BSOD every few days.
MEMORY_MANAGEMENT (1a)
BugCheck 1E, {ffffffffc0000005, fffff800033b33de, 0, ffffffffffffffff}
Faulty RAM? Overclocking with Intel Turbo Boost?
Update drivers:
Touchpad
SynTP.sys Wed Dec 23 15:10:23 2009
Notebook support
Intel Manasgement Engine
HECIx64.sys Thu Sep 17 15:54:16 2009
Intel® Driver Update Utility
Webcam
CtClsFlt.sys Mon Jun 15 01:06:41 2009
Notebook support
If blue screens persist, next uninstall AVG and replace it with MSE:
AVG Worldwide - Download tools
Virus, Spyware & Malware Protection | Microsoft Security Essentials
Uninstall Daemon Tools:
sptd.sys Sun Oct 11 16:55:14 2009
DuplexSecure - FAQ
Uninstall Intel(R) Turbo Boost
Impcd.sys Fri Feb 26 18:32:11 2010
If crashes don't go away, first of all make sure you have uninstalled AVG, DAEMON TOOLS, Intel Turbo Boost, and updated the above listed drivers, and then attach this stuff:
- screenshots of CPU-Z CPU and memory tabs
- RAMMon HTML report zipped
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
CRASH DUMPS
Loading Dump File [F:\DMP\032911-50403-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.20826.amd64fre.win7_ldr.101026-1502
Machine Name:
Kernel base = 0xfffff800`03051000 PsLoadedModuleList = 0xfffff800`03285eb0
Debug session time: Tue Mar 29 22:37:57.916 2011 (UTC - 4:00)
System Uptime: 1 days 23:48:29.567
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1A, {41201, fffff683ff7d3988, 3c200001811e0825, fffffa800a5bb970}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+138f2 )
Followup: MachineOwner
2: kd> !analyze -v
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041201, The subtype of the bugcheck.
Arg2: fffff683ff7d3988
Arg3: 3c200001811e0825
Arg4: fffffa800a5bb970
Debugging Details:
BUGCHECK_STR:  0x1a_41201
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000311ed6e to fffff800030b7580
STACK_TEXT:
fffff880`078949b8 fffff800`0311ed6e : 00000000`0000001a 00000000`00041201 fffff683`ff7d3988 3c200001`811e0825 : nt!KeBugCheckEx
fffff880`078949c0 fffff800`0308412e : 00000000`00000000 fffffa80`0a7e0060 00000000`00000000 3c200001`811e0825 : nt! ?? ::FNODOBFM::`string'+0x138f2
fffff880`07894a00 fffff800`03083dca : fffffa80`0a5bb970 fffffa80`09f19b30 fffffa80`09f19b30 000007fe`fa731000 : nt!MiQueryAddressState+0x2ae
fffff880`07894a50 fffff800`0339dff8 : fffff880`07894ca0 000007fe`fa732000 fffffa80`0a5bb970 00000000`00000000 : nt!MiQueryAddressSpan+0xaa
fffff880`07894ac0 fffff800`030b67d3 : 00000000`00000114 fffffa80`0a7e0060 fffff880`07894bc8 00000000`0018a988 : nt!NtQueryVirtualMemory+0x386
fffff880`07894bb0 00000000`7772f8ea : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0018a968 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7772f8ea
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`0311ed6e cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+138f2
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc792b2
FAILURE_BUCKET_ID:  X64_0x1a_41201_nt!_??_::FNODOBFM::_string_+138f2
Loading Dump File [F:\DMP\040311-47939-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`03066000 PsLoadedModuleList = 0xfffff800`032abe90
Debug session time: Sun Apr  3 10:08:22.100 2011 (UTC - 4:00)
System Uptime: 2 days 12:26:02.786
Probably caused by : ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1de )
2: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800033b33de, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
fffff800`033b33de 418b45f4        mov     eax,dword ptr [r13-0Ch]
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800033170e8
 ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR:  0x1E_c0000005
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80003132028 to fffff800030e6640
STACK_TEXT:
fffff880`028f1248 fffff800`03132028 : 00000000`0000001e ffffffff`c0000005 fffff800`033b33de 00000000`00000000 : nt!KeBugCheckEx
fffff880`028f1250 fffff800`030e5cc2 : fffff880`028f1a28 00000000`00000000 fffff880`028f1ad0 fffff880`028f1de0 : nt! ?? ::FNODOBFM::`string'+0x4987d
fffff880`028f18f0 fffff800`030e45ca : 00000000`00000000 00000000`00080008 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`028f1ad0 fffff800`033b33de : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiGeneralProtectionFault+0x10a
fffff880`028f1c60 fffff800`033b40e5 : fffff880`028f1de0 fffff880`00000001 fffff880`028f21f8 fffff880`028f21f0 : nt!CmpKcbCacheLookup+0x1de
fffff880`028f1d50 fffff800`033b0794 : fffff8a0`0ba166f0 fffff880`028f21f0 fffff880`028f2240 fffff880`028f2220 : nt!CmpBuildHashStackAndLookupCache+0x335
fffff880`028f2130 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!CmpParseKey+0x294
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  nt!CmpKcbCacheLookup+1de
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!CmpKcbCacheLookup+1de
DRIVERS
fffff880`0182b000 fffff880`01870000   a9z6aizq a9z6aizq.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00f45000 fffff880`00f9c000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`03ef5000 fffff880`03f7e000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`01de9000 fffff880`01dff000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01461000 fffff880`0146c000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`01413000 fffff880`0141c000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0141c000 fffff880`01446000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`008b0000 fffff960`00911000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`06a43000 fffff880`06a77000   AVGIDSDriver AVGIDSDriver.Sys Tue Aug 03 18:24:45 2010 (4C58972D)
fffff880`01a3a000 fffff880`01a44000   AVGIDSEH AVGIDSEH.Sys Mon Sep 13 18:46:38 2010 (4C8EA9CE)
fffff880`04184000 fffff880`04190000   AVGIDSFilter AVGIDSFilter.Sys Tue Aug 03 18:23:21 2010 (4C5896D9)
fffff880`01a52000 fffff880`01aa2000   avgldx64 avgldx64.sys Tue Dec 07 21:01:55 2010 (4CFEE713)
fffff880`0465f000 fffff880`0466e000   avgmfx64 avgmfx64.sys Mon Sep 06 20:49:14 2010 (4C858C0A)
fffff880`01a30000 fffff880`01a3a000   avgrkx64 avgrkx64.sys Mon Sep 06 20:49:37 2010 (4C858C21)
fffff880`04727000 fffff880`04788000   avgtdia  avgtdia.sys  Fri Nov 12 06:08:42 2010 (4CDD203A)
fffff880`0101e000 fffff880`0102a000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`06eae000 fffff880`06eb7000   BCM42RLY BCM42RLY.sys Thu Jan 21 22:28:23 2010 (4B591B57)
fffff880`01636000 fffff880`0163f000   bcmvwl64 bcmvwl64.sys Thu Jan 21 22:28:30 2010 (4B591B5E)
fffff880`05a0b000 fffff880`05cfa000   bcmwl664 bcmwl664.sys Thu Jan 21 22:30:58 2010 (4B591BF2)
fffff880`04677000 fffff880`0467e000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ea9000 fffff880`03eba000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`027be000 fffff880`027dc000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00670000 fffff960`00697000   cdd      cdd.dll      unavailable (00000000)
fffff880`04635000 fffff880`0465f000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01a00000 fffff880`01a30000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00d2e000 fffff880`00d8c000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05dfb000 fffff880`05dff500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01536000 fffff880`015a8000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`01015000 fffff880`0101e000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`03fed000 fffff880`03ffd000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`065ee000 fffff880`065fc000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`065b5000 fffff880`065df2a0   CtClsFlt CtClsFlt.sys Mon Jun 15 01:06:41 2009 (4A35D6E1)
fffff880`03e8b000 fffff880`03ea9000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`03e7c000 fffff880`03e8b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01dd3000 fffff880`01de9000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`064fb000 fffff880`0651d000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04620000 fffff880`04633000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04416000 fffff880`04620000   dump_iaStor dump_iaStor.sys Tue Jun 08 13:33:03 2010 (4C0E7ECF)
fffff880`0642f000 fffff880`0643b000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`056b1000 fffff880`057a5000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`057a5000 fffff880`057eb000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`06eb7000 fffff880`06eed000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`014b8000 fffff880`014cc000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0146c000 fffff880`014b8000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0162c000 fffff880`01636000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01d99000 fffff880`01dd3000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01ca6000 fffff880`01cf0000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`03ee0000 fffff880`03eed000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`0301d000 fffff800`03066000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04c67000 fffff880`04c8b000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`057eb000 fffff880`057fc000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`06400000 fffff880`06419000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06419000 fffff880`06421080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`065e0000 fffff880`065ee000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`02600000 fffff880`026c9000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01d90000 fffff880`01d99000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`05d6e000 fffff880`05d8c000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01209000 fffff880`01413000   iaStor   iaStor.sys   Tue Jun 08 13:33:03 2010 (4C0E7ECF)
fffff880`04c92000 fffff880`056b0b60   igdkmd64 igdkmd64.sys Wed Aug 25 15:35:58 2010 (4C75709E)
fffff880`047cd000 fffff880`047f3d00   Impcd    Impcd.sys    Fri Feb 26 18:32:11 2010 (4B8859FB)
fffff880`06523000 fffff880`0656a000   IntcDAud IntcDAud.sys Wed Feb 03 08:38:31 2010 (4B697C57)
fffff880`04400000 fffff880`04416000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`05dec000 fffff880`05dfb000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc3000 fffff800`00bcd000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`00e3b000 fffff880`00e7e000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01600000 fffff880`0161b000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01800000 fffff880`0182b000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`0651d000 fffff880`06522200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0272b000 fffff880`02740000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`026dc000 fffff880`026ff000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ccb000 fffff880`00d1a000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`082b4000 fffff880`082c2000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05ddd000 fffff880`05dec000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06422000 fffff880`0642f000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`027dc000 fffff880`027f4000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`040e6000 fffff880`04113000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`04113000 fffff880`04160000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`04160000 fffff880`04184000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`01446000 fffff880`01451000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`046dc000 fffff880`046e7000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011b4000 fffff880`011be000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014d8000 fffff880`01536000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03e71000 fffff880`03e7c000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01d7e000 fffff880`01d90000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0188f000 fffff880`01982000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`047f4000 fffff880`04800000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02793000 fffff880`027a6000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`015cc000 fffff880`015fb000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`00de6000 fffff880`00dfb000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`03fc3000 fffff880`03fd2000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04788000 fffff880`047cd000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01982000 fffff880`019e2000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`046e7000 fffff880`046f8000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03e65000 fffff880`03e71000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03066000 fffff800`03650000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0164f000 fffff880`017f2000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`0466e000 fffff880`04677000   Null     Null.SYS     unavailable (00000000)
fffff880`02740000 fffff880`02793000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03f87000 fffff880`03fad000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`01000000 fffff880`01015000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`011cb000 fffff880`011fe000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`01451000 fffff880`01461000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0161b000 fffff880`0162c000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`04000000 fffff880`040a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`064be000 fffff880`064fb000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d1a000 fffff880`00d2e000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`014cc000 fffff880`014d7e00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`015a8000 fffff880`015cc000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`01870000 fffff880`0188b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`00e1a000 fffff880`00e3b000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`019e2000 fffff880`019fc000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e14000 fffff880`03e65000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`046c1000 fffff880`046ca000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`046ca000 fffff880`046d3000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`046d3000 fffff880`046dc000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01d44000 fffff880`01d7e000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`027a6000 fffff880`027be000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05d07000 fffff880`05d6e000   Rt64win7 Rt64win7.sys Fri Jan 21 02:34:00 2011 (4D3936E8)
fffff880`01185000 fffff880`011b4000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`040a6000 fffff880`040b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06aea000 fffff880`06ba1000   Sftfslh  Sftfslh.sys  Wed Dec 02 19:55:48 2009 (4B170C94)
fffff880`06ba1000 fffff880`06bee000   Sftplaylh Sftplaylh.sys Wed Dec 02 19:55:40 2009 (4B170C8C)
fffff880`06bee000 fffff880`06bf9000   Sftredirlh Sftredirlh.sys Wed Dec 02 19:55:52 2009 (4B170C98)
fffff880`026ff000 fffff880`0270a000   Sftvollh Sftvollh.sys Wed Dec 02 19:55:23 2009 (4B170C7B)
fffff880`01d3c000 fffff880`01d44000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01056000 fffff880`0117c000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`06e15000 fffff880`06eae000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`06a77000 fffff880`06ae2000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`06a00000 fffff880`06a31000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`0643c000 fffff880`064be000   stwrt64  stwrt64.sys  Thu Jun 17 22:16:06 2010 (4C1AD6E6)
fffff880`05a09000 fffff880`05a0a480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`05d8c000 fffff880`05ddb000   SynTP    SynTP.sys    Wed Dec 23 15:10:23 2009 (4B32792F)
fffff880`01aa2000 fffff880`01ca6000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`06a31000 fffff880`06a43000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`0471a000 fffff880`04727000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`046f8000 fffff880`0471a000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`03e00000 fffff880`03e14000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03eba000 fffff880`03ee0000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`0103f000 fffff880`01051000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`0656a000 fffff880`06587000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`05ddb000 fffff880`05ddcf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04c00000 fffff880`04c11000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`00d8c000 fffff880`00de6000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04c11000 fffff880`04c67000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`06587000 fffff880`065b4280   usbvideo usbvideo.sys Sat Nov 20 05:44:34 2010 (4CE7A692)
fffff880`011be000 fffff880`011cb000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0467e000 fffff880`0468c000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0468c000 fffff880`046b1000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0102a000 fffff880`0103f000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00f9c000 fffff880`00ff8000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01cf0000 fffff880`01d3c000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`05cfa000 fffff880`05d07000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`03fad000 fffff880`03fc3000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03fd2000 fffff880`03fed000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`046b1000 fffff880`046c1000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e92000 fffff880`00f36000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f36000 fffff880`00f45000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f7e000 fffff880`03f87000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00321000   win32k   win32k.sys   unavailable (00000000)
fffff880`05a00000 fffff880`05a09000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0117c000 fffff880`01185000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0270a000 fffff880`0272b000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`08097000 fffff880`082a1000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  0020A000
fffff880`082a1000 fffff880`082b4000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06f6c000 fffff880`06f7a000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06f5e000 fffff880`06f6c000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0a4bf000 fffff880`0a4cd000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0a200000 fffff880`0a40a000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  0020A000
fffff880`0a40a000 fffff880`0a41d000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a4cd000 fffff880`0a53e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0a2a2000 fffff880`0a4ac000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  0020A000
fffff880`0a4ac000 fffff880`0a4bf000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`01a44000 fffff880`01a52000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06eed000 fffff880`06f5e000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01a44000 fffff880`01a52000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`04418000 fffff880`04622000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0020A000
fffff880`04622000 fffff880`04635000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks for the help will let you know within next couple days if problem persists after taking all recommended procedures.
