BSOD HELP! Keeps happening alot...
I've built a new pc about 2-3 months ago. Started getting some bluescreens, been trying to follow ppls advice. Been the bluescreen keeps happening more and more now. Getting really desperate :( dunno what to do..
I've ran memtest86 on my ram (just 1 4gb in atm, thought something was wrong with other one)
0 errors. I've Driver programs, that are suppose to find the newest drivers etc.
Dunno what to do :( PLEAAAASE help me :(
View attachment Minidumpha.rar
Elmer
Hi Hantimilon and Welcome to The Forum.
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes:
System service, Device driver, graphics driver, ?memory.
Your latest dump file lists win32k.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Make sure your system is fully updated including SP1.
AsIO.sys Tue Aug 24 02:53:02 2010 ASUS Probe Utility - Has issues with Windows 7. Uninstall.
Although fine as an indicator as to which drivers may need updating I would never rely on any these driver programs, or Windows update, to provide me with the latest drivers for my PC.
Drivers with Updates:
e1c62x64.sys Tue Sep 21 22:34:15 2010 Intel(R) 82579V Gigabit Network Connection driver
point64.sys Tue Jun 29 09:54:31 2010 Microsoft IntelliPoint
RTKVHD64.sys Tue Jun 08 10:08:08 2010 Realtek HD Audio R2.66
Bugcheck Analysis:
BugCheck 3B, {c0000005, fffff960002c8083, fffff880048fdef0, 0}
Probably caused by : win32k.sys ( win32k!DEVLOCKBLTOBJ::bLock+6ff )
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff960002c8083, Address of the instruction which caused the bugcheck
Arg3: fffff880048fdef0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: win32k
FAULTING_MODULE: fffff80003061000 nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4e83ef5b
FAULTING_IP:
fffff960`002c8083 483bc8          cmp     rcx,rax
CONTEXT:  fffff880048fdef0 -- (.cxr 0xfffff880048fdef0)
rax=fffff900c3961420 rbx=fffff880048fea40 rcx=fffff900c208f3a0
rdx=fffff900c1dc1630 rsi=0000000000000000 rdi=0000000000000000
rip=fffff960002c8083 rsp=fffff880048fe8c0 rbp=000000000000000b
 r8=0000000000001009  r9=0000000000000000 r10=fffff900c0200000
r11=fffffa8003cbfb60 r12=fffff880048fe9f0 r13=fffff880048fe9d8
r14=fffff880048fea90 r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
win32k!DEVLOCKBLTOBJ::bLock+0x6ff:
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff960002c8083
STACK_TEXT:
fffff880`048fe8c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : win32k!DEVLOCKBLTOBJ::bLock+0x6ff
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  win32k!DEVLOCKBLTOBJ::bLock+6ff
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  win32k.sys
STACK_COMMAND:  .cxr 0xfffff880048fdef0 ; kb
Followup: MachineOwner
Drivers:
fffff880`10064000 fffff880`100a2000   1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00f15000 fffff880`00f6c000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02ebf000 fffff880`02f48000   afd      afd.sys      Mon Apr 25 03:43:58 2011 (4DB4DFEE)
fffff880`100b8000 fffff880`100ce000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0103e000 fffff880`01049000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`045ba000 fffff880`045c0000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`05279000 fffff880`0529d000   asmthub3 asmthub3.sys Wed Sep 14 08:36:19 2011 (4E705973)
fffff880`10000000 fffff880`10064000   asmtxhci asmtxhci.sys Wed Sep 14 08:36:09 2011 (4E705969)
fffff880`045b3000 fffff880`045ba000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`0529d000 fffff880`052ab000   ASUSFILTER ASUSFILTER.sys Tue Sep 20 16:46:33 2011 (4E78B559)
fffff880`01000000 fffff880`01009000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01009000 fffff880`01033000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff960`00990000 fffff960`009f1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`043f8000 fffff880`043ff000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`045a2000 fffff880`045b3000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05b9f000 fffff880`05bbd000   bowser   bowser.sys   Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff960`007a0000 fffff960`007c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`043c5000 fffff880`043ef000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00d3c000 fffff880`00dfc000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`015bf000 fffff880`015ef000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00cde000 fffff880`00d3c000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01738000 fffff880`017ab000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`047ee000 fffff880`047fe000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`05258000 fffff880`05266000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04501000 fffff880`04584000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`04584000 fffff880`045a2000   dfsc     dfsc.sys     Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`044f2000 fffff880`04501000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`017c6000 fffff880`017dc000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04dbf000 fffff880`04de1000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05266000 fffff880`05279000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0400e000 fffff880`043b0000   dump_iaStor dump_iaStor.sys Wed Aug 24 05:30:39 2011 (4E547E6F)
fffff880`052ab000 fffff880`052b7000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`046fa000 fffff880`047ee000   dxgkrnl  dxgkrnl.sys  Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`04600000 fffff880`04646000   dxgmms1  dxgmms1.sys  Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`0467b000 fffff880`046ca000   e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`00c66000 fffff880`00c7a000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00c1a000 fffff880`00c66000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`017bc000 fffff880`017c6000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01686000 fffff880`016c0000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`0182b000 fffff880`01875000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff800`03018000 fffff800`03061000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`04646000 fffff880`0466a000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`0466a000 fffff880`0467b000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`052d3000 fffff880`052ec000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`052ec000 fffff880`052f4080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`052c5000 fffff880`052d3000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`05ad7000 fffff880`05b9f000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`019f4000 fffff880`019fd000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`0105a000 fffff880`013fc000   iaStor   iaStor.sys   Wed Aug 24 05:30:39 2011 (4E547E6F)
fffff880`046db000 fffff880`046e7000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`100a2000 fffff880`100b8000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0445b000 fffff880`0446a000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05331000 fffff880`0533f000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bb7000 fffff800`00bc1000   kdcom    kdcom.dll    Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff880`04c91000 fffff880`04cd4000   ks       ks.sys       Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`0171e000 fffff880`01738000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`01800000 fffff880`0182b000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`04de1000 fffff880`04de6200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05383000 fffff880`05398000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0533f000 fffff880`05362000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c86000 fffff880`00cca000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`052b7000 fffff880`052c5000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`0446a000 fffff880`04479000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`052f7000 fffff880`05304000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c00000 fffff880`00c1a000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`05bbd000 fffff880`05bd5000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05a00000 fffff880`05a2d000   mrxsmb   mrxsmb.sys   Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`05a2d000 fffff880`05a7b000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:44:55 2011 (4E17C0A7)
fffff880`05a7b000 fffff880`05a9e000   mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`01033000 fffff880`0103e000   msahci   msahci.sys   Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`02e78000 fffff880`02e83000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f75000 fffff880`00f7f000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`016c0000 fffff880`0171e000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`044e7000 fffff880`044f2000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`0188d000 fffff880`0189f000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`018a2000 fffff880`01994000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`10dda000 fffff880`10de6000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04400000 fffff880`0442f000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04d40000 fffff880`04d55000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02fbc000 fffff880`02fcb000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02f48000 fffff880`02f8d000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01994000 fffff880`019f4000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`02e83000 fffff880`02e94000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`044db000 fffff880`044e7000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03061000 fffff800`03635000   nt       ntkrnlmp.exe Thu Jun 23 03:53:22 2011 (4E02AAA2)
fffff880`0141d000 fffff880`015bf000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:25 2011 (4D79996D)
fffff880`043ef000 fffff880`043f8000   Null     Null.SYS     unavailable (00000000)
fffff880`04d55000 fffff880`04d82000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`100e9000 fffff880`10d60000   nvlddmkm nvlddmkm.sys Tue Nov 08 01:04:52 2011 (4EB88034)
fffff880`02f96000 fffff880`02fbc000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fbf000 fffff880`00fd4000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f7f000 fffff880`00fb2000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fe9000 fffff880`00ff0000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00ff0000 fffff880`01000000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`017ab000 fffff880`017bc000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0620d000 fffff880`062b3000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05304000 fffff880`05314000   point64  point64.sys  Tue Jun 29 09:54:31 2010 (4C29B4C7)
fffff880`04d82000 fffff880`04dbf000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cca000 fffff880`00cde000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`10db6000 fffff880`10dda000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`100ce000 fffff880`100e9000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0442f000 fffff880`04450000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`10de6000 fffff880`10e00000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0448a000 fffff880`044db000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`04450000 fffff880`0445b000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`02e5d000 fffff880`02e66000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02e66000 fffff880`02e6f000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02e6f000 fffff880`02e78000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0164c000 fffff880`01686000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`05398000 fffff880`053b0000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05011000 fffff880`05257e00   RTKVHD64 RTKVHD64.sys Tue Jun 08 10:08:08 2010 (4C0E0878)
fffff880`062b3000 fffff880`062be000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01885000 fffff880`0188d000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`06664000 fffff880`066f9000   srv      srv.sys      Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`0636e000 fffff880`063d5000   srv2     srv2.sys     Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`062be000 fffff880`062eb000   srvnet   srvnet.sys   Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`047fe000 fffff880`047ff480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01a01000 fffff880`01bff000   tcpip    tcpip.sys    Thu Sep 29 04:52:31 2011 (4E83EB7F)
fffff880`0635c000 fffff880`0636e000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`02eb2000 fffff880`02ebf000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`02e94000 fffff880`02eb2000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02fe6000 fffff880`02ffa000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`045c0000 fffff880`045e6000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`04cd4000 fffff880`04ce6000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`05314000 fffff880`05331000   usbccgp  usbccgp.sys  Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`052f5000 fffff880`052f6f00   USBD     USBD.SYS     Fri Mar 25 03:22:51 2011 (4D8C0A8B)
fffff880`046ca000 fffff880`046db000   usbehci  usbehci.sys  Fri Mar 25 03:22:57 2011 (4D8C0A91)
fffff880`04ce6000 fffff880`04d40000   usbhub   usbhub.sys   Fri Mar 25 03:23:22 2011 (4D8C0AAA)
fffff880`10d60000 fffff880`10db6000   USBPORT  USBPORT.SYS  Fri Mar 25 03:23:03 2011 (4D8C0A97)
fffff880`00fb2000 fffff880`00fbf000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04000000 fffff880`0400e000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`02e28000 fffff880`02e4d000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01875000 fffff880`01885000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`00fd4000 fffff880`00fe9000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01600000 fffff880`0164c000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`02fcb000 fffff880`02fe6000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`02e4d000 fffff880`02e5d000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e62000 fffff880`00f06000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f06000 fffff880`00f15000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02f8d000 fffff880`02f96000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f4000   win32k   win32k.sys   Thu Sep 29 05:08:59 2011 (4E83EF5B)
fffff880`046e7000 fffff880`046f0000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f6c000 fffff880`00f75000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05362000 fffff880`05383000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`09c1f000 fffff880`09fc1000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`09fc1000 fffff880`09fd4000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`062eb000 fffff880`0635c000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`017dc000 fffff880`017ea000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`04010000 fffff880`043b2000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`043b2000 fffff880`043c5000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
