BSOD Problem here...
My PC is scheduled to shutdown every morning at 7:30 am (2 am - 8 am unmetered broadband). Every alternate morning on even dates ...18,20,22,24
th I get a BSOD instead of shutdown.Im worried.Any help appreciated.Thanx in advance.
Programs running morning:
*bit torrent
*jdownloader
*scheduled (windows scheduler) to shutdown at 7:30 am everyday.
PC config:
*core 2 duo e8400 3GHz
*4GB DDR2 Ram
*DG41RQ Intel Motherboard
*Nvidia 9800GT 1GB
Trouble
Noob Whisperer
Hello and welcome to the forum.
First get rid of Daemon Tools (sptd.sys) use this tool DuplexSecure - Downloads get the correct version for your architecture click "UNINTALL" button.
This looks like a virus to me a99fq47k.SYS 3/28/2011 so unless you know specifically what the driver is for then grab a blank CD and this program Microsoft Standalone System Sweeper Beta | Microsoft Connect download and double click it. It will build you a bootable CD from which you can perform a FULL offline scan of your system independent of the Operating System.
You should probably address the old drivers as well
[TABLE="width: 1165"]
[TR]
[TD]PxHelp20.sys[/TD]
[TD="align: right"]2/2/2007
[/TD]
[TD]Sonic CD/DVD
[/TD]
[/TR]
[TR]
[TD]LHidFilt.Sys[/TD]
[TD="align: right"]9/21/2007
[/TD]
[TD]Logitech http://www.logitech.com/en-us/support-downloads/downloads[/TD]
[/TR]
[TR]
[TD]LMouFilt.Sys[/TD]
[/TD]
[/TR]
[TR]
[TD]LUsbFilt.Sys[/TD]
[/TD]
[/TR]
[TR]
[TD]L8042Kbd.sys[/TD]
[/TD]
[/TR]
[TR]
[TD]FsUsbExDisk.SYS[/TD]
[TD="align: right"]6/10/2008
[/TD]
[TD]Teruten Content Wall or Samsung PC Studio[/TD]
[/TR]
[TR]
[TD]RTKVHDA.sys[/TD]
[TD="align: right"]12/23/2008[/TD]
[TD]RealTek http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false[/TD]
[/TR]
[/TABLE]
If Blue Screens persist then;
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here How to ask for help with a BSOD problem
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area http://windows7forums.com/windows-7...you-filling-your-system-specs.html#post235529 .
Good luck
Randy
Thnx...will try.
WOW....seems to be working...no problems so far...will see for a few more days and post here if any more BSOD occurs. Thanks.;)
Trouble
Noob Whisperer
You're welcome, and thanks for the followup.
Keep us posted, we'll be here.
Regards
Randy
