I opened my dumps in WinDbg, and found something is causing csrss.exe to close;
not sure how to identify which driver could be the culprit, any assistance would be greatly appreciated!
Symbol search path is:
http://msdl.microsoft.com/download/symbols Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`0280a000 PsLoadedModuleList = 0xfffff800`02a4f670
Debug session time: Sat Nov 5 01:27:55.397 2011 (GMT-5)
System Uptime: 0 days 1:48:03.020
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck F4, {3, fffffa8004fe9280, fffffa8004fe9560, fffff80002b8a8b0}
Probably caused by : csrss.exe
Followup: MachineOwner
0: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8004fe9280, Terminating object
Arg3: fffffa8004fe9560, Process image file name
Arg4: fffff80002b8a8b0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa8004fe9280
IMAGE_NAME: csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: csrss.exe
BUGCHECK_STR: 0xF4_C0000005
CUSTOMER_CRASH_COUNT: 1
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`043d00e8 fffff800`02c115e2 : 00000000`000000f4 00000000`00000003 fffffa80`04fe9280 fffffa80`04fe9560 : nt!KeBugCheckEx
fffff880`043d00f0 fffff800`02bbe99b : ffffffff`ffffffff fffffa80`0562fa00 fffffa80`04fe9280 fffffa80`04fe9280 : nt!PspCatchCriticalBreak+0x92
fffff880`043d0130 fffff800`02b3e448 : ffffffff`ffffffff 00000000`00000001 fffffa80`04fe9280 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176d6
fffff880`043d0180 fffff800`02885ed3 : fffffa80`04fe9280 fffff800`c0000005 fffffa80`0562fa00 00000000`02370a40 : nt!NtTerminateProcess+0xf4
fffff880`043d0200 fffff800`02882470 : fffff800`028d267f fffff880`043d0b78 fffff880`043d08d0 fffff880`043d0c20 : nt!KiSystemServiceCopyEnd+0x13
fffff880`043d0398 fffff800`028d267f : fffff880`043d0b78 fffff880`043d08d0 fffff880`043d0c20 00000000`023715f0 : nt!KiServiceLinkage
fffff880`043d03a0 fffff800`028862c2 : fffff880`043d0b78 00000000`77229c12 fffff880`043d0c20 00000000`023710c8 : nt! ?? ::FNODOBFM::`string'+0x49874
fffff880`043d0a40 fffff800`02884e3a : 00000000`00000001 00000000`02370ff8 00000000`0238e001 00000000`77229c12 : nt!KiExceptionDispatch+0xc2
fffff880`043d0c20 00000000`77229a9b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
00000000`02371000 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77229a9b
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_C0000005_IMAGE_csrss.exe
0: kd> !analyze -show D1
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000000, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: 0000000000000000, address which referenced memory
