Unable to load image \??\C:\Windows\SysWOW64\Drivers\IesDrv.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for IesDrv.sys
*** ERROR: Module load completed but symbols could not be loaded for IesDrv.sys
Probably caused by : IesDrv.sys ( IesDrv+54ef )
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff880063c04ef, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff880063c04ef, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f050e0
fffff880063c04ef
CURRENT_IRQL: 2
FAULTING_IP:
IesDrv+54ef
fffff880`063c04ef 440f22c1 mov cr8,rcx
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VERIFIER_ENABLED_VISTA_MINIDUMP
BUGCHECK_STR: 0xD1
PROCESS_NAME: AsrIes.exe
TRAP_FRAME: fffff8800681f7e0 -- (.trap 0xfffff8800681f7e0)
rax=00000000000eba9c rbx=0000000000000000 rcx=0000000000000001
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880063c04ef rsp=fffff8800681f970 rbp=fffff9800f696ee0
r8=0000000000000b34 r9=0000000000000000 r10=fffff9800f696ee0
r11=0000020b9abd6800 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na po nc
IesDrv+0x54ef:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002cccb29 to fffff80002ccd5c0
FAILED_INSTRUCTION_ADDRESS:
IesDrv+54ef
STACK_TEXT:
fffff880`0681f698 fffff800`02cccb29 : 00000000`0000000a fffff880`063c04ef 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`0681f6a0 fffff800`02ccb7a0 : 00000000`0015bada 00000000`0015bada 00000000`00000001 00000000`00d10461 : nt!KiBugCheckDispatch+0x69
fffff880`0681f7e0 fffff880`063c04ef : 00000000`0015bada fffff800`031602a7 00000000`00000001 00000000`00000001 : nt!KiPageFault+0x260
fffff880`0681f970 00000000`0015bada : fffff800`031602a7 00000000`00000001 00000000`00000001 00000000`00000001 : IesDrv+0x54ef
fffff880`0681f978 fffff800`031602a7 : 00000000`00000001 00000000`00000001 00000000`00000001 00000000`00000000 : 0x15bada
fffff880`0681f980 fffff800`03173c16 : fffff980`0f696ee0 00000000`00000002 fffffa80`07bb07b0 fffffa80`03ceb418 : nt!VfIrpAllocateCallDriverData+0x47
fffff880`0681f9b0 fffff800`02fe5597 : fffffa80`07b30090 fffff880`0681fca0 fffffa80`07b30090 fffffa80`07b68f40 : nt!IovCallDriver+0x566
fffff880`0681fa10 fffff800`02fe5df6 : fffff800`00000001 00000000`00000000 00000000`00000000 00000000`00000000 : nt!IopXxxControlFile+0x607
fffff880`0681fb40 fffff800`02ccc813 : fffff8a0`0abd0000 fffff8a0`0bc6f000 fffff8a0`0704e000 fffff8a0`0704d000 : nt!NtDeviceIoControlFile+0x56
fffff880`0681fbb0 00000000`75152dd9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0008ebf8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75152dd9
STACK_COMMAND: kb
FOLLOWUP_IP:
IesDrv+54ef
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: IesDrv+54ef
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: IesDrv
IMAGE_NAME: IesDrv.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4965bc6c
FAILURE_BUCKET_ID: X64_0xD1_VRF_CODE_AV_BAD_IP_IesDrv+54ef
