Windows 7 BSOD for the past 6 months
wolverine217
Hi guys would like to ask u guys to help figure out the BSod i have been receiving for the past 6 months. I have been tring to figure out the root of the problem but to no avail. I have reformatted my pc a week ago so the previous bsod is no longer there
Hey..
Update your Realtek lan driver. To do so, type systeminfo in a command prompt then press enter. See which Realtek lan number you have. If it's 8111, use the following link. If anything else, serch for the number on the left side of the link, instead:
Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
Update this ancient Realtek HD Audio driver:
RTKVHD64 RTKVHD64.sys Thu Jul 24 06:05:39 2008
Let Intel's website scan and install the latest drivers. If it doesn't install the Matrix Storage driver to update the following for some reason, go to your motherboard website and download from there:
 iaStor   iaStor.sys   Sun Jul 20 20:29:34 2008
Link...
Hey..
You're definitely having issues with McAfee. Uninstall that in safe mode with the tool from here:
AV Uninstallers - Windows 7 Forums
Then reboot to normal mode and install MSE to replace.
091210-21262-01.dmp
BugCheck 116, {fffffa80095364e0, fffff88000db6dcc, 0, 2}
Unable to load image \SystemRoot\system32\DRIVERS\atikmpag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+6dcc )
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
090510-22916-01.dmp
BugCheck D1, {fffff80052c8c052, 2, 0, fffff80052c8c052}
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+260 )
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
090510-26473-01.dmp
BugCheck 50, {fffffa804767d828, 0, fffff80002a6fd84, 5}
Unable to load image \SystemRoot\system32\drivers\mfehidk.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for mfehidk.sys
*** ERROR: Module load completed but symbols could not be loaded for mfehidk.sys
Probably caused by : fileinfo.sys ( fileinfo!FIStreamGet+52 )
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
PROCESS_NAME: iTunes.exe
090510-26644-01.dmp
Probably caused by : mfehidk.sys ( mfehidk+48034 )
IRQL_NOT_LESS_OR_EQUAL (a)
090610-25194-01.dmp
BugCheck D1, {fffff80052d72230, 2, 0, fffff80052d72230}
PROCESS_NAME: mcshield.exe
091210-20514-01.dmp
BugCheck 19, {20, fffffa80051b5ad0, fffffa80051b5c30, 4160015}
GetPointerFromAddress: unable to read from fffff800030ab0e0
Probably caused by : Ntfs.sys ( Ntfs!NtfsDeleteFcb+3a3 )
BAD_POOL_HEADER (19)
The pool is already corrupt at the time of the current request.
Uninstall McAfee and replace it with MSE.
Check the hdd for errors.
Update the following drivers, if more crashes attach the crash dumps.
Video_TDR signals something might be wrong with the video card.
Update:
jraid.sys Tue Nov 04 04:20:09 2008
Jmicron Driver
dump_iaStor.sys Mon Jul 21 03:29:34 2008
Intel Matrix Storage/Sata Controller
RTKVHD64.sys Thu Jul 24 13:05:39 2008
Realtek High Definition Audio
Edit:
VClone.sys Mon Aug 10 00:25:45 2009
Virtual Clone CD
fffff800`00ba5000 fffff800`00baf000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e07000 fffff800`02e50000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`02e50000 fffff800`0342c000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00cc0000 fffff880`00cda000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`00cfa000 fffff880`00d3e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:29:10 2009 (4A5BDF66)
fffff880`00d3e000 fffff880`00d52000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00d52000 fffff880`00db0000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00db0000 fffff880`00df7000   atikmpag atikmpag.sys Wed Aug 04 04:15:45 2010 (4C58BF41)
fffff880`00e00000 fffff880`00e21000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`00e21000 fffff880`00e30000   VClone   VClone.sys   Mon Aug 10 00:25:45 2009 (4A7F3ED9)
fffff880`00e39000 fffff880`00edd000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00edd000 fffff880`00eec000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00eec000 fffff880`00f43000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f43000 fffff880`00f4c000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f4c000 fffff880`00f56000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f56000 fffff880`00f89000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f89000 fffff880`00f96000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00f96000 fffff880`00fab000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00fab000 fffff880`00fc0000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00fc0000 fffff880`00fef000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`0105e000 fffff880`010a3000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`010a3000 fffff880`010b2000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`010b2000 fffff880`0110e000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`0110e000 fffff880`01115000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`01115000 fffff880`01125000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01125000 fffff880`0113f000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`0113f000 fffff880`01153000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01153000 fffff880`011d1a80   mfehidk  mfehidk.sys  Fri Apr 23 20:33:40 2010 (4BD1D9F4)
fffff880`011d2000 fffff880`011f6000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`01200000 fffff880`0120b000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`0120b000 fffff880`01257000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`01258000 fffff880`01372000   iaStor   iaStor.sys   Mon Jul 21 03:29:34 2008 (4883D86E)
fffff880`01372000 fffff880`0137b000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`0137b000 fffff880`013a5000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`013a5000 fffff880`013b0000   msahci   msahci.sys   Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`013b0000 fffff880`013cb000   jraid    jraid.sys    Tue Nov 04 04:20:09 2008 (490FB159)
fffff880`013cb000 fffff880`013fa000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`01400000 fffff880`0141e000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`0141e000 fffff880`01439000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0143a000 fffff880`015dd000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`015dd000 fffff880`015f7000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`01630000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01630000 fffff880`0163f000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`01644000 fffff880`016b7000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`016b7000 fffff880`016c8000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`016c8000 fffff880`016d2000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`016d2000 fffff880`017c4000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`017c4000 fffff880`017fe000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01800000 fffff880`01816000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01824000 fffff880`01884000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01884000 fffff880`018af000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`018af000 fffff880`018f9000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`018f9000 fffff880`0193b400   mfewfpk  mfewfpk.sys  Fri Apr 23 20:33:53 2010 (4BD1DA01)
fffff880`0193c000 fffff880`01949000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01949000 fffff880`01995000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`01995000 fffff880`0199d000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`0199d000 fffff880`019d7000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`019d7000 fffff880`019e9000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`019e9000 fffff880`019f2000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`019f2000 fffff880`019fe000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`01a03000 fffff880`01c00000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02e00000 fffff880`02e25000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`02e25000 fffff880`02e35000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`02e35000 fffff880`02e3e000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02e3e000 fffff880`02e47000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02e47000 fffff880`02e50000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`02e50000 fffff880`02e5b000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`02e5b000 fffff880`02f75000   dump_iaStor dump_iaStor.sys Mon Jul 21 03:29:34 2008 (4883D86E)
fffff880`02f89000 fffff880`02fb3000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02fb3000 fffff880`02fc9000   MOBK     MOBK.sys     Fri Jan 01 05:20:07 2010 (4B3D69E7)
fffff880`02fc9000 fffff880`02fd2000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`02fd2000 fffff880`02fd9000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02fd9000 fffff880`02fe7000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`02fe7000 fffff880`02ff8000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`03e00000 fffff880`03e4e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`03e4e000 fffff880`03e71000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`03e73000 fffff880`03f3b000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`03f3b000 fffff880`03f71000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`03f71000 fffff880`03f8f000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`03f8f000 fffff880`03fa7000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`03fa7000 fffff880`03fd4000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`03fd4000 fffff880`03fdd000   cpuz134_x64 cpuz134_x64.sys Fri Jul 09 14:16:58 2010 (4C37052A)
fffff880`04200000 fffff880`04251000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`04251000 fffff880`0425d000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`0425d000 fffff880`04268000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`04268000 fffff880`04273000   ElbyCDIO ElbyCDIO.sys Fri Dec 18 00:25:16 2009 (4B2AAFCC)
fffff880`04273000 fffff880`04282000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`04282000 fffff880`042a0000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`042a0000 fffff880`042b1000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`042b1000 fffff880`042d7000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`042de000 fffff880`04368000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`04368000 fffff880`04371000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`04371000 fffff880`04397000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`04397000 fffff880`043a7a00   mfenlfk  mfenlfk.sys  Fri Apr 23 20:34:02 2010 (4BD1DA0A)
fffff880`043a8000 fffff880`043b7000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`043b7000 fffff880`043d2000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`043d2000 fffff880`043e6000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`043e6000 fffff880`043fc000   intelppm intelppm.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`04600000 fffff880`0460d000   usbuhci  usbuhci.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`0460d000 fffff880`04663000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04663000 fffff880`04674000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04674000 fffff880`04681000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 15:17:04 2009 (4A1151C0)
fffff880`04681000 fffff880`04691000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04691000 fffff880`04692480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`04697000 fffff880`0478b000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`0478b000 fffff880`047d1000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`047d1000 fffff880`047f5000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`04a00000 fffff880`04a3e000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`04a49000 fffff880`051b7000   atikmdag atikmdag.sys Wed Aug 04 04:39:08 2010 (4C58C4BC)
fffff880`051b7000 fffff880`051e9000   Rt64win7 Rt64win7.sys Thu Feb 26 11:04:13 2009 (49A65B0D)
fffff880`051e9000 fffff880`051ff000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`05451000 fffff880`05494000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`05494000 fffff880`054a6000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`054a6000 fffff880`05500000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`05500000 fffff880`05515000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`05515000 fffff880`05535000   AtihdW76 AtihdW76.sys Thu Jul 15 15:46:49 2010 (4C3F0339)
fffff880`05535000 fffff880`05572000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`05572000 fffff880`05594000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`05594000 fffff880`05599200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`05661000 fffff880`05707000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`05707000 fffff880`05712000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`05712000 fffff880`0573f000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`0573f000 fffff880`05751000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`05751000 fffff880`057b9000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`0623b000 fffff880`063a4f80   RTKVHD64 RTKVHD64.sys Thu Jul 24 13:05:39 2008 (488853F3)
fffff880`063a5000 fffff880`063d1700   mfeavfk  mfeavfk.sys  Fri Apr 23 20:34:38 2010 (4BD1DA2E)
fffff880`06800000 fffff880`0681ac00   usbaudio usbaudio.sys Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`06827000 fffff880`0684a000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`0684a000 fffff880`0686b000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`0686b000 fffff880`06880000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`06880000 fffff880`06898000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`068cd000 fffff880`06936500   mfefirek mfefirek.sys Fri Apr 23 20:37:36 2010 (4BD1DAE0)
fffff880`06937000 fffff880`06945000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06945000 fffff880`06958000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`06958000 fffff880`06975000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`06975000 fffff880`06976f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`06977000 fffff880`06985000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`06985000 fffff880`0699e000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`0699e000 fffff880`069a6080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`069a7000 fffff880`069b5000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`069b5000 fffff880`069c2000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`069c2000 fffff880`069dd000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`069dd000 fffff880`069e9000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`069e9000 fffff880`069f7000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`06a53000 fffff880`06ae9000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`06b1a000 fffff880`06b35d80   mfeapfk  mfeapfk.sys  Fri Apr 23 20:34:15 2010 (4BD1DA17)
fffff880`06b36000 fffff880`06b43800   cfwids   cfwids.sys   Fri Apr 23 20:38:25 2010 (4BD1DB11)
fffff880`06bb5000 fffff880`06bc0000   asyncmac asyncmac.sys Tue Jul 14 03:10:13 2009 (4A5BCCE5)
fffff960`000c0000 fffff960`003cf000   win32k   win32k.sys   unavailable (00000000)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00760000 fffff960`00787000   cdd      cdd.dll      unavailable (00000000)
fffff960`00990000 fffff960`009f1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Thank You Man You Just Solved My Problem
Glad to hear you feel it's sorted. However, the best proof of that will be a week from now running your pc without any bsod's.
Should crashes reoccur, attach the dumps. : )
