Windows 7 BSOD - Memory management
yamahasi
I've been getting semi-frequent (few per day) BSOD's with the "memory management" message, mostly while playing WoW, but sometimes just doing random web surfing. On a possibly related note, I've been getting very frequent WoW errors that cite:
"ERROR #132 (0x85100084) Fatal exception!
Program: C:\Program Files (x86)\World of Warcraft\Wow-64.exe
ProcessID: 5516
Exception: 0xC0000005 (ACCESS_VIOLATION) at 0033:000000013FE6481E
The instruction at "0x000000013FE6481E" referenced memory at "0x0000000000000000".
The memory could not be "written"."
Attached all files as instructed in the stickied post. Any help would be extremely appreciated!
View attachment W7F_14-04-2013.zip
*EDIT* Just got another BSOD: PFN_LIST_CORRUPT, as I was trying to run Windows update. Strongly thinking this is leading to bad memory now?
usasma
Fantastic Member
Sorry for the delay in responding. There just aren't that many people who do BSOD analysis, so at times we get a bit overwhelmed!
Only 86 Windows Updates installed. Most systems have 150 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all). Try it with a wired connection to help speed it up (and to isolate if the wifi connection is the cause).
You have a Linksys AE2500 wireless USB network adapter:
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
Beyond that, I also suspect your Norton security software. Please try this:
Anti-Virus Removal:
Please do the following:
- download a free anti-virus for testing purposes: Free AntiVirus If using Windows 8, enable Windows Defender and the Windows Firewall instead.
- un-install the Norton from your system (you can reinstall it, if so desired, when we're done troubleshooting)
- remove any remnants of Norton using this free tool: http://us.norton.com/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN
- IMMEDIATELY install and update the free anti-virus (if using Win8, enable Windows Defender), then check to ensure that the Windows Firewall is turned on.
- perform a full system scan to ensure that no malware has snuck onto your system while the anti-virus was malfunctioning.
- check to see if this fixes the BSOD's
NOTE: NEVER run more than 1 anti-virus, firewall, Internet Security/Security Center application at the same time.
AppleCharger.sys Tue Nov 1 22:46:00 2011 (4EB0AEE8)
GIGABYTE On/Off Charge driver. See here for details - GIGABYTE ON/OFF Charge [br] May cause BSOD on Win7/8 systems - uninstall to test (haven't seen recently (15Jan2013))
http://www.carrona.org/drivers/driver.php?id=AppleCharger.sys
You can try these free hardware diagnostics also (I don't suspect a hardware problem, but it's always a good idea to check): Initial Hardware Diagnostics
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sun Apr 14 21:59:22.430 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041413-22557-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:15:50.678[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )[/B]
BugCheck [B]1A, {41790, fffffa80031a4960, ffff, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001A]MEMORY_MANAGEMENT (1a)[/url]
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
    contains the address of the PFN for the corrupted page table page.
    On a 32 bit OS, parameter 2 contains a pointer to the number of used
    PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa80031a4960
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  WerFault.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084[/B]
CPUID:        "Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3292[/B]
  BIOS Version                  F12
  BIOS Release Date             10/26/2012
  Manufacturer                  Gigabyte Technology Co., Ltd.
  Product Name                  To be filled by O.E.M.
**************************Sun Apr 14 21:42:54.895 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041413-21652-01.dmp]
System Uptime:[B]0 days 0:08:36.144[/B]
*** WARNING: Unable to verify timestamp for SYMEFA64.SYS
*** ERROR: Module load completed but symbols could not be loaded for SYMEFA64.SYS
Probably caused by :[B]SYMEFA64.SYS ( SYMEFA64+103ec2 )[/B]
BugCheck [B]1A, {41287, ca6398d0, 0, 0}[/B]
Arguments:
Arg1: 0000000000041287, An illegal page fault occurred while holding working set synchronization.
    Parameter 2 contains the referenced virtual address.
Arg2: 00000000ca6398d0
Arg3: 0000000000000000
BUGCHECK_STR:  0x1a_41287
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41287_SYMEFA64+103ec2[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Apr 14 15:00:16.836 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041413-16068-01.dmp]
System Uptime:[B]0 days 5:24:29.868[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]109, {a3a039d8a2226546, 0, 84e2cfba521eb9f0, 101}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000109]CRITICAL_STRUCTURE_CORRUPTION (109)[/url]
Arguments:
Arg1: a3a039d8a2226546, Reserved
Arg2: 0000000000000000, Reserved
Arg3: 84e2cfba521eb9f0, Failure type dependent information
Arg4: 0000000000000101, Type of corrupted region, can be
    0 : A generic data region
    1 : Modification of a function or .pdata
    2 : A processor IDT
    3 : A processor GDT
    4 : Type 1 process list corruption
    5 : Type 2 process list corruption
    6 : Debug routine modification
    7 : Critical MSR modification
BUGCHECK_STR:  0x109
PROCESS_NAME:  System
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sat Apr 13 23:51:29.116 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041413-20966-01.dmp]
System Uptime:[B]0 days 7:50:39.991[/B]
BugCheck [B]1A, {41790, fffffa80031a4900, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a4900
PROCESS_NAME:  IAStorDataMgrS
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sat Apr 13 16:00:18.356 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041313-22105-01.dmp]
System Uptime:[B]0 days 0:02:38.230[/B]
BugCheck [B]1A, {41790, fffffa80031a43c0, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a43c0
MaxSpeed:     3300
  BIOS Version                  F12
**************************Fri Apr 12 14:32:57.356 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041213-22230-01.dmp]
System Uptime:[B]0 days 0:03:38.230[/B]
BugCheck [B]1A, {41790, fffffa80031a51d0, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a51d0
PROCESS_NAME:  GoogleUpdate.e
MaxSpeed:     3300
  BIOS Version                  F12
**************************Thu Apr 11 00:30:17.740 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041213-21496-01.dmp]
System Uptime:[B]0 days 21:14:01.614[/B]
BugCheck [B]1A, {41790, fffffa80031a43f0, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a43f0
PROCESS_NAME:  rundll32.exe
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Apr  7 19:38:19.887 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040713-22089-01.dmp]
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 0:18:10.762[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!FsRtlCurrentBatchOplock+a )[/B]
BugCheck [B]24, {1904fb, fffff8800917e678, fffff8800917ded0, fffff800031bce56}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000024]NTFS_FILE_SYSTEM (24)[/url]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff8800917e678
Arg3: fffff8800917ded0
Arg4: fffff800031bce56
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_0x24_nt!FsRtlCurrentBatchOplock+a[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Apr  7 13:52:09.160 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040713-24835-01.dmp]
System Uptime:[B]0 days 0:41:11.035[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )[/B]
BugCheck [B]1, {7736138a, 0, ffff, fffff88003f11b60}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000001]APC_INDEX_MISMATCH (1)[/url]
Arguments:
Arg1: 000000007736138a, Address of system call function or worker routine
Arg2: 0000000000000000, Thread->ApcStateIndex
Arg3: 000000000000ffff, (Thread->SpecialApcDisable << 16) | Thread->KernelApcDisable
Arg4: fffff88003f11b60, Call type (0 - system call, 1 - worker routine)
BUGCHECK_STR:  0x1
FAILURE_BUCKET_ID: [B]X64_0x1_SysCallNum_4_nt!KiSystemServiceExit+245[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Apr  7 13:10:31.891 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040713-24913-01.dmp]
System Uptime:[B]0 days 1:06:31.766[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+a53 )[/B]
BugCheck [B]19, {3, fffff8000301faf0, fffff80003019bf0, fffff8000301faf0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000019]BAD_POOL_HEADER (19)[/url]
Arguments:
Arg1: 0000000000000003, the pool freelist is corrupt.
Arg2: fffff8000301faf0, the pool entry being checked.
Arg3: fffff80003019bf0, the read back flink freelist value (should be the same as 2).
Arg4: fffff8000301faf0, the read back blink freelist value (should be the same as 2).
BUGCHECK_STR:  0x19_3
PROCESS_NAME:  mumble.exe
FAILURE_BUCKET_ID: [B]X64_0x19_3_nt!ExDeferredFreePool+a53[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Apr  7 12:03:21.300 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040713-25849-01.dmp]
System Uptime:[B]0 days 0:04:46.174[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+249 )[/B]
BugCheck [B]3B, {c0000005, fffff80002fabb05, fffff8800a8a9ca0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002fabb05, Address of the instruction which caused the bugcheck
Arg3: fffff8800a8a9ca0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ExDeferredFreePool+249[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr  3 20:31:00.061 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040313-25022-01.dmp]
System Uptime:[B]0 days 3:25:46.310[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4ad3 )[/B]
BugCheck [B]1A, {41284, 28fe0001, 1fbe1, fffff70001080000}[/B]
Arguments:
Arg1: 0000000000041284, A PTE or the working set list is corrupt.
Arg2: 0000000028fe0001
Arg3: 000000000001fbe1
Arg4: fffff70001080000
BUGCHECK_STR:  0x1a_41284
PROCESS_NAME:  Wow-64.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41284_nt!_??_::FNODOBFM::_string_+4ad3[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Tue Apr  2 22:11:40.151 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040313-23883-01.dmp]
System Uptime:[B]1 days 23:48:57.025[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+45f7d )[/B]
BugCheck [B]1A, {5003, fffff70001080000, 13f3, 2f0d000026e6}[/B]
Arguments:
Arg1: 0000000000005003, The subtype of the bugcheck.
Arg2: fffff70001080000
Arg3: 00000000000013f3
Arg4: 00002f0d000026e6
BUGCHECK_STR:  0x1a_5003
FAILURE_BUCKET_ID: [B]X64_0x1a_5003_nt!_??_::FNODOBFM::_string_+45f7d[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Sun Mar 31 22:22:24.837 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\033113-25084-01.dmp]
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
System Uptime:[B]0 days 11:53:21.711[/B]
BugCheck [B]3B, {c0000005, fffff800031b2388, fffff8800b6b5cd0, 0}[/B]
Arguments:
Arg2: fffff800031b2388, Address of the instruction which caused the bugcheck
Arg3: fffff8800b6b5cd0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
**************************Sun Mar 31 10:27:41.767 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\033113-25584-01.dmp]
System Uptime:[B]1 days 17:25:20.016[/B]
BugCheck [B]1A, {41790, fffffa80031a4930, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a4930
PROCESS_NAME:  ccsvchst.exe
MaxSpeed:     3300
  BIOS Version                  F12
**************************Fri Mar 29 17:01:40.418 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032913-18626-01.dmp]
System Uptime:[B]15 days 13:43:22.640[/B]
BugCheck [B]1A, {41284, 185cf001, 23fe1, fffff70001080000}[/B]
Arguments:
Arg2: 00000000185cf001
Arg3: 0000000000023fe1
MaxSpeed:     3300
  BIOS Version                  F12
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AE2500w764.sys              Mon Mar 28 20:22:08 2011 (4D912630)
Rt64win7.sys                Tue Sep 27 10:50:33 2011 (4E81E2B9)
[COLOR=RED][B]AppleCharger.sys            Tue Nov  1 22:46:00 2011 (4EB0AEE8)[/B][/COLOR]
iaStor.sys                  Wed Feb  1 19:15:24 2012 (4F29D59C)
iusb3hub.sys                Mon May 21 03:21:36 2012 (4FB9ED00)
iusb3xhc.sys                Mon May 21 03:21:40 2012 (4FB9ED04)
iusb3hcs.sys                Mon May 21 03:23:42 2012 (4FB9ED7E)
SYMEVENT64x86.SYS           Wed May 23 20:52:24 2012 (4FBD8648)
IDSVia64.sys                Thu May 24 20:08:33 2012 (4FBECD81)
BHDrvx64.sys                Tue Jun  5 15:46:48 2012 (4FCE6228)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
SYMNETS.SYS                 Fri Jul 20 22:07:07 2012 (500A0ECB)
Ironx64.SYS                 Mon Jul 23 20:34:50 2012 (500DEDAA)
ccSetx64.sys                Thu Aug 16 17:18:11 2012 (502D6393)
t_mouse.sys                 Mon Dec  3 01:19:30 2012 (50BC4472)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
SYMDS64.SYS                 Wed Jan 16 20:56:45 2013 (50F75A5D)
SYMEFA64.SYS                Fri Jan 18 19:31:37 2013 (50F9E969)
SRTSPX64.SYS                Fri Jan 25 16:30:05 2013 (5102F95D)
nvlddmkm.sys                Sat Feb  9 18:13:08 2013 (5116D804)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
nvlddmkm.sys                Fri Jan 18 08:22:15 2013 (50F94C87)
nvlddmkm.sys                Sat Dec 29 01:47:52 2012 (50DE9218)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=AE2500w764.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
http://www.carrona.org/drivers/driver.php?id=IDSVia64.sys
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
http://www.carrona.org/drivers/driver.php?id=t_mouse.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
yamahasi
I removed Norton and installed Microsoft Security Essentials instead, but got another BSOD while it was running a full scan. I'm currently using a wired connection, but after installing a few updates and restarting, now I'm unable to search for updates because of error Code C002001B. The driver for the Linksys 2500 is the most up to date Windows 7 version.
Working on getting updates and new drivers installed, will report back with results ASAP.
Thanks for your help so far!
yamahasi
I'm unable to manually uninstall AppCharger via add/remove programs, but I unchecked the box for the driver via Autorun. I've tried running a full system scan with MSE a few times, but I can't make it all the way through before a BSOD. I've tried even a quick scan with the same results. Today's minidumps zipped and attached.
View attachment 041713-16114-01.zip
usasma
Fantastic Member
Does the system run in Safe Mode without Networking?
In the event that this is a malware problem, you can try these free, bootable rescue CD's: Free Online AntiMalware Resources
Also try these free bootable hardware diagnostics: Initial Hardware Diagnostics
Out of 13 memory dumps there were 6 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
Testing has most likely ruled out video drivers, wireless USB driver, Norton program, AppCharger program
There are (IMO) no more suspicious drivers in the memory dumps (caveat: not all faulting drivers will appear in the memory dumps)
This means (to me) that the problem probably isn't due to compatibility or low-level driver problems (although a corrupted driver is possible)
Problems with Windows Updates and anti-virus scans are suggestive of a malware problem - so the malware scans are advisable.
After that (presuming that the system scans clean), please try running Driver Verifier according to these instructions: Driver Verifier Settings (if you're able to get into Windows) This will help to verify that it's not a corrupted 3rd party driver
Problems in Safe Mode are generally indicative of an issue that's not due to 3rd party drivers (leaving hardware or Windows as the likely cause). There are a few 3rd party drivers that load in Safe Mode, but they're mostly for the storage sub-system.
When operating in Safe Mode w/Networking, the 3rd party network drivers will load also. Also, a lot of malware won't load in Safe Mode - but there's enough out there that does load in Safe Mode that we can't dismiss it.
Try running SFC.EXE /SCANNOW from an elevated (Run as administrator) Command Prompt if the system will stay in Windows long enough.
Just FYI - at some point it may become advisable to wipe the hard drive and reinstall Windows. Should you choose to do this, please have a look at these instructions (it'll help with ruling out Windows problems if the BSOD's remain after the re-install): Canned Speeches Don't forget to run the hardware diagnostics before doing this!!!
Analysis:
[FONT=lucida console]**************************Wed Apr 17 22:18:01.306 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-17269-01.dmp]
System Uptime:[B]0 days 0:14:04.180[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35148 )[/B]
BugCheck [B]1A, {41790, fffffa80031a5710, ffff, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001A"]MEMORY_MANAGEMENT (1a)[/URL]
Arguments:
Arg2: fffffa80031a5710
PROCESS_NAME:  mscorsvw.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35148[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 22:02:53.948 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-16832-01.dmp]
System Uptime:[B]0 days 0:04:33.823[/B]
Arguments:
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 21:29:45.419 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-25755-01.dmp]
System Uptime:[B]0 days 0:19:56.668[/B]
BugCheck [B]1A, {41790, fffffa80031a56e0, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a56e0
PROCESS_NAME:  MsMpEng.exe
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 20:34:56.136 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-27908-01.dmp]
System Uptime:[B]0 days 0:08:52.010[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+71d1 )[/B]
BugCheck [B]1A, {31, fffffa800c898600, fffff8800830b000, fffff8a00cb9d057}[/B]
Arguments:
Arg1: 0000000000000031, The subtype of the bugcheck.
Arg2: fffffa800c898600
Arg3: fffff8800830b000
Arg4: fffff8a00cb9d057
BUGCHECK_STR:  0x1a_31
FAILURE_BUCKET_ID: [B]X64_0x1a_31_nt!_??_::NNGAKEGL::_string_+71d1[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 17:31:40.759 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-15740-01.dmp]
System Uptime:[B]0 days 0:05:55.633[/B]
Probably caused by :[B]memory_corruption ( nt!MiCaptureProtectionFromProto+1c )[/B]
BugCheck [B]3B, {c0000005, fffff800022dbcec, fffff88005439e50, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000003B"]SYSTEM_SERVICE_EXCEPTION (3b)[/URL]
Arguments:
Arg2: fffff800022dbcec, Address of the instruction which caused the bugcheck
Arg3: fffff88005439e50, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiCaptureProtectionFromProto+1c[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 17:25:10.215 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-14601-01.dmp]
System Uptime:[B]0 days 0:06:16.464[/B]
BugCheck [B]3B, {c0000005, fffff80002f16cec, fffff8800ae8ce50, 0}[/B]
Arguments:
Arg2: fffff80002f16cec, Address of the instruction which caused the bugcheck
Arg3: fffff8800ae8ce50, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 17:18:23.852 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-15771-01.dmp]
System Uptime:[B]0 days 0:01:50.101[/B]
Probably caused by :[B]memory_corruption ( nt!MiStoreSetEvictPageFile+b )[/B]
BugCheck [B]A, {8, 2, 0, fffff80002f9975b}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Arguments:
Arg1: 0000000000000008, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002f9975b, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiStoreSetEvictPageFile+b[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 16:54:27.361 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-16114-01.dmp]
System Uptime:[B]0 days 0:06:52.610[/B]
Probably caused by :[B]memory_corruption ( nt!MiUnlinkPageFromLockedList+8d )[/B]
BugCheck [B]4E, {2, 106, 21dfff, 1}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000004E"]PFN_LIST_CORRUPT (4e)[/URL]
Arguments:
Arg1: 0000000000000002, A list entry was corrupt
Arg2: 0000000000000106, entry in list being removed
Arg3: 000000000021dfff, highest physical page number
Arg4: 0000000000000001, reference count of entry being removed
BUGCHECK_STR:  0x4E_2
FAILURE_BUCKET_ID: [B]X64_0x4E_2_nt!MiUnlinkPageFromLockedList+8d[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 16:25:06.378 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-16582-01.dmp]
System Uptime:[B]0 days 0:06:54.627[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff80002ed4cec, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001E"]KMODE_EXCEPTION_NOT_HANDLED (1e)[/URL]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002ed4cec, The address that the exception occurred at
BUGCHECK_STR:  0x1E_c0000005_R
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!MiCaptureProtectionFromProto+1c[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 16:17:46.499 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-22074-01.dmp]
System Uptime:[B]0 days 0:03:19.748[/B]
BugCheck [B]1A, {41790, fffffa80031a4450, ffff, 0}[/B]
Arguments:
Arg2: fffffa80031a4450
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 16:13:57.637 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-22807-01.dmp]
System Uptime:[B]0 days 0:14:29.886[/B]
Arguments:
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 14:31:44.656 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-21746-01.dmp]
System Uptime:[B]0 days 0:02:37.531[/B]
Probably caused by :[B]win32k.sys ( win32k+c72e8 )[/B]
Arguments:
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_win32k+c72e8[/B]
MaxSpeed:     3300
  BIOS Version                  F12
**************************Wed Apr 17 03:02:12.231 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041713-20638-01.dmp]
System Uptime:[B]1 days 10:14:41.106[/B]
Probably caused by :[B]memory_corruption ( nt!MiUpdateWsleHash+136 )[/B]
BugCheck [B]50, {fffffab4f7c124b0, 0, fffff80002efa4a6, 5}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: fffffab4f7c124b0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002efa4a6, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  taskeng.exe
FAILURE_BUCKET_ID: [B]X64_0x50_nt!MiUpdateWsleHash+136[/B]
MaxSpeed:     3300
  BIOS Version                  F12
[/FONT]
3rd Party Drivers:
MpFilter.sys       Wed Oct 31 18:43:06 2012 (5091A97A)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
yamahasi
I tried booting into safe mode to run SFC, but it gets to 26% and stops with the message: "Windows Resource Protection could not perform the requested operation."
Do you recommend just trying to reinstall Win7 at this point?
*EDIT* tried again, got to 47%/BSOD, 36%/fail, 52%/fail, 0%/BSOD.
yamahasi
Ran Memtest86 and got a ton of errors. Narrowed it down to a bad stick of RAM, going to pick up a new set and see if that solves it. Seems to be running pretty stable on just the single good stick at the moment.
yamahasi
All seems to be good after replacing the RAM! Thanks for all your time helping to narrow down the root cause of my issue. :cool:
Top Bottom
