Bsod help
levi
I was having a bsod early this year and uploaded the mini dump here and you guys helped me with the solution. that time I had to install an o2 card reader program. solved.
worked well, but in about two times I got the bsod again when put a sd card while media player was open. I stopped doing this and was fine.
till now.
I got another bsod when I was not even using the notebook. dont have any clue about this, so i'm uploading another minidump and expecting your kindness to decipher =D
thank you already.
this shows in debugger as a 0x124 error which is normally hardware :(
although it is possible to be started by drivers it invariably ends up being a hardware fault
go to your motherboard manufacturers website and make sure you have the latest BIOS ?
check and make sure your system is not overclocked ?
ensure your system is adequately cooled, remove the side of the case (as long as this doesn't void any warranty) , then blow cool air possibly with a house fan and try to recreate the crash by playing games and music etc ?
Update all hardware-related drivers , so video, sound, RAID (if any) and NIC etc ?
make sure windows itself is fully updated ?
these drivers
OEM13Vfx.sys fffff880`05a42000 fffff880`05a4b000 0x00009000 0x45ebf733 05/03/2007 11:55:47
OEM13Vid.sys fffff880`05a00000 fffff880`05a41420 0x00041420 0x483e0499 29/05/2008 02:19:21
which are for your video capture device by creative need updating ?
what are your basic system specs and what antivirus and or third party firewall are you using ?
