i open my pc, it goes up to startup repair, then its say the blue screen of death.
i try to go in normal boot , still no response (says window is loading files)
i try to go in F8, the menu boots, i click safe mode and still windows 7 says
windows in loading files and then takes me to BSOD.
i try agian F8, go to repair computer Option, takes me to a screen where it says
"system restore", i have to restore points.
i try agian with F8 , repair computer, i click CMD, it opens, but i dont no what to type.
any ideas?? i had this problem before but then i reboot it then it started start up repair.
problem was fixed at that time, but this BSOD is still not going.
btw.. the problem its say is BAD_POOL_HEADER.
