Hello and welcome to the forum.
Start by getting rid of this
sptd.sys 8/24/2010
Normally associated with Daemon Tools (but may be Alcohol or something else) go here
DuplexSecure - Downloads, get the correct version for your architecture and run it and click
UNINSTALL Code:
BugCheck BE, {fffff880010910b0, 8000000003caa121, fffff8800ac89270, a}
Unable to load image \SystemRoot\System32\Drivers\[COLOR=#ff0000][U][B]sptd.sys[/B][/U][/COLOR], Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for [COLOR=#ff0000][U][B]sptd.sys[/B][/U][/COLOR]
Probably caused by : atapi.sys ( atapi!AtapiSetupPrdTable+2b )
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff880010910b0, Virtual address for the attempted write.
Arg2: 8000000003caa121, PTE contents.
Arg3: fffff8800ac89270, (reserved)
Arg4: 000000000000000a, (reserved)
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xBE
PROCESS_NAME: Diablo III.exe
CURRENT_IRQL: 7
TRAP_FRAME: fffff8800ac89270 -- (.trap 0xfffff8800ac89270)
rax=fffff8800ac89450 rbx=0000000000000000 rcx=fffffa800d6da6a8
rdx=fffffa800e626978 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001090bde rsp=fffff8800ac89408 rbp=000000000000000e
r8=000000000000000a r9=fffffa800d6da6a8 r10=3ee3dab0a4950000
r11=fffff8800ac89450 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei ng nz na pe nc
atapi!AtaPortGetScatterGatherList:
fffff880`01090bde ff25cc040000 jmp qword ptr [atapi!_imp_AtaPortGetScatterGatherList (fffff880`010910b0)] ds:ff00:fffff880`010910b0={ataport!AtaPortGetScatterGatherList (fffff880`0109bf24)}
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80003153718 to fffff800030d5f00
STACK_TEXT:
fffff880`0ac89108 fffff800`03153718 : 00000000`000000be fffff880`010910b0 80000000`03caa121 fffff880`0ac89270 : nt!KeBugCheckEx
fffff880`0ac89110 fffff800`030d3fee : 00000000`c7287000 fffffa80`0e626978 000020d0`b51d0028 00000000`00000010 : nt! ?? ::FNODOBFM::`string'+0x40a84
fffff880`0ac89270 fffff880`01090bde : fffff880`0108f60b 00000000`000001f6 fffffa80`0e626901 00000000`0000000e : nt!KiPageFault+0x16e
fffff880`0ac89408 fffff880`0108f60b : 00000000`000001f6 fffffa80`0e626901 00000000`0000000e fffff880`0108f5c9 : atapi!AtaPortGetScatterGatherList
fffff880`0ac89410 fffff880`0108f137 : fffffa80`0e626978 00000000`0000000e fffffa80`0e6269c0 fffffa80`0d6da6a8 : atapi!AtapiSetupPrdTable+0x2b
fffff880`0ac89460 fffff880`0108eee1 : fffffa80`0d450a50 fffffa80`0e626978 00000000`0000000e fffffa80`0cbd9000 : atapi!AtapiSendAtaCommand+0x11b
fffff880`0ac894d0 fffff880`0108e656 : fffffa80`0e626978 fffffa80`0da7b950 fffff880`0ac89750 00000004`000002d4 : atapi!AtapiHandleAtaCommand+0x45
fffff880`0ac89500 fffff880`00e7e296 : 00000000`0000003c 00000000`00000000 00000000`00000000 00000000`00000000 : atapi!AtapiHwStartIo+0x66
fffff880`0ac89530 00000000`0000003c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : [SIZE=3][COLOR=#ff0000][U][B]sptd[/B][/U][/COLOR][/SIZE]+0x46296
fffff880`0ac89538 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x3c
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff880`0108f60b 488bf0 mov rsi,rax
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: atapi!AtapiSetupPrdTable+2b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atapi
IMAGE_NAME: atapi.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc113
FAILURE_BUCKET_ID: X64_0xBE_atapi!AtapiSetupPrdTable+2b
One other suspicious driver
ahur1i04.SYS 7/17/2010
I say suspicious, because neither Google or Bing produces any information. So it may be worth doing a little investigating to see if you can determine what it is, what it is for and why it is loading. If not sure you may want to consider renaming it by changing the extension from ahur1i04.SYS to ahur1i04.OLD .... up to you.
If Blue Screens persist then:
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here
How to ask for help with a BSOD problem Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and
right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from
all tabs
including all slots populated with memory under the SPD tab. Likewise RAMMon.
Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area
http://windows7forums.com/windows-7...you-filling-your-system-specs.html#post235529 .
And perhaps consider updating to Service Pack 1 for Windows 7
UPDATE READINESS TOOL.
Download and install the correct system readiness tool
prior to installing SP1.
System Update Readiness Tool for 32bit (x86) System Update Readiness Tool for 64bit (x64)
Good luck
Randy
