Windows 7 BSoD on my PC... please help!
mikelo
Hi All,
This is my first post in this forum. I'm looking forward to reading and joining in with you all here!
I hope someone could help me with a problem I have concerning my system.
First of all, I am a musician and purchased a 3XS D.A.W. (Digital Audio Workstation) pc last November from scan.co.uk.
From the second day of use, I got my first blue screen of death! Just paid £1500, so my heart sank as you could imagine!
This happened when I inserted an 2G Cn Memory flash drive to transfer software from my laptop to the 3XS. I didn't use the drive for a little while after.
Recently, I started using it again, and again it started BSoD my system or after I safely removed it from the USB. I think this might of happened when I never used this particular flash drive one time, which makes me think that there is a chance that this is not the problem after all.
I got in contact with Scan (who have been very helpful!) and they told me to download and install Memtest and give it 10 passes to check for Ram faults. I gave it 13 with no errors.
I was then asked to send them the minidump files.
They came back saying that most were vague but pointed towards kernal issues.
I was then emailed this from the helpful person at Scan...
"Had a look through these this morning, and they are quite vague. Each of them points towards a Kernal level issue which normally points to a driver within the system but they don’t specify what driver which tends to point in the direction of an unofficial patch or the such.
We get lucky with one of the files through which points at a memory collision between NFDS & SPSYS.EXE. NFDS is part of the OS disk management system and is fine but SPSYS.EXE reports as a Trojan (a variant of the CODBOT Trojan) which could be the issue your seeing as it appears to be hogging memory space leading to hangs when other applications try to access the same memory locations.
I’ve not dealt with it before, but from what I can gather Windows malware removal should fix it."
I was shocked as the pc is not and never has been connected online and that all software is scanned before transfer.
As asked, I tried the Windows malware removal and it found nothing. I also tried a full scan using Malwarebytes but this also came clean as a whistle!
I've also tried manually to find this CODBOT and found nothing.
I'm now at a loss! Well sort of ,as of the last few days, I stopped using the CnMemory flash drive, and low and behold.. No crashes!
I've also un/re installed my M Audio soundcard drivers and e-licenser software.
But if the flash drive was the problem, why was I told that a trojan called CODBOT was in the systems minidumps??
I'm really confused and a loss.
I would be grateful for any help or suggestions.
regards,
Michael.
System specs:
Intel i7 920 Core DO (not overclocked)
Gigabyte GA-EX58-UD5 motherboard
6Gb (3x2GB) Corsair XMS3, PC3-10666 (1600)
1 x 500 GB Seagate ST3500320NS Barracuda ES.2, SATA 3Gb/s, 7200rpm, 32MB Cache (OS Drive)
2 x 1T Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache
625w Enermax PSU
512MB Palit/XpertVision 9500 GT Super GPU
Windows 7 64 bit Premium
Hi Michael,
welcome to the forum. :)
Reading through your post it seems it's the flash drive at fault.. I checked with their website and it seems the drive is compatible with win 7. Why not try running chkdsk on the drive to see if any errors crop up? Just right-click on the drive via 'Computer' and choose 'Tools'. See the screenshot as I used one of mine for example..
Link Removed due to 404 Error
Hi Kemical,
thank you for your reply. I will try it. Could it still be the cause even though it may come error free?
I also have a 8G Lexar flash drive which I bought in January and that works flawlessly.
The CnMemory stick that I think might be at fault, is about 4-5 years old now.
I still can't understand why Scan say I might have a trojan in my pc? Could this just be a false positive?
Hi Kemical, well I checked the flash drive using this laptop Im currently writing this (XP) and well... it didn't do anything! The check disk box just vanishes, even if you tick the two boxes. There's no summary or anything.
To be honest I was hoping you were going to say that... Reason being is that chkdsk is quite a good way in determining if a HD or flash drive is working alright.
If chkdsk won't run at all then usually it's because the drive is either broken or very close to it.. This is perhaps why your seeing weird messages for viruses as a broken HD or flash drive can throw up some really bizarre messages sometimes akin to bad RAM.
If I were you I'd consign it to the great scrap heap in the sky and use the other one which works without a problem..
Kemical, you're a star! Thank you so much for your help... its like you've put my mind to rest! I can't thank you enough for that.
The flash drive has seen its last day!
Your very welcome Mikelo and if you encounter any problems in future (and I hope you don't) then please don't hesitate to post again.. :)
Top Bottom
