Jasperrr
After opening some corrupt software two nights ago, my task manager got disabled and my computer started to lock up. I immediately rebooted in Safe Mode and ran HijackThis to remove any suspicious startup programs.
After doing this, I rebooted into windows and logged in. However, shortly after logging in I received an IRQL_NOT_LESS_OR_EQUAL BSOD, I then rebooted into safe mode and once again got the BSOD. I then decided to remove one of my two RAM sticks but I still got the error, same thing happened when I tried using only the second RAM stick.
I then decided to boot into repair mode and ran the hardware test which gave me no errors. Afterwards I logged in to windows again and this time I received a SYSTEM_SERVICE_EXCEPTION BSOD instead of the IRQL error. I decided to once again try safe mode and this time it worked and I was able to acces the dmp files.
However, as we speak. My computer has broke down again thus I cannot attach any CPU-Z screenshots atm. I did attach my collection of dumpfiles.
View attachment minidumps.zip
Hello and Welcome !
Seems like your Marvell Yukon Ethernet Controller i.e. yk62x64.sys is casung the crash. See if you could uninstall it completely and reboot the System download a fresh version Marvell: Support rest follow Trouble's excellent suggestions.
Bugcheck:
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa80047b4060, Physical Device Object of the stack
Arg3: fffff8000453c4d8, Functional Device Object of the stack
Arg4: fffffa8004f81990, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IRP_ADDRESS:  fffffa8004f81990...
Not exactly sure what your options might be if you can't even boot any longer even in safemode but your most recent dump files indicate that the problem is with ataport.sys which is probably being cause by the presence of Daemon Tools and it's driver sptd.sys. You would probably need to start there by uninstalling Daemon Tools and it's driver Link Removed
Additionally there are a couple old drivers
hardlock.sys 11/20/2006
and
aksdf.sys 12/13/2006
both associated with a Software Product called Alladin Knowledge Systems you may want to consider removing that as well.
Also uninstall LogMeIn for the time being
And see if Logitech has any updates for your mouse and keyboard
L8042Kbd.sys and LMouFilt.sys both dated 6/17/2009, they may have something more current, if not don' worry about it for now.
Hello and Welcome !
Bugcheck:
Arguments:
Debugging Details:
DEVICE_OBJECT: fffffa8004f0f050
DRIVER_OBJECT: fffffa8004ecb2e0
IMAGE_NAME:  yk62x64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  49a2ba83
MODULE_NAME: yk62x64
FAULTING_MODULE: fffff88004f92000 yk62x64
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002f3fe23 to fffff80002ed0f00
STACK_TEXT:
fffff800`0453c488 fffff800`02f3fe23 : 00000000`0000009f 00000000`00000003 fffffa80`047b4060 fffff800`0453c4d8 : nt!KeBugCheckEx
fffff800`0453c490 fffff800`02edcfa6 : fffff800`0453c620 fffff800`0453c620 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x29330
fffff800`0453c530 fffff800`02edc326 : fffffa80`05834200 fffffa80`05834200 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`0453c5a0 fffff800`02edce7e : 000006bd`a6f2870a fffff800`0453cc18 00000000`02d4f23c fffff800`0304ca08 : nt!KiProcessExpiredTimerList+0xc6
fffff800`0453cbf0 fffff800`02edc697 : 000001fa`7bde2ec6 000001fa`02d4f23c 000001fa`7bde2e00 00000000`0000003c : nt!KiTimerExpiration+0x1be
fffff800`0453cc90 fffff800`02ed96fa : fffff800`03049e80 fffff800`03057c40 00000000`00000000 fffffa80`039af0a0 : nt!KiRetireDpcList+0x277
fffff800`0453cd40 00000000`00000000 : fffff800`0453d000 fffff800`04537000 fffff800`0453cd00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_IMAGE_yk62x64.sys
Followup: MachineOwner
