[bsod] help please
View attachment error reports.zip
Hello,
iam getting lots of diffrent bsods on my machine,i think its hardware but need to know what please?
using both windows 7 32bit at present but was also getting them in x64.
most common bsod is memory mangement ,i have checked the ram and found some sticks to have errors and removed them,but iam still getting bsods?:confused:
thanks for the support.
yours,
gareth
Hello and welcome.
1) Download, install and run CPU-Z. Make a screen shot of the spd and memory tabs. Attach to the next post here.
2) C:\Windows\Minidump
Copy the files in there to any other folder. Zip the files then attach the zip to the next post here, too.
We'll see what's up for ya.
1) Google for the AVG uninstall tool. Download it.
Do the same for this link for Driver Sweeper.
Phyxion.net | Driver Sweeper | Products | Products
Run both tools after rebooting to safe mode.
In Driver Sweeper, use it to clear all Creative drivers/settings.
Reboot and install MSE.
Then visit Creative's site to install the latest drivers.
2) Update Atheros L1E lan driver:
L1E62x64 L1E62x64.sys Sun Aug 23 01:08:09 2009
ATHEROS Network drivers for Windows
3) Install my attachment to update this very old driver:
ASACPI ASACPI.sys Mon Oct 30 22:09:12 2006
4) Uninstall Daemon Tools. Then use this installer/uninstaller to remove sptd.sys, being careful to click Uninstall while using:
DuplexSecure - Downloads
Reboot and install PowerISO to replace it. Disc emulation is free forever:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
hello,
my system is a fresh install done yesterday,iam install mse and fully updated windows 7 and installed all optional updates.i then installed the gpu (5850) and the sound card (sound blaster x-fi pci-e).the problem with bsods was happening before i even bought or had either of them.i used to have a 5870 which the blower fan broke so i replaced it with the gpu and sound card, and it would bluescreen with or without the 5870.
please help some more.
#7
If you've had any new crash dumps, feel free to attach them.
#9
120410-29109-01.dmp
NTFS_FILE_SYSTEM (24)
PROCESS_NAME: svchost.exe
Stack text: nt ntfs
FAILURE_BUCKET_ID: 0x24_Ntfs!NtfsInsertNameLink+af
Your drivers are fine now. Test the file system and hard disk:
chkdsk:
Disk Check - Windows 7 Forums
hdd:
HD Diagnostic
Loading Dump File [F:\a\Minidump\D M P\120410-29109-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82c51000 PsLoadedModuleList = 0x82d99810
Debug session time: Sat Dec  4 08:49:51.052 2010 (UTC - 5:00)
System Uptime: 0 days 0:08:15.301
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
3: kd> !analyze -v
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 001904fb
Arg2: aa9439d4
Arg3: aa9435b0
Arg4: 82cdb34d
Debugging Details:
EXCEPTION_RECORD:  aa9439d4 -- (.exr 0xffffffffaa9439d4)
ExceptionAddress: 82cdb34d (nt!RtlSplay+0x000000e2)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000001
   Parameter[1]: 00007a00
Attempt to write to address 00007a00
CONTEXT:  aa9435b0 -- (.cxr 0xffffffffaa9435b0)
eax=a167c514 ebx=a167c50c ecx=99927a6c edx=a175ff4c esi=00007a00 edi=a175ff54
eip=82cdb34d esp=aa943a9c ebp=aa943aa4 iopl=0         nv up ei pl nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010206
nt!RtlSplay+0xe2:
82cdb34d 890e            mov     dword ptr [esi],ecx  ds:0023:00007a00=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  1
ERROR_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
EXCEPTION_PARAMETER1:  00000001
EXCEPTION_PARAMETER2:  00007a00
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82db9718
Unable to read MiSystemVaType memory at 82d99160
 00007a00
FOLLOWUP_IP:
8baa28bf 8b4d08          mov     ecx,dword ptr [ebp+8]
FAULTING_IP:
nt!RtlSplay+e2
BUGCHECK_STR:  0x24
LAST_CONTROL_TRANSFER:  from 8baa28bf to 82cdb34d
STACK_TEXT:
aa943aa4 8baa28bf a167c514 a167c4e8 a167c4e8 nt!RtlSplay+0xe2
aa943abc 8baa545a 8d86a8e4 00000016 a167c340 Ntfs!NtfsInsertNameLink+0xaf
aa943ad0 8ba84a73 a167c4e8 00006a20 213000e6 Ntfs!NtfsInsertPrefix+0x33
aa943bf4 8ba98381 88747ee0 85bec008 8d86a770 Ntfs!NtfsOpenFile+0x93e
aa943cdc 8ba1e210 88747ee0 85bec008 aa913344 Ntfs!NtfsCommonCreate+0xd84
aa943d1c 82cc111e aa9132dc 00000000 ffffffff Ntfs!NtfsCommonCreateCallout+0x20
aa943d1c 82cc1215 aa9132dc 00000000 ffffffff nt!KiSwapKernelStackAndExit+0x15a
aa913240 00000000 00000000 00000000 00000000 nt!KiSwitchKernelStackAndCallout+0x31
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  Ntfs!NtfsInsertNameLink+af
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME:  Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bbf45
STACK_COMMAND:  .cxr 0xffffffffaa9435b0 ; kb
91146000 91172000   1394ohci 1394ohci.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
8b80e000 8b856000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8f02e000 8f088000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
8f1e5000 8f1f7000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
8f1d4000 8f1e5000   amdppm   amdppm.sys   Mon Jul 13 19:11:03 2009 (4A5BBF07)
8b95f000 8b968000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
91212000 912136c0   ASACPI   ASACPI.sys   Wed Jul 15 23:28:28 2009 (4A5E9E5C)
8f1b2000 8f1b2fa0   AsIO     AsIO.sys     Mon Aug 03 03:02:32 2009 (4A768B88)
8b933000 8b93c000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b93c000 8b95f000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
91214000 918a7000   atikmdag atikmdag.sys Tue Oct 26 22:26:21 2010 (4CC78DCD)
9100e000 9104b000   atikmpag atikmpag.sys Tue Oct 26 22:14:03 2010 (4CC78AEB)
8bda6000 8bdae000   AtiPcie  AtiPcie.sys  Mon Oct 30 14:23:10 2006 (4546430E)
8bc07000 8bc0e000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8f1a4000 8f1b2000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
8324d000 83255000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
91d9f000 91db8000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
992a0000 992be000   cdd      cdd.dll      unavailable (00000000)
8bdae000 8bdc4000   cdfs     cdfs.sys     Mon Jul 13 19:11:14 2009 (4A5BBF12)
8bde0000 8bdff000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
83297000 83342000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8bd81000 8bda6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
83255000 83297000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8bb72000 8bbcf000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
911ea000 911f7000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
8bdc4000 8bdd1000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
95078000 950ad000   CT20XUT  CT20XUT.SYS  Wed Jul 07 08:20:06 2010 (4C3470F6)
9104b000 910cc780   ctaud2k  ctaud2k.sys  Wed Jul 07 08:16:27 2010 (4C34701B)
950ad000 951fb000   CTEXFIFX CTEXFIFX.SYS Wed Jul 07 08:19:54 2010 (4C3470EA)
95063000 95078000   CTHWIUT  CTHWIUT.SYS  Wed Jul 07 08:20:11 2010 (4C3470FB)
91101000 91136000   ctoss2k  ctoss2k.sys  Wed Jul 07 08:14:50 2010 (4C346FBA)
91200000 91208000   ctprxy2k ctprxy2k.sys Wed Jul 07 08:16:32 2010 (4C347020)
95039000 95063000   ctsfm2k  ctsfm2k.sys  Wed Jul 07 08:14:35 2010 (4C346FAB)
8f18c000 8f1a4000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
8f180000 8f18c000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8bd70000 8bd81000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
919e5000 919fe000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
95000000 95009000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8bdd1000 8bddc000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
91c10000 91c21000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
82200000 8220a000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
918a7000 9195e000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
9195e000 91997000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
95009000 95039000   emupia2k emupia2k.sys Wed Jul 07 08:14:31 2010 (4C346FA7)
91d75000 91d9f000   fastfat  fastfat.SYS  Mon Jul 13 19:14:01 2009 (4A5BBFB9)
911d6000 911e1000   fdc      fdc.sys      Mon Jul 13 19:45:45 2009 (4A5BC729)
8b99c000 8b9ad000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
822c0000 822ca000   flpydisk flpydisk.sys Mon Jul 13 19:45:45 2009 (4A5BC729)
8b968000 8b99c000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8bbdd000 8bbe6000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8bd3e000 8bd70000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8bf49000 8bf7a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
822ca000 823f9000   ha20x22k ha20x22k.sys Wed Jul 07 08:15:53 2010 (4C346FF9)
82c1a000 82c51000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
91997000 919b6000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
91c67000 91c7a000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
91c7a000 91c80480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
91c5c000 91c67000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
91cf0000 91d75000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8bd36000 8bd3e000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
82252000 8225f000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
91c8c000 91c98000   kbdhid   kbdhid.sys   Mon Jul 13 19:45:09 2009 (4A5BC705)
80ba9000 80bb1000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
910cd000 91101000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
8bb5f000 8bb72000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8bd11000 8bd36000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
91136000 91146000   L1E62x86 L1E62x86.sys Sun Mar 28 22:08:36 2010 (4BB00BA4)
91ccd000 91cdd000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
91c98000 91cb3000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
83231000 8323c000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:13:13 2009 (4A5BBF89)
91c3a000 91c45000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
8225f000 8226c000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
91c81000 91c8c000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8b91d000 8b933000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8b9ad000 8b9d0000   MpFilter MpFilter.sys Sat Mar 20 00:03:26 2010 (4BA4490E)
a2e00000 a2e08e00   MpNWMon  MpNWMon.sys  Sat Mar 20 00:03:24 2010 (4BA4490C)
91db8000 91dca000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
91dca000 91ded000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
a2e1f000 a2e5a000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
a2e5a000 a2e75000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
833c1000 833cc000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8b85f000 8b867000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8bb34000 8bb5f000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8f176000 8f180000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8bfee000 8bffe000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8bc1c000 8bcd3000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
91000000 9100b000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
83200000 83222000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
8f018000 8f029000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
8f0e0000 8f0ee000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8f088000 8f0ba000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8bcd3000 8bd11000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
833cc000 833da000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8f16c000 8f176000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82c51000 83061000   nt       ntkrpamp.exe Fri Jun 18 23:55:24 2010 (4C1C3FAC)
8ba05000 8bb34000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8bc00000 8bc07000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
8f0c1000 8f0e0000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8b89c000 8b8ad000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
8b867000 8b891000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8b908000 8b90f000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
8b90f000 8b91d000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8bbcf000 8bbdd000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
a2e8d000 a2f24000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
919b6000 919e5000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
8323c000 8324d000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
8f000000 8f018000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
8220c000 82224000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
82224000 8223b000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
8223b000 82252000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
8f12b000 8f16c000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
8bbf3000 8bbfb000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8b9f1000 8b9f9000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8b800000 8b808000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8bfc1000 8bfee000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
91cdd000 91cf0000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
a2f24000 a2f2e000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
911cc000 911d6000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
8f0ee000 8f108000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
8bfb9000 8bfc1000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
a124e000 a12b8000   spsys    spsys.sys    Mon May 11 12:37:10 2009 (4A085436)
a2fab000 a2ffc000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
a2f5c000 a2fab000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
a2f2e000 a2f4f000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
8226c000 8226d380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8be00000 8bf49000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
a2f4f000 a2f5c000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
833f1000 833fc000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
833da000 833f1000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8f11b000 8f12b000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
99270000 99279000   TSDDD    TSDDD.dll    Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8f1b3000 8f1d4000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
8226e000 8227c000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
91c45000 91c5c000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
91c38000 91c39700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
911bd000 911cc000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
8227c000 822c0000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
91208000 91212000   usbohci  usbohci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
91172000 911bd000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
91c21000 91c38000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
8b891000 8b89c000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8bc0e000 8bc1a000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8b9d0000 8b9f1000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8b8ad000 8b8bd000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8b8bd000 8b908000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8bf7a000 8bfb9000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8f108000 8f11b000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8bbe6000 8bbf3000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
83342000 833b3000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
833b3000 833c1000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8f0ba000 8f0c1000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
99010000 9925b000   win32k   win32k.sys   Tue Aug 31 22:34:29 2010 (4C7DBBB5)
911e1000 911ea000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
8b856000 8b85f000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
91cb3000 91ccd000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
a122d000 a124e000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00021000
a2e75000 a2e8d000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8bdae000 8bdbb000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8bdbb000 8bdc6000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8bdc6000 8bdcf000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8bdcf000 8bde0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
#10
this is the odd bit,the hard drives are oldish but i was running a raid 10 when the memory management bsods started,i got no critical reports or drive stoppages in raid manager?.
#12
Don't do that yet. Remove all external storage USB, HDD, etc...
Then run this command from an elevated command prompt, changing C to match each time with each run for each drive letter on the system that's a HDD:
chkdsk C: /r
#13
ok,thanks
i just added a thing in asus forum to ask if the problem could be with there mobo,it bsoded while i was typing.
i have logged in on safe mode with networking,which i havent tried yet to see if it stops bsoding.:confused: View attachment bsod 5.zip
we will see.
#15
i just found this stashed on a drive \AppData\Local\Temp\AIH1007265274.exe (Trojan.Agent) -> Quarantined and deleted successfully.
i dont know where that came from and i cant find it as a search,odd.
#18
Your CPU or RAM is probably overclocked and causing these crashes. Post a screen shot each of the cpu, memory and spd tabs of CPU-Z.
Upload them directly as attachments, without zipping.
#19
a friend advised me to swap change around my ram,so i did .iam tested one strip last night with memtest and did 30 passes.ill test the other tonight.
thanks torrent G.
#20
Yep, everything looks well there. So if you experience more crashes, there is unfortunately a memory defect.
The reasons that is for sure are because all your drivers are well and also that you said you crashed in safe mode.
