BSOD ntoskrnl.exe and ntkrnlmp.exe
cmb
Hi, thanks in advance for any insights anyone may have.
Here are the descriptions from "Who Crashed":
On Wed 3/9/2011 10:45:36 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\030911-22526-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x80640)
Bugcheck code: 0x3B (0xC000001D, 0xFFFFF800030D0E67, 0xFFFFF88005BE5110, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
I am also attaching the dmp files as well.
I am using Windows 7 x64 Premium, NVIDIA GeForce 8500 GT (newest drivers), Intel Q9300 Quad Core, using Microsoft Security Essentials, Windows Firewall.
Thanks again.
Hello and welcome to windows7forums. : )
BugCheck D1, {1, b, 1, fffff8800f01065b}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : hardware ( dxgmms1!memmove+24b )
BugCheck 3B, {c000001d, fffff800030d0e67, fffff88005be5110, 0}
PROCESS_NAME: svchost.exe
Probably caused by : ntkrnlmp.exe ( nt!KxWaitForLockChainValid+17 )
1. Uninstall Lavasoft.
2. Update Realtek Audio
RTKVHD64.sys Mon Jul 20 06:52:29 2009
ftp://WebUser:7p5XTFw@208.70.202.219/pc/audio/Vista_Win7_R257.exe
3. Update Marvell Yukon Ethernet Controller
yk62x64.sys Mon Feb 23 10:02:27 2009
Marvell: Support
4. If bsod's reoccur after above steps 1-3, let me see your memory settings:
a) CPU-Z memory tab screenshot
b) Rammon HTML report
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\030711-23774-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`03003000 PsLoadedModuleList = 0xfffff800`03248e90
Debug session time: Sun Mar  6 16:33:49.877 2011 (UTC - 5:00)
System Uptime: 2 days 0:23:42.672
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000001, memory referenced
Arg2: 000000000000000b, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8800f01065b, address which referenced memory
Debugging Details:
WORKER_ROUTINE:
+3238613836613730
00000000`00000001 ??              ???
WORK_ITEM:  fffff8800f01065b
CURRENT_IRQL:  b
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff8000445b1a0 -- (.trap 0xfffff8000445b1a0)
rax=0000000000000001 rbx=0000000000000000 rcx=fffffa80097a9150
rdx=fffffd7ffacb2450 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800f01065b rsp=fffff8000445b338 rbp=0000000000000000
 r8=0000000000000050  r9=0000000000000002 r10=fffffa80097a47d0
r11=fffffa80097a9100 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
dxgmms1!memmove+0x24b:
fffff880`0f01065b 2000            and     byte ptr [rax],al ds:b000:00000000`00000001=??
Resetting default scope
MISALIGNED_IP:
dxgmms1!memmove+24b
LAST_CONTROL_TRANSFER:  from fffff80003082be9 to fffff80003083640
STACK_TEXT:
fffff800`0445b058 fffff800`03082be9 : 00000000`0000000a 00000000`00000001 00000000`0000000b 00000000`00000001 : nt!KeBugCheckEx
fffff800`0445b060 fffff800`03081860 : fffffa80`06a18760 fffff880`0f0e3068 0000057f`f741b598 00000000`00aa6930 : nt!KiBugCheckDispatch+0x69
fffff800`0445b1a0 fffff880`0f01065b : fffff880`0f008077 00000000`00aa6930 00000000`00000000 00000000`00700000 : nt!KiPageFault+0x260
fffff800`0445b338 fffff880`0f008077 : 00000000`00aa6930 00000000`00000000 00000000`00700000 00000000`00000002 : dxgmms1!memmove+0x24b
fffff800`0445b340 fffff880`0f007f76 : fffffa80`0a2cb850 fffff800`03089a3a fffffa80`097c0000 fffff800`0445b710 : dxgmms1!VidSchDdiNotifyInterruptWorker+0xef
fffff800`0445b390 fffff880`0fd0413f : fffffa80`08087480 00000000`0000000f 00000000`00000000 00000000`00000000 : dxgmms1!VidSchDdiNotifyInterrupt+0x9e
fffff800`0445b3c0 fffff880`0f110418 : fffff800`0445b550 fffff800`0445b550 00000000`00700000 00000000`00000000 : dxgkrnl!DxgNotifyInterruptCB+0x83
fffff800`0445b3f0 fffff800`0445b550 : fffff800`0445b550 00000000`00700000 00000000`00000000 fffffa80`08627000 : nvlddmkm+0xa3418
fffff800`0445b3f8 fffff800`0445b550 : 00000000`00700000 00000000`00000000 fffffa80`08627000 00000000`00000000 : 0xfffff800`0445b550
fffff800`0445b400 00000000`00700000 : 00000000`00000000 fffffa80`08627000 00000000`00000000 00000000`00000000 : 0xfffff800`0445b550
fffff800`0445b408 00000000`00000000 : fffffa80`08627000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x700000
STACK_COMMAND:  kb
FOLLOWUP_IP:
dxgmms1!memmove+24b
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  dxgmms1!memmove+24b
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: hardware
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED_dxgmms1.sys
Loading Dump File [F:\a\Minidump\D M P\DMP\030911-22526-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0301f000 PsLoadedModuleList = 0xfffff800`03264e90
Debug session time: Wed Mar  9 17:45:36.695 2011 (UTC - 5:00)
System Uptime: 1 days 23:30:46.490
1: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c000001d, Exception code that caused the bugcheck
Arg2: fffff800030d0e67, Address of the instruction which caused the bugcheck
Arg3: fffff88005be5110, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION}  Illegal Instruction  An attempt was made to execute an illegal instruction.
FAULTING_IP:
fffff800`030d0e67 0f84f6b1faff    je      nt! ?? ::FNODOBFM::`string'+0x5db0 (fffff800`0307c063)
CONTEXT:  fffff88005be5110 -- (.cxr 0xfffff88005be5110)
rax=fffff8800ba26b68 rbx=0000000000000001 rcx=fffff88005be5b68
rdx=fffffa8009adca98 rsi=fffff88005be5be0 rdi=fffff88005be5b68
rip=fffff800030d0e67 rsp=fffff88005be5af0 rbp=fffff88005be5ca0
 r8=fffffa8009adcac1  r9=0000000000000000 r10=fffffa8006a87f30
r11=00000000000f00ff r12=fffffa8009adca50 r13=0000000000000000
r14=0000000000000000 r15=0000000000000001
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!KxWaitForLockChainValid+0x17:
fffff800`030d0e67 0f84f6b1faff    je      nt! ?? ::FNODOBFM::`string'+0x5db0 (fffff800`0307c063) [br=0]
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff8000308b6dc to fffff800030d0e67
STACK_TEXT:
fffff880`05be5af0 fffff800`0308b6dc : fffffa80`09adca00 fffff880`00000002 fffffa80`06a87f30 fffff800`000e0001 : nt!KxWaitForLockChainValid+0x17
fffff880`05be5b20 fffff800`0309e8d3 : fffffa80`0b8e4b60 00000000`76e445c0 00000000`00000000 fffffa80`0a10fdb0 : nt!NtWaitForWorkViaWorkerFactory+0x43b
fffff880`05be5c20 00000000`76d92c1a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`04ccf5e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76d92c1a
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KxWaitForLockChainValid+17
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
STACK_COMMAND:  .cxr 0xfffff88005be5110 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!KxWaitForLockChainValid+17
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  2
STACK_TEXT:
FOLLOWUP_IP:
MODULE_NAME: nt
Drivers:
fffff880`0fd82000 fffff880`0fdc0000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00ec4000 fffff880`00f1b000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`0408e000 fffff880`04117000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`0f000000 fffff880`0f016000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01032000 fffff880`0103d000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`065f3000 fffff880`065fe000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00cda000 fffff880`00ce3000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01008000 fffff880`01032000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`01633000 fffff880`0163a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`042d3000 fffff880`042e4000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`05cd1000 fffff880`05cef000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00650000 fffff960`00677000   cdd      cdd.dll      unavailable (00000000)
fffff880`01600000 fffff880`0162a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01993000 fffff880`019c3000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00d50000 fffff880`00dae000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01110000 fffff880`01182000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`0fddd000 fffff880`0fded000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`048c9000 fffff880`048d7000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04232000 fffff880`042b5000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`042b5000 fffff880`042d3000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04068000 fffff880`04077000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0197d000 fffff880`01993000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05600000 fffff880`05622000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`048d7000 fffff880`048e0000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`057f3000 fffff880`057ff000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`048e0000 fffff880`048f3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`057e7000 fffff880`057f3000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0444d000 fffff880`04541000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`04541000 fffff880`04587000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`04998000 fffff880`049ce000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`04431000 fffff880`0443e000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01089000 fffff880`0109d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0103d000 fffff880`01089000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01943000 fffff880`0197d000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01840000 fffff880`0188a000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`04424000 fffff880`04431000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03609000 fffff800`03652000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04400000 fffff880`04424000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`04949000 fffff880`04962000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`04962000 fffff880`0496a080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0493b000 fffff880`04949000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05c08000 fffff880`05cd1000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`0193a000 fffff880`01943000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`0430a000 fffff880`04320000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0fded000 fffff880`0fdfc000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0497e000 fffff880`0498c000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00b96000 fffff800`00ba0000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0648d000 fffff880`06494000   KernExplorer64 KernExplorer64.sys Mon Oct 25 03:11:16 2010 (4CC52D94)
fffff880`04385000 fffff880`043c8000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`013e2000 fffff880`013fd000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`057e1000 fffff880`057e6200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0109d000 fffff880`010b2000   Lbd      Lbd.sys      Tue May 25 03:45:36 2010 (4BFB8020)
fffff880`0496b000 fffff880`0497e000   LHidFilt LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
fffff880`03c21000 fffff880`03c36000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03dc2000 fffff880`03dd6000   LMouFilt LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
fffff880`03dd6000 fffff880`03df9000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`03da5000 fffff880`03db5000   LUsbFilt LUsbFilt.Sys Wed Jun 17 12:49:46 2009 (4A391EAA)
fffff880`00ced000 fffff880`00d3c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`06417000 fffff880`06425000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04376000 fffff880`04385000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03db5000 fffff880`03dc2000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`0142b000 fffff880`0145c000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`06407000 fffff880`06417000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`05cef000 fffff880`05d07000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05d07000 fffff880`05d34000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`05d34000 fffff880`05d81000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`05d81000 fffff880`05da5000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`0122d000 fffff880`01238000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f24000 fffff880`00f2e000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010b2000 fffff880`01110000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0405d000 fffff880`04068000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01928000 fffff880`0193a000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0149d000 fffff880`01590000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`0f03a000 fffff880`0f046000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03c89000 fffff880`03c9c000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`0f046000 fffff880`0f075000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04877000 fffff880`0488c000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`041a1000 fffff880`041b0000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04117000 fffff880`0415c000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01590000 fffff880`015f0000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`03cdf000 fffff880`03d98000   netr7364 netr7364.sys Wed Feb 24 02:02:51 2010 (4B84CF1B)
fffff880`0653c000 fffff880`06551000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`01182000 fffff880`01193000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04051000 fffff880`0405d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0301f000 fffff800`03609000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0123f000 fffff880`013e2000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`0162a000 fffff880`01633000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0fd1d000 fffff880`0fd1e180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffff880`0f080000 fffff880`0fcdad00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`03c36000 fffff880`03c89000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04165000 fffff880`0418b000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`0fdc0000 fffff880`0fddd000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00f6e000 fffff880`00f83000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00f2e000 fffff880`00f61000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00ff4000 fffff880`00ffb000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e00000 fffff880`00e10000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`060ef000 fffff880`06195000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0488c000 fffff880`048c9000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d3c000 fffff880`00d50000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0f016000 fffff880`0f03a000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`04320000 fffff880`0433b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0433b000 fffff880`0435c000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`0435c000 fffff880`04376000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04000000 fffff880`04051000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`0f075000 fffff880`0f080000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`0148f000 fffff880`01498000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0121b000 fffff880`01224000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01224000 fffff880`0122d000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018ee000 fffff880`01928000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`03c9c000 fffff880`03cb4000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05623000 fffff880`057e0a00   RTKVHD64 RTKVHD64.sys Mon Jul 20 06:52:29 2009 (4A644C6D)
fffff880`06195000 fffff880`061a0000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0443e000 fffff880`0444a000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`041b0000 fffff880`041cd000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018e6000 fffff880`018ee000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`064a3000 fffff880`0653c000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`06000000 fffff880`0606b000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`061a0000 fffff880`061d1000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`0444a000 fffff880`0444b480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0163c000 fffff880`01840000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`061d1000 fffff880`061e3000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`011b5000 fffff880`011c2000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01193000 fffff880`011b5000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`041e8000 fffff880`041fc000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`042e4000 fffff880`0430a000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`043c8000 fffff880`043da000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`04901000 fffff880`0491e000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`0491e000 fffff880`0491ff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`045ea000 fffff880`045fb000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0481d000 fffff880`04877000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04594000 fffff880`045ea000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0659e000 fffff880`065aa000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`04920000 fffff880`0493b000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`04587000 fffff880`04594000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00f61000 fffff880`00f6e000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0145c000 fffff880`0146a000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0146a000 fffff880`0148f000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00dae000 fffff880`00dea000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`0188a000 fffff880`0189a000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00f83000 fffff880`00f98000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00f98000 fffff880`00ff4000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`0189a000 fffff880`018e6000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`03d98000 fffff880`03da5000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`0418b000 fffff880`041a1000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03cb4000 fffff880`03cbe000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`041cd000 fffff880`041e8000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`015f0000 fffff880`01600000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e11000 fffff880`00eb5000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00eb5000 fffff880`00ec4000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0415c000 fffff880`04165000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00321000   win32k   win32k.sys   unavailable (00000000)
fffff880`00dea000 fffff880`00dfe000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`00f1b000 fffff880`00f24000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`03c00000 fffff880`03c21000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`06551000 fffff880`06582000   WUDFRd   WUDFRd.sys   Sat Nov 20 05:43:32 2010 (4CE7A654)
fffff880`0fd1f000 fffff880`0fd82000   yk62x64  yk62x64.sys  Mon Feb 23 10:02:27 2009 (49A2BA83)
Unloaded modules:
fffff880`06494000 fffff880`064a0000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06582000 fffff880`0658b000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0658b000 fffff880`0659e000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06481000 fffff880`0648d000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06400000 fffff880`06407000   KernExplorer
    Checksum:  00000000
    ImageSize:  00007000
fffff880`06459000 fffff880`06465000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06465000 fffff880`0646e000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0646e000 fffff880`06481000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0644d000 fffff880`06459000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06425000 fffff880`06431000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06431000 fffff880`0643a000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0643a000 fffff880`0644d000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0498c000 fffff880`04998000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0f08b000 fffff880`0fd1d000   nvlddmkm.sys
    Checksum:  00000000
    ImageSize:  00C92000
fffff880`048f3000 fffff880`04901000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06582000 fffff880`065f3000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`019c3000 fffff880`019d1000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019d1000 fffff880`019dd000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019dd000 fffff880`019e6000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019e6000 fffff880`019f9000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
cmb
Thanks! I will try the first three steps and report back. I had a feeling it was a driver issue since Linux runs fine.
Exactly, Lavasoft is known to produce BSOD's when combined with other AV brands such as MSE in your case. Uninstalling Lavasoft should fix you. : )
cmb
So I tried everything, and now I am getting a new error related to DirectX. So, I updated DirectX and it didn't work. Here is the Who Crashed report, and I will attach the latest dmp file, and the other things you asked for above (Rammon and CpuZ).
Thanks again for your help.
On Thu 3/10/2011 9:20:01 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031011-24304-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x14BFD)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800FCE8BFD, 0xFFFFF88003D83DA8, 0xFFFFF88003D83600)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
WinDbg points to hardware, probably faulty RAM:
BugCheck 1000007E, {ffffffffc0000005, fffff8800fce8bfd, fffff88003d83da8, fffff88003d83600}
PROCESS_NAME: csrss.exe
Stack nt dxkgrnl dll
ExceptionCode: c0000005 (Access violation)
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800032be0e8
Probably caused by : hardware ( dxgkrnl!memset+7d )
1. You got 4 sticks of GSkill F2-6400CL5-2GBPQ 800 Mhz 5-5-5-15 1.8V - 1.9V - your current settings are right except that I don't know your current voltage.
Run Memtest86+ - Advanced Memory Diagnostic Tool for 10 passes.
2. Update Logitech Setpoint
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031011-24304-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0300d000 PsLoadedModuleList = 0xfffff800`03252e90
Debug session time: Thu Mar 10 16:20:01.800 2011 (UTC - 5:00)
System Uptime: 0 days 0:48:58.595
2: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800fce8bfd, The address that the exception occurred at
Arg3: fffff88003d83da8, Exception Record Address
Arg4: fffff88003d83600, Context Record Address
Debugging Details:
FAULTING_IP:
dxgkrnl!memset+7d
fffff880`0fce8bfd 007330          add     byte ptr [rbx+30h],dh
EXCEPTION_RECORD:  fffff88003d83da8 -- (.exr 0xfffff88003d83da8)
ExceptionAddress: fffff8800fce8bfd (dxgkrnl!memset+0x000000000000007d)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000001
   Parameter[1]: 0000000000000230
Attempt to write to address 0000000000000230
CONTEXT:  fffff88003d83600 -- (.cxr 0xfffff88003d83600)
rax=fffff88003d840c0 rbx=0000000000000200 rcx=fffff88003d840c0
rdx=0000000000000000 rsi=0000000000000000 rdi=fffff8a002cc1d90
rip=fffff8800fce8bfd rsp=fffff88003d83fe8 rbp=fffff88003d847f0
 r8=0000000000000020  r9=0000000000000001 r10=fffffffffffffffb
r11=fffff8a002cd1000 r12=0000000000000002 r13=0000000000000001
r14=fffff8a002cd1000 r15=0000000000000001
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
dxgkrnl!memset+0x7d:
fffff880`0fce8bfd 007330          add     byte ptr [rbx+30h],dh ds:002b:00000000`00000230=??
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000001
EXCEPTION_PARAMETER2:  0000000000000230
 0000000000000230
FOLLOWUP_IP:
dxgkrnl!memset+7d
BUGCHECK_STR:  0x7E
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
MISALIGNED_IP:
dxgkrnl!memset+7d
LAST_CONTROL_TRANSFER:  from fffff8800fd43e6c to fffff8800fce8bfd
STACK_TEXT:
fffff880`03d83fe8 fffff880`0fd43e6c : 00000000`00000000 00000000`00000200 fffff880`03d847f0 00000000`00000000 : dxgkrnl!memset+0x7d
fffff880`03d83ff0 fffff880`0fd1afb2 : fffff8a0`00000001 fffff8a0`02cd1000 fffff880`03d84638 fffff880`03d846a8 : dxgkrnl!DXGCONTEXT::Render+0x1e4
fffff880`03d84600 fffff960`0069b264 : 00000000`00000000 00000000`00000000 fffff900`c00c1020 00000000`00000000 : dxgkrnl!DxgkCddGdiCommand+0x1ea
fffff880`03d84690 fffff960`006995d5 : fffffa80`07f29830 fffffa80`07f29830 00000000`00000000 fffff900`c00c1020 : cdd!CHwCommandBuffer::FlushGdiCommands+0xb4
fffff880`03d84980 fffff960`00695c6e : ffffffff`fffd73b0 00000000`00000010 00000000`00000000 fffff900`c00c1020 : cdd!CDDPDEV::FlushGdiOutput+0x81
fffff880`03d849b0 fffff800`0332acce : 00000000`046db3c2 fffffa80`09553b60 00000000`00000080 fffffa80`0939a6a0 : cdd!PresentWorkerThread+0x902
fffff880`03d84d40 fffff800`0307efe6 : fffff880`02f64180 fffffa80`09553b60 fffff880`02f6efc0 fffff880`01251384 : nt!PspSystemThreadStartup+0x5a
fffff880`03d84d80 00000000`00000000 : fffff880`03d85000 fffff880`03d7f000 fffff880`03d84350 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_NAME:  dxgkrnl!memset+7d
STACK_COMMAND:  .cxr 0xfffff88003d83600 ; kb
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED_dxgkrnl.sys
Drivers:
fffff880`042b6000 fffff880`042f4000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00f52000 fffff880`00fa9000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`02c5e000 fffff880`02ce7000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`0433a000 fffff880`04350000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0110a000 fffff880`01115000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`06a71000 fffff880`06a7c000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00ded000 fffff880`00df6000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`010e0000 fffff880`0110a000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`019f6000 fffff880`019fd000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040c7000 fffff880`040d8000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`05b8b000 fffff880`05ba9000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      Sat Nov 20 07:55:34 2010 (4CE7C546)
fffff880`019c3000 fffff880`019ed000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`0195d000 fffff880`0198d000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00d39000 fffff880`00d97000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01072000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`0432a000 fffff880`0433a000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`059ae000 fffff880`059bc000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04026000 fffff880`040a9000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`040a9000 fffff880`040c7000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`02dd7000 fffff880`02de6000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01947000 fffff880`0195d000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05986000 fffff880`059a8000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`059c8000 fffff880`059d1000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`059bc000 fffff880`059c8000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`059d1000 fffff880`059e4000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`059e4000 fffff880`059f0000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0fcd4000 fffff880`0fdc8000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0f000000 fffff880`0f046000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`05b4b000 fffff880`05b81000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`042f4000 fffff880`04301000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01161000 fffff880`01175000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01115000 fffff880`01161000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0190d000 fffff880`01947000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`0180a000 fffff880`01854000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`0fdec000 fffff880`0fdf9000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`035f7000 fffff800`03640000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0fdc8000 fffff880`0fdec000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`0562d000 fffff880`05646000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05646000 fffff880`0564e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0561f000 fffff880`0562d000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`05a00000 fffff880`05ac9000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01904000 fffff880`0190d000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`040fe000 fffff880`04114000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04225000 fffff880`04234000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05662000 fffff880`05670000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00b9d000 fffff800`00ba7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04245000 fffff880`04288000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`013e1000 fffff880`013fc000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`059a8000 fffff880`059ad200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0564f000 fffff880`05662000   LHidFilt LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
fffff880`04800000 fffff880`04815000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04998000 fffff880`049ac000   LMouFilt LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
fffff880`049ac000 fffff880`049cf000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`0497b000 fffff880`0498b000   LUsbFilt LUsbFilt.Sys Wed Jun 17 12:49:46 2009 (4A391EAA)
fffff880`00cd6000 fffff880`00d25000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`05670000 fffff880`0567e000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04234000 fffff880`04243000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0498b000 fffff880`04998000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d97000 fffff880`00db1000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`0148b000 fffff880`014bc000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`06b48000 fffff880`06b58000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`05ba9000 fffff880`05bc1000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05bc1000 fffff880`05bee000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`05ea0000 fffff880`05eed000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`05eed000 fffff880`05f11000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`01072000 fffff880`0107d000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fb2000 fffff880`00fbc000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01175000 fffff880`011d3000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`02dcc000 fffff880`02dd7000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018f2000 fffff880`01904000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014d1000 fffff880`015c4000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`04374000 fffff880`04380000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`05b20000 fffff880`05b33000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`04380000 fffff880`043af000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`048ad000 fffff880`048c2000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`02d71000 fffff880`02d80000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02ce7000 fffff880`02d2c000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`048c2000 fffff880`0497b000   netr7364 netr7364.sys Wed Feb 24 02:02:51 2010 (4B84CF1B)
fffff880`06b58000 fffff880`06b6d000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`0107d000 fffff880`0108e000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0300d000 fffff800`035f7000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0123e000 fffff880`013e1000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`019ed000 fffff880`019f6000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0fcd2000 fffff880`0fcd3180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`0f077000 fffff880`0fcd1d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`05acd000 fffff880`05b20000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d35000 fffff880`02d5b000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`0430d000 fffff880`0432a000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00e00000 fffff880`00e15000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00fbc000 fffff880`00fef000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00e86000 fffff880`00e8d000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e8d000 fffff880`00e9d000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`05f11000 fffff880`05fb7000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05949000 fffff880`05986000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d25000 fffff880`00d39000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04350000 fffff880`04374000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`043af000 fffff880`043ca000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043ca000 fffff880`043eb000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`04200000 fffff880`0421a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`0421a000 fffff880`04225000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`0121b000 fffff880`01224000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01224000 fffff880`0122d000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0122d000 fffff880`01236000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018b8000 fffff880`018f2000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`05b33000 fffff880`05b4b000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`056aa000 fffff880`05948980   RTKVHD64 RTKVHD64.sys Thu Feb 24 05:19:18 2011 (4D6630A6)
fffff880`05fb7000 fffff880`05fc2000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04301000 fffff880`0430d000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d80000 fffff880`02d9d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018b0000 fffff880`018b8000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06aaf000 fffff880`06b48000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`05e12000 fffff880`05e7d000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`05fc2000 fffff880`05ff3000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`04243000 fffff880`04244480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01606000 fffff880`0180a000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`05e00000 fffff880`05e12000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`010b0000 fffff880`010bd000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`0108e000 fffff880`010b0000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`02db8000 fffff880`02dcc000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00490000 fffff960`0049a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`040d8000 fffff880`040fe000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`04288000 fffff880`0429a000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`05600000 fffff880`0561d000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`0561d000 fffff880`0561ef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0f053000 fffff880`0f064000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04853000 fffff880`048ad000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04114000 fffff880`0416a000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`059f0000 fffff880`059fc000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`0568b000 fffff880`056a6000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`0f046000 fffff880`0f053000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fef000 fffff880`00ffc000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`014bc000 fffff880`014ca000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`015c4000 fffff880`015e9000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00db1000 fffff880`00ded000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01854000 fffff880`01864000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e2a000 fffff880`00e86000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01864000 fffff880`018b0000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`0567e000 fffff880`0568b000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02d5b000 fffff880`02d71000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`05b81000 fffff880`05b8b000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`02d9d000 fffff880`02db8000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`015e9000 fffff880`015f9000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e9f000 fffff880`00f43000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f43000 fffff880`00f52000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d2c000 fffff880`02d35000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a1000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`00cc0000 fffff880`00cd4000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`00fa9000 fffff880`00fb2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`049cf000 fffff880`049f0000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`06b6d000 fffff880`06b9e000   WUDFRd   WUDFRd.sys   Sat Nov 20 05:43:32 2010 (4CE7A654)
fffff880`0416a000 fffff880`041d0000   yk62x64  yk62x64.sys  Tue Jan 18 04:35:15 2011 (4D355ED3)
Unloaded modules:
fffff880`06a00000 fffff880`06a71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0198d000 fffff880`0199b000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0199b000 fffff880`019a7000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019a7000 fffff880`019b0000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019b0000 fffff880`019c3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
cmb
#7
I went ahead and updated the Logitech drivers from their website.
I am now on pass three for Memtest86+ ver. 4.20. No errors reported so far.
Here are the settings:
L1 Cache: 32k 35180 MB/s
L2 Cache: 3072K 16325 MB/s
L3 Cache: None
Memory: 8190m 4359 MB.s
Chipset: Intel P35/G33 (ECC: Disabled) – FSB 33 MHz – Type DDR2
Settings: Ram: 399 MHz (DDR799) / CAS: 5-5-5-15 / Dual Channel
I'm not sure how to find the voltage settings...
#8
In the bios. 'Auto' should set it right.
Memtest - 10 passes without interruptions.
cmb
#9
21 hours later, 11 passes complete no errors.
I went into the BIOS and checked the Frequency/Voltage Control settings. All memory timing set features are on "AUTO."
That includes:
CAS Latency Time
DRAM RAS# to CAS# Delay
DRAM RAS# Precharge
Precharge Delay (tRAS)
Write Recovery Time
Refresh Command Period
Write to Read Delay
Row Active Delay
Read to Precharge Delay
Any chance the problem could be video card related? I have had my suspicions about the card because I have had issue with it in Linux. Thanks again for your help.
#10
cmb
#11
I ran the Fur Mark GPU test. I did a 1.5 hour burnin (no problems) in standard Windows. The temp reached as much as 116 deg C. Then I ran a 720 test, score of 106, max temp of 112 deg C. FPS: min 2, max 1, avg 1, Options: DYNBkg
I then used OCCT to do the GPU memtest. 10 passes, no problems reported.
Then, I ran a GPU OCCT test, ran for 1 hour with no problems reported.
The good news is I have been running in regular Windows 7 mode since this morning and there are no crashes (though I am using my laptop for all of my work at this point).
Any thoughts? More tests I should run?
#12
Since nVidia and DX drivers were involved in the crashes, you may want to try another driver if blue screens reoccur.
#13
For anyone still encountering this problem - there are several points which you need to consider that I found out to be the source of most of the problems related to ntkrnlmp.exe. Drivers, RAM mem.,Windows auto update, power supply. These are the four possible points of failure that you need to take a look into. (You can find more details in the following research about this problem)
