BsoD Minidumps atch. W7 tcpip.sys maybe? help
Hello I'm attaching the dumps from my girlfriends computer. Its a lenovo Thinkpad (not sure model)... has an i5 though. I didn't look at it that much. I grabbed these and said i would look at them.
i see that this comes up in the first tcpip.sys ( tcpip!Ipv6pRouterSolicitationTimeout+41
i haven't looked at the others will after posting this.
I will note that she has windows updates including sp1 (windows 7 btw..) to do. there might be a network update... heard that might help
Any help would be great! Thank you !
Incase the attachment is gone ) TechSpot OpenBoards)
kaos
BUGCHECK
BugCheck 1000009F, {4, 258, fffffa8003b64680, fffff8000482b510}
Unable to load image \SystemRoot\system32\DRIVERS\iaStor.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for iaStor.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStor.sys
Probably caused by : iaStor.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
    subsystem.
Arg2: 0000000000000258, Timeout in seconds.
Arg3: fffffa8003b64680, The thread currently holding on to the Pnp lock.
Arg4: fffff8000482b510
Debugging Details:
DRVPOWERSTATE_SUBCODE:  4
DRIVER_OBJECT: fffffa800490f6d0
[COLOR=#ff0000]
IMAGE_NAME:  iaStor.sys[/COLOR]
DEBUG_FLR_IMAGE_TIMESTAMP:  4b50ce65
MODULE_NAME: iaStor
FAULTING_MODULE: fffff8800102b000 iaStor
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff880`031b6490 fffff800`034ca992 : fffffa80`03b64680 fffffa80`03b64680 00000000`00000000 00000000`00000000 : nt!KiSwapContext+0x7a
fffff880`031b65d0 fffff800`034cccff : fffffa80`06d326a0 fffff800`035f82dd fffffa80`00000000 00000000`00000003 : nt!KiCommitThreadWait+0x1d2
fffff880`031b6660 fffff800`035d38b5 : 00000000`00000000 00000000`00000000 fffffa80`06d32600 fffff880`00e15400 : nt!KeWaitForSingleObject+0x19f
fffff880`031b6700 fffff880`01073220 : fffffa80`0493c1a0 fffffa80`07eb6402 00000000`00000000 fffffa80`0493c1a0 : nt!IoReleaseRemoveLockAndWaitEx+0x45
fffff880`031b6740 fffffa80`0493c1a0 : fffffa80`07eb6402 00000000`00000000 fffffa80`0493c1a0 00000000`00000000 : iaStor+0x48220
fffff880`031b6748 fffffa80`07eb6402 : 00000000`00000000 fffffa80`0493c1a0 00000000`00000000 fffff880`01098fc3 : 0xfffffa80`0493c1a0
fffff880`031b6750 00000000`00000000 : fffffa80`0493c1a0 00000000`00000000 fffff880`01098fc3 fffffa80`07eb64a0 : 0xfffffa80`07eb6402
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_4_IMAGE_iaStor.sys
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - The operation completed successfully.
FAULTING_IP:
+64e42faf006fd8d4
00000000`00000000 ??              ???
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
ERROR_CODE: (NTSTATUS) 0 - STATUS_WAIT_0
BUGCHECK_STR:  0x1E_0
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff80000b9c178 -- (.exr 0xfffff80000b9c178)
ExceptionAddress: fffff88002c5b691 (tcpip!Ipv6pRouterSolicitationTimeout+0x0000000000000041)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff80000b9c220 -- (.trap 0xfffff80000b9c220)
rax=fffffa800806f338 rbx=0000000000000000 rcx=fffffa8008328ca0
rdx=fffff80000b9c420 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88002c5b691 rsp=fffff80000b9c3b0 rbp=fffffa8007043b00
 r8=fffff80000b9c400  r9=ffeffa8008328e38 r10=fffffa8008328e38
r11=fffffa800b1c9510 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po cy
tcpip!Ipv6pRouterSolicitationTimeout+0x41:
fffff880`02c5b691 418b4114        mov     eax,dword ptr [r9+14h] ds:c3e0:ffeffa80`08328e4c=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff8000346c2ee to fffff80003474590
STACK_TEXT:
fffff800`00b9b268 fffff800`0346c2ee : 00000000`0002278c fffff880`02c784c4 fffff800`00b9b9e0 fffff800`034a1524 : nt!KeBugCheck
fffff800`00b9b270 fffff800`0349a2dd : fffff800`03682b7c fffff800`035bce68 fffff800`03404000 fffff800`00b9c178 : nt!KiKernelCalloutExceptionHandler+0xe
fffff800`00b9b2a0 fffff800`034a1950 : fffff800`035c3b0c fffff800`00b9b318 fffff800`00b9c178 fffff800`03404000 : nt!RtlpExecuteHandlerForException+0xd
fffff800`00b9b2d0 fffff800`034ae8cf : fffff800`00b9c178 fffff800`00b9b9e0 fffff800`00000000 fffffa80`00000006 : nt!RtlDispatchException+0x410
fffff800`00b9b9b0 fffff800`03473c02 : fffff800`00b9c178 00000000`00000000 fffff800`00b9c220 fffff800`00b9c400 : nt!KiDispatchException+0x16f
fffff800`00b9c040 fffff800`0347250a : fffffa01`00000001 00000000`00000002 fffffa80`080d4048 fffffa80`080d4010 : nt!KiExceptionDispatch+0xc2
fffff800`00b9c220 fffff880`02c5b691 : fffff800`00b9c678 fffffa80`0703aa30 00000000`00000000 fffffa80`07043b00 : nt!KiGeneralProtectionFault+0x10a
fffff800`00b9c3b0 fffff880`02c5aed2 : 00000000`00000000 fffffa80`07043b00 fffffa80`08328ca0 fffff800`00b9c3f0 : tcpip!Ipv6pRouterSolicitationTimeout+0x41
fffff800`00b9c3e0 fffff880`02c5ad63 : 00000000`00000000 00000000`00000000 fffffa80`07043bc0 fffffa80`07043b58 : tcpip!Ipv6pRouterDiscoveryTimeout+0x72
fffff800`00b9c460 fffff880`02c5b808 : fffffa80`07043bb8 fffffa80`07043b58 00000000`00000000 fffff800`00b9c678 : tcpip!Ipv6pInterfaceSetTimeout+0x158
fffff800`00b9c4d0 fffff880`02c5a6b9 : 00000000`00000000 fffff800`00b9c678 00000000`00000001 fffff800`035fcc40 : tcpip!IppCompartmentSetTimeout+0x88
fffff800`00b9c540 fffff800`0348012e : fffff800`00b9c660 00000000`000128cd 00000000`00000002 00000000`00000000 : tcpip!IppTimeout+0x89
fffff800`00b9c570 fffff800`0347fc76 : fffffa80`0476bc68 fffffa80`0476bc68 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5e0 fffff800`0348034e : 00000003`49536aba fffff800`00b9cc58 00000000`00016170 fffff800`035f2088 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`0347fb57 : 00000000`da9f4fc8 00000000`00016170 00000000`da9f4fab 00000000`00000070 : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`0347cd8a : fffff800`035eee80 fffff800`035fcc40 00000000`00000002 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cd80 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  tcpip!Ipv6pRouterSolicitationTimeout+41
MODULE_NAME: tcpip
IMAGE_NAME:  tcpip.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4e0013b7
FAILURE_BUCKET_ID:  X64_0x1E_0_tcpip!Ipv6pRouterSolicitationTimeout+41
DRIVERS
fffff800`00bcb000 fffff800`00bd5000   kdcom    kdcom.dll    Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff800`03404000 fffff800`039e0000   nt       ntkrnlmp.exe Thu Jun 23 03:51:48 2011 (4E02AA44)
fffff800`039e0000 fffff800`03a29000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c3a000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`00c3a000 fffff880`00c5f000   Apsx64   Apsx64.sys   Fri Oct 09 03:22:36 2009 (4ACE9E6C)
fffff880`00c69000 fffff880`00cad000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`00cad000 fffff880`00cc1000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00cc1000 fffff880`00d1f000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d1f000 fffff880`00ddf000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`00ddf000 fffff880`00df9000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`00e71000 fffff880`00f15000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f15000 fffff880`00f24000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f24000 fffff880`00f7b000   ACPI     ACPI.sys     Tue Dec 01 07:18:02 2009 (4B14C32A)
fffff880`00f7b000 fffff880`00f84000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f84000 fffff880`00f8e000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f8e000 fffff880`00fc1000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00fc1000 fffff880`00fce000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00fce000 fffff880`00fe3000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00fe3000 fffff880`00fec000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fec000 fffff880`00ff8000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`0101a000 fffff880`01222000   iaStor   iaStor.sys   Fri Jan 15 20:21:57 2010 (4B50CE65)
fffff880`01222000 fffff880`0122d000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0122d000 fffff880`01279000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`01279000 fffff880`0128d000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0128d000 fffff880`0130c100   mfehidk  mfehidk.sys  Wed Mar 02 16:38:02 2011 (4D6E726A)
fffff880`0130d000 fffff880`0136b000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`0136b000 fffff880`013de000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`01400000 fffff880`0141a000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`0141a000 fffff880`0142b000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0142b000 fffff880`01436000   DzHDD64  DzHDD64.sys  Tue Nov 10 13:47:48 2009 (4AF96F04)
fffff880`01436000 fffff880`01440000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01440000 fffff880`01452000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01453000 fffff880`015f5000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:25 2011 (4D79996D)
fffff880`01600000 fffff880`01610000   vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`01610000 fffff880`0165c000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`0165c000 fffff880`01666000   ApsHM64  ApsHM64.sys  Fri Oct 09 03:18:01 2009 (4ACE9D59)
fffff880`01666000 fffff880`0166e000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0166e000 fffff880`01677000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`0167e000 fffff880`01770000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`01770000 fffff880`017d0000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`017d0000 fffff880`017fb000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`01828000 fffff880`01862000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01862000 fffff880`01878000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01878000 fffff880`018a8000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`018b6000 fffff880`018fb000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`018fb000 fffff880`01984000   afd      afd.sys      Mon Apr 25 03:43:58 2011 (4DB4DFEE)
fffff880`01984000 fffff880`019a1000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`019a1000 fffff880`019bc000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`019bc000 fffff880`019d0000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff880`019d0000 fffff880`019f4000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`02c02000 fffff880`02dff000   tcpip    tcpip.sys    Tue Jun 21 04:44:55 2011 (4E0013B7)
fffff880`03a50000 fffff880`03b18000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`03b18000 fffff880`03b36000   bowser   bowser.sys   Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff880`03b36000 fffff880`03b4e000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03b4e000 fffff880`03b7b000   mrxsmb   mrxsmb.sys   Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`03b7b000 fffff880`03bc9000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:44:55 2011 (4E17C0A7)
fffff880`03bc9000 fffff880`03bec000   mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`03bec000 fffff880`03bf0280  [COLOR=#ff0000] mdmxsdk  mdmxsdk.sys  Mon Jun 19 22:27:26 2006 (449716BE)[/COLOR]
fffff880`03e00000 fffff880`03e4a000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`03e4a000 fffff880`03e8d380   mfewfpk  mfewfpk.sys  Wed Mar 02 16:38:16 2011 (4D6E7278)
fffff880`03e8e000 fffff880`03e9b000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`03e9b000 fffff880`03eb9000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`03eb9000 fffff880`03ec2000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03ec2000 fffff880`03ee8000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
[COLOR=#ff0000]fffff880`03ee8000 fffff880`03eee000   Tppwr64v Tppwr64v.sys Wed Oct 18 09:40:21 2006 (4535E875)[/COLOR]
fffff880`03eee000 fffff880`040f6000   dump_iaStor dump_iaStor.sys Fri Jan 15 20:21:57 2010 (4B50CE65)
fffff880`0413f000 fffff880`04148000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04148000 fffff880`0414f000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0414f000 fffff880`0415d000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0415d000 fffff880`04182000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`04182000 fffff880`04192000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`04192000 fffff880`0419b000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0419b000 fffff880`041a4000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`041a4000 fffff880`041ad000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`041ad000 fffff880`041b8000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`041b8000 fffff880`041c9000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`041c9000 fffff880`041df000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`041df000 fffff880`041ef980   mfenlfk  mfenlfk.sys  Wed Mar 02 16:38:26 2011 (4D6E7282)
fffff880`041f0000 fffff880`041ff000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04200000 fffff880`04216000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04239000 fffff880`0428a000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`0428a000 fffff880`04296000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`04296000 fffff880`042a1000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`042a1000 fffff880`042a8000   smiifx64 smiifx64.sys Mon May 12 10:01:13 2008 (48280759)
fffff880`042a8000 fffff880`042b7000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`042b7000 fffff880`0433a000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`0433a000 fffff880`04358000   dfsc     dfsc.sys     Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`04358000 fffff880`04369000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04369000 fffff880`0438f000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`0438f000 fffff880`043a5000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`043a5000 fffff880`043f8000   SynTP    SynTP.sys    Fri Apr 23 00:11:30 2010 (4BD0D7A2)
fffff880`04400000 fffff880`0440c000   ibmpmdrv ibmpmdrv.sys Wed Nov 18 03:13:20 2009 (4B036650)
fffff880`0440c000 fffff880`04415000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`04415000 fffff880`04421000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04423000 fffff880`04517000   dxgkrnl  dxgkrnl.sys  Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`04517000 fffff880`0455d000   dxgmms1  dxgmms1.sys  Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`0455d000 fffff880`04581000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04581000 fffff880`04592000   HECIx64  HECIx64.sys  Thu Sep 17 20:54:16 2009 (4AB293E8)
fffff880`04592000 fffff880`0459e000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0459e000 fffff880`045e7000   e1k62x64 e1k62x64.sys Thu Dec 10 17:37:53 2009 (4B2131F1)
fffff880`045e7000 fffff880`045f8000   usbehci  usbehci.sys  Tue Mar 29 04:32:16 2011 (4D9152C0)
fffff880`04800000 fffff880`04825180   Impcd    Impcd.sys    Mon Oct 26 20:39:41 2009 (4AE6090D)
fffff880`04826000 fffff880`04836000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0483b000 fffff880`05366800   nvlddmkm nvlddmkm.sys Fri Mar 19 14:57:26 2010 (4BA390D6)
fffff880`05367000 fffff880`05368180   nvBridge nvBridge.kmd Fri Mar 19 14:13:57 2010 (4BA386A5)
fffff880`05369000 fffff880`053bf000   USBPORT  USBPORT.SYS  Tue Mar 29 04:32:20 2011 (4D9152C4)
fffff880`053bf000 fffff880`053fd000   1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`05600000 fffff880`05601f00   USBD     USBD.SYS     Tue Mar 29 04:32:09 2011 (4D9152B9)
fffff880`05602000 fffff880`05611000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05611000 fffff880`05620000   tpm      tpm.sys      Tue Jul 14 00:21:48 2009 (4A5BC18C)
fffff880`05620000 fffff880`05624500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0562c000 fffff880`05d8c000   NETw5s64 NETw5s64.sys Thu Mar 18 05:21:53 2010 (4BA1B871)
fffff880`05d8c000 fffff880`05d99000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`05d99000 fffff880`05db9000   sdbus    sdbus.sys    Sat Oct 10 03:41:20 2009 (4ACFF450)
fffff880`05db9000 fffff880`05dd2000   rimspe64 rimspe64.sys Mon Oct 26 05:52:27 2009 (4AE5391B)
fffff880`05dd2000 fffff880`05df0000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05df0000 fffff880`05dff000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06000000 fffff880`0605a000   usbhub   usbhub.sys   Tue Mar 29 04:32:44 2011 (4D9152DC)
fffff880`0605a000 fffff880`0606f000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`0606f000 fffff880`06088000   nvhda64v nvhda64v.sys Thu Jan 28 14:24:54 2010 (4B619E36)
fffff880`06090000 fffff880`060bf000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`060bf000 fffff880`060da000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`060da000 fffff880`060fb000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`060fb000 fffff880`06115000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`06115000 fffff880`06120000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`06120000 fffff880`0612e000   psadd    psadd.sys    Thu Jul 02 03:17:26 2009 (4A4C18B6)
fffff880`0612e000 fffff880`0613c000   Tvti2c   Tvti2c.sys   Thu Sep 24 12:56:38 2009 (4ABB5E76)
fffff880`0613c000 fffff880`0613d480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0613e000 fffff880`06181000   ks       ks.sys       Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`06181000 fffff880`061c5000   NWADIenum NWADIenum.sys Fri Nov 06 01:50:15 2009 (4AF380D7)
fffff880`061c5000 fffff880`061d7000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`06614000 fffff880`06651000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`06651000 fffff880`06673000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`06673000 fffff880`06678200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`06679000 fffff880`06723000   CHDRT64  CHDRT64.sys  Sat Jan 23 04:58:04 2010 (4B5A81DC)
fffff880`06723000 fffff880`06775000   CAXHWAZL CAXHWAZL.sys Tue Jun 30 21:01:14 2009 (4A4A6F0A)
fffff880`06775000 fffff880`067fb000   btwaudio btwaudio.sys Wed Jul 01 14:54:56 2009 (4A4B6AB0)
fffff880`06838000 fffff880`069ac000   CAX_DPV  CAX_DPV.sys  Tue Jun 30 21:05:11 2009 (4A4A6FF7)
fffff880`069ac000 fffff880`069d8980   mfeavfk  mfeavfk.sys  Wed Mar 02 16:39:02 2011 (4D6E72A6)
fffff880`06c00000 fffff880`06c2af80   PTUMLCVsp PTUMLCVsp.sys Tue Nov 02 14:59:55 2010 (4CD0276B)
fffff880`06c2b000 fffff880`06c40000   PTUMLRMNET PTUMLRMNET.sys Tue Nov 02 15:05:43 2010 (4CD028C7)
fffff880`06c40000 fffff880`06c58000   BTHUSB   BTHUSB.sys   Thu Apr 28 04:58:34 2011 (4DB8E5EA)
fffff880`06c76000 fffff880`06d41000   CAX_CNXT CAX_CNXT.sys Tue Jun 30 20:59:52 2009 (4A4A6EB8)
fffff880`06d41000 fffff880`06d50000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`06d50000 fffff880`06d60580   PTUMLBUS PTUMLBUS.sys Tue Nov 02 14:58:39 2010 (4CD0271F)
fffff880`06d61000 fffff880`06d8bf80   PTUMLMdm PTUMLMdm.sys Tue Nov 02 14:59:17 2010 (4CD02745)
fffff880`06d8c000 fffff880`06db6f80   PTUMLVsp PTUMLVsp.sys Tue Nov 02 15:04:20 2010 (4CD02874)
fffff880`06db7000 fffff880`06de2400   PTUMLNVsp PTUMLNVsp.sys Tue Nov 02 15:00:33 2010 (4CD02791)
fffff880`06e00000 fffff880`06e7b000   btwavdt  btwavdt.sys  Thu Jun 25 06:50:13 2009 (4A431015)
fffff880`06e7b000 fffff880`06e87000   btwl2cap btwl2cap.sys Sat Apr 04 01:28:45 2009 (49D6A9BD)
fffff880`06e87000 fffff880`06e8a880   btwrchid btwrchid.sys Thu Jun 25 06:51:37 2009 (4A431069)
fffff880`06e8b000 fffff880`06ea4000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`06ea4000 fffff880`06eac080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06eb9000 fffff880`06f45000   bthport  bthport.sys  Thu Apr 28 04:58:42 2011 (4DB8E5F2)
fffff880`06f45000 fffff880`06f62000   usbccgp  usbccgp.sys  Tue Mar 29 04:32:29 2011 (4D9152CD)
fffff880`06f62000 fffff880`06f89d00   5U877    5U877.sys    Mon Dec 14 08:09:07 2009 (4B25F2A3)
fffff880`06f8a000 fffff880`06f9ad00   STREAM   STREAM.SYS   Tue Jul 14 01:06:18 2009 (4A5BCBFA)
fffff880`06f9b000 fffff880`06fc7000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`06fc7000 fffff880`06fd7000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`06fd7000 fffff880`06ff7000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`07200000 fffff880`07253000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`07253000 fffff880`07266000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`07266000 fffff880`0727e000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0727e000 fffff880`07285000   TurboB   TurboB.sys   Wed Sep 30 01:25:28 2009 (4AC2A578)
fffff880`072d8000 fffff880`07341980   mfefirek mfefirek.sys Wed Mar 02 16:42:01 2011 (4D6E7359)
fffff880`07342000 fffff880`0734e000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0734e000 fffff880`0735c000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0735c000 fffff880`0736f000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0736f000 fffff880`0737d000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`0737d000 fffff880`073a0000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`073a0000 fffff880`073c1000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`073c1000 fffff880`073d6000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07412000 fffff880`074b8000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`074b8000 fffff880`074c3000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`074c3000 fffff880`074f0000   srvnet   srvnet.sys   Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`074f0000 fffff880`07502000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`07506000 fffff880`0750e000   XAudio64 XAudio64.sys Wed Apr 29 19:21:07 2009 (49F89A93)
fffff880`0753b000 fffff880`075a2000   srv2     srv2.sys     Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`078c2000 fffff880`07957000   srv      srv.sys      Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`07957000 fffff880`07964a80   cfwids   cfwids.sys   Wed Mar 02 16:42:51 2011 (4D6E738B)
fffff880`07965000 fffff880`07980d00   mfeapfk  mfeapfk.sys  Wed Mar 02 16:38:39 2011 (4D6E728F)
fffff960`00060000 fffff960`00373000   win32k   win32k.sys   unavailable (00000000)
fffff960`00420000 fffff960`0042a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`07981000 fffff880`079f2000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`04115000 fffff880`0413f000   cdrom.sys
    Checksum:  00000000
    ImageSize:  0002A000
fffff880`07504000 fffff880`07506000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07502000 fffff880`07504000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0750e000 fffff880`0753b000   mfeavfk01.sy
    Checksum:  00000000
    ImageSize:  0002D000
fffff880`018a8000 fffff880`018b6000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`03efa000 fffff880`04102000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  00208000
fffff880`04102000 fffff880`04115000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Intel matrix storage manager seems to be the fault, you can update this from the manufacturers website. I.E DELL
i would update all the drivers on the pc i.e graphics card chipset , network card etc. some of them i have highlighted are quite old.. i wouild say this is the reason for the bsod's
zigzag3143
Honorable Member
Microsoft MVP
Old drivers
mdmxsdk.sys    6/19/2006 5:27:26 PM        fffff880`02671000    fffff880`02675280    0x00004280    0x449716be
smiifx64.sys    5/12/2008 5:01:13 AM        fffff880`04337000    fffff880`0433e000    0x00007000    0x48280759
btwl2cap.sys    4/3/2009 8:28:45 PM        fffff880`06bd9000    fffff880`06be5000    0x0000c000    0x49d6a9bd
XAudio64.sys    4/29/2009 2:21:07 PM        fffff880`08570000    fffff880`08578000    0x00008000    0x49f89a93
btwavdt.sys    6/25/2009 1:50:13 AM        fffff880`03eee000    fffff880`03f69000    0x0007b000    0x4a431015
btwrchid.sys    6/25/2009 1:51:37 AM        fffff880`06df6000    fffff880`06df9880    0x00003880    0x4a431069
CAX_CNXT.sys    6/30/2009 3:59:52 PM        fffff880`06c9b000    fffff880`06d66000    0x000cb000    0x4a4a6eb8
CAXHWAZL.sys    6/30/2009 4:01:14 PM        fffff880`06915000    fffff880`06967000    0x00052000    0x4a4a6f0a
CAX_DPV.sys    6/30/2009 4:05:11 PM        fffff880`06a28000    fffff880`06b9c000    0x00174000    0x4a4a6ff7
btwaudio.sys    7/1/2009 9:54:56 AM        fffff880`03f69000    fffff880`03fef000    0x00086000    0x4a4b6ab0
psadd.sys    7/1/2009 10:17:26 PM        fffff880`0606f000    fffff880`0607d000    0x0000e000    0x4a4c18b6
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
ALSO UPDATE TO SP-1
* Download > Install > Run the System Update Readiness Tool
Ensure you install the correct 64 or 32bit option for your system)
Download the System Update Readiness Tool (64bit)
Download the System Update Readiness Tool (32bit)
ISC Diary | Windows 7 / 2008 R2 Service Pack 1 Problems
links courtesy jmh
