Hi oakfold and Welcome to The Forum.
STOP 0x00000024: NTFS_FILE_SYSTEM
Usual causes: Disk corruption, insufficient physical memory, Device driver, Indexing, Resident antivirus, backup, defrag programs, Disk/Drive failing/failure.
Your latest dump file lists
Ntfs.sys as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes
(which you have!) can often indicate hardware issues.
As a Priority: AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct
AVG Remover for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well
(it wouldn't hurt to download and run it anyway). Download BSOD friendly
Link Removed due to 404 Error as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the
AVG Removal tool
(s). Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled! After your blue screens have been resolved, feel free to re-try AVG.
ASACPI.sys Mon Mar 28 03:30:36 2005 This driver is notorious for causing BSOD's. You have two options:
- You can disable the ATK0110 ACPI Utility in the DeviceManager (under System Devices) with no apparent issues. OR (and if disabling does cause issues)
- There is an update here: Asus ATK0110 driver. Look under the sub-heading: Utilities. 12th one down.
Driver Install - Manual method - Download the driver and extract it to a folder.
- Open the Device Manager.
- Right click the device you wish to change the drivers for. You can select Properties > Driver > Driver Details to check you have the right device. In this case System Devices >> ATK0110 ACPI Utility
- Choose Update Driver Software.
- Select Browse My Computer For Driver Software.
- Select Let me pick from a list of device drivers on my computer.
- Select Have disk...
- Select Browse..
- Navigate to the extracted folder and double click on the .inf file
- Hit OK, then Next and the driver(s) will then begin to install.
- After it has installed, GoTo C:\Windows\System32\Drivers. Locate the Asacpi.sys driver, right click it and check the dates under its properties. You're looking for a "Modified" date of 2009 or 2010. Occasionally it can be a bit stubborn to change.
Make sure your system is fully updated including SP1. Download and install the correct system readiness tool
prior to installing SP1.
System Update Readiness Tool for 32bit (x86) System Update Readiness Tool for 64bit (x64) Drivers that pre-date Windows 7. Update: Rt64win7.sys Thu Feb 26 09:04:13 2009 Realtek PCIe GBE Family Controller v7.050 If you're unsure about manually installing drivers then choose the
Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
nvlddmkm.sys Thu May 14 21:48:07 2009 nVidia Graphics Drivers. - Download and install DriverSweeper.
- Uninstall your current Graphics setup through Programs and Features
- Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
- Reboot to Normal Mode.
- Install your new Graphics set up.
Drivers with Updates: RTL8192su.sys Thu Nov 25 06:13:42 2010 Realtek RTL8192SU Wireless LAN 802.11n USB 2.0 Network Adapter Driver. Scroll down the page to the
8192SU sub header.
Bugcheck Analysis: Code:
* Bugcheck Analysis *
BugCheck 24, {1904fb, fffff880047f5528, fffff880047f4d90, fffff80002847758}
Probably caused by : Ntfs.sys ( Ntfs!NtfsCreateNewFile+3a0 )
Followup: MachineOwner
Drivers: Code:
fffff880`03c00000 fffff880`03c3e000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00f8a000 fffff880`00fe1000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02d5d000 fffff880`02de6000 afd afd.sys Wed Dec 28 03:59:08 2011 (4EFA940C)
fffff880`0487b000 fffff880`04891000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`03ba8000 fffff880`03bbd000 amdppm amdppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00ff4000 fffff880`00fff000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`03df2000 fffff880`03dfa000 ASACPI ASACPI.sys Mon Mar 28 03:30:36 2005 (42476C4C)
fffff880`07b41000 fffff880`07b4c000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00ecd000 fffff880`00ed6000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00d90000 fffff880`00dba000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`01982000 fffff880`01991000 avgfwd6a avgfwd6a.sys Sun May 22 23:33:25 2011 (4DD98F35)
fffff880`07937000 fffff880`07962000 AVGIDSDriver AVGIDSDriver.Sys Sun Jul 10 23:36:37 2011 (4E1A2975)
fffff880`0187e000 fffff880`01888000 AVGIDSEH AVGIDSEH.Sys Sun Jul 10 23:36:50 2011 (4E1A2982)
fffff880`061dd000 fffff880`061e8000 AVGIDSFilter AVGIDSFilter.Sys Sun Jul 10 23:37:05 2011 (4E1A2991)
fffff880`03b39000 fffff880`03b82000 avgldx64 avgldx64.sys Fri Oct 07 04:55:41 2011 (4E8E783D)
fffff880`018e8000 fffff880`018f8000 avgmfx64 avgmfx64.sys Mon Aug 08 04:41:46 2011 (4E3F5AFA)
fffff880`01872000 fffff880`0187e000 avgrkx64 avgrkx64.sys Tue Sep 13 05:02:34 2011 (4E6ED5DA)
fffff880`02cb8000 fffff880`02d18000 avgtdia avgtdia.sys Sun Jul 10 23:46:53 2011 (4E1A2BDD)
fffff880`01901000 fffff880`01908000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03b28000 fffff880`03b39000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`06157000 fffff880`06175000 bowser bowser.sys Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff960`006f0000 fffff960`00717000 cdd cdd.dll unavailable (00000000)
fffff880`05fc0000 fffff880`05fdd000 cdfs cdfs.sys Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`018be000 fffff880`018e8000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00ca6000 fffff880`00d66000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`01842000 fffff880`01872000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00c48000 fffff880`00ca6000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`010d9000 fffff880`0114c000 cng cng.sys Thu Nov 17 04:26:35 2011 (4EC48CFB)
fffff880`0486b000 fffff880`0487b000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`05e31000 fffff880`05e3f000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03a87000 fffff880`03b0a000 csc csc.sys Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03b0a000 fffff880`03b28000 dfsc dfsc.sys Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`03a78000 fffff880`03a87000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01235000 fffff880`0124b000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0403d000 fffff880`0405f000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05e4b000 fffff880`05e54000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05e3f000 fffff880`05e4b000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05e54000 fffff880`05e67000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05e92000 fffff880`05e9e000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`03c62000 fffff880`03d56000 dxgkrnl dxgkrnl.sys Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`03d56000 fffff880`03d9c000 dxgmms1 dxgmms1.sys Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`01067000 fffff880`0107b000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0101b000 fffff880`01067000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`00dba000 fffff880`00df4000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff800`02de8000 fffff800`02e31000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`03dce000 fffff880`03df2000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`0417b000 fffff880`041d7000 HdAudio HdAudio.sys Tue Jul 14 01:06:59 2009 (4A5BCC23)
fffff880`05e00000 fffff880`05e19000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`05e19000 fffff880`05e21080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05fdd000 fffff880`05feb000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`06000000 fffff880`060c8000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`015f3000 fffff880`015fc000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`03bec000 fffff880`03bfb000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05e84000 fffff880`05e92000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bd5000 fffff800`00bdf000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`040b7000 fffff880`040fa000 ks ks.sys Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000 ksecdd ksecdd.sys Thu Nov 17 03:54:33 2011 (4EC48579)
fffff880`01460000 fffff880`0148b000 ksecpkg ksecpkg.sys Thu Nov 17 04:27:30 2011 (4EC48D32)
fffff880`0405f000 fffff880`04064200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05ecf000 fffff880`05ee4000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05eac000 fffff880`05ecf000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c27000 fffff880`00c34000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`05e9e000 fffff880`05eac000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03a00000 fffff880`03a0f000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05e24000 fffff880`05e31000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00d76000 fffff880`00d90000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`06175000 fffff880`0618d000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0618d000 fffff880`061ba000 mrxsmb mrxsmb.sys Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`04065000 fffff880`040b3000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:44:55 2011 (4E17C0A7)
fffff880`061ba000 fffff880`061dd000 mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`01966000 fffff880`01971000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fea000 fffff880`00ff4000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0107b000 fffff880`010d9000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`03a6d000 fffff880`03a78000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`015e1000 fffff880`015f3000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014ef000 fffff880`015e1000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`053d0000 fffff880`053dc000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0612c000 fffff880`0613f000 ndisuio ndisuio.sys Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`03bbd000 fffff880`03bec000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04166000 fffff880`0417b000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02c3c000 fffff880`02c4b000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02d18000 fffff880`02d5d000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01971000 fffff880`01982000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03a61000 fffff880`03a6d000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0280d000 fffff800`02de8000 nt ntkrnlmp.exe Sat Nov 19 12:35:16 2011 (4EC7A284)
fffff880`01257000 fffff880`013fa000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`018f8000 fffff880`01901000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`048a4000 fffff880`053abb00 nvlddmkm nvlddmkm.sys Thu May 14 21:48:07 2009 (4A0C8387)
fffff880`060d9000 fffff880`0612c000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02c00000 fffff880`02c26000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00ec6000 fffff880`00ecd000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00d66000 fffff880`00d76000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`07847000 fffff880`078ed000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04000000 fffff880`0403d000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c34000 fffff880`00c48000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`053ac000 fffff880`053d0000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`053dc000 fffff880`053f7000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`02c97000 fffff880`02cb8000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`019bc000 fffff880`019d6000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03a10000 fffff880`03a61000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`04891000 fffff880`0489c000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`0194b000 fffff880`01954000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01954000 fffff880`0195d000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0195d000 fffff880`01966000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01198000 fffff880`011d2000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`0613f000 fffff880`06157000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03d9c000 fffff880`03dce000 Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`05ef0000 fffff880`05fb3000 RTL8192su RTL8192su.sys Thu Nov 25 06:13:42 2010 (4CEDFE96)
fffff880`078ed000 fffff880`078f8000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`04856000 fffff880`04862000 serenum serenum.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`02c4b000 fffff880`02c68000 serial serial.sys Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`014e5000 fffff880`014ed000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`07ad0000 fffff880`07b41000 spsys spsys.sys Mon May 11 18:20:58 2009 (4A085E7A)
fffff880`07a3b000 fffff880`07ad0000 srv srv.sys Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`07962000 fffff880`079c9000 srv2 srv2.sys Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`078f8000 fffff880`07925000 srvnet srvnet.sys Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`03dfa000 fffff880`03dfb480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`01800000 tcpip tcpip.sys Thu Sep 29 04:52:31 2011 (4E83EB7F)
fffff880`07925000 fffff880`07937000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`019af000 fffff880`019bc000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01991000 fffff880`019af000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02c83000 fffff880`02c97000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`004b0000 fffff960`004ba000 TSDDD TSDDD.dll Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`03b82000 fffff880`03ba8000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`040fa000 fffff880`0410c000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`05e67000 fffff880`05e84000 usbccgp usbccgp.sys Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`05e22000 fffff880`05e23f00 USBD USBD.SYS Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`03c49000 fffff880`03c5a000 usbehci usbehci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`0410c000 fffff880`04166000 usbhub usbhub.sys Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`03c3e000 fffff880`03c49000 usbohci usbohci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04800000 fffff880`04856000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`00e33000 fffff880`00e40000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01908000 fffff880`01916000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01916000 fffff880`0193b000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000 vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`0114c000 fffff880`01198000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`05fb3000 fffff880`05fc0000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02c26000 fffff880`02c3c000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`02c68000 fffff880`02c83000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`0193b000 fffff880`0194b000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00ed7000 fffff880`00f7b000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f7b000 fffff880`00f8a000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02de6000 fffff880`02def000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00334000 win32k win32k.sys Fri Feb 03 04:15:32 2012 (4F2B5F64)
fffff880`04862000 fffff880`0486b000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fe1000 fffff880`00fea000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
Unloaded modules:
fffff880`01888000 fffff880`01896000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01896000 fffff880`018a2000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`018a2000 fffff880`018ab000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`018ab000 fffff880`018be000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
