Loading Dump File [F:\DMP\041711-18532-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00ba2730?
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`03014000 PsLoadedModuleList = 0xfffff800`03251e50
Debug session time: Sun Apr 17 07:34:58.042 2011 (UTC - 4:00)
System Uptime: 0 days 0:43:58.995
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 9F, {3, fffffa800784c050, fffff80000ba2748, fffffa800730c910}
*** WARNING: Unable to verify timestamp for mv91xx.sys
*** ERROR: Module load completed but symbols could not be loaded for mv91xx.sys
Probably caused by : mv91xx.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa800784c050, Physical Device Object of the stack
Arg3: fffff80000ba2748, Functional Device Object of the stack
Arg4: fffffa800730c910, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: mv91xx.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ca5550b
MODULE_NAME: mv91xx
FAULTING_MODULE: fffff88001048000 mv91xx
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x9F
PROCESS_NAME: hon.exe
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`00ba26f8 fffff800`030f3273 : 00000000`0000009f 00000000`00000003 fffffa80`0784c050 fffff800`00ba2748 : nt!KeBugCheckEx
fffff800`00ba2700 fffff800`0309029e : fffff800`00ba2830 fffff800`00ba2830 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00ba27a0 fffff800`0308fdd6 : fffff800`03234700 00000000`000294cd 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00ba2810 fffff800`030904be : 00000006`24f6af7c fffff800`00ba2e88 00000000`000294cd fffff800`03202c28 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00ba2e60 fffff800`0308fcb7 : fffff800`031feec1 fffffa80`000294cd fffffa80`0783a060 00000000`000000cd : nt!KiTimerExpiration+0x1be
fffff800`00ba2f00 fffff800`0308a865 : 00000000`00000000 fffffa80`08d8c060 00000000`00000000 fffff880`010da4c0 : nt!KiRetireDpcList+0x277
fffff800`00ba2fb0 fffff800`0308a67c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
fffff880`0e2b9ba0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0x9F_3_disk_IMAGE_mv91xx.sys
Loading Dump File [F:\DMP\042411-19141-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c4c0?
Machine Name:
Kernel base = 0xfffff800`03000000 PsLoadedModuleList = 0xfffff800`0323de50
Debug session time: Sun Apr 24 07:34:59.589 2011 (UTC - 4:00)
System Uptime: 0 days 9:01:58.542
BugCheck 9F, {3, fffffa8007833050, fffff80000b9c4d8, fffffa8008d64010}
0: kd> !analyze -v
Arguments:
Arg2: fffffa8007833050, Physical Device Object of the stack
Arg3: fffff80000b9c4d8, Functional Device Object of the stack
Arg4: fffffa8008d64010, The blocked IRP
Debugging Details:
MODULE_NAME: mv91xx
FAULTING_MODULE: fffff88001019000 mv91xx
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`00b9c488 fffff800`030df273 : 00000000`0000009f 00000000`00000003 fffffa80`07833050 fffff800`00b9c4d8 : nt!KeBugCheckEx
fffff800`00b9c490 fffff800`0307c29e : fffff800`00b9c5c0 fffff800`00b9c5c0 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00b9c530 fffff800`0307bdd6 : fffffa80`06da45f8 fffffa80`06da45f8 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5a0 fffff800`0307c4be : 0000004b`b68fd911 fffff800`00b9cc18 00000000`001fce9c fffff800`031ee608 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cbf0 fffff800`0307bcb7 : 00000019`151471c2 00000019`001fce9c 00000019`15147142 00000000`0000009c : nt!KiTimerExpiration+0x1be
fffff800`00b9cc90 fffff800`03078eea : fffff800`031eae80 fffff800`031f8c40 00000000`00000001 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cd40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
