Ridillz333
- Joined
- Aug 16, 2011
[h=3]Hello,[/h][h=3]I recently put together a new PC and have been having random BSOD problems from the word go. They happen at random times sometimes one every minute for an hour(as many as 50 a day), and sometimes days w/o issue. Its really starting to drive me up the wall. I tried to exhaust all other methods before posting like this, to avoid dumping the problem on someone else, but my patients has run out and the new semester is starting so I need a stable system.
Any help would be appreciated
Cheers.
View attachment Dump.zip
RAMMon v1.0 Build: 1002 built with SysInfo v1.0 Build: 1006
PassMark (R) Software - www.passmark.com[/h]Memory Summary For COREY-PC
Number of Memory Devices: 2 Total Physical Memory: 4072 MB (4096 MB) Total Available Physical Memory: 2889 MB Memory Load: 29%
ItemSlot #1Slot #2Slot #3Slot #4
Cheers.
Ram Type | Not Populated | DDR3 | Not Populated | DDR3 |
Standard Name | DDR3-1333 | DDR3-1333 | ||
Module Name | PC3-10600 | PC3-10600 | ||
Memory Capacity (MB) | 2048 | 2048 | ||
Bus Clockspeed (Mhz) | 666.67 | 666.67 | ||
Jedec Manufacture Name | Corsair | Corsair | ||
Search Amazon.com | Search! | Search! | ||
SPD Revision | 1.0 | 1.0 | ||
Registered | No | No | ||
ECC | No | No | ||
DIMM Slot # | 2 | 4 | ||
Manufactured | Year 2000 | Year 2000 | ||
Module Part # | CMZ4GX3M2A1600C8 | CMZ4GX3M2A1600C8 | ||
Module Revision | 0x0 | 0x0 | ||
Module Serial # | 0x0 | 0x0 | ||
Module Manufacturing Location | 1 | 1 | ||
# of Row Addressing Bits | 14 | 14 | ||
# of Column Addressing Bits | 10 | 10 | ||
# of Banks | 8 | 8 | ||
# of Ranks | 2 | 2 | ||
Device Width in Bits | 8 | 8 | ||
Bus Width in Bits | 64 | 64 | ||
Module Voltage | 1.5V | 1.5V | ||
CAS Latencies Supported | 6 8 9 | 6 8 9 | ||
Timings @ Max Frequency | 9-9-9-24 | 9-9-9-24 | ||
Minimum Clock Cycle Time, tCK (ns) | 1.500 | 1.500 | ||
Minimum CAS Latency Time, tAA (ns) | 13.500 | 13.500 | ||
Minimum RAS to CAS Delay, tRCD (ns) | 13.500 | 13.500 | ||
Minimum Row Precharge Time, tRP (ns) | 13.500 | 13.500 | ||
Minimum Active to Precharge Time, tRAS (ns) | 36.000 | 36.000 | ||
Minimum Row Active to Row Active Delay, tRRD (ns) | 7.500 | 7.500 | ||
Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) | 50.625 | 50.625 | ||
Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) | 110.000 | 110.000 | ||
DDR3 Specific SPD Attributes | ||||
Write Recovery Time, tWR (ns) | 15.000 | 15.000 | ||
Internal Write to Read Command Delay, tWTR (ns) | 7.500 | 7.500 | ||
Internal Read to Precharge Command Delay, tRTP (ns) | 7.500 | 7.500 | ||
Minimum Four Activate Window Delay, tFAW (ns) | 37.500 | 37.500 | ||
RZQ / 6 Supported | Yes | Yes | ||
RZQ / 7 Supported | Yes | Yes | ||
DLL-Off Mode Supported | Yes | Yes | ||
Maximum Operating Temperature (C) | 95 | 95 | ||
Refresh Rate at Extended Operating Temperature Range | 1X | 1X | ||
Auto-self Refresh Supported | No | No | ||
On-die Thermal Sensor Readout Supported | No | No | ||
Partial Array Self Refresh Supported | Yes | Yes | ||
Thermal Sensor Present | No | No | ||
Non-standard SDRAM Type | Standard Monolithic | Standard Monolithic | ||
Module Type | UDIMM | UDIMM | ||
Module Height (mm) | 31 | 31 | ||
Module Thickness (front), (mm) | 2 | 2 | ||
Module Thickness (back), (mm) | 2 | 2 | ||
Module Width (mm) | 133.5 | 133.5 | ||
Reference Raw Card Used | Raw Card B Rev. 0 | Raw Card B Rev. 0 | ||
DRAM Manufacture ID | 0 | 0 | ||
# of DRAM Rows | 0 | 0 | ||
# of Registers | 0 | 0 | ||
Register Manufacturer | ||||
Register Type | ||||
Register Revision | 0 | 0 | ||
XMP Attributes | ||||
XMP Revision | 1.2 | 1.2 | ||
Enthusiast / Certified Profile | ||||
Module voltage | 1.50V | 1.50V | ||
Clock speed (Mhz) | 800.00 | 800.00 | ||
Minimum clock cycle time, tCK (ns) | 1.250 | 1.250 | ||
Supported CAS latencies | 6 8 | 6 8 | ||
Minimum CAS latency time, tAA (ns) | 10.000 | 10.000 | ||
Minimum RAS to CAS delay time, tRCD (ns) | 10.000 | 10.000 | ||
Minimum row precharge time, tRP (ns) | 10.000 | 10.000 | ||
Minimum active to precharge time, tRAS (ns) | 30.000 | 30.000 | ||
Supported timing at highest clock speed | 8-8-8-24 | 8-8-8-24 | ||
Minimum Active to Auto-Refresh Delay, tRC (ns) | 50.625 | 50.625 | ||
Minimum Recovery Delay, tRFC (ns) | 110.000 | 110.000 | ||
Minimum Write Recovery time, tWR (ns) | 15.000 | 15.000 | ||
Minimum Write to Read CMD Delay, tWTR (ns) | 7.500 | 7.500 | ||
Minimum Read to Pre-charge CMD Delay, tRTP (ns) | 7.500 | 7.500 | ||
Maximum Average Periodic Refresh Interval, tREFI (us) | 7.750 | 7.750 | ||
Write to Read CMD Turn-around Time Optimizations | No adjustment | No adjustment | ||
Read to Write CMD Turn-around Time Optimizations | No adjustment | No adjustment | ||
Back 2 Back CMD Turn-around Time Optimizations | No adjustment | No adjustment | ||
System CMD Rate Mode | 2T | 2T |
