ishdeepanand
I am getting Windows 7 crashes (BSOD) with alarmingly increasing frequency.
A bit of googling and I reached this software called WhoCrashed.
THe output of the last few crashes is below.
Can someone suggest what could be the problem
System Information (local)
computer name: RUBAL-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 3077238784 total
VM: 2147352576, free: 1982308352
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 12/2/2011 4:47:52 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-18642-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x664C0)
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF88005815FB5)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: netw5s64.sys (NETw5s64+0x13FB5)
file path: C:\Windows\system32\drivers\netw5s64.sys
product: Intel® Wireless WiFi Link Adapter
company: Intel Corporation
description: Intel® Wireless WiFi Link Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: netw5s64.sys (Intel® Wireless WiFi Link Driver, Intel Corporation).
Google query: netw5s64.sys Intel Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
On Fri 12/2/2011 3:14:29 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-15709-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF88005889FB5)
On Fri 12/2/2011 2:26:05 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-23774-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF88005845FB5)
On Fri 12/2/2011 2:13:48 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-17721-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF88005866FB5)
On Fri 12/2/2011 1:48:49 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-16286-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF88005822FB5)
On Fri 12/2/2011 1:18:47 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\120211-19952-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF880058B0FB5)
Crash Dump Analysis
