Windows 7 BSOD Please help
David Ayala
My computer is turned on five minutes and I get the BSOD :mad: Page_fault_in_nonpaged
_Area 0x50.
The specs:
Motherboard: DZ77sl-50k
Cpu: Intel core i5 3470
Ram: Single ddr3 8GB in slot #2
Video: Nvidia GF GTX 550ti 1gb
View attachment W7F_DMP_CPUIZ.rar
Please help thanks.
usasma
Fantastic Member
Please be advised, there's enough different errors here that I have to wonder about this installation. Should this be a pirated copy of Windows, please be aware that we may not be able to fix it (as the hacks that were done to activate it will cause the OS to behave differently than we expect it to). If that's the case, our efforts to help may just waste your time. Secondly, the forum rules prohibit assisting with pirated software - so the topic would be closed if that is the case.
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
These devices have problems:
Controladora simple de comunicaciones PCI PCI\VEN_8086&DEV_1E3A&SUBSYS_20308086&REV_04\3&11583659&0&B0 Los controladores de este dispositivo no están instalados.
epfwwfpr ROOT\LEGACY_EPFWWFPR\0000 Este dispositivo no está presente, no funciona correctamente o no tiene todos sus controladores instalados.
The first one is most likely the Intel(R) Management Engine Interface - please install the latest version on your system
The epfwwfpr driver is likely a part of your ESET Personal Firewall. Please uninstall this software, reboot the system, then install a fresh copy of the latest available Win7 version.
You have both ESET and the Microsoft Security Client. Only have 1 anti-virus and 1 firewall running at any one time (this includes the Windows Firewall).
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sun Apr 21 05:06:42.841 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042113-19812-01.dmp]
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
[B][COLOR=RED]Missing Windows 7 Service Pack 1[/COLOR][/B]
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:03:39.339[/B]
Probably caused by :[B]memory_corruption ( nt!MiCompressRelocations+70 )[/B]
BugCheck [B]50, {fffff8a002df6000, 0, fffff80003348079, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff8a002df6000, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80003348079, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  explorer.exe
FAILURE_BUCKET_ID: [B]X64_0x50_nt!MiCompressRelocations+70[/B]
CPUID:        "Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz"
MaxSpeed:     3200
CurrentSpeed: [B]3192[/B]
  BIOS Version                  SLZ7710H.86A.0055.2012.0319.2140
  BIOS Release Date             03/19/2012
  Manufacturer
  Product Name
**************************Sun Apr 21 04:50:44.323 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042113-12854-01.dmp]
System Uptime:[B]0 days 0:06:09.821[/B]
BugCheck [B]50, {fffff8a007df6000, 0, fffff80003181079, 0}[/B]
Arguments:
Arg1: fffff8a007df6000, memory referenced.
Arg3: fffff80003181079, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
PROCESS_NAME:  svchost.exe
MaxSpeed:     3200
  Manufacturer
  Product Name
**************************Sun Apr 21 04:43:39.305 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042113-14804-01.dmp]
System Uptime:[B]0 days 0:06:04.803[/B]
BugCheck [B]50, {fffff8a009f66000, 0, fffff80003190079, 0}[/B]
Arguments:
Arg1: fffff8a009f66000, memory referenced.
Arg3: fffff80003190079, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
MaxSpeed:     3200
  Manufacturer
  Product Name
**************************Sun Apr 21 04:09:47.619 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042113-12558-01.dmp]
System Uptime:[B]0 days 0:06:05.117[/B]
BugCheck [B]50, {fffff8a003166000, 0, fffff8000313e079, 0}[/B]
Arguments:
Arg1: fffff8a003166000, memory referenced.
Arg3: fffff8000313e079, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
MaxSpeed:     3200
  Manufacturer
  Product Name
[/font]
3rd Party Drivers:
[COLOR=RED][B]amdxata.sys                 Tue May 19 13:56:59 2009 (4A12F2EB)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
Epfwndis.sys                Wed Jul 14 04:10:31 2010 (4C3D70F7)
epfwwfp.sys                 Wed Jul 14 04:10:34 2010 (4C3D70FA)
epfw.sys                    Wed Jul 14 04:10:34 2010 (4C3D70FA)
eamonm.sys                  Wed Jul 14 04:13:43 2010 (4C3D71B7)
ehdrv.sys                   Wed Jul 14 04:14:21 2010 (4C3D71DD)
[COLOR=RED][B]sptd.sys                    Mon Nov  8 19:25:33 2010 (4CD894FD)[/B][/COLOR]
RTKVHD64.sys                Tue Dec 13 05:24:54 2011 (4EE727F6)
e1c62x64.sys                Wed Jan 11 15:30:54 2012 (4F0DF17E)
iusb3hub.sys                Fri Jan 27 04:35:25 2012 (4F226FDD)
iusb3xhc.sys                Fri Jan 27 04:35:28 2012 (4F226FE0)
iusb3hcs.sys                Fri Jan 27 04:37:23 2012 (4F227053)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
nvlddmkm.sys                Thu Mar 14 21:37:00 2013 (51427B3C)
[/font]
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=Epfwndis.sys
http://www.carrona.org/drivers/driver.php?id=epfwwfp.sys
http://www.carrona.org/drivers/driver.php?id=epfw.sys
http://www.carrona.org/drivers/driver.php?id=eamonm.sys
http://www.carrona.org/drivers/driver.php?id=ehdrv.sys
http://www.carrona.org/drivers/driver.php?id=sptd.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
Top Bottom
