BSOD Minidump problem
Hello,
Since yesterday, i begin to have BSOD crash. I ran Memtest and it looks to be fine. Crash mostly happens when i'm just browsing on the internet. I've attach the minidump files, hopefully someone can help me find the problem.
Greatly appreciate any help or some sort.
Thanks,
Pat.
Elmer
Hi tangpt127 and Welcome to The Forum.
STOP 0x0000001A: MEMORY_MANAGEMENT
Usual causes:
Device driver, memory, kernel
Your latest dump file lists ntkrnlmp.exe as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
dtsoftbus01.sys Mon Oct 17 13:12:30 2011 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved. But do not replace with Daemon Tools!!
Drivers with Updates:
e1c62x64.sys Tue Sep 21 22:34:15 2010 Intel(R) 82579V Gigabit Network Connection driver Use the Intel® Driver Update Utility (in Internet Explorer gives me the best results). Update any and all drivers available.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
jraid.sys Tue Aug 10 10:28:44 2010 JMicron Raid Driver June '11
mv91xx.sys Fri Aug 27 10:49:22 2010
mvxxmm.sys Fri Aug 27 10:49:03 2010
Drivers: Marvell MV9xxx
RTKVHD64.sys Tue Nov 23 10:14:08 2010 Realtek HD Audio R2.67
Please see: How to ask for help with a BSOD problem Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
Also see: http://windows7forums.com/blue-scre...lp-us-help-you-filling-your-system-specs.html
Bugcheck Analysis:
BugCheck 1A, {41284, 7fef98f5001, 4b, fffff70001080000}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4ac3 )
Followup: MachineOwner
Drivers:
fffff880`078d5000 fffff880`07913000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f93000 fffff880`00fea000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`074a5000 fffff880`0752e000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0795b000 fffff880`07971000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00e14000 fffff880`00e15e00   AiChargerPlus AiChargerPlus.sys Mon Nov 08 06:48:26 2010 (4CD79D3A)
fffff880`01194000 fffff880`0119f000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`07600000 fffff880`07606000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`085b9000 fffff880`085dd000   asmthub3 asmthub3.sys Wed Sep 14 08:36:19 2011 (4E705973)
fffff880`07871000 fffff880`078d5000   asmtxhci asmtxhci.sys Wed Sep 14 08:36:09 2011 (4E705969)
fffff880`077f6000 fffff880`077fd000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`085dd000 fffff880`085eb000   ASUSFILTER ASUSFILTER.sys Tue Sep 20 16:46:33 2011 (4E78B559)
fffff880`0828c000 fffff880`08295000   aswFsBlk aswFsBlk.SYS Mon Nov 28 17:51:52 2011 (4ED3CA38)
fffff880`08250000 fffff880`0828c000   aswMonFlt aswMonFlt.sys Mon Nov 28 17:52:10 2011 (4ED3CA4A)
fffff880`0752e000 fffff880`0753b000   aswRdr   aswRdr.SYS   Mon Nov 28 17:52:20 2011 (4ED3CA54)
fffff880`01567000 fffff880`015fd000   aswSnx   aswSnx.SYS   Mon Nov 28 17:54:05 2011 (4ED3CABD)
fffff880`077a5000 fffff880`077f6000   aswSP    aswSP.SYS    Mon Nov 28 17:53:57 2011 (4ED3CAB5)
fffff880`01470000 fffff880`01482000   aswTdi   aswTdi.SYS   Mon Nov 28 17:52:18 2011 (4ED3CA52)
fffff880`010c2000 fffff880`010cb000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`010cb000 fffff880`010f5000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01bf7000 fffff880`01bfe000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`07794000 fffff880`077a5000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0b375000 fffff880`0b393000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`0ae31000 fffff880`0ae98000   btath_a2dp btath_a2dp.sys Tue Feb 15 01:47:47 2011 (4D59DB43)
fffff880`079eb000 fffff880`079f6000   btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff880`0bd20000 fffff880`0bd2f000   btath_flt btath_flt.sys Thu Jun 24 07:17:38 2010 (4C22F882)
fffff880`0bcbd000 fffff880`0bd20000   btath_hcrp btath_hcrp.sys Tue Jun 29 10:30:43 2010 (4C29BD43)
fffff880`0bd2f000 fffff880`0bd42000   btath_lwflt btath_lwflt.sys Mon Sep 13 09:26:54 2010 (4C8DE04E)
fffff880`0b9a1000 fffff880`0b9c5e00   btath_rcp btath_rcp.sys Thu Jun 24 07:17:21 2010 (4C22F871)
fffff880`07e28000 fffff880`07e70000   btfilter btfilter.sys Tue Mar 08 06:15:22 2011 (4D75C97A)
fffff880`0b95a000 fffff880`0b96a000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`0b98a000 fffff880`0b9a1000   bthmodem bthmodem.sys Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`0b96a000 fffff880`0b98a000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`0ae98000 fffff880`0af24000   bthport  bthport.sys  Thu Apr 28 04:55:07 2011 (4DB8E51B)
fffff880`07e70000 fffff880`07e88000   BTHUSB   BTHUSB.sys   Thu Apr 28 04:54:56 2011 (4DB8E510)
fffff960`007b0000 fffff960`007d7000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00e20000 fffff880`00ee0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01b8f000 fffff880`01bbf000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d0d000 fffff880`00d6b000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`014da000 fffff880`0154c000   cng      cng.sys      Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`0794b000 fffff880`0795b000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0b272000 fffff880`0b27b000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`08581000 fffff880`0858f000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`076f3000 fffff880`07776000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`07776000 fffff880`07794000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`07468000 fffff880`07477000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01b79000 fffff880`01b8f000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07e00000 fffff880`07e22000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0162b000 fffff880`01673000   dtsoftbus01 dtsoftbus01.sys Mon Oct 17 13:12:30 2011 (4E9C1BAE)
fffff880`085a6000 fffff880`085b9000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0859b000 fffff880`085a6000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`0858f000 fffff880`0859b000   dump_pciidex dump_pciidex.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`08575000 fffff880`08581000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0fecd000 fffff880`0ffc1000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0f200000 fffff880`0f246000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0762c000 fffff880`0767b000   e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`011eb000 fffff880`011ff000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0119f000 fffff880`011eb000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0155d000 fffff880`01567000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01b3f000 fffff880`01b79000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a3c000 fffff880`01a86000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`07913000 fffff880`07920000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`03bf7000 fffff800`03c40000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0ffc1000 fffff880`0ffe5000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0ffe5000 fffff880`0fff6000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`07f56000 fffff880`07f6f000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`07f6f000 fffff880`07f77080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0821f000 fffff880`0822d000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0b2ac000 fffff880`0b375000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01b36000 fffff880`01b3f000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`07920000 fffff880`0792c000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`07935000 fffff880`0794b000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00c6c000 fffff880`00c8d000   jraid    jraid.sys    Tue Aug 10 10:28:44 2010 (4C611BCC)
fffff880`07851000 fffff880`07860000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`0855a000 fffff880`08568000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bb6000 fffff800`00bc0000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`01482000 fffff880`014c5000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`07e22000 fffff880`07e27200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0af24000 fffff880`0af39000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0822d000 fffff880`08250000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00caa000 fffff880`00cf9000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`085eb000 fffff880`085f9000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`07860000 fffff880`0786f000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`08568000 fffff880`08575000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c8d000 fffff880`00ca7000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0b393000 fffff880`0b3ab000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0b3ab000 fffff880`0b3d8000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0b200000 fffff880`0b24e000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0b24e000 fffff880`0b272000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`010f5000 fffff880`01100000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01425000 fffff880`01430000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00ff3000 fffff880`00ffd000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`0745d000 fffff880`07468000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01b24000 fffff880`01b36000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01100000 fffff880`0118c000   mv91xx   mv91xx.sys   Fri Aug 27 10:49:22 2010 (4C778A22)
fffff880`0118c000 fffff880`01194000   mvxxmm   mvxxmm.sys   Fri Aug 27 10:49:03 2010 (4C778A0F)
fffff880`01691000 fffff880`01784000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`07995000 fffff880`079a1000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`079a1000 fffff880`079d0000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`07f3d000 fffff880`07f52000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`075af000 fffff880`075be000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0753b000 fffff880`07580000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01784000 fffff880`017e4000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01430000 fffff880`01441000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`07451000 fffff880`0745d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0360e000 fffff800`03bf7000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01254000 fffff880`013f7000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0182a000 fffff880`01833000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0fec8000 fffff880`0fecd000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`07f78000 fffff880`07fa5000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f251000 fffff880`0fec8000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`07589000 fffff880`075af000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00d9e000 fffff880`00db3000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d6b000 fffff880`00d9e000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e0d000 fffff880`00e14000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0154c000 fffff880`0155d000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0af51000 fffff880`0aff7000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07fa5000 fffff880`07fe2000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cf9000 fffff880`00d0d000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`07971000 fffff880`07995000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`079d0000 fffff880`079eb000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`07800000 fffff880`07821000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`07821000 fffff880`0783b000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`07400000 fffff880`07451000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`07846000 fffff880`07851000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`017e4000 fffff880`017ed000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017ed000 fffff880`017f6000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017f6000 fffff880`017ff000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01aea000 fffff880`01b24000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`0b92e000 fffff880`0b95a000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`0af39000 fffff880`0af51000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`082e9000 fffff880`08559c00   RTKVHD64 RTKVHD64.sys Tue Nov 23 10:14:08 2010 (4CEB93F0)
fffff880`0783b000 fffff880`07845a80   SaiBus   SaiBus.sys   Wed Aug 10 22:50:35 2011 (4E42FD2B)
fffff880`082b6000 fffff880`082e6000   SaiK0CCE SaiK0CCE.sys Wed Aug 10 22:43:21 2011 (4E42FB79)
fffff880`07f52000 fffff880`07f55f00   SaiMini  SaiMini.sys  Wed Aug 10 22:50:35 2011 (4E42FD2B)
fffff880`00dc8000 fffff880`00df7000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`0b27b000 fffff880`0b286000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01ae2000 fffff880`01aea000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0bd42000 fffff880`0bdb3000   spsys    spsys.sys    Mon May 11 18:20:58 2009 (4A085E7A)
fffff880`0b896000 fffff880`0b92e000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0b82d000 fffff880`0b896000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0ae00000 fffff880`0ae31000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0786f000 fffff880`07870480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01838000 fffff880`01a3c000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`0b286000 fffff880`0b298000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01463000 fffff880`01470000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01441000 fffff880`01463000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`075d9000 fffff880`075ed000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005d0000 fffff960`005da000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`07606000 fffff880`0762c000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`07477000 fffff880`07489000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`08200000 fffff880`0821d000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0821d000 fffff880`0821ef00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`0767b000 fffff880`0768c000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`07ee3000 fffff880`07f3d000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`0768c000 fffff880`076e2000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01673000 fffff880`01681000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01400000 fffff880`01425000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01072000 fffff880`010ae000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`01a86000 fffff880`01a96000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00db3000 fffff880`00dc8000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01a96000 fffff880`01ae2000   volsnap  volsnap.sys  Fri Feb 25 03:38:18 2011 (4D67242A)
fffff880`075be000 fffff880`075d9000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01681000 fffff880`01691000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00ee0000 fffff880`00f84000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f84000 fffff880`00f93000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`07580000 fffff880`07589000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00314000   win32k   win32k.sys   Thu Nov 24 04:51:38 2011 (4ECDCD5A)
fffff880`010ae000 fffff880`010c2000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`0792c000 fffff880`07935000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fea000 fffff880`00ff3000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`08295000 fffff880`082b6000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`01bbf000 fffff880`01bcd000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bcd000 fffff880`01bd9000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bd9000 fffff880`01be4000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01be4000 fffff880`01bf7000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
