gallo2fire
- Joined
- May 10, 2016
I was playing Overwatch when suddenly I got a bsod. I'm assuming hidusb.sys caused the issue but i'm not sure how to go about fixing it.
Executable search path is:
Windows 10 Kernel Version 10586 MP (8 procs) Free x64
Built by: 10586.212.amd64fre.th2_release_sec.160328-1908
Machine Name:
Kernel base = 0xfffff801`b381c000 PsLoadedModuleList = 0xfffff801`b3afacd0
Debug session time: Mon May 9 23:45:22.463 2016 (UTC - 4:00)
System Uptime: 0 days 0:45:07.090
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1E, {ffffffffc0000005, fffff80052db1105, 0, ffffffffffffffff}
Probably caused by : hidusb.sys ( hidusb!HumInternalIoctl+2aa )
Followup: MachineOwner
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80052db1105, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10586.212.amd64fre.th2_release_sec.160328-1908
SYSTEM_MANUFACTURER: MSI
SYSTEM_PRODUCT_NAME: MS-7977
SYSTEM_SKU: Default string
SYSTEM_VERSION: 1.0
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: 1.60
BIOS_DATE: 12/18/2015
BASEBOARD_MANUFACTURER: MSI
BASEBOARD_PRODUCT: Z170A GAMING M5 (MS-7977)
BASEBOARD_VERSION: 1.0
DUMP_TYPE: 2
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80052db1105
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
READ_ADDRESS: fffff801b3b9a520: Unable to get MiVisibleState
ffffffffffffffff
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
FAULTING_IP:
Wdf01000!FxDevice::DispatchWithLock+65 [d:\th\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1402]
fffff800`52db1105 488b78d0 mov rdi,qword ptr [rax-30h]
EXCEPTION_PARAMETER2: ffffffffffffffff
BUGCHECK_STR: 0x1E_c0000005_R
CPU_COUNT: 8
CPU_MHZ: fa8
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R) SIG: 55'00000000 (cache) 55'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
ANALYSIS_SESSION_HOST: DESKTOP-1C58DV3
ANALYSIS_SESSION_TIME: 05-10-2016 00:32:02.0794
ANALYSIS_VERSION: 10.0.10586.567 x86fre
EXCEPTION_RECORD: 0000000000000001 -- (.exr 0x1)
Cannot read Exception record @ 0000000000000001
TRAP_FRAME: ffff95858f669407 -- (.trap 0xffff95858f669407)
Unable to read trap frame at ffff9585`8f669407
LAST_CONTROL_TRANSFER: from fffff801b39dbafe to fffff801b395e760
STACK_TEXT:
fffff801`b56bba38 fffff801`b39dbafe : 00000000`0000001e ffffffff`c0000005 fffff800`52db1105 00000000`00000000 : nt!KeBugCheckEx
fffff801`b56bba40 fffff801`b396480d : fffff801`b3b4d000 fffff801`b381c000 0004c74c`007cc000 20202020`44415057 : nt!KiFatalExceptionHandler+0x22
fffff801`b56bba80 fffff801`b3821139 : 00000000`00000000 00000000`000000e9 fffff801`b56bc080 00000000`00000000 : nt!RtlpExecuteHandlerForException+0xd
fffff801`b56bbab0 fffff801`b381f5a8 : fffff801`b56bc9c8 fffff801`b56bc6e0 fffff801`b56bc9c8 00000000`00000001 : nt!RtlDispatchException+0x429
fffff801`b56bc1b0 fffff801`b39693c2 : 00000000`00000001 ffffe001`f08b7f20 ffff9585`8f669407 ffffe001`f5dceaa0 : nt!KiDispatchException+0x144
fffff801`b56bc890 fffff801`b396787d : 014a2814`14141400 00000006`d7e16c74 00000000`00000000 fffff801`b3a4cc33 : nt!KiExceptionDispatch+0xc2
fffff801`b56bca70 fffff800`52db1105 : ffffe001`f1532280 00000000`00000000 ffffe001`f15c0c00 ffffe001`f1590720 : nt!KiGeneralProtectionFault+0xfd
fffff801`b56bcc00 fffff800`52f81367 : ffffe001`f1532280 ffffe001`f1532280 ffffe001`f15c0c00 00000000`00000801 : Wdf01000!FxDevice::DispatchWithLock+0x65 [d:\th\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1402]
fffff801`b56bcc60 fffff800`52f810be : ffffe001`eeda3010 00000000`00000007 ffffe001`f1532740 00000000`00000000 : ACPI!ACPIIrpDispatchDeviceControl+0x97
fffff801`b56bcca0 fffff800`55b0169e : 00000000`00000007 ffffe001`f1532280 fffff801`b56bcdc9 00000000`00000001 : ACPI!ACPIDispatchIrp+0xbe
fffff801`b56bcd10 fffff800`55b014d4 : ffffe001`f1532280 fffff800`55b13098 ffffe001`f15a2a28 00000000`00000000 : usbccgp!DispatchPdoUrb+0x16e
fffff801`b56bce30 fffff800`55b011b1 : ffffe001`f1549a28 ffffe001`f1549a20 ffffe001`f1532280 fffff800`55b130a8 : usbccgp!DispatchPdoInternalDeviceControl+0x84
fffff801`b56bce90 fffff800`55bb12aa : ffffe001`f15498d0 00000000`00000000 ffffe001`00000000 ffffe001`f1532280 : usbccgp!USBC_Dispatch+0x1b1
fffff801`b56bcf50 fffff800`55bd2222 : ffffe001`00000000 ffffe001`f15d2810 ffffe001`f15d2810 fffff801`b3a4c2a1 : hidusb!HumInternalIoctl+0x2aa
fffff801`b56bd240 fffff800`55bd2000 : ffffe001`f23d82b0 00000000`00000006 fffff800`55be61f0 00000000`00000008 : HIDCLASS!HidpSubmitInterruptRead+0x152
fffff801`b56bd2c0 fffff801`b3896596 : ffffe001`f1532280 ffffe001`f1532280 ffffe001`f15d2810 ffffe001`f1532601 : HIDCLASS!HidpInterruptReadComplete+0x750
fffff801`b56bd3a0 fffff800`52db7ffb : 00000000`00000000 00000000`00000000 ffffe001`f260b900 00000000`00000001 : nt!IopfCompleteRequest+0x216
fffff801`b56bd4c0 fffff800`52db55f0 : fffff801`b56bd702 fffff800`52dbfd36 ffffe001`00000001 ffffe001`f1532280 : Wdf01000!FxRequest::CompleteInternal+0x25b [d:\th\minkernel\wdf\framework\shared\core\fxrequest.cpp @ 861]
fffff801`b56bd570 fffff800`55e7287f : ffffe001`f26001c0 ffffe001`f2600020 ffffe001`f260bce0 ffffe001`f26001c0 : Wdf01000!imp_WdfRequestComplete+0x90 [d:\th\minkernel\wdf\framework\shared\core\fxrequestapi.cpp @ 436]
fffff801`b56bd5d0 fffff800`55e7da69 : ffffe001`f26001c0 ffffe001`f13b1b00 ffffe001`f2600240 fffff801`b56bd748 : USBXHCI!Bulk_Transfer_CompleteCancelable+0x177
fffff801`b56bd630 fffff800`55e7b309 : 00000000`000004c0 ffffe001`f0898b10 00000000`000004c0 ffffe001`f13b1bb0 : USBXHCI!Bulk_ProcessTransferEventWithED1+0x3d9
fffff801`b56bd6d0 fffff801`b388a6a0 : 00001b14`45174d8c fffff801`b3b39180 fffff801`b56bd8c0 fffff801`b3b39180 : USBXHCI!Interrupter_WdfEvtInterruptDpc+0x759
fffff801`b56bd7c0 fffff801`b3889db9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExecuteAllDpcs+0x270
fffff801`b56bd910 fffff801`b396151a : 00000000`00000000 fffff801`b3b39180 fffff801`b3baf740 ffffe001`f32c8840 : nt!KiRetireDpcList+0xe9
fffff801`b56bdb60 00000000`00000000 : fffff801`b56be000 fffff801`b56b7000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: eed988b1b4c2afda972fc7213b2d7f1d2438c739
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 812402ca51f2a669721ac487eb91380fe9a27329
THREAD_SHA1_HASH_MOD: 10af56dc21cbacd33164e0ff4e09f5a7f1ffb4a4
FOLLOWUP_IP:
fffff800`55bb12aa 8bf8 mov edi,eax
FAULT_INSTR_CODE: 8844f88b
SYMBOL_STACK_INDEX: d
SYMBOL_NAME: hidusb!HumInternalIoctl+2aa
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hidusb
IMAGE_NAME: hidusb.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5632d8e8
IMAGE_VERSION: 10.0.10586.0
BUCKET_ID_FUNC_OFFSET: 2aa
FAILURE_BUCKET_ID: 0x1E_c0000005_R_hidusb!HumInternalIoctl
PRIMARY_PROBLEM_CLASS: 0x1E_c0000005_R_hidusb!HumInternalIoctl
TARGET_TIME: 2016-05-10T03:45:22.000Z
OSBUILD: 10586
OSSERVICEPACK: 0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-03-29 02:19:02
BUILDDATESTAMP_STR: 160328-1908
BUILDLAB_STR: th2_release_sec
BUILDOSVER_STR: 10.0.10586.212.amd64fre.th2_release_sec.160328-1908
ANALYSIS_SESSION_ELAPSED_TIME: 5637
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x1e_c0000005_r_hidusb!huminternalioctl
FAILURE_ID_HASH: {1db1b3ef-c820-f961-4df4-46999018d214}
