MarkusRuckus
I am working on a new build. View attachment Seven Forums.zip I was able to get windows 7 hp 64bit sp1 installed with most updates installed. I am testing the functionality of all aspects of this system to verify stability and confirm all components are working properly. Currently, the on board audio isn't working and every time that I run windows system rating, this rig BSODs. I had the same issue with an aftermarket vid card installed, so I removed it, now using the onboard video and I am still getting the same BSOD issue. I tried running passmark BurnIn test and have found that I can run all the tests fine EXCEPT for the 3D test... it always BSODs. please help... do I have a bad motherboard? I'm wondering if its a bad North/southbridge chip. Thanks.
