Windows 7 BSOD Help please!
BugCheck 50, {fffffae007520308, 0, fffff800030a0357, 5}
Probably caused by : ntkrnlmp.exe ( nt!PoIdle+378 )
Followup: MachineOwner
1: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffffae007520308, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800030a0357, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000005, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032c6100
fffffae007520308
FAULTING_IP:
nt!PoIdle+378
fffff800`030a0357 49837c242800    cmp     qword ptr [r12+28h],0
MM_INTERNAL_CODE:  5
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff8800331bb10 -- (.trap 0xfffff8800331bb10)
rax=000000cbe1dc500c rbx=0000000000000000 rcx=00000000ffffffff
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030a0357 rsp=fffff8800331bca0 rbp=0000000000000000
r8=ffffffffffffffff  r9=000000cbe1dc500c r10=0000000000000e19
r11=00000000ffffffff r12=0000000000000000 r13=0000000000000000
iopl=0         nv up di ng nz ac pe cy
nt!PoIdle+0x378:
fffff800`030a0357 49837c242800    cmp     qword ptr [r12+28h],0 ds:61a0:00000000`00000028=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030413cf to fffff80003096d00
STACK_TEXT:
fffff880`0331b9a8 fffff800`030413cf : 00000000`00000050 fffffae0`07520308 00000000`00000000 fffff880`0331bb10 : nt!KeBugCheckEx
fffff880`0331b9b0 fffff800`03094e2e : 00000000`00000000 fffffae0`07520308 fffffa80`08d21600 00000000`ffffffff : nt! ?? ::FNODOBFM::`string'+0x44891
fffff880`0331bb10 fffff800`030a0357 : 00000000`0037102f fffffa80`07594dd8 00000000`00000000 ffffd319`2eee1e22 : nt!KiPageFault+0x16e
fffff880`0331bca0 fffff800`0308e9fc : fffff880`009eb180 fffff880`00000000 00000000`00000000 fffff880`0111ef5c : nt!PoIdle+0x378
fffff880`0331bd80 00000000`00000000 : fffff880`0331c000 fffff880`03316000 fffff880`0331bd40 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!PoIdle+378
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!PoIdle+378
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4d9fdd5b
FAILURE_BUCKET_ID:  X64_0x50_nt!PoIdle+378
DRIVERS
fffff800`00bab000 fffff800`00bb5000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`03017000 fffff800`03600000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff800`03600000 fffff800`03649000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00cc9000 fffff880`00d18000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00d18000 fffff880`00d2c000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00d2c000 fffff880`00d8a000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d8a000 fffff880`00da4000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00da4000 fffff880`00dcc000   nvraid   nvraid.sys   Fri Mar 19 20:59:20 2010 (4BA3E5A8)
fffff880`00dcc000 fffff880`00dfc000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e78000 fffff880`00e88000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00e88000 fffff880`00f2c000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f2c000 fffff880`00f3b000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f3b000 fffff880`00f92000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00f92000 fffff880`00f9b000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f9b000 fffff880`00fa5000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00fa5000 fffff880`00fd8000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fd8000 fffff880`00fe5000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00fe5000 fffff880`00ffa000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`01000000 fffff880`0104c000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0104c000 fffff880`01060000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01060000 fffff880`01086000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`01086000 fffff880`010aa000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`010ba000 fffff880`010f6000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`010f6000 fffff880`0110a000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`0110a000 fffff880`01113000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01113000 fffff880`0113d000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0113d000 fffff880`01148000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01148000 fffff880`01153000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`01153000 fffff880`0117e000   nvstor   nvstor.sys   Fri Mar 19 20:45:11 2010 (4BA3E257)
fffff880`0117e000 fffff880`011e1000   storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`0120c000 fffff880`013af000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`013af000 fffff880`013cd000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`013cd000 fffff880`013de000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`013de000 fffff880`013f4000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01400000 fffff880`0140d000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0140d000 fffff880`01490000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`01490000 fffff880`014ee000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`014ee000 fffff880`01509000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01509000 fffff880`0157b000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0157b000 fffff880`0158c000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0158c000 fffff880`01596000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01596000 fffff880`015a6000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`015a6000 fffff880`015af000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015af000 fffff880`015b8000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015b8000 fffff880`015c1000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`015c1000 fffff880`015cc000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`015cc000 fffff880`015dd000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`015dd000 fffff880`015ff000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0163e000 fffff880`0166f000   MpFilter MpFilter.sys Wed Sep 15 01:19:28 2010 (4C901110)
fffff880`0166f000 fffff880`0167d000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01683000 fffff880`01776000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`01776000 fffff880`017d6000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`017d6000 fffff880`017fb000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01800000 fffff880`0184c000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0184c000 fffff880`01886000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01886000 fffff880`01a8a000   tcpip    tcpip.sys    Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`01a8a000 fffff880`01ad4000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01ad4000 fffff880`01bc4000   timntr   timntr.sys   Wed Jun 02 13:56:47 2010 (4C06550F)
fffff880`01bc4000 fffff880`01bd4000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`01bd4000 fffff880`01be9000   LHidFilt LHidFilt.Sys Tue Aug 24 18:21:36 2010 (4C73FFA0)
fffff880`01be9000 fffff880`01bf7000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff880`01bf9000 fffff880`01c00000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`01c00000 fffff880`01c12000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01c12000 fffff880`01c1b000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`01c1b000 fffff880`01c31000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01c37000 fffff880`01d6e000   tdrpm273 tdrpm273.sys Tue Aug 10 10:54:18 2010 (4C6121CA)
fffff880`01d6e000 fffff880`01d76000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01d76000 fffff880`01dbc000   snapman  snapman.sys  Thu Nov 11 11:05:10 2010 (4CDBCDE6)
fffff880`01dbc000 fffff880`01df6000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01df6000 fffff880`01dff000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`03000000 fffff880`0301d000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`0301d000 fffff880`03038000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`03038000 fffff880`0304c000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`0304c000 fffff880`0309d000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0309d000 fffff880`030a9000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`030a9000 fffff880`030b4000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`030b4000 fffff880`030c0000   ElbyCDIO ElbyCDIO.sys Thu Dec 16 22:58:13 2010 (4D0A9985)
fffff880`030c0000 fffff880`030cf000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`030d2000 fffff880`0315b000   afd      afd.sys      Sat Nov 20 09:23:27 2010 (4CE7938F)
fffff880`0315b000 fffff880`031a0000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`031a0000 fffff880`031a9000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`031a9000 fffff880`031cf000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`031cf000 fffff880`031e5000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`031e5000 fffff880`031f4000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03e00000 fffff880`03ec9000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`03ec9000 fffff880`03ee7000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`03eed000 fffff880`03f40000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03f40000 fffff880`03f53000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`03f53000 fffff880`03f6b000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03f6b000 fffff880`03f83000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03f83000 fffff880`03fb0000   mrxsmb   mrxsmb.sys   Wed Feb 23 04:56:22 2011 (4D649376)
fffff880`03fb0000 fffff880`03ffd000   mrxsmb10 mrxsmb10.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`04200000 fffff880`04208000   ASACPI   ASACPI.sys   Thu May 14 02:25:17 2009 (4A0B72FD)
fffff880`04208000 fffff880`04214000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04214000 fffff880`04224000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`04224000 fffff880`0423a000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0423a000 fffff880`0425e000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0425e000 fffff880`0426a000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0426a000 fffff880`04283000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`04283000 fffff880`0428b080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0428f000 fffff880`042e5000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`042e5000 fffff880`04315000   nusb3xhc nusb3xhc.sys Fri Jan 22 03:22:21 2010 (4B5919ED)
fffff880`04315000 fffff880`04316f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04317000 fffff880`0437e000   Rt64win7 Rt64win7.sys Fri Jan 21 07:34:00 2011 (4D3936E8)
fffff880`0437e000 fffff880`043f1000   netr6164 netr6164.sys Wed Apr 07 13:07:21 2010 (4BBC7579)
fffff880`043f1000 fffff880`043fe000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`04400000 fffff880`04418000   nusb3hub nusb3hub.sys Fri Jan 22 03:22:18 2010 (4B5919EA)
fffff880`04418000 fffff880`0442d000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`0442d000 fffff880`0445a000   nvhda64v nvhda64v.sys Thu Mar 03 15:59:02 2011 (4D6FBAC6)
fffff880`0445f000 fffff880`0448e000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`0448e000 fffff880`044a9000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`044a9000 fffff880`044ca000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`044ca000 fffff880`044e4000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`044e4000 fffff880`044ef000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`044ef000 fffff880`044fe000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`044fe000 fffff880`0450d000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0450d000 fffff880`0451c000   VClone   VClone.sys   Sat Jan 15 16:21:04 2011 (4D31C970)
fffff880`0451c000 fffff880`0454b000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`0454b000 fffff880`0454c480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0454d000 fffff880`04590000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`04590000 fffff880`045a2000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`045a2000 fffff880`045fc000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`05000000 fffff880`05023000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`05023000 fffff880`05044000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`05044000 fffff880`05059000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05059000 fffff880`0507d000   mrxsmb20 mrxsmb20.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`0507d000 fffff880`0509a000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`050a0000 fffff880`050dd000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`050dd000 fffff880`050ff000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`050ff000 fffff880`05104200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05105000 fffff880`05161000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`05161000 fffff880`0518b000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`0518b000 fffff880`05198000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff880`05198000 fffff880`051a6000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`051a6000 fffff880`051b2000   dump_pciidex dump_pciidex.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`051b2000 fffff880`051bd000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`051bd000 fffff880`051d0000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`051d0000 fffff880`051dc000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`051ea000 fffff880`051f8000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06a44000 fffff880`06aea000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`06aea000 fffff880`06af5000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`06af5000 fffff880`06b26000   srvnet   srvnet.sys   Wed Feb 23 04:55:44 2011 (4D649350)
fffff880`06b26000 fffff880`06b38000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`06b38000 fffff880`06ba2000   srv2     srv2.sys     Wed Feb 23 04:56:00 2011 (4D649360)
fffff880`07200000 fffff880`07215000   NisDrvWFP NisDrvWFP.sys Wed Sep 15 01:20:25 2010 (4C901149)
fffff880`07215000 fffff880`07243000   rdpdr    rdpdr.sys    Sat Nov 20 11:06:41 2010 (4CE7ABC1)
fffff880`07243000 fffff880`0724e000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`0724e000 fffff880`0725d000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`0725d000 fffff880`07296000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`072bc000 fffff880`07354000   srv      srv.sys      Wed Feb 23 04:56:21 2011 (4D649375)
fffff880`07394000 fffff880`073a4000   MpNWMon  MpNWMon.sys  Wed Sep 15 01:19:30 2010 (4C901112)
fffff880`073a4000 fffff880`073ec000   afcdp    afcdp.sys    Thu Nov 18 16:20:02 2010 (4CE55232)
fffff880`08a00000 fffff880`08a17000   LEqdUsb  LEqdUsb.Sys  Tue Aug 24 18:21:23 2010 (4C73FF93)
fffff880`08a17000 fffff880`08a24000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`08a24000 fffff880`08a2c000   LHidEqd  LHidEqd.Sys  Tue Aug 24 18:21:26 2010 (4C73FF96)
fffff880`08a2c000 fffff880`08a40000   LMouFilt LMouFilt.Sys Tue Aug 24 18:21:43 2010 (4C73FFA7)
fffff880`08abb000 fffff880`08ac6000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`08b8b000 fffff880`08bc1000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`08bf2000 fffff880`08c00000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`0f400000 fffff880`0f446000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0f446000 fffff880`0f457000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`0f459000 fffff880`100fd300   nvlddmkm nvlddmkm.sys Fri Apr 08 04:22:12 2011 (4D9E7F64)
fffff880`100fe000 fffff880`100ff180   nvBridge nvBridge.kmd Fri Apr 08 04:14:49 2011 (4D9E7DA9)
fffff880`10100000 fffff880`101f4000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff960`00030000 fffff960`00342000   win32k   win32k.sys   Thu Mar 03 03:51:40 2011 (4D6F104C)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff960`00750000 fffff960`00777000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff960`00800000 fffff960`00861000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
Unloaded modules:
fffff880`08b5c000 fffff880`08b70000   LMouFilt.Sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`08b54000 fffff880`08b5c000   LHidEqd.Sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`08b30000 fffff880`08b47000   LEqdUsb.Sys
    Checksum:  00000000
    ImageSize:  00017000
fffff880`08b47000 fffff880`08b54000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`08af4000 fffff880`08b02000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`08bc1000 fffff880`08bf2000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`08b70000 fffff880`08b8b000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`08add000 fffff880`08ae8000   WSDPrint.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`08ae8000 fffff880`08af4000   WSDScan.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`08b0c000 fffff880`08b23000   LEqdUsb.Sys
    Checksum:  00000000
    ImageSize:  00017000
fffff880`08b23000 fffff880`08b30000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`08b02000 fffff880`08b0c000   LNonPnP.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`08ac6000 fffff880`08ad1000   WSDPrint.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`08ad1000 fffff880`08add000   WSDScan.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`051dc000 fffff880`051ea000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07380000 fffff880`07394000   LMouFilt.Sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`07378000 fffff880`07380000   LHidEqd.Sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`07354000 fffff880`0736b000   LEqdUsb.Sys
    Checksum:  00000000
    ImageSize:  00017000
fffff880`0736b000 fffff880`07378000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`08a4a000 fffff880`08abb000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01bd4000 fffff880`01be2000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01be2000 fffff880`01bee000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bee000 fffff880`01bf9000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0162b000 fffff880`0163e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0163e000 fffff880`01668000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
download a program called memtest86
take all your ram sticks out except one
put it in the first slot run this for 7 passes if this doesnt error put the same stick in the 2nd slot and so on untill all all slots have been tried with the same stick of ram, for 7 passess
repaet the process with all sticks of ram
stop at 7 passes or errors which ever comes first
if errors come up this can indiciate problems with the ram stick
