Windows 7 BSOD out of nowhere
Master64
So, this BSOD appeared just a couple of minutes ago, it's the first time it happens on this computer, the only weird thing that happened before it came out was a Windows message that said "USB port not recognized" or something like, and I wasn't able to use my External Hard Drive, which of course is connected via USB, I can use it now though.
I want to know if that USB error caused the BSOD or if was another reason.
Thanks =)Link Removed
Hi Master64.
STOP 0x0000007E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Usual causes: Insufficient disk space, Device driver, Video card, BIOS, Breakpoint with no debugger attached, Hardware incompatibility, Faulty system service, Memory, 3rd party remote control.
Your dump file lists PCTSD64.sys as the probable cause. This is part of PCTools.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes often indicate hardware issues.
As a Priority:
PC Tools is known to be a cause of BSOD's on many Windows 7 systems. Uninstall PC Tools, including ThreatFire. Download Link Removed due to 404 Error as its replacement. Make sure your Windows...
Hi Master64.
As a Priority:
PC Tools is known to be a cause of BSOD's on many Windows 7 systems. Uninstall PC Tools, including ThreatFire. Download Link Removed due to 404 Error as its replacement. Make sure your Windows firewall is switched on!
Outdated Drivers. Update:
RTKVHD64.sys Fri May 22 19:04:20 2009 Link Removed
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also loads with iTunes
k57nd60a.sys Sat Jun 20 12:34:49 2009 Broadcom Ethernet
LHidFilt.Sys Wed Jun 17 17:49:39 2009
LMouFilt.Sys Wed Jun 17 17:49:43 2009 Link Removed
t3.sys Wed May 06 03:25:42 2009 Sound Blaster X-Fi Xtreme Audio.
Bugcheck Analysis:
BugCheck 1000007E, {ffffffffc0000005, fffff80002e1f41d, fffff8800637f7a8, fffff8800637f000}
Unable to load image \SystemRoot\System32\Drivers\PCTSD64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for PCTSD64.sys
*** ERROR: Module load completed but symbols could not be loaded for PCTSD64.sys
Probably caused by : PCTSD64.sys ( PCTSD64+3fede )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002e1f41d, The address that the exception occurred at
Arg3: fffff8800637f7a8, Exception Record Address
Arg4: fffff8800637f000, Context Record Address
Debugging Details:
FAULTING_IP:
nt!RtlRealSuccessor+39
fffff800`02e1f41d 488b4908        mov     rcx,qword ptr [rcx+8]
EXCEPTION_RECORD:  fffff8800637f7a8 -- (.exr 0xfffff8800637f7a8)
ExceptionAddress: fffff80002e1f41d (nt!RtlRealSuccessor+0x0000000000000039)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000460009
Attempt to read from address 0000000000460009
CONTEXT:  fffff8800637f000 -- (.cxr 0xfffff8800637f000)
rax=0000000000460001 rbx=fffff8a00b2879c0 rcx=0000000000460001
rdx=fffff8800637fa70 rsi=0000000000000238 rdi=fffff880012aa148
rip=fffff80002e1f41d rsp=fffff8800637f9e8 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000000 r10=fffff8800637fa70
r11=fffff8800637fa00 r12=fffff8a004c06e08 r13=fffff880012a8000
r14=fffff8a0188c8030 r15=fffffa800b74c070
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!RtlRealSuccessor+0x39:
fffff800`02e1f41d 488b4908        mov     rcx,qword ptr [rcx+8] ds:002b:00000000`00460009=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000460009
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030af100
 0000000000460009
FOLLOWUP_IP:
PCTSD64+3fede
fffff880`012bcede ??              ???
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff80002f1088f to fffff80002e1f41d
STACK_TEXT:
fffff880`0637f9e8 fffff800`02f1088f : fffff8a0`0345e6e8 00000000`00000238 fffff8a0`04c06e08 fffff880`012aa148 : nt!RtlRealSuccessor+0x39
fffff880`0637f9f0 fffff880`012bcede : fffff8a0`0b2879c0 fffff8a0`04c06e30 00000000`00000000 00000000`000007ff : nt!RtlEnumerateGenericTableWithoutSplaying+0x3f
fffff880`0637fa20 fffff8a0`0b2879c0 : fffff8a0`04c06e30 00000000`00000000 00000000`000007ff ffffffff`80001598 : PCTSD64+0x3fede
fffff880`0637fa28 fffff8a0`04c06e30 : 00000000`00000000 00000000`000007ff ffffffff`80001598 00000000`00000000 : 0xfffff8a0`0b2879c0
fffff880`0637fa30 00000000`00000000 : 00000000`000007ff ffffffff`80001598 00000000`00000000 fffff880`0637fa68 : 0xfffff8a0`04c06e30
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  PCTSD64+3fede
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: PCTSD64
IMAGE_NAME:  PCTSD64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d77fdcc
STACK_COMMAND:  .cxr 0xfffff8800637f000 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_PCTSD64+3fede
Drivers:
fffff880`02ef1000 fffff880`02f2f000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f92000 fffff880`00fe9000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03e38000 fffff880`03ec1000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04a00000 fffff880`04a16000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`01106000 fffff880`01111000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00ec7000 fffff880`00ed0000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`010dc000 fffff880`01106000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`04a45000 fffff880`04bc2000   athrx    athrx.sys    Sat Oct 24 02:49:44 2009 (4AE25D38)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`01846000 fffff880`0184d000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`01400000 fffff880`01411000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05d42000 fffff880`05d60000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00760000 fffff960`00787000   cdd      cdd.dll      unavailable (00000000)
fffff880`0518c000 fffff880`051a9000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`01813000 fffff880`0183d000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00ed2000 fffff880`00f92000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01b9c000 fffff880`01bcc000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cf7000 fffff880`00d55000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01349000 fffff880`013bb000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`04bdc000 fffff880`04bec000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`01800000 fffff880`0180e000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03e0f000 fffff880`03e2d000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03e00000 fffff880`03e0f000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01b86000 fffff880`01b9c000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`050cb000 fffff880`050ed000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04a3a000 fffff880`04a43000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`015f3000 fffff880`015ff000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`048a3000 fffff880`048b6000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05400000 fffff880`0540c000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0fed6000 fffff880`0ffca000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0f200000 fffff880`0f246000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`05c24000 fffff880`05c5a000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`01111000 fffff880`01125000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00d55000 fffff880`00da1000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`015e9000 fffff880`015f3000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01b4c000 fffff880`01b86000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a59000 fffff880`01aa3000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`04bcf000 fffff880`04bdc000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`033e9000 fffff800`03432000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0ffca000 fffff880`0ffee000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`051e2000 fffff880`051fb000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05000000 fffff880`05008080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`051d4000 fffff880`051e2000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05c79000 fffff880`05d42000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01b43000 fffff880`01b4c000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`02e85000 fffff880`02e9b000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`02f2f000 fffff880`02f80000   k57nd60a k57nd60a.sys Sat Jun 20 12:34:49 2009 (4A3CC959)
fffff880`0ffee000 fffff880`0fffd000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05016000 fffff880`05024000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bca000 fffff800`00bd4000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`02e00000 fffff880`02e43000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015bd000 fffff880`015d8000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`055f8000 fffff880`055fd200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`048b6000 fffff880`048c9000   LHidFilt LHidFilt.Sys Wed Jun 17 17:49:39 2009 (4A391EA3)
fffff880`048dd000 fffff880`048f2000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`048c9000 fffff880`048dd000   LMouFilt LMouFilt.Sys Wed Jun 17 17:49:43 2009 (4A391EA7)
fffff880`01bcc000 fffff880`01bef000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c94000 fffff880`00ce3000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`051a9000 fffff880`051b7000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`02fea000 fffff880`02ff9000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05009000 fffff880`05016000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00c6c000 fffff880`00c86000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`05d60000 fffff880`05d78000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05d78000 fffff880`05da5000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`05da5000 fffff880`05df3000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`05c00000 fffff880`05c24000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`0167b000 fffff880`01686000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00ff2000 fffff880`00ffc000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`012eb000 fffff880`01349000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03ff1000 fffff880`03ffc000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01b31000 fffff880`01b43000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`016ab000 fffff880`0179e000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`04bec000 fffff880`04bf8000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04945000 fffff880`04958000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`02f80000 fffff880`02faf000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`050b6000 fffff880`050cb000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03f56000 fffff880`03f65000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03ec1000 fffff880`03f06000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0179e000 fffff880`017fe000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01686000 fffff880`01697000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03fe5000 fffff880`03ff1000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e00000 fffff800`033e9000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`0141a000 fffff880`015bd000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0183d000 fffff880`01846000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0fed4000 fffff880`0fed5180   nvBridge nvBridge.kmd Sat Jan 08 01:57:22 2011 (4D27C482)
fffff880`0f279000 fffff880`0fed3d00   nvlddmkm nvlddmkm.sys Sat Jan 08 02:07:22 2011 (4D27C6DA)
fffff880`048f2000 fffff880`04945000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03f1a000 fffff880`03f40000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00dd4000 fffff880`00de9000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00da1000 fffff880`00dd4000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00ec0000 fffff880`00ec7000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01125000 fffff880`0116d000   PCTCore64 PCTCore64.sys Wed May 11 00:48:58 2011 (4DC9CEEA)
fffff880`0116d000 fffff880`011de000   pctDS64  pctDS64.sys  Fri Jun 04 03:06:38 2010 (4C085FAE)
fffff880`01000000 fffff880`010cc000   pctEFA64 pctEFA64.sys Fri Jul 16 05:45:25 2010 (4C3FE3E5)
fffff880`01200000 fffff880`01257000   pctgntdi64 pctgntdi64.sys Thu May 05 01:14:53 2011 (4DC1EBFD)
fffff880`067de000 fffff880`067f7000   pctplsg64 pctplsg64.sys Thu May 05 01:17:45 2011 (4DC1ECA9)
fffff880`0127d000 fffff880`012c4000   PCTSD64  PCTSD64.sys  Wed Mar 09 22:23:08 2011 (4D77FDCC)
fffff880`01257000 fffff880`0127d000   PctWfpFilter64 PctWfpFilter64.sys Wed May 11 21:19:15 2011 (4DCAEF43)
fffff880`015d8000 fffff880`015e9000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`066dc000 fffff880`06782000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`055bb000 fffff880`055f8000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00ce3000 fffff880`00cf7000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`012df000 fffff880`012eae00   PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`04a16000 fffff880`04a3a000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0f257000 fffff880`0f272000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`02faf000 fffff880`02fd0000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`02fd0000 fffff880`02fea000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03f94000 fffff880`03fe5000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01660000 fffff880`01669000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01669000 fffff880`01672000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01672000 fffff880`0167b000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01af7000 fffff880`01b31000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`04958000 fffff880`04970000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0540e000 fffff880`055ba900   RTKVHD64 RTKVHD64.sys Fri May 22 19:04:20 2009 (4A16E924)
fffff880`06782000 fffff880`0678d000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01aef000 fffff880`01af7000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`04800000 fffff880`04898000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06600000 fffff880`06669000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0678d000 fffff880`067be000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04bf8000 fffff880`04bf9480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`050ed000 fffff880`0518c000   t3       t3.sys       Wed May 06 03:25:42 2009 (4A00F526)
fffff880`01855000 fffff880`01a59000   tcpip    tcpip.sys    Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`067be000 fffff880`067d0000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01697000 fffff880`016a4000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`013bb000 fffff880`013dd000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03f80000 fffff880`03f94000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`012cb000 fffff880`012df000   TfFsMon  TfFsMon.sys  Tue Jan 18 22:05:44 2011 (4D360EB8)
fffff880`067d0000 fffff880`067de000   TfNetMon TfNetMon.sys Tue Jan 18 22:05:52 2011 (4D360EC0)
fffff880`011de000 fffff880`011f3000   TfSysMon TfSysMon.sys Tue Jan 18 22:05:48 2011 (4D360EBC)
fffff960`005a0000 fffff960`005aa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02e5f000 fffff880`02e85000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`02e43000 fffff880`02e55000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`066b3000 fffff880`066c4000   usbaapl64 usbaapl64.sys Thu Apr 28 19:25:59 2011 (4DB9B137)
fffff880`0503f000 fffff880`05059c80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`051b7000 fffff880`051d4000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0540c000 fffff880`0540df00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`0f246000 fffff880`0f257000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`0505c000 fffff880`050b6000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`02e9b000 fffff880`02ef1000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`05024000 fffff880`0503f000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`00eb3000 fffff880`00ec0000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01bef000 fffff880`01bfd000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0162b000 fffff880`01650000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00de9000 fffff880`00dfe000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01aa3000 fffff880`01aef000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`04bc2000 fffff880`04bcf000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03f40000 fffff880`03f56000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`03f65000 fffff880`03f80000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01650000 fffff880`01660000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03f11000 fffff880`03f1a000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00313000   win32k   win32k.sys   unavailable (00000000)
fffff880`066c4000 fffff880`066d5000   WinUsb   WinUsb.sys   Sat Nov 20 10:43:56 2010 (4CE7A66C)
fffff880`00fe9000 fffff880`00ff2000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`03f06000 fffff880`03f11000   ws2ifsl  ws2ifsl.sys  Tue Jul 14 01:10:33 2009 (4A5BCCF9)
fffff880`013dd000 fffff880`013fe000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`06682000 fffff880`066b3000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`06669000 fffff880`06682000   pctplsg64.sy
    Checksum:  00000000
    ImageSize:  00019000
fffff880`04970000 fffff880`049e1000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01bcc000 fffff880`01bda000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bda000 fffff880`01be6000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01be6000 fffff880`01bef000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01800000 fffff880`01813000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
