Hi tosca and Welcome to The Forum.
STOP 0x0000007A: KERNEL_DATA_INPAGE_ERROR
Usual causes: Memory, Paging file corruption, File system, Hard drive, Cabling, Virus infection, Improperly seated cards, BIOS, Bad motherboard, Missing Service Pack
Your latest dump file lists
ntkrnlmp.exe as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority: Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the
Norton Removal Tool in Safe Mode. Download Blue Screen friendly
Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Drivers that pre-date Windows 7. Update: GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with
iTunes Drivers with Updates: Rt64win7.sys Fri Jun 10 07:33:15 2011 Realtek PCIe GBE Family Controller v7.053 If you're unsure about manually installing drivers then choose the
Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
Bugcheck Analysis: Code:
* Bugcheck Analysis *
BugCheck 7A, {20, ffffffffc000009d, fffffa8005d3b7c8, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+505f0 )
Followup: MachineOwner
Drivers: Code:
fffff880`00efb000 fffff880`00f52000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`02e0b000 fffff880`02e94000 afd afd.sys Wed Dec 28 03:59:20 2011 (4EFA9418)
fffff880`042e2000 fffff880`042f8000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04174000 fffff880`04189000 amdppm amdppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00ec4000 fffff880`00ee2000 amdsata amdsata.sys Fri Mar 19 00:45:17 2010 (4BA2C91D)
fffff880`0111e000 fffff880`01129000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00e76000 fffff880`00e7f000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e7f000 fffff880`00ea9000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`04495000 fffff880`04737000 athrx athrx.sys Tue Feb 22 20:17:31 2011 (4D6419DB)
fffff880`05a87000 fffff880`05aaa000 AtiHdmi AtiHdmi.sys Thu May 06 10:20:39 2010 (4BE289E7)
fffff880`04189000 fffff880`041d3000 atikmpag atikmpag.sys Mon Sep 20 02:21:01 2010 (4C96B6FD)
fffff880`01bb3000 fffff880`01bbb000 AtiPcie AtiPcie.sys Mon Aug 24 09:25:26 2009 (4A924E76)
fffff880`04a82000 fffff880`050f1000 atipmdag atipmdag.sys Thu Jun 17 13:45:34 2010 (4C1A18EE)
fffff960`00950000 fffff960`009b1000 ATMFD ATMFD.DLL unavailable (00000000)
fffff880`00fc3000 fffff880`00fcf000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`0181c000 fffff880`01823000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0402e000 fffff880`0414e000 BHDrvx64 BHDrvx64.sys Tue Mar 13 20:02:37 2012 (4F5FA7DD)
fffff880`03c00000 fffff880`03c11000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05771000 fffff880`0578f000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`017af000 fffff880`017dd000 ccSetx64 ccSetx64.sys Fri Nov 04 22:05:25 2011 (4EB461A5)
fffff960`006a0000 fffff960`006c7000 cdd cdd.dll unavailable (00000000)
fffff880`01785000 fffff880`017af000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01b83000 fffff880`01bb3000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00ce4000 fffff880`00d42000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`042c4000 fffff880`042c8500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0136f000 fffff880`013e1000 cng cng.sys Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`00fba000 fffff880`00fc3000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`042d2000 fffff880`042e2000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`069a3000 fffff880`069b1000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0853e000 fffff880`08550000 dc3d dc3d.sys Wed May 18 09:07:24 2011 (4DD37E3C)
fffff880`03ddc000 fffff880`03dfa000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03dcd000 fffff880`03ddc000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01b6d000 fffff880`01b83000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05ae7000 fffff880`05b09000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`069bb000 fffff880`069d9000 dump_amdsata dump_amdsata.sys Fri Mar 19 00:45:17 2010 (4BA2C91D)
fffff880`069b1000 fffff880`069bb000 dump_diskdump dump_diskdump.sys Fri Apr 22 21:04:32 2011 (4DB1DF50)
fffff880`069d9000 fffff880`069ec000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`068fd000 fffff880`06909000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`050f1000 fffff880`051e5000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04a00000 fffff880`04a46000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`03d2e000 fffff880`03da7000 eeCtrl64 eeCtrl64.sys Fri Jan 20 23:39:48 2012 (4F19FB44)
fffff880`0a36a000 fffff880`0a38a000 ENG64 ENG64.SYS Fri Jul 29 14:17:51 2011 (4E32B2FF)
fffff880`03da7000 fffff880`03dcd000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri Jan 20 23:39:49 2012 (4F19FB45)
fffff880`0a400000 fffff880`0a5f8000 EX64 EX64.SYS Fri Jul 29 14:15:11 2011 (4E32B25F)
fffff880`0688a000 fffff880`068c0000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`011e6000 fffff880`011fa000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01129000 fffff880`01175000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01400000 fffff880`0140a000 Fs_Rec Fs_Rec.sys Thu Mar 01 03:41:06 2012 (4F4EEFD2)
fffff880`01b33000 fffff880`01b6d000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a40000 fffff880`01a8a000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`047c9000 fffff880`047d6000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`031ef000 fffff800`03238000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04a46000 fffff880`04a6a000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0855e000 fffff880`08577000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`068e7000 fffff880`068ef080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`08550000 fffff880`0855e000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`056a8000 fffff880`05771000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01b2a000 fffff880`01b33000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04474000 fffff880`04492000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03cb1000 fffff880`03d2e000 IDSvia64 IDSvia64.sys Tue Nov 22 20:23:23 2011 (4ECC04BB)
fffff880`01000000 fffff880`01031000 Ironx64 Ironx64.SYS Tue Nov 15 02:00:53 2011 (4EC1C7D5)
fffff880`047e1000 fffff880`047f0000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bab000 fffff800`00bb5000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`043af000 fffff880`043f2000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015d3000 fffff880`015ee000 ksecdd ksecdd.sys Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`0175a000 fffff880`01785000 ksecpkg ksecpkg.sys Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`05b09000 fffff880`05b0e200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`06957000 fffff880`0696c000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06600000 fffff880`06623000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cc3000 fffff880`00cd0000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`069ec000 fffff880`069fa000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`042b5000 fffff880`042c4000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`085a0000 fffff880`085ad000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0578f000 fffff880`057a7000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`057a7000 fffff880`057d4000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`05600000 fffff880`0564e000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0564e000 fffff880`05672000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00ea9000 fffff880`00eb4000 msahci msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`013e1000 fffff880`013ec000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f5b000 fffff880`00f65000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01311000 fffff880`0136f000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03ca6000 fffff880`03cb1000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01b18000 fffff880`01b2a000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01607000 fffff880`016fa000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0431c000 fffff880`04328000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0662e000 fffff880`06641000 ndisuio ndisuio.sys Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04328000 fffff880`04357000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`05a72000 fffff880`05a87000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02f1e000 fffff880`02f2d000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02e94000 fffff880`02ed9000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`016fa000 fffff880`0175a000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`013ec000 fffff880`013fd000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03c9a000 fffff880`03ca6000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c07000 fffff800`031ef000 nt ntkrnlmp.exe Tue Mar 06 03:58:13 2012 (4F558B55)
fffff880`01430000 fffff880`015d3000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`08577000 fffff880`08583000 NuidFltr NuidFltr.sys Fri Apr 08 23:58:16 2011 (4D9F9308)
fffff880`01813000 fffff880`0181c000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`05b0f000 fffff880`05b62000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02ee2000 fffff880`02f08000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fa5000 fffff880`00fba000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f65000 fffff880`00f98000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00eb4000 fffff880`00ec4000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`015ee000 fffff880`015ff000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06e78000 fffff880`06f1e000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`08590000 fffff880`085a0000 point64 point64.sys Wed May 18 09:07:20 2011 (4DD37E38)
fffff880`05aaa000 fffff880`05ae7000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cd0000 fffff880`00ce4000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`042f8000 fffff880`0431c000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04357000 fffff880`04372000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04372000 fffff880`04393000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04393000 fffff880`043ad000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03c49000 fffff880`03c9a000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01831000 fffff880`0183a000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01bf1000 fffff880`01bfa000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017ed000 fffff880`017f6000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01ade000 fffff880`01b18000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05b62000 fffff880`05b7a000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04744000 fffff880`047c9000 Rt64win7 Rt64win7.sys Fri Jun 10 07:33:15 2011 (4DF1BAAB)
fffff880`06647000 fffff880`06889180 RTKVHD64 RTKVHD64.sys Tue May 25 10:15:27 2010 (4BFB952F)
fffff880`06f1e000 fffff880`06f29000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`06f29000 fffff880`06fea000 Sftfslh Sftfslh.sys Fri Sep 30 17:43:06 2011 (4E85F19A)
fffff880`06e00000 fffff880`06e4d000 Sftplaylh Sftplaylh.sys Fri Sep 30 17:43:05 2011 (4E85F199)
fffff880`08525000 fffff880`08530000 Sftredirlh Sftredirlh.sys Fri Sep 30 17:43:14 2011 (4E85F1A2)
fffff880`06623000 fffff880`0662e000 Sftvollh Sftvollh.sys Fri Sep 30 17:42:46 2011 (4E85F186)
fffff880`01ad6000 fffff880`01ade000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0a21a000 fffff880`0a2d9000 SRTSP64 SRTSP64.SYS Tue Nov 22 23:52:13 2011 (4ECC35AD)
fffff880`01060000 fffff880`01075000 SRTSPX64 SRTSPX64.SYS Tue Nov 22 23:52:20 2011 (4ECC35B4)
fffff880`0848d000 fffff880`08525000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`05b84000 fffff880`05bed000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`05672000 fffff880`056a3000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`010bb000 fffff880`0111e000 storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`043ad000 fffff880`043ae480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01175000 fffff880`011e6000 SYMDS64 SYMDS64.SYS Mon May 16 23:15:03 2011 (4DD1A1E7)
fffff880`01200000 fffff880`01311000 SYMEFA64 SYMEFA64.SYS Wed Nov 23 00:49:28 2011 (4ECC4318)
fffff880`02fc8000 fffff880`03000000 SYMEVENT64x86 SYMEVENT64x86.SYS Mon Jan 23 18:57:54 2012 (4F1DADB2)
fffff880`02f5c000 fffff880`02fc8000 SYMNETS SYMNETS.SYS Sat Nov 12 21:11:53 2011 (4EBEE119)
fffff880`0424c000 fffff880`042b3000 SynTP SynTP.sys Fri Oct 14 03:34:52 2011 (4E979FCC)
fffff880`0183c000 fffff880`01a40000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`06e4d000 fffff880`06e5f000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01053000 fffff880`01060000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01031000 fffff880`01053000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02f48000 fffff880`02f5c000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00470000 fffff960`0047a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`0414e000 fffff880`04174000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04200000 fffff880`04212000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`06919000 fffff880`06936000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`042b3000 fffff880`042b4f00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04463000 fffff880`04474000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04456000 fffff880`04463000 usbfilter usbfilter.sys Tue Dec 22 08:26:22 2009 (4B3082AE)
fffff880`05a18000 fffff880`05a72000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`047d6000 fffff880`047e1000 usbohci usbohci.sys Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`04400000 fffff880`04456000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`06975000 fffff880`069a2280 usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00f98000 fffff880`00fa5000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01823000 fffff880`01831000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0140a000 fffff880`0142f000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fcf000 fffff880`00fe4000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01a8a000 fffff880`01ad6000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`04737000 fffff880`04744000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02f08000 fffff880`02f1e000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`05b7a000 fffff880`05b84000 vwifimp vwifimp.sys Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`02f2d000 fffff880`02f48000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`017dd000 fffff880`017ed000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00d42000 fffff880`00de6000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00de6000 fffff880`00df5000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02ed9000 fffff880`02ee2000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`00395000 win32k win32k.sys unavailable (00000000)
fffff880`042c9000 fffff880`042d2000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f52000 fffff880`00f5b000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`06936000 fffff880`06957000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0a2d9000 fffff880`0a2f9000 ENG64.SYS
Checksum: 00000000
ImageSize: 00020000
fffff880`0a400000 fffff880`0a5f8000 EX64.SYS
Checksum: 00000000
ImageSize: 001F8000
fffff880`0a2f9000 fffff880`0a36a000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`08530000 fffff880`08532000 MSPQM.sys
Checksum: 00000000
ImageSize: 00002000
fffff880`08583000 fffff880`08590000 mouhid.sys
Checksum: 00000000
ImageSize: 0000D000
fffff880`068ce000 fffff880`068e7000 HIDCLASS.SYS
Checksum: 00000000
ImageSize: 00019000
fffff880`068c0000 fffff880`068ce000 hidusb.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`08532000 fffff880`0853e000 NuidFltr.sys
Checksum: 00000000
ImageSize: 0000C000
fffff880`06909000 fffff880`06919000 point64.sys
Checksum: 00000000
ImageSize: 00010000
fffff880`068f0000 fffff880`068fd000 mouhid.sys
Checksum: 00000000
ImageSize: 0000D000
fffff880`06936000 fffff880`06975000 RtsUStor.sys
Checksum: 00000000
ImageSize: 0003F000
fffff880`01bbb000 fffff880`01bc9000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01bc9000 fffff880`01bd3000 dump_storpor
Checksum: 00000000
ImageSize: 0000A000
fffff880`01bd3000 fffff880`01bf1000 dump_amdsata
Checksum: 00000000
ImageSize: 0001E000
fffff880`01800000 fffff880`01813000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
