* Bugcheck Analysis *
BugCheck 1A, {41289, 7fefe812001, 5ef, 7fefc812005}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4a99 )
Followup: MachineOwner
looking through the dump files there over 12 different types of Bugcheck which in itself can sometimes be indicative of a hardware issue. The most frequent Bugchecks were ones relating to memory issues and you might well have some faulty RAM. The above dump file means a memory management error occurred.
McAfee was mentioned in quite a few dump files and is known on occasion to cause issues. Please uninstall and use MSE for the interim as it's super stable:
atikmdag.sys Thu Sep 12 03:08:03 2013: AMD GPU driver. Please update:
Rt64win7.sys Mon Mar 22 09:57:14 2010: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet please update:
I think your also missing a Realtek Hi-Def audio driver:
If after making the above changes you still get the bsod then you need to test your RAM.
Windows does have it's own memory testing app but it can often miss errors and the best app for the job is Memtest86. The latest version of which can be found here:
http://www.memtest.org/
To run Memtest86 you need to either burn a copy of it to disk or use a USB stick. If you look down the page you'll eventually find the latest version and it's associated downloads. If your burning to disk choose the pre-compiled iso zip. If your using a USB method then the corresponding download is the auto installer for a USB stick.
Once you have Memtest86 on the media you selected you'll then need to enter your bios and change the boot order so that the machine will boot from either the disk or stick you have Memtest86 on.
Try and run the test overnight if possible unless it becomes clear that there is a issue. If there is a problem with the RAM you'll see the errors pop up in red so you can't miss them.
Post any new dump files.
