Windows 7 BSOD on Asus PK5 pro
Hi and welcome to the forums.
Dump file: 072010-25942-01.dmp
Module path: C:\Windows\system32\ntoskrnl.exe
Bugcheck code: 0x50 (0xFFFFF6801A021A88, 0x0, 0xFFFFF80002899AE2, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
The crash took place in a standard Microsoft module.
Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
0x50 error can be caused by hardware issues, software issues (e.g anti-virus), and faulty drivers.
What to do:
1. Download and install updates and device drivers for your computer from Windows Update.
Diagnose any recently installed hardware for hardware compatibility and again drivers.
2. Scan your computer for viruses.
3. Check your hard disk for errors (cmd->chkdsk /f /r).
4. Restoring to Last Known Good Configuration is worth trying.
Giving us some more info could help us more precisely identify the cause of the error, msinfo32, as well as check the event viewer's alerts.
I suspect 2 causes, both low-level drivers.
Please remove any CD virtualization programs such as Daemon Tools and Alcohol 120%. They use a driver, found in your dmp, sptd.sys, that is notorious for causing BSODs. Use this SPTD uninstaller when you're done: DuplexSecure - Downloads
sptd.sys     Sun Oct 11 16:55:14 2009
ASACPI.sys needs an update too. Install the ATK0110 driver for Windows 7/Vista from the Utilities section: ASUSTeK Computer Inc.-Support-
Loading Dump File [C:\Users\Jonathan\_jcgriff2_\dbug\__Kernel__\072010-25942-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02814000 PsLoadedModuleList = 0xfffff800`02a51e50
Debug session time: Tue Jul 20 14:08:16.693 2010 (UTC - 4:00)
System Uptime: 0 days 0:06:54.800
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffff6801a021a88, 0, fffff80002899ae2, 2}
Probably caused by : memory_corruption ( nt!MiAgeWorkingSet+1c2 )
Followup: MachineOwner
2: kd> !analyze -v;lmtsmn;.bugcheck;.logclose;q
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff6801a021a88, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002899ae2, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002abc0e0
 fffff6801a021a88
FAULTING_IP:
fffff800`02899ae2 488b19          mov     rbx,qword ptr [rcx]
MM_INTERNAL_CODE:  2
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880033167a0 -- (.trap 0xfffff880033167a0)
rax=0000007ffffffff8 rbx=0000000000000000 rcx=fffff6801a021a88
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002899ae2 rsp=fffff88003316930 rbp=000000001a021a88
 r8=0000000000000001  r9=fffffa8005b58ec8 r10=0000000000000005
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po cy
nt!MiAgeWorkingSet+0x1c2:
fffff800`02899ae2 488b19          mov     rbx,qword ptr [rcx] ds:fffff680`1a021a88=????????????????
.trap
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002903bc2 to fffff80002885f00
STACK_TEXT:
fffff880`03316638 fffff800`02903bc2 : 00000000`00000050 fffff680`1a021a88 00000000`00000000 fffff880`033167a0 : nt!KeBugCheckEx
fffff880`03316640 fffff800`02883fee : 00000000`00000000 00000980`00000000 00000000`00040000 00000000`0000000b : nt! ?? ::FNODOBFM::`string'+0x40f90
fffff880`033167a0 fffff800`02899ae2 : 00000003`00000000 f9200000`9b76f867 00000000`00000000 00000000`00001f92 : nt!KiPageFault+0x16e
fffff880`03316930 fffff800`02906a0e : fffffa80`05b58ec8 fffff880`00000001 00000000`00000001 fffff880`03316bb0 : nt!MiAgeWorkingSet+0x1c2
fffff880`03316ae0 fffff800`0289a6e2 : 00000000`0000019f 00000000`00000000 fffffa80`00000000 00000000`00000004 : nt! ?? ::FNODOBFM::`string'+0x49926
fffff880`03316b80 fffff800`0289a96f : 00000000`00000008 fffff880`03316c10 00000000`00000001 fffffa80`00000000 : nt!MmWorkingSetManager+0x6e
fffff880`03316bd0 fffff800`02b29166 : fffffa80`039eb1a0 00000000`00000080 fffffa80`039cb040 00000000`00000001 : nt!KeBalanceSetManager+0x1c3
fffff880`03316d40 fffff800`02864486 : fffff880`02f63180 fffffa80`039eb1a0 fffff880`02f6dfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`03316d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiAgeWorkingSet+1c2
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc600
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x50_nt!MiAgeWorkingSet+1c2
fffff880`0fe65000 fffff880`0fea3000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`01175000 fffff880`011cc000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02d26000 fffff880`02db0000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03a8d000 fffff880`03aa3000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`077a3000 fffff880`077e8000   agyjjppa agyjjppa.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00fdb000 fffff880`00fe6000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`041eb000 fffff880`041f3000   ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005 (42476C4C)
fffff880`05194000 fffff880`0519d000   aswFsBlk aswFsBlk.SYS Mon Jun 28 16:32:34 2010 (4C2906E2)
fffff880`0517a000 fffff880`05194000   aswMonFlt aswMonFlt.sys Mon Jun 28 16:32:58 2010 (4C2906FA)
fffff880`02db0000 fffff880`02dba000   aswRdr   aswRdr.SYS   Mon Jun 28 16:33:15 2010 (4C29070B)
fffff880`03a00000 fffff880`03a23000   aswSP    aswSP.SYS    Mon Jun 28 16:37:34 2010 (4C29080E)
fffff880`02d16000 fffff880`02d26000   aswTdi   aswTdi.SYS   Mon Jun 28 16:37:54 2010 (4C290822)
fffff880`00fa8000 fffff880`00fb1000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fb1000 fffff880`00fdb000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`014e4000 fffff880`014eb000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03bcd000 fffff880`03bde000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06fb1000 fffff880`06fcf000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00600000 fffff960`00627000   cdd      cdd.dll      unavailable (00000000)
fffff880`00e00000 fffff880`00e2a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cce000 fffff880`00d8e000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`013af000 fffff880`013df000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c70000 fffff880`00cce000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01564000 fffff880`015d7000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03a7d000 fffff880`03a8d000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`050f6000 fffff880`05104000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03b2c000 fffff880`03baf000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03baf000 fffff880`03bcd000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03b1d000 fffff880`03b2c000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`014c0000 fffff880`014d6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`050c2000 fffff880`050e4000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05110000 fffff880`05119000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05104000 fffff880`05110000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05119000 fffff880`0512c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`050ea000 fffff880`050f6000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04097000 fffff880`0418b000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:38:56 2009 (4A5BC590)
fffff880`0418b000 fffff880`041d1000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`05000000 fffff880`05036000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`041de000 fffff880`041eb000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`00fe6000 fffff880`00ffa000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0445a000 fffff880`04465000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`00d8e000 fffff880`00dda000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015e8000 fffff880`015f2000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01486000 fffff880`014c0000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`0178c000 fffff880`017d6000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02df1000 fffff800`02e3a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04067000 fffff880`0408b000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0447a000 fffff880`044d6000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`06ee9000 fffff880`06fb1000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01600000 fffff880`01609000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03a5f000 fffff880`03a7d000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03a49000 fffff880`03a5f000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0fea3000 fffff880`0feb2000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bb3000 fffff800`00bbd000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04588000 fffff880`045cb000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`0154a000 fffff880`01564000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01761000 fffff880`0178c000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:50:34 2009 (4A5BC84A)
fffff880`050e4000 fffff880`050e9200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`051be000 fffff880`051d3000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05157000 fffff880`0517a000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c18000 fffff880`00c5c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05149000 fffff880`05157000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`10bec000 fffff880`10bfb000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00f8e000 fffff880`00fa8000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`06fcf000 fffff880`06fe7000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06e00000 fffff880`06e2c000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`06e2c000 fffff880`06e79000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`06e79000 fffff880`06e9c000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`02ccf000 fffff880`02cda000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011cc000 fffff880`011d6000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014ec000 fffff880`0154a000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03b12000 fffff880`03b1d000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017ee000 fffff880`01800000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0160f000 fffff880`01701000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0408b000 fffff880`04097000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`044f6000 fffff880`04525000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04465000 fffff880`0447a000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02c2f000 fffff880`02c3e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02dba000 fffff880`02dff000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01701000 fffff880`01761000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02cda000 fffff880`02ceb000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03b06000 fffff880`03b12000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02814000 fffff800`02df1000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`0120c000 fffff880`013af000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01200000 fffff880`01209000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10bea000 fffff880`10beb180   nvBridge nvBridge.kmd Sat Apr 03 19:50:52 2010 (4BB7D45C)
fffff880`0fec0000 fffff880`10be9700   nvlddmkm nvlddmkm.sys Sat Apr 03 20:06:21 2010 (4BB7D7FD)
fffff880`02c09000 fffff880`02c2f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`011e3000 fffff880`011f8000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00eef000 fffff880`00f22000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`011f8000 fffff880`011ff000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00f7e000 fffff880`00f8e000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015d7000 fffff880`015e8000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07228000 fffff880`072ce000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05085000 fffff880`050c2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c5c000 fffff880`00c70000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`02c8a000 fffff880`02cae000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04525000 fffff880`04540000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04540000 fffff880`04561000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04561000 fffff880`0457b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03ab5000 fffff880`03b06000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0457b000 fffff880`04586000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02cb4000 fffff880`02cbd000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02cbd000 fffff880`02cc6000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02cc6000 fffff880`02ccf000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`051d3000 fffff880`051eb000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01146000 fffff880`01175000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`072ce000 fffff880`072d9000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`041f3000 fffff880`041ff000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c3e000 fffff880`02c5b000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`017e6000 fffff880`017ee000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01017000 fffff880`0113d000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`07669000 fffff880`07701000   srv      srv.sys      Mon Jul 13 19:25:11 2009 (4A5BC257)
fffff880`07318000 fffff880`07381000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`072d9000 fffff880`07306000   srvnet   srvnet.sys   Mon Jul 13 19:24:58 2009 (4A5BC24A)
fffff880`04586000 fffff880`04587480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`07306000 fffff880`07318000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02d09000 fffff880`02d16000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02ceb000 fffff880`02d09000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c76000 fffff880`02c8a000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00460000 fffff960`0046a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03a23000 fffff880`03a49000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`045cb000 fffff880`045dd000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05147000 fffff880`05148f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04056000 fffff880`04067000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04400000 fffff880`0445a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04000000 fffff880`04056000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0512c000 fffff880`05147000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`041d1000 fffff880`041de000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`011d6000 fffff880`011e3000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00e2a000 fffff880`00e38000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`00dda000 fffff880`00dff000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`017d6000 fffff880`017e6000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`01000000 fffff880`01015000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f22000 fffff880`00f7e000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c5b000 fffff880`02c76000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`00c00000 fffff880`00c10000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e3c000 fffff880`00ee0000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ee0000 fffff880`00eef000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02c00000 fffff880`02c09000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003af000   win32k   win32k.sys   Mon Jul 13 19:40:16 2009 (4A5BC5E0)
fffff880`0113d000 fffff880`01146000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0519d000 fffff880`051be000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`07772000 fffff880`077a3000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`0fe00000 fffff880`0fe65000   yk62x64  yk62x64.sys  Mon Sep 28 04:19:31 2009 (4AC07193)
Unloaded modules:
fffff880`07701000 fffff880`07772000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`014d6000 fffff880`014e4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`015f2000 fffff880`015fe000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`013df000 fffff880`013e8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`013e8000 fffff880`013fb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Bugcheck code 00000050
Arguments fffff680`1a021a88 00000000`00000000 fffff800`02899ae2 00000000`00000002
Hi.
There is definitely a problem with a driver. Based on experience, I can tell you that it is sptd.sys which is notorious for this.
Arguments:
    address.
Debugging Details:
[COLOR=Red][B]Could not read faulting driver name[/B][/COLOR]
Please uninstall Daemon Tools in the normal way then use this installer/uninstaller to remove sptd.sys from the system, which is important:
As always, I recommend PowerISO as a drive emulator to replace that because it is perfectly stable. The software is not free but the drive emulation capabilities of it remains so, forever.
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
This driver should be updated.
Here's the link for it (motherboard is P5K Pro):
Downloads, Windows 7 64 bit, Utilities section
Download and install "ATK0110 Driver".
Top Bottom
