Windows 7 BSOD help !!!
Kalashnikov
I'm using vmware and running 5 virtual machines (win2k3). Unfortunately, I double click on Black Ops, the game running and minimize to taskbar. Then I use Task Manager to end it and I got a BSOD. As I guest, it may because of Ram overloading. So any help would be very thankful.
Specs:
Windows 7 Pro 64bit
Retail version
Lappy: Dell Inspiron 15R
Bought on January 2011
Ram 4Gb, CPU core i5 2.67GHz, VGA Ati HD5650, HDD Seagate 500GB.
  • 051311-17284-01.rar
Your blue screens probably come from Intel Turbo Boost.
The crash was caused by cdd.dll:
051311-17284-01.dmp
BugCheck 3B, {c0000005, fffff80002c8974e, fffff88008db5cd0, 0}
PROCESS_NAME: BlackOps.exe
Probably caused by : cdd.dll ( cdd+dce0 )
This could also mean problems with NTFS and hard disk. Therefore,
1. Command Prompt > chkdsk /f
2. HDDScan
3. Update drivers:
WinRing-library based software, update or uninstall it for now
WinRing0x64.sys Sat Jul 26 09:29:37 2008
Intel Management Engine
HECIx64.sys Thu Sep 17 15:54:16 2009
Intel® Driver Update Utility
Touchpad
SynTP.sys Wed Dec 23 15:10:23 2009
VMWare
vmnetadapter.sys Mon Aug 10 08:04:53 2009
4. If crashes persist, uninstall Intel Turbo Boost.
CRASH DUMPS
Loading Dump File [F:\DMP\051311-17284-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16792.amd64fre.win7_gdr.110408-1633
Machine Name:
Kernel base = 0xfffff800`02c4f000 PsLoadedModuleList = 0xfffff800`02e8ce50
Debug session time: Thu May 12 23:58:42.252 2011 (UTC - 4:00)
System Uptime: 0 days 0:47:30.969
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*** ERROR: Module load completed but symbols could not be loaded for cdd.dll
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002c8974e, Address of the instruction which caused the bugcheck
Arg3: fffff88008db5cd0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+26
fffff800`02c8974e f00fba3100      lock btr dword ptr [rcx],0
CONTEXT:  fffff88008db5cd0 -- (.cxr 0xfffff88008db5cd0)
rax=fffffa8003ecf060 rbx=0000000000000000 rcx=0000000000000000
rdx=fffffa8003ecf060 rsi=00000000ffffffff rdi=fffffa8003ecf060
rip=fffff80002c8974e rsp=fffff88008db66a0 rbp=0000000000000001
 r8=0000000000000000  r9=0000000000000000 r10=0000000000005e02
r11=fffff88008db66f0 r12=0000000000000000 r13=0000000000000001
r14=0000000000000000 r15=fffff900c06b6370
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+0x26:
fffff800`02c8974e f00fba3100      lock btr dword ptr [rcx],0 ds:002b:00000000`00000000=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff9600074dce0 to fffff80002c8974e
STACK_TEXT:
fffff880`08db66a0 fffff960`0074dce0 : 00000000`00000000 00000a60`00000000 00001f56`00000000 00000000`00000010 : nt!ExEnterCriticalRegionAndAcquireFastMutexUnsafe+0x26
fffff880`08db66d0 fffff960`001254a0 : 00000000`00000001 fffff900`c00bf010 00000000`00000001 fffff900`c01dc860 : cdd+0xdce0
fffff880`08db6710 fffff960`0012d771 : 00000000`00000000 fffff880`00000001 fffff900`c01dc860 fffff900`00000000 : win32k!SURFACE::bDeleteSurface+0x358
fffff880`08db6860 fffff960`00124d40 : 00000000`00000a60 fffff880`08db6c00 fffff900`c2d3da10 fffffa80`00000000 : win32k!NtGdiCloseProcess+0x2c9
fffff880`08db68c0 fffff960`00124487 : fffffa80`08016200 fffff880`08db6c20 00000000`00000000 00000000`00000202 : win32k!GdiProcessCallout+0x200
fffff880`08db6940 fffff800`02fa357d : fffffa80`080162a0 00000000`00000000 00000000`00000000 fffffa80`03ecf060 : win32k!W32pProcessCallout+0x6b
fffff880`08db6970 fffff800`02f7d5bd : 00000000`00000001 00000000`00000001 00000000`78457300 fffffa80`03ea4060 : nt!PspExitThread+0x561
fffff880`08db6a30 fffff800`02c9c16b : 00000000`00000100 fffffa80`03ecf120 00000000`00000001 fffff800`02cc6b9d : nt!PsExitSpecialApc+0x1d
fffff880`08db6a60 fffff800`02c9c5b0 : 00000000`00000000 fffff880`08db6ae0 fffff800`02f7d6cc 00000000`00000001 : nt!KiDeliverApc+0x2eb
fffff880`08db6ae0 fffff800`02cbe9f7 : fffffa80`03ecf060 00000000`00000534 fffff880`08db6bf8 fffffa80`090ba820 : nt!KiInitiateUserApc+0x70
fffff880`08db6c20 00000000`73f92dd9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9c
00000000`2ca9f0f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x73f92dd9
FOLLOWUP_IP:
cdd+dce0
fffff960`0074dce0 488b4738        mov     rax,qword ptr [rdi+38h]
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  cdd+dce0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: cdd
IMAGE_NAME:  cdd.dll
DEBUG_FLR_IMAGE_TIMESTAMP:  4bf4408a
STACK_COMMAND:  .cxr 0xfffff88008db5cd0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_cdd+dce0
DRIVERS
fffff880`00f5c000 fffff880`00fb3000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`04000000 fffff880`0408a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045d4000 fffff880`045ea000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`012d8000 fffff880`012e3000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0933f000 fffff880`0934a000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`0128a000 fffff880`01293000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01293000 fffff880`012bd000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`054de000 fffff880`05501000   AtiHdmi  AtiHdmi.sys  Thu May 06 05:20:39 2010 (4BE289E7)
fffff880`04a4b000 fffff880`05282000   atikmdag atikmdag.sys Tue Jan 04 21:48:52 2011 (4D23DC14)
fffff880`02e00000 fffff880`02e4d000   atikmpag atikmpag.sys Tue Jan 04 21:19:38 2011 (4D23D53A)
fffff880`00e2b000 fffff880`00e37000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`04315000 fffff880`0431c000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02f8f000 fffff880`02fa0000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`073ce000 fffff880`073ec000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`042b1000 fffff880`042db000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01b35000 fffff880`01b65000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d3d000 fffff880`00d9b000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`045a9000 fffff880`045ad500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00e22000 fffff880`00e2b000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`045c4000 fffff880`045d4000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`05400000 fffff880`0540e000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02eee000 fffff880`02f71000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`02f71000 fffff880`02f8f000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`01a7c000 fffff880`01a8b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01b1f000 fffff880`01b35000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0553e000 fffff880`05560000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`0540e000 fffff880`05421000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0408a000 fffff880`04294000   dump_iaStor dump_iaStor.sys Tue Jun 08 13:33:03 2010 (4C0E7ECF)
fffff880`055e8000 fffff880`055f4000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05282000 fffff880`05376000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`05376000 fffff880`053bc000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`0132f000 fffff880`01343000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`012e3000 fffff880`0132f000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01411000 fffff880`0141b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01ae5000 fffff880`01b1f000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`017a8000 fffff880`017f2000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02c06000 fffff800`02c4f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`08890000 fffff880`0889c000   hcmon    hcmon.sys    Sat Mar 26 00:40:38 2011 (4D8D6E46)
fffff880`053bc000 fffff880`053e0000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`053e0000 fffff880`053f1000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`0544c000 fffff880`05465000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05465000 fffff880`0546d080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0543e000 fffff880`0544c000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`07306000 fffff880`073ce000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0161f000 fffff880`01628000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04a11000 fffff880`04a2f000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01080000 fffff880`0128a000   iaStor   iaStor.sys   Tue Jun 08 13:33:03 2010 (4C0E7ECF)
fffff880`0898a000 fffff880`089b0000   idmwfp   idmwfp.sys   Mon Jan 24 09:52:08 2011 (4D3D9218)
fffff880`04579000 fffff880`0459fd00   Impcd    Impcd.sys    Fri Feb 26 18:32:11 2010 (4B8859FB)
fffff880`045ae000 fffff880`045c4000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0455f000 fffff880`0456e000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05fe8000 fffff880`05ff6000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb0000 fffff800`00bba000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`02ea3000 fffff880`02ee6000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`015e6000 fffff880`01600000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0177d000 fffff880`017a8000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05560000 fffff880`05565200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02fe9000 fffff880`02ffe000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02fc6000 fffff880`02fe9000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ce5000 fffff880`00d29000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`045ea000 fffff880`045f8000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04550000 fffff880`0455f000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`044e6000 fffff880`044f3000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`042db000 fffff880`0430c000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`07200000 fffff880`07218000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07218000 fffff880`07245000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:15:23 2011 (4D6497EB)
fffff880`0881f000 fffff880`0886d000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:15:14 2011 (4D6497E2)
fffff880`0886d000 fffff880`08890000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:15:13 2011 (4D6497E1)
fffff880`012bd000 fffff880`012c8000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0437a000 fffff880`04385000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fbc000 fffff880`00fc6000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01343000 fffff880`013a1000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`01a71000 fffff880`01a7c000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0141b000 fffff880`0142d000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0162b000 fffff880`0171d000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04424000 fffff880`04430000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`072db000 fffff880`072ee000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04430000 fffff880`0445f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`054c9000 fffff880`054de000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`01bce000 fffff880`01bdd000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`01b73000 fffff880`01bb8000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0171d000 fffff880`0177d000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`05808000 fffff880`05fdb000   NETwNs64 NETwNs64.sys Mon Oct 18 05:21:28 2010 (4CBC1198)
fffff880`092b2000 fffff880`092c7000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`04385000 fffff880`04396000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01a65000 fffff880`01a71000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c4f000 fffff800`0322b000   nt       ntkrnlmp.exe Sat Apr 09 00:14:44 2011 (4D9FDD34)
fffff880`01443000 fffff880`015e6000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0430c000 fffff880`04315000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`07288000 fffff880`072db000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`043d5000 fffff880`043fb000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e0d000 fffff880`00e22000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fc6000 fffff880`00ff9000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`012c8000 fffff880`012d8000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`08e2b000 fffff880`08ed1000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05501000 fffff880`0553e000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d29000 fffff880`00d3d000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04400000 fffff880`04424000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0445f000 fffff880`0447a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0447a000 fffff880`0449b000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0449b000 fffff880`044b5000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`01a14000 fffff880`01a65000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`044b5000 fffff880`044c0000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`0435f000 fffff880`04368000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04368000 fffff880`04371000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04371000 fffff880`0437a000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`00d9b000 fffff880`00dd5000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`072ee000 fffff880`07306000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01a8b000 fffff880`01ae1000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`08ed1000 fffff880`08edc000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01618000 fffff880`0161f000   SmartDefragDriver SmartDefragDriver.sys Wed Feb 23 03:37:56 2011 (4D64C764)
fffff880`01610000 fffff880`01618000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0921d000 fffff880`092b2000   srv      srv.sys      Wed Feb 23 00:16:24 2011 (4D649828)
fffff880`08f3b000 fffff880`08fa2000   srv2     srv2.sys     Wed Feb 23 00:15:59 2011 (4D64980F)
fffff880`08edc000 fffff880`08f09000   srvnet   srvnet.sys   Wed Feb 23 00:15:49 2011 (4D649805)
fffff880`05566000 fffff880`055e8000   stwrt64  stwrt64.sys  Thu Jun 17 22:16:06 2010 (4C1AD6E6)
fffff880`044c0000 fffff880`044c1480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`044ff000 fffff880`0454e000   SynTP    SynTP.sys    Wed Dec 23 15:10:23 2009 (4B32792F)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`08f13000 fffff880`08f25000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`043b4000 fffff880`043c1000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`04396000 fffff880`043b4000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`01a00000 fffff880`01a14000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00470000 fffff960`0047a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02fa0000 fffff880`02fc6000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`044c2000 fffff880`044d4000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05421000 fffff880`0543e000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0454e000 fffff880`0454ff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a00000 fffff880`04a11000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0546f000 fffff880`054c9000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`02e4d000 fffff880`02ea3000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0431c000 fffff880`0432a000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0432a000 fffff880`0434f000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0889c000 fffff880`088b4000   vmci     vmci.sys     Sat Mar 26 00:08:49 2011 (4D8D66D1)
fffff880`0456e000 fffff880`04579000   VMkbd    VMkbd.sys    Sat Mar 26 01:31:22 2011 (4D8D7A2A)
fffff880`044dc000 fffff880`044e6000   VMNET    VMNET.SYS    Mon Aug 10 08:04:50 2009 (4A800CE2)
fffff880`044d4000 fffff880`044dc000   vmnetadapter vmnetadapter.sys Mon Aug 10 08:04:53 2009 (4A800CE5)
fffff880`04a2f000 fffff880`04a3f000   vmnetbridge vmnetbridge.sys Mon Aug 10 08:05:58 2009 (4A800D26)
fffff880`08f25000 fffff880`08f2f000   vmnetuserif vmnetuserif.sys Sat Mar 26 00:55:31 2011 (4D8D71C3)
fffff880`01600000 fffff880`01610000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`088b4000 fffff880`0898a000   vmx86    vmx86.sys    Sat Mar 26 02:18:58 2011 (4D8D8552)
fffff880`00e37000 fffff880`00e4c000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e4c000 fffff880`00ea8000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`013a1000 fffff880`013ed000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`08f2f000 fffff880`08f3b000   vstor2_ws60 vstor2-ws60.sys Thu Aug 19 16:28:39 2010 (4C6D93F7)
fffff880`05fdb000 fffff880`05fe8000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`01bb8000 fffff880`01bce000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`08f09000 fffff880`08f13000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`01bdd000 fffff880`01bf8000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0434f000 fffff880`0435f000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ea9000 fffff880`00f4d000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f4d000 fffff880`00f5c000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`043cc000 fffff880`043d5000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00372000   win32k   win32k.sys   Wed Mar 02 22:58:01 2011 (4D6F11C9)
fffff880`092c7000 fffff880`092ce000   WinRing0x64 WinRing0x64.sys Sat Jul 26 09:29:37 2008 (488B26C1)
fffff880`045a0000 fffff880`045a9000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fb3000 fffff880`00fbc000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`043c1000 fffff880`043cc000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 20:10:33 2009 (4A5BCCF9)
fffff880`00dd5000 fffff880`00df6000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`092ce000 fffff880`0933f000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01b65000 fffff880`01b73000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`04094000 fffff880`0429e000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0020A000
fffff880`0429e000 fffff880`042b1000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Does it relate to BlackOps, cuz at that time I got win2k3 virtual machines so running one more programs like Black Ops could be overwhelming for Ram to handle. That may cause BSOD. Any idea please !!!
Wrong memory management by drivers and software can cause blue screens. Bad ntfs system can cause blue screens as well. Follow steps outlined in my 1st post.
If you give me all crash files from C:\Windows\Minidump, not just 1 that you attached, I will tell you for sure if BlackOps is the main culprit or not. It would be extremely rare case that a pc game causes bsod. Yes, it is possible if all your crash dumps look like this one.
Top Bottom
