BSOD on fresh install
I've run memtest for 2 hours and nothing came up, and western digital's hard drive check device and nothing came out. I do have 2 HDD inside and I'm afraid the problem may be the second one. This is a fresh install and it should have all the drivers. I've gotten both a page fault in nonpaged area message and a win32k.sys message.
Oh, more information. The BSOD doesn't appear to particularly happen when I'm accessing my 2nd HDD, mostly when I'm playing games.
Hold on, let me see it.
---> attach (CPU-Z) spd for each of your RAM slot.
The RAM is set wrong - 400 Mhz currently while you need it 800 Mhz.
RAM is the culprit.
PAGE_FAULT_IN_NONPAGED_AREA (50)
MODULE_NAME: hardware
FAILURE_BUCKET_ID: IP_MISALIGNED
1. Load setup defaults in the bios, save, reboot, and re-attach new cpu-z screenshots with the SPD under each slot.
2. Update motherboard drivers, especially the 1st one on the list:
ASUS ATK0110 ACPI Utility
ASACPI.sys Thu Aug 12 22:52:52 2004
nForce
nvmf6232.sys Wed Jul 01 14:54:57 2009
VIA Audio
viahduaa.sys Mon Aug 17 07:17:42 2009
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020511-15444-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82a3b000 PsLoadedModuleList = 0x82b83810
Debug session time: Sat Feb  5 15:04:34.208 2011 (UTC - 5:00)
System Uptime: 0 days 1:06:57.940
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
1: kd> !analyze -v
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: d5df3344, memory referenced.
Arg2: 00000001, value 0 = read operation, 1 = write operation.
Arg3: 974072b0, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 00000002, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82ba3718
Unable to read MiSystemVaType memory at 82b83160
 d5df3344
FAULTING_IP:
win32k!xxxActivateThisWindow+478
974072b0 008b402833db    add     byte ptr [ebx-24CCD7C0h],cl
MM_INTERNAL_CODE:  2
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  firefox.exe
CURRENT_IRQL:  0
TRAP_FRAME:  a1c53914 -- (.trap 0xffffffffa1c53914)
ErrCode = 00000002
eax=faac0b04 ebx=faac0b04 ecx=00000000 edx=00000000 esi=a1c53b24 edi=0db705dc
eip=974072b0 esp=a1c53988 ebp=a1c539a4 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
win32k!xxxActivateThisWindow+0x478:
974072b0 008b402833db    add     byte ptr [ebx-24CCD7C0h],cl ds:0023:d5df3344=??
Resetting default scope
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from 82a81638 to 82ac0903
STACK_TEXT:
a1c538fc 82a81638 00000001 d5df3344 00000000 nt!MmAccessFault+0x106
a1c538fc 974072b0 00000001 d5df3344 00000000 nt!KiTrap0E+0xdc
a1c539a4 974271ea 0000009d 369d4bd4 ffa34008 win32k!xxxActivateThisWindow+0x478
a1c53be4 9745cdd2 fa9bf010 fe0f8aa0 00000000 win32k!EngCopyBits+0x604
a1c53ccc 97444fae fba05688 ff4933f8 fe5dfd10 win32k!NtGdiBitBltInternal+0x6ab
a1c53d00 82a7e44a 73011a31 00000000 00000000 win32k!NtGdiBitBlt+0x2f
a1c53d00 77a164f4 73011a31 00000000 00000000 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
001ddb88 00000000 00000000 00000000 00000000 0x77a164f4
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  win32k!xxxActivateThisWindow+478
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
Followup: MachineOwner
Drivers:
start    end        module name
8b607000 8b64f000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8f630000 8f68a000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
94f2f000 94f41000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
90ed3000 90ee5000   amdk8    amdk8.sys    Mon Jul 13 19:11:03 2009 (4A5BBF07)
8b758000 8b761000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
90f08000 90f09420   ASACPI   ASACPI.sys   Thu Aug 12 22:52:52 2004 (411C2D04)
8b72c000 8b735000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b735000 8b758000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
8ba26000 8ba2d000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
90ea4000 90eb2000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
8b45b000 8b463000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
96eac000 96ec5000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
97220000 9723e000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
8ba00000 8ba1f000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
8b4a5000 8b550000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8bbbc000 8bbe1000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
8b463000 8b4a5000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8b982000 8b9df000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
94f22000 94f2f000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
8cc99000 8cca6000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
90e28000 90e8c000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
90e8c000 90ea4000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
8f793000 8f79f000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8bbab000 8bbbc000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
95fdd000 95ff6000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
8ccb1000 8ccba000   dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8cca6000 8ccb1000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14)
8ccba000 8cccb000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
95ff6000 96000000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
94e29000 94ee0000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
94ee0000 94f19000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
90ee5000 90ef0000   fdc      fdc.sys      Mon Jul 13 19:45:45 2009 (4A5BC729)
8b795000 8b7a6000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
94e00000 94e0a000   flpydisk flpydisk.sys Mon Jul 13 19:45:45 2009 (4A5BC729)
8b761000 8b795000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8b9ed000 8b9f6000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8bb79000 8bbab000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8bd58000 8bd89000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
82a04000 82a3b000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
90f81000 90fa0000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
94e0a000 94e1d000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
95e0b000 95e11480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
95e00000 95e0b000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
96e27000 96eac000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8bde9000 8bdf1000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
94fd6000 94fe3000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8cccb000 8ccd7000   kbdhid   kbdhid.sys   Mon Jul 13 19:45:09 2009 (4A5BC705)
80bbd000 80bc5000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8f79f000 8f7d3000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
8b96f000 8b982000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8bb27000 8bb4c000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
8cd0c000 8cd1c000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
8ccd7000 8ccf2000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
8b43f000 8b44a000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:13:13 2009 (4A5BBF89)
8cc7a000 8cc85000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
94fe3000 94ff0000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
8cc58000 8cc63000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8b716000 8b72c000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
96ec5000 96ed7000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
96ed7000 96efa000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
96efa000 96f35000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
96f35000 96f50000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
8b7dc000 8b7e7000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8b658000 8b660000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8b944000 8b96f000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8f789000 8f793000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8bdd9000 8bde9000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8ba32000 8bae9000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
94f59000 94f64000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
8cd62000 8cd72000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
94f64000 94f86000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
95e5a000 95e6b000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
8f6f3000 8f701000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8f68a000 8f6bc000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8bae9000 8bb27000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8b7e7000 8b7f5000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8f77f000 8f789000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82a3b000 82e4b000   nt       ntkrpamp.exe Fri Jun 18 23:55:24 2010 (4C1C3FAC)
8b815000 8b944000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8ba1f000 8ba26000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
95dfa000 95dfb040   nvBridge nvBridge.kmd Fri Jan 07 20:57:19 2011 (4D27C47F)
90e00000 90e21000   nvhda32v nvhda32v.sys Thu Nov 11 18:10:19 2010 (4CDC77DB)
95400000 95df9ee0   nvlddmkm nvlddmkm.sys Fri Jan 07 21:03:58 2011 (4D27C60E)
90fa0000 90fe4880   nvmf6232 nvmf6232.sys Wed Jul 01 14:54:57 2009 (4A4BB101)
90f14000 90f1d000   nvsmu    nvsmu.sys    Mon Jun 29 03:36:34 2009 (4A486F02)
8cd1c000 8cd62000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
8f6c3000 8f6e2000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
90ef0000 90f08000   parport  parport.sys  Mon Jul 13 19:45:34 2009 (4A5BC71E)
8b695000 8b6a6000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
96f50000 96f57000   parvdm   parvdm.sys   Mon Jul 13 19:45:29 2009 (4A5BC719)
8b660000 8b68a000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8b701000 8b708000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
8b708000 8b716000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8b9df000 8b9ed000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
96f57000 96fee000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
8f600000 8f62f000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
8b44a000 8b45b000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
94f41000 94f59000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
94f86000 94f9e000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
94f9e000 94fb5000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
94fb5000 94fcc000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
8f73e000 8f77f000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
94fcc000 94fd6000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8b80c000 8b814000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8b9f6000 8b9fe000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8b7d4000 8b7dc000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8bb4c000 8bb79000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8cd72000 8cd85000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
96fee000 96ff8000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
90f0a000 90f14000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
8f701000 8f71b000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
8bdd1000 8bdd9000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
9ca5b000 9cac5000   spsys    spsys.sys    Mon May 11 12:37:10 2009 (4A085436)
9ca0a000 9ca5b000   srv      srv.sys      Thu Aug 26 23:31:26 2010 (4C77318E)
8cd92000 8cde1000   srv2     srv2.sys     Thu Aug 26 23:30:45 2010 (4C773165)
96e00000 96e21000   srvnet   srvnet.sys   Thu Aug 26 23:30:39 2010 (4C77315F)
94ff0000 94ff1380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8bc0f000 8bd58000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
8cd85000 8cd92000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
8b7f5000 8b800000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8b5cf000 8b5e6000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8f72e000 8f73e000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
975e0000 975e9000   TSDDD    TSDDD.dll    unavailable (00000000)
90eb2000 90ed3000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
8cc18000 8cc58000   udfs     udfs.sys     Mon Jul 13 19:14:09 2009 (4A5BBFC1)
94ff2000 95000000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
8cc85000 8cc98b00   usbaudio usbaudio.sys Mon Jul 13 19:51:23 2009 (4A5BC87B)
8cc63000 8cc7a000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
95e12000 95e13700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
90f72000 90f81000   usbehci  usbehci.sys  Fri Oct 23 23:58:55 2009 (4AE27B7F)
95e16000 95e5a000   usbhub   usbhub.sys   Sat Oct 24 00:00:05 2009 (4AE27BC5)
90f1d000 90f27000   usbohci  usbohci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
90f27000 90f72000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
8b68a000 8b695000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8b800000 8b80c000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
95e6b000 95fdd000   viahduaa viahduaa.sys Mon Aug 17 07:17:42 2009 (4A893C56)
8b7a6000 8b7c7000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8bd89000 8bd91380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8b6a6000 8b6b6000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8b6b6000 8b701000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8bd92000 8bdd1000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8f6e2000 8f6f3000   vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
8f71b000 8f72e000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8b7c7000 8b7d4000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
8b550000 8b5c1000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
8b5c1000 8b5cf000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8f6bc000 8f6c3000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
97380000 975cb000   win32k   win32k.sys   Tue Oct 19 23:00:01 2010 (4CBE5B31)
94f19000 94f22000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:19:16 2009 (4A5BC0F4)
8b64f000 8b658000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
8ccf2000 8cd0c000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
Unloaded modules:
8bdf1000 8bdfe000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8bc00000 8bc0b000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8bbe1000 8bbea000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8bbea000 8bbfb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
#7
Attach CPU-Z memory tab as you have it right now.
#8
oh right sorry
#9
Set wrong - 750Mhz. You need it 800.
#10
How could you tell, and what can I do to change it?
#11
In the bios, set Dram frequency 800Mhz. Or load setup defaults for the entire bios.
1. See your motherboard manual
2. See the official rated specs for your RAM sticks
