BugCheck D1, {4, 2, 0, 8743fb02}
Probably caused by : athr.sys ( athr+212e1 )
Loading Dump File [F:\DMP\032311-23743-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x81c4a000 PsLoadedModuleList = 0x81d89570
Debug session time: Wed Mar 23 17:11:22.988 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:36.706
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Unable to load image \SystemRoot\system32\DRIVERS\athr.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athr.sys
*** ERROR: Module load completed but symbols could not be loaded for athr.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000004, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 8743fb02, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 81da9700
Unable to read MiSystemVaType memory at 81d890c0
00000004
CURRENT_IRQL: 2
FAULTING_IP:
ndis!NdisFreeTimerObject+18
8743fb02 8b4b04 mov ecx,dword ptr [ebx+4]
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: 86a5cba8 -- (.trap 0xffffffff86a5cba8)
ErrCode = 00000000
eax=00000000 ebx=00000000 ecx=8744b970 edx=85086020 esi=85046028 edi=8744b970
eip=8743fb02 esp=86a5cc1c ebp=86a5cc28 iopl=0 nv up ei ng nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
ndis!NdisFreeTimerObject+0x18:
8743fb02 8b4b04 mov ecx,dword ptr [ebx+4] ds:0023:00000004=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from 8743fb02 to 81c82b5b
STACK_TEXT:
86a5cba8 8743fb02 badb0d00 85086020 86a5cbc4 nt!KiTrap0E+0x2cf
86a5cc28 8c6642e1 00000000 86a5cc40 8c6642bf ndis!NdisFreeTimerObject+0x18
WARNING: Stack unwind information not available. Following frames may be wrong.
86a5cc34 8c6642bf 85086210 86a5cc4c 8c669f0c athr+0x212e1
86a5cc40 8c669f0c 85086020 86a5cc64 8c669ebf athr+0x212bf
86a5cc4c 8c669ebf 85086020 c000009a 85086020 athr+0x26f0c
86a5cc64 8c65b82e 85245028 86a5cc78 00000001 athr+0x26ebf
86a5cc84 8c654313 85245028 00000001 86a5cc9c athr+0x1882e
86a5ccc4 8c6541e8 85245028 86a7038c 85245028 athr+0x11313
86a5ccdc 8740a30a 85245028 85006600 86a5cd00 athr+0x111e8
86a5ccec 81e36f34 85046028 85006600 83670d48 ndis!ndisDispatchIoWorkItem+0xf
86a5cd00 81ca5043 852067e8 00000000 83670d48 nt!IopProcessWorkItem+0x23
86a5cd50 81e31d16 00000000 90b1dba4 00000000 nt!ExpWorkerThread+0x10d
86a5cd90 81cd3159 81ca4f36 00000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND: kb
FOLLOWUP_IP:
athr+212e1
8c6642e1 ?? ???
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: athr+212e1
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: athr
IMAGE_NAME: athr.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a80c5f1
FAILURE_BUCKET_ID: 0xD1_athr+212e1
Loading Dump File [F:\DMP\032311-22916-01.dmp]
Machine Name:
Kernel base = 0x81c48000 PsLoadedModuleList = 0x81d87570
Debug session time: Wed Mar 23 17:00:10.600 2011 (UTC - 4:00)
System Uptime: 0 days 0:01:04.318
BugCheck D1, {4, 2, 0, 86f6db02}
0: kd> !analyze -v
Arguments:
Arg4: 86f6db02, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 81da7700
Unable to read MiSystemVaType memory at 81d870c0
00000004
CURRENT_IRQL: 2
FAULTING_IP:
86f6db02 8b4b04 mov ecx,dword ptr [ebx+4]
BUGCHECK_STR: 0xD1
TRAP_FRAME: 86a3bba8 -- (.trap 0xffffffff86a3bba8)
ErrCode = 00000000
eax=00000000 ebx=00000000 ecx=86f79970 edx=84324020 esi=85058028 edi=86f79970
eip=86f6db02 esp=86a3bc1c ebp=86a3bc28 iopl=0 nv up ei ng nz na po nc
86f6db02 8b4b04 mov ecx,dword ptr [ebx+4] ds:0023:00000004=????????
LAST_CONTROL_TRANSFER: from 86f6db02 to 81c80b5b
STACK_TEXT:
86a3bba8 86f6db02 badb0d00 84324020 86a3bbc4 nt!KiTrap0E+0x2cf
86a3bc28 8ca642e1 00000000 86a3bc40 8ca642bf ndis!NdisFreeTimerObject+0x18
86a3bc34 8ca642bf 84324210 86a3bc4c 8ca69f0c athr+0x212e1
86a3bc40 8ca69f0c 84324020 86a3bc64 8ca69ebf athr+0x212bf
86a3bc4c 8ca69ebf 84324020 c000009a 84324020 athr+0x26f0c
86a3bc64 8ca5b82e 84320028 86a3bc78 00000001 athr+0x26ebf
86a3bc84 8ca54313 84320028 00000001 86a3bc9c athr+0x1882e
86a3bcc4 8ca541e8 84320028 86a7438c 84320028 athr+0x11313
86a3bcdc 86f3830a 84320028 8518b108 86a3bd00 athr+0x111e8
86a3bcec 81e34f34 85058028 8518b108 83687350 ndis!ndisDispatchIoWorkItem+0xf
86a3bd00 81ca3043 850dfe08 00000000 83687350 nt!IopProcessWorkItem+0x23
86a3bd50 81e2fd16 00000000 90b4b8be 00000000 nt!ExpWorkerThread+0x10d
86a3bd90 81cd1159 81ca2f36 00000000 00000000 nt!PspSystemThreadStartup+0x9e
STACK_COMMAND: kb
FOLLOWUP_IP:
athr+212e1
8ca642e1 ?? ???
MODULE_NAME: athr
Loading Dump File [F:\DMP\032311-22198-01.dmp]
Machine Name:
Kernel base = 0x81c00000 PsLoadedModuleList = 0x81d3f570
Debug session time: Wed Mar 23 17:33:59.459 2011 (UTC - 4:00)
System Uptime: 0 days 0:10:18.037
BugCheck D1, {4, 2, 0, 8736cb02}
0: kd> !analyze -v
Arguments:
Arg4: 8736cb02, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 81d5f700
Unable to read MiSystemVaType memory at 81d3f0c0
00000004
CURRENT_IRQL: 2
FAULTING_IP:
8736cb02 8b4b04 mov ecx,dword ptr [ebx+4]
BUGCHECK_STR: 0xD1
TRAP_FRAME: 86a58ba8 -- (.trap 0xffffffff86a58ba8)
ErrCode = 00000000
eax=00000000 ebx=00000000 ecx=87378970 edx=84007020 esi=83a7b028 edi=87378970
eip=8736cb02 esp=86a58c1c ebp=86a58c28 iopl=0 nv up ei ng nz na po nc
8736cb02 8b4b04 mov ecx,dword ptr [ebx+4] ds:0023:00000004=????????
LAST_CONTROL_TRANSFER: from 8736cb02 to 81c38b5b
STACK_TEXT:
86a58ba8 8736cb02 badb0d00 84007020 86a58bc4 nt!KiTrap0E+0x2cf
86a58c28 a3e622e1 00000000 86a58c40 a3e622bf ndis!NdisFreeTimerObject+0x18
86a58c34 a3e622bf 84007210 86a58c4c a3e67f0c athr+0x212e1
86a58c40 a3e67f0c 84007020 86a58c64 a3e67ebf athr+0x212bf
86a58c4c a3e67ebf 84007020 c000009a 84007020 athr+0x26f0c
86a58c64 a3e5982e 83a7c408 86a58c78 00000001 athr+0x26ebf
86a58c84 a3e52313 83a7c408 00000001 86a58c9c athr+0x1882e
86a58cc4 a3e521e8 83a7c408 86a6c38c 83a7c408 athr+0x11313
86a58cdc 8733730a 83a7c408 83698258 86a58d00 athr+0x111e8
86a58cec 81decf34 83a7b028 83698258 83670020 ndis!ndisDispatchIoWorkItem+0xf
86a58d00 81c5b043 83780a08 00000000 83670020 nt!IopProcessWorkItem+0x23
86a58d50 81de7d16 00000000 90dd2603 00000000 nt!ExpWorkerThread+0x10d
86a58d90 81c89159 81c5af36 00000000 00000000 nt!PspSystemThreadStartup+0x9e
STACK_COMMAND: kb
FOLLOWUP_IP:
athr+212e1
a3e622e1 ?? ???
MODULE_NAME: athr
start end module name
86e1f000 86e67000 ACPI ACPI.sys Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8b46f000 8b4c9000 afd afd.sys Mon Jul 13 19:12:34 2009 (4A5BBF62)
8c727000 8c739000 AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
87107000 87110000 amdxata amdxata.sys Tue May 19 13:57:35 2009 (4A12F30F)
870db000 870e4000 atapi atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
870e4000 87107000 ataport ataport.SYS Mon Jul 13 19:11:18 2009 (4A5BBF16)
a3e41000 a3f65000 athr athr.sys Mon Aug 10 21:14:25 2009 (4A80C5F1)
86ec6000 86ed1000 BATTC BATTC.SYS Mon Jul 13 19:19:15 2009 (4A5BC0F3)
8761c000 87623000 Beep Beep.SYS Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8b5fc000 8b60a000 blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
86cab000 86cb3000 BOOTVID BOOTVID.dll Mon Jul 13 21:04:34 2009 (4A5BD9A2)
8b79c000 8b7b5000 bowser bowser.sys Mon Jul 13 19:14:21 2009 (4A5BBFCD)
81330000 8134e000 cdd cdd.dll unavailable (00000000)
86cf5000 86da0000 CI CI.dll Mon Jul 13 21:09:28 2009 (4A5BDAC8)
874aa000 874cf000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
86cb3000 86cf5000 CLFS CLFS.SYS Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8c698000 8c69b700 CmBatt CmBatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
872c2000 8731f000 cng cng.sys Mon Jul 13 19:32:55 2009 (4A5BC427)
86ebe000 86ec6000 compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6)
8c71a000 8c727000 CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
80eec000 80ef9000 crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
8b5e4000 8b5fc000 dfsc dfsc.sys Mon Jul 13 19:14:16 2009 (4A5BBFC8)
8b5d8000 8b5e4000 discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
87499000 874aa000 disk disk.sys Mon Jul 13 19:11:28 2009 (4A5BBF20)
8c6b4000 8c6be000 DKbFltr DKbFltr.sys Wed Mar 25 23:10:12 2009 (49CAF214)
80ec9000 80ee2000 drmk drmk.sys Mon Jul 13 20:36:05 2009 (4A5BD2F5)
80fd3000 80fe4000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
80ef9000 80fd3000 dump_iaStor dump_iaStor.sys Thu Jun 04 21:42:33 2009 (4A287809)
80ee2000 80eec000 Dxapi Dxapi.sys Mon Jul 13 19:25:25 2009 (4A5BC265)
8c524000 8c5db000 dxgkrnl dxgkrnl.sys Mon Jul 13 19:26:15 2009 (4A5BC297)
8c5db000 8c614000 dxgmms1 dxgmms1.sys Mon Jul 13 19:25:25 2009 (4A5BC265)
8b772000 8b79c000 fastfat fastfat.SYS Mon Jul 13 19:14:01 2009 (4A5BBFB9)
87144000 87155000 fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
87110000 87144000 fltmgr fltmgr.sys Mon Jul 13 19:11:13 2009 (4A5BBF11)
8732d000 87336000 Fs_Rec Fs_Rec.sys Mon Jul 13 19:11:14 2009 (4A5BBF12)
87467000 87499000 fvevol fvevol.sys Mon Jul 13 19:13:01 2009 (4A5BBF7D)
8b41c000 8b44d000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
82000000 82037000 hal halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
8c614000 8c633000 HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
874cf000 87554000 HTTP HTTP.sys Mon Jul 13 19:12:53 2009 (4A5BBF75)
8745f000 87467000 hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
8c69c000 8c6b4000 i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
87001000 870db000 iaStor iaStor.sys Thu Jun 04 21:42:33 2009 (4A287809)
8c01b000 8c524000 igdkmd32 igdkmd32.sys Wed Sep 23 15:18:09 2009 (4ABA7471)
86f2c000 86f33000 intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)
8b62b000 8b63d000 intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
8c6be000 8c6cb000 kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
81a0c000 81a14000 kdcom kdcom.dll Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8c7c6000 8c7fa000 ks ks.sys Mon Jul 13 19:45:13 2009 (4A5BC709)
872af000 872c2000 ksecdd ksecdd.sys Mon Jul 13 19:11:56 2009 (4A5BBF3C)
86f95000 86fba000 ksecpkg ksecpkg.sys Mon Jul 13 19:34:00 2009 (4A5BC468)
a3e31000 a3e41000 L1C60x86 L1C60x86.sys Mon Jul 27 02:38:59 2009 (4A6D4B83)
80fef000 80fff000 lltdio lltdio.sys Mon Jul 13 19:53:18 2009 (4A5BC8EE)
8b6e4000 8b6ff000 luafv luafv.sys Mon Jul 13 19:15:44 2009 (4A5BC020)
86c22000 86c9a000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
80fe4000 80fef000 monitor monitor.sys Mon Jul 13 19:25:58 2009 (4A5BC286)
8c704000 8c711000 mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
86f41000 86f57000 mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
875e6000 8760c680 MpFilter MpFilter.sys Tue Sep 14 17:23:59 2010 (4C8FE7EF)
a3da0000 a3da5900 MpKsl4ff56318 MpKsl4ff56318.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
8b5d2000 8b5d7900 MpKsl6658dfa3 MpKsl6658dfa3.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
a3d8a000 a3d93200 MpNWMon MpNWMon.sys Tue Sep 14 17:23:50 2010 (4C8FE7E6)
8b7b5000 8b7c7000 mpsdrv mpsdrv.sys Mon Jul 13 19:52:52 2009 (4A5BC8D4)
8b7c7000 8b7ea000 mrxsmb mrxsmb.sys Mon Jul 13 19:14:24 2009 (4A5BBFD0)
87554000 8758f000 mrxsmb10 mrxsmb10.sys Mon Jul 13 19:14:34 2009 (4A5BBFDA)
8b400000 8b41b000 mrxsmb20 mrxsmb20.sys Mon Jul 13 19:14:29 2009 (4A5BBFD5)
87675000 87680000 Msfs Msfs.SYS Mon Jul 13 19:11:26 2009 (4A5BBF1E)
86e70000 86e78000 msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
87284000 872af000 msrpc msrpc.sys Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8b5c8000 8b5d2000 mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8744f000 8745f000 mup mup.sys Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8760d000 87615000 mwlPSDFilter mwlPSDFilter.sys Tue Jun 02 06:06:37 2009 (4A24F9AD)
8b5c0000 8b5c8000 mwlPSDNServ mwlPSDNServ.sys Tue Jun 02 06:06:48 2009 (4A24F9B8)
8b5ae000 8b5c0000 mwlPSDVDisk mwlPSDVDisk.sys Tue Jun 02 06:07:00 2009 (4A24F9C4)
87336000 873ed000 ndis ndis.sys Mon Jul 13 19:12:24 2009 (4A5BBF58)
8c751000 8c75c000 ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
80c00000 80c10000 ndisuio ndisuio.sys Mon Jul 13 19:53:51 2009 (4A5BC90F)
8c75c000 8c77e000 ndiswan ndiswan.sys Mon Jul 13 19:54:34 2009 (4A5BC93A)
8b681000 8b692000 NDProxy NDProxy.SYS Mon Jul 13 19:54:27 2009 (4A5BC933)
8b532000 8b540000 netbios netbios.sys Mon Jul 13 19:53:54 2009 (4A5BC912)
8b4c9000 8b4fb000 netbt netbt.sys Mon Jul 13 19:12:18 2009 (4A5BBF52)
86f57000 86f95000 NETIO NETIO.SYS Thu Apr 08 22:32:21 2010 (4BBE91B5)
a3d94000 a3d9fc00 NisDrvWFP NisDrvWFP.sys Tue Sep 14 17:24:12 2010 (4C8FE7FC)
87680000 8768e000 Npfs Npfs.SYS Mon Jul 13 19:11:31 2009 (4A5BBF23)
8b5a4000 8b5ae000 nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
81c00000 82000000 nt ntkrnlmp.exe Mon Jul 13 19:15:08 2009 (4A5BBFFC)
87155000 87284000 Ntfs Ntfs.sys Mon Jul 13 19:12:05 2009 (4A5BBF45)
87615000 8761c000 Null Null.SYS Mon Jul 13 19:11:12 2009 (4A5BBF10)
8b719000 8b75f000 nwifi nwifi.sys Mon Jul 13 19:51:59 2009 (4A5BC89F)
8b502000 8b521000 pacer pacer.sys Mon Jul 13 19:53:58 2009 (4A5BC916)
86ead000 86ebe000 partmgr partmgr.sys Mon Jul 13 19:11:35 2009 (4A5BBF27)
86e78000 86ea2000 pci pci.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
86f33000 86f41000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:11:15 2009 (4A5BBF13)
8731f000 8732d000 pcw pcw.sys Mon Jul 13 19:11:10 2009 (4A5BBF0E)
a3c1b000 a3cb2000 peauth peauth.sys Mon Jul 13 20:35:44 2009 (4A5BD2E0)
80e9a000 80ec9000 portcls portcls.sys Mon Jul 13 19:51:00 2009 (4A5BC864)
86c9a000 86cab000 PSHED PSHED.dll Mon Jul 13 21:09:36 2009 (4A5BDAD0)
8c739000 8c751000 rasl2tp rasl2tp.sys Mon Jul 13 19:54:33 2009 (4A5BC939)
8c77e000 8c796000 raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
8c796000 8c7ad000 raspptp raspptp.sys Mon Jul 13 19:54:47 2009 (4A5BC947)
8c7ad000 8c7c4000 rassstp rassstp.sys Mon Jul 13 19:54:57 2009 (4A5BC951)
8b563000 8b5a4000 rdbss rdbss.sys Mon Jul 13 19:14:26 2009 (4A5BBFD2)
8765d000 87665000 RDPCDD RDPCDD.sys Mon Jul 13 20:01:40 2009 (4A5BCAE4)
87665000 8766d000 rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8766d000 87675000 rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
87422000 8744f000 rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8b75f000 8b772000 rspndr rspndr.sys Mon Jul 13 19:53:20 2009 (4A5BC8F0)
80c12000 80e99140 RTKVHDA RTKVHDA.sys Mon Jul 06 05:12:43 2009 (4A51C00B)
a3cb2000 a3cbc000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
873ed000 873f5000 spldr spldr.sys Mon May 11 12:13:47 2009 (4A084EBB)
a3dc7000 a3e31000 spsys spsys.sys Mon May 11 12:37:10 2009 (4A085436)
a3d39000 a3d8a000 srv srv.sys Mon Jul 13 19:15:10 2009 (4A5BBFFE)
a3cea000 a3d39000 srv2 srv2.sys Mon Jul 13 19:14:52 2009 (4A5BBFEC)
a3cbc000 a3cdd000 srvnet srvnet.sys Mon Jul 13 19:14:45 2009 (4A5BBFE5)
8c7c4000 8c7c5380 swenum swenum.sys Mon Jul 13 19:45:08 2009 (4A5BC704)
8c6cb000 8c701400 SynTP SynTP.sys Thu Sep 03 20:32:25 2009 (4AA06019)
8768e000 877d7000 tcpip tcpip.sys Thu Apr 08 22:32:59 2010 (4BBE91DB)
a3cdd000 a3cea000 tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
8b464000 8b46f000 TDI TDI.SYS Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8b44d000 8b464000 tdx tdx.sys Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8b553000 8b563000 termdd termdd.sys Mon Jul 13 20:01:35 2009 (4A5BCADF)
81300000 81309000 TSDDD TSDDD.dll unavailable (00000000)
8b60a000 8b62b000 tunnel tunnel.sys Mon Jul 13 19:54:03 2009 (4A5BC91B)
8c000000 8c00e000 umbus umbus.sys Mon Jul 13 19:51:38 2009 (4A5BC88A)
8b6a9000 8b6c0000 usbccgp usbccgp.sys Mon Jul 13 19:51:31 2009 (4A5BC883)
8c702000 8c703700 USBD USBD.SYS Mon Jul 13 19:51:05 2009 (4A5BC869)
8c689000 8c698000 usbehci usbehci.sys Mon Jul 13 19:51:14 2009 (4A5BC872)
8b63d000 8b681000 usbhub usbhub.sys Mon Jul 13 19:52:06 2009 (4A5BC8A6)
8c63e000 8c689000 USBPORT USBPORT.SYS Mon Jul 13 19:51:13 2009 (4A5BC871)
8b692000 8b6a9000 USBSTOR USBSTOR.SYS Mon Jul 13 19:51:19 2009 (4A5BC877)
8c633000 8c63e000 usbuhci usbuhci.sys Mon Jul 13 19:51:10 2009 (4A5BC86E)
8b6c0000 8b6e3b00 usbvideo usbvideo.sys Mon Jul 13 19:51:51 2009 (4A5BC897)
86ea2000 86ead000 vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
87623000 8762f000 vga vga.sys Mon Jul 13 19:25:50 2009 (4A5BC27E)
8762f000 87650000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
86ed1000 86ee1000 volmgr volmgr.sys Mon Jul 13 19:11:25 2009 (4A5BBF1D)
86ee1000 86f2c000 volmgrx volmgrx.sys Mon Jul 13 19:11:41 2009 (4A5BBF2D)
86fba000 86ff9000 volsnap volsnap.sys Mon Jul 13 19:11:34 2009 (4A5BBF26)
a3f65000 a3f6f000 vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2)
8b521000 8b532000 vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
a3f6f000 a3f78000 vwifimp vwifimp.sys Mon Jul 13 19:52:09 2009 (4A5BC8A9)
8b540000 8b553000 wanarp wanarp.sys Mon Jul 13 19:55:02 2009 (4A5BC956)
87650000 8765d000 watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
86da0000 86e11000 Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
86e11000 86e1f000 WDFLDR WDFLDR.SYS Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8b4fb000 8b502000 wfplwf wfplwf.sys Mon Jul 13 19:53:51 2009 (4A5BC90F)
810a0000 812ea000 win32k win32k.sys unavailable (00000000)
8c711000 8c71a000 wmiacpi wmiacpi.sys Mon Jul 13 19:19:16 2009 (4A5BC0F4)
86e67000 86e70000 WMILIB WMILIB.SYS Mon Jul 13 19:11:22 2009 (4A5BBF1A)
8b6ff000 8b719000 WudfPf WudfPf.sys Mon Jul 13 19:50:13 2009 (4A5BC835)
a3da6000 a3dc6480 WUDFRd WUDFRd.sys Mon Jul 13 19:50:44 2009 (4A5BC854)
Unloaded modules:
8758f000 875a7000 parport.sys
Checksum: 00000000
ImageSize: 00018000
874cf000 874dc000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000D000
874dc000 875b6000 dump_iaStor.
Checksum: 00000000
ImageSize: 000DA000
875b6000 875c7000 dump_dumpfve
Checksum: 00000000
ImageSize: 00011000
875c7000 875e6000 cdrom.sys
Checksum: 00000000
ImageSize: 0001F000
