BSOD on newly built computer
Shing
Hi, i have gotten blue screen of death twice already. Both happened when i was playing mabinogi(a MMORPG which eats a lot of cpu) and watching youtube. I was just wondering if the cause of BSOD is because of computer overheating?
Problem signature:
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF88004363D3B
BCP3: FFFFF88008584AA0
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\020611-15241-01.dmp
C:\Users\Shing\AppData\Local\Temp\WER-20576-0.sysdata.xml
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
0x3B_dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction
Update drivers:
Realtek Lan
Rt64win7.sys Thu Feb 26 04:04:13 2009
ATI
atikmdag.sys Fri Apr 24 06:51:57 2009
If crashes persist after the updates, uninstall 360.cn and replace it with MSE:
https://www.microsoft.com/security_essentials/
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020211-21902-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`0280d000 PsLoadedModuleList = 0xfffff800`02a4ae50
Debug session time: Wed Feb  2 13:00:36.885 2011 (UTC - 5:00)
System Uptime: 0 days 1:24:46.976
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 3B, {c0000005, fffff8000292b8b8, fffff8800820df30, 0}
Probably caused by : memory_corruption ( nt!MiUnlinkPageFromBadList+38 )
Followup: MachineOwner
2: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8000292b8b8, Address of the instruction which caused the bugcheck
Arg3: fffff8800820df30, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`0292b8b8 488914c1        mov     qword ptr [rcx+rax*8],rdx
CONTEXT:  fffff8800820df30 -- (.cxr 0xfffff8800820df30)
rax=ffffdf00001abb60 rbx=fffffa80006b34c0 rcx=fffffa8000000008
rdx=0000000000000000 rsi=fffffa80006b34c0 rdi=fffff800029f5c50
rip=fffff8000292b8b8 rsp=fffff8800820e910 rbp=8000000023bc4880
 r8=fffff8800820e930  r9=0000000000000000 r10=fffff80002ab7840
r11=fffffa8000047490 r12=0000000000000000 r13=fffff8a007f889d0
r14=fffffa8000b06490 r15=0000000000000000
iopl=0         nv up ei ng nz na po cy
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010287
nt!MiUnlinkPageFromBadList+0x38:
fffff800`0292b8b8 488914c1        mov     qword ptr [rcx+rax*8],rdx ds:002b:fffef280`00d5db08=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  chrome.exe
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff8000292b8b8
STACK_TEXT:
fffff880`0820e910 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiUnlinkPageFromBadList+0x38
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!MiUnlinkPageFromBadList+38
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc600
STACK_COMMAND:  .cxr 0xfffff8800820df30 ; kb
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x3B_nt!MiUnlinkPageFromBadList+38
Loading Dump File [F:\a\Minidump\D M P\DMP\020611-15241-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0280b000 PsLoadedModuleList = 0xfffff800`02a48e50
Debug session time: Sun Feb  6 00:14:11.987 2011 (UTC - 5:00)
System Uptime: 0 days 1:34:09.078
BugCheck 3B, {c0000005, fffff88004363d3b, fffff88008584aa0, 0}
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction+c3 )
3: kd> !analyze -v
Arguments:
Arg2: fffff88004363d3b, Address of the instruction which caused the bugcheck
Arg3: fffff88008584aa0, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff880`04363d3b 488b01          mov     rax,qword ptr [rcx]
CONTEXT:  fffff88008584aa0 -- (.cxr 0xfffff88008584aa0)
rax=ffffffffffffffe0 rbx=fffff8a002faaa00 rcx=0000000000000000
rdx=0000000000000000 rsi=fffff8a0031b1a60 rdi=fffffa8005c25ea0
rip=fffff88004363d3b rsp=fffff88008585480 rbp=fffffa80057a5820
 r8=fffff880085854e8  r9=fffff880085854f0 r10=0000000000000000
r11=fffffa80057a5860 r12=0000000000000000 r13=fffff8a002faa9e0
r14=0000000000000000 r15=fffff88008585878
iopl=0         nv up ei pl zr na po cy
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010247
dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction+0xc3:
fffff880`04363d3b 488b01          mov     rax,qword ptr [rcx] ds:002b:00000000`00000000=????????????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  Client.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff88004363d3b
STACK_TEXT:
fffff880`08585480 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction+0xc3
FOLLOWUP_IP:
SYMBOL_NAME:  dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction+c3
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc578
STACK_COMMAND:  .cxr 0xfffff88008584aa0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgmms1!VIDMM_SEGMENT::MarkResourcesForEviction+c3
Drivers:
fffff880`00f9e000 fffff880`00ff5000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03ece000 fffff880`03f58000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`043ba000 fffff880`043d0000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`041be000 fffff880`041d3000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0111d000 fffff880`01128000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00cda000 fffff880`00ce3000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00d7c000 fffff880`00da6000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0483c000 fffff880`04d5e000   atikmdag atikmdag.sys Fri Apr 24 06:51:57 2009 (49F199CD)
fffff880`04169000 fffff880`04198000   BAPIDRV64 BAPIDRV64.SYS Wed Sep 01 21:29:57 2010 (4C7EFE15)
fffff880`019c8000 fffff880`019cf000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04158000 fffff880`04169000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02800000 fffff880`0281e000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006d0000 fffff960`006f7000   cdd      cdd.dll      Mon Jul 13 21:25:40 2009 (4A5BDE94)
fffff880`01995000 fffff880`019bf000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0190f000 fffff880`0193f000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d1e000 fffff880`00d7c000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`043aa000 fffff880`043ba000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03b12000 fffff880`03b1b000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`04dd2000 fffff880`04de0000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`040b7000 fffff880`0413a000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`0413a000 fffff880`04158000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03ff1000 fffff880`04000000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`018f9000 fffff880`0190f000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`045c5000 fffff880`045e7000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`0445d000 fffff880`04467000   dump_diskdump dump_diskdump.sys Mon Jul 13 20:01:00 2009 (4A5BCABC)
fffff880`04de0000 fffff880`04df3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04800000 fffff880`0482b000   dump_nvstor dump_nvstor.sys Wed May 20 02:45:37 2009 (4A13A711)
fffff880`04df3000 fffff880`04dff000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0423e000 fffff880`04332000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:38:56 2009 (4A5BC590)
fffff880`04332000 fffff880`04378000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`01174000 fffff880`01188000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01128000 fffff880`01174000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013ef000 fffff880`013f9000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018bf000 fffff880`018f9000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`0142b000 fffff880`01475000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04096000 fffff880`040a3000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02de8000 fffff800`02e31000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04072000 fffff880`04096000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0452c000 fffff880`04588000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`0442d000 fffff880`04446000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`04446000 fffff880`0444e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0441f000 fffff880`0442d000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0291f000 fffff880`029e7000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`018b6000 fffff880`018bf000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04db4000 fffff880`04dc3000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0444f000 fffff880`0445d000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba7000 fffff800`00bb1000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04468000 fffff880`044ab000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`013c4000 fffff880`013de000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:50:34 2009 (4A5BC84A)
fffff880`045e7000 fffff880`045ec200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`01091000 fffff880`010a6000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0193f000 fffff880`01962000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cfd000 fffff880`00d0a000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`0482b000 fffff880`04839000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04dc3000 fffff880`04dd2000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`045ed000 fffff880`045fa000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0281e000 fffff880`02836000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02836000 fffff880`02862000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`03aa2000 fffff880`03aef000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`03aef000 fffff880`03b12000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`01809000 fffff880`01814000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e0a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01188000 fffff880`011e6000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03ec3000 fffff880`03ece000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`018a4000 fffff880`018b6000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01485000 fffff880`01577000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`043f4000 fffff880`04400000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`028f4000 fffff880`02907000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04200000 fffff880`0422f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04517000 fffff880`0452c000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03fe2000 fffff880`03ff1000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03f58000 fffff880`03f9d000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01577000 fffff880`015d7000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01200000 fffff880`01211000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03eb7000 fffff880`03ec3000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0280b000 fffff800`02de8000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`01221000 fffff880`013c4000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019bf000 fffff880`019c8000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`00da6000 fffff880`00dd1000   nvstor   nvstor.sys   Wed May 20 02:45:37 2009 (4A13A711)
fffff880`028a1000 fffff880`028f4000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03fa6000 fffff880`03fcc000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`041df000 fffff880`041fc000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00e4a000 fffff880`00e5f000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e0a000 fffff880`00e3d000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ed0000 fffff880`00ed7000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00ed7000 fffff880`00ee7000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013de000 fffff880`013ef000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03b1b000 fffff880`03bc1000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04588000 fffff880`045c5000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d0a000 fffff880`00d1e000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03e9d000 fffff880`03eb7000   qutmdrv  qutmdrv.sys  Thu Apr 15 03:18:03 2010 (4BC6BDAB)
fffff880`043d0000 fffff880`043f4000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04d5e000 fffff880`04d79000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04d79000 fffff880`04d9a000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04d9a000 fffff880`04db4000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e4c000 fffff880`03e9d000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0422f000 fffff880`0423a000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`019ed000 fffff880`019f6000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019f6000 fffff880`019ff000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01800000 fffff880`01809000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0186a000 fffff880`018a4000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02907000 fffff880`0291f000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04378000 fffff880`043aa000   Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`03bc1000 fffff880`03bcc000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`041d3000 fffff880`041df000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03e00000 fffff880`03e1d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01862000 fffff880`0186a000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06acf000 fffff880`06b67000   srv      srv.sys      Mon Jul 13 19:25:11 2009 (4A5BC257)
fffff880`03a12000 fffff880`03a7b000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`03bcc000 fffff880`03bf9000   srvnet   srvnet.sys   Mon Jul 13 19:24:58 2009 (4A5BC24A)
fffff880`010bb000 fffff880`0111d000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`0423a000 fffff880`0423b480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`03a00000 fffff880`03a12000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`01211000 fffff880`0121e000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01073000 fffff880`01091000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03e38000 fffff880`03e4c000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00430000 fffff960`0043a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04198000 fffff880`041be000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`044ab000 fffff880`044bd000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`04400000 fffff880`0441d000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0441d000 fffff880`0441ef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04061000 fffff880`04072000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`044bd000 fffff880`04517000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04000000 fffff880`0400b000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0400b000 fffff880`04061000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00e3d000 fffff880`00e4a000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019cf000 fffff880`019dd000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`015d7000 fffff880`015fc000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01475000 fffff880`01485000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e5f000 fffff880`00e74000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e74000 fffff880`00ed0000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01816000 fffff880`01862000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03fcc000 fffff880`03fe2000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03e1d000 fffff880`03e38000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019dd000 fffff880`019ed000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eeb000 fffff880`00f8f000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f8f000 fffff880`00f9e000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f9d000 fffff880`03fa6000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000d0000 fffff960`003df000   win32k   win32k.sys   Mon Jul 13 19:40:16 2009 (4A5BC5E0)
fffff880`00ff5000 fffff880`00ffe000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01962000 fffff880`01983000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`06b67000 fffff880`06bd8000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0193f000 fffff880`0194d000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0194d000 fffff880`01957000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01957000 fffff880`01982000   dump_nvstor.
    Checksum:  00000000
    ImageSize:  0002B000
fffff880`01982000 fffff880`01995000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
