff880`06cfaf00   RTKVHD64 RTKVHD64.sys Tue Dec 06 10:47:23 2011 (4EDDF2BB)
fffff880`080d7000 fffff880`080e2000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`044d7000 fffff880`044e3000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0412e000 fffff880`0414b000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`018bb000 fffff880`018c3000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0843d000 fffff880`084d5000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`08125000 fffff880`0818e000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`080e2000 fffff880`08113000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0440f000 fffff880`04410480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01611000 fffff880`01815000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`08113000 fffff880`08125000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`011a6000 fffff880`011b3000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01184000 fffff880`011a6000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04166000 fffff880`0417a000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04387000 fffff880`043ad000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`05a97000 fffff880`05aa9000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0856f000 fffff880`08589c80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`07312000 fffff880`0732f000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`053ee000 fffff880`053eff00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`053dd000 fffff880`053ee000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`05aa9000 fffff880`05b03000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04255000 fffff880`042ab000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00fef000 fffff880`00ffc000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0145c000 fffff880`0146a000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0146a000 fffff880`0148f000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00c00000 fffff880`00c3c000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`0185f000 fffff880`0186f000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e2a000 fffff880`00e86000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`0186f000 fffff880`018bb000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`072f9000 fffff880`07306000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`04109000 fffff880`0411f000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`0414b000 fffff880`04166000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`0148f000 fffff880`0149f000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e9f000 fffff880`00f43000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f43000 fffff880`00f52000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`040da000 fffff880`040e3000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000d0000 fffff960`003e4000   win32k   win32k.sys   Thu Nov 24 04:51:38 2011 (4ECDCD5A)
fffff880`00de5000 fffff880`00df9000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`05a80000 fffff880`05a84d00   WmBEnum  WmBEnum.sys  Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`06d6f000 fffff880`06d78180   WmFilter WmFilter.sys Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`044e3000 fffff880`044ec000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fa9000 fffff880`00fb2000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`0856c000 fffff880`0856e500   WmVirHid WmVirHid.sys Tue Apr 27 21:08:53 2010 (4BD74455)
fffff880`05a85000 fffff880`05a96480   WmXlCore WmXlCore.sys Tue Apr 27 21:09:26 2010 (4BD74476)
Unloaded modules:
fffff880`084ed000 fffff880`0855e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01998000 fffff880`019a6000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019a6000 fffff880`019b2000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019b2000 fffff880`019bb000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019bb000 fffff880`019ce000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Thank you so much. I'm gonna try it out now. Really appreciate the help.
#7
Still having BSOD issues and only during Battlefield 3 on ultra settings. I will attach a folder with the new BSOD. Any help would be appreciated.
Saltgrass
#8
Maybe more info about how you are running the game and system particulars.
Are you using Steam to run online?
What type of Internet connection do you have, if you are online?
Have you or can you change individual settings in the Ultra quality settings?
Have you tried any sound quality changes?
Any heat problems?
Edit: Do you notice any situations when the crashes occur, like during certain scenes with bright graphics or explosions, in gave videos, etc.
Trouble
Noob Whisperer
#9
Additionally you may have a go at
Disabling EIST (Enhanced Intel SpeedStep Technology)
and
Enabling XMP (eXtreme Memory Profile) in your BIOS and see if that has any impact on how the game performs.
Regards
Randy
#10
Any heat problems?
I run the game without anything else in the background. I am now running on auto settings, which does NOT bsod, but I should be able to handle ultra settings. The game runs smoothly on ultra, just it will BSOD randomly
The game runs through origin (EA) not steam
I am at a hotel currently, using a usb network adapter (600 transfer rate)
I can change the settings, just this is a brand new computer and I should be able to run ultra. Like I said, I'm currently playing on auto now (mostly high) to avoid BSOD
sound quality in the game can't really be changed. You just pick the source.
I don't think I have heat issues, I am using a cooler master HAF932 advanced case, it has 3 GIANT fans. Not sure how to check that though.
Lastly, the crashes seem to occur at random. I haven't figured out any pattern.
