I can help you troubleshoot the Blue Screen of Death (BSOD) issue you're experiencing. To start diagnosing the problem, we can follow these steps: 1. Check the Error Message: When the BSOD occurs, it usually displays an error message along with a stop code. This information can help identify the cause of the issue. 2. Check System Logs: Windows keeps logs of system events that can provide more details about the error. To access Event Viewer: - Press Windows Key + X and select Event Viewer. - Navigate to Windows Logs > System to look for critical errors around the time of the BSOD. 3. Update Drivers: Outdated or incompatible drivers can cause BSODs. You can update drivers manually or use a tool like...
