Windows 7 BSOD problem help
Erniuxas
[lang=lt]Sveiki, pas manę tokia pat problema laptopas acer aspire 5739g windows 7 ultimate. kas diena mėto BSOD, nezinau kas čia per problema. štai keli paskutiniai minidump failiukai.
<a href='http://www.sendspace.com/file/x59d4v'>http://www.sendspace.com/file/x59d4v</a>
Download 110910-20451-01.dmp
Download 110910-20576-01.dmp
iš anksto didelis ACIU už pagalbą.[/lang]
Hey there, I've moved your post to its own thread because it needs to be dealt independently from other problems.
Your issue is with the Intel network driver:
1: kd> lmvm NETw5s64
fffff880`040b8000 fffff880`04765000   NETw5s64 T (no symbols)
    Loaded symbol image file: NETw5s64.sys
    Image path: \SystemRoot\system32\DRIVERS\NETw5s64.sys
    Image name: NETw5s64.sys
    Timestamp:        Tue Sep 15 15:40:39 2009 (4AAFEDB7)
    CheckSum:         006A6E93
    ImageSize:        006AD000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
Visit Acer's site and install the update to it from there. While there, update all available drivers shown.
Then uninstall notorious Daemon Tools. After, use the installer/uninstaller found here to remove sptd.sys. Do not update instead:
DuplexSecure - Downloads
Reboot.
