Windows 7 BSOD Problem on computer for work...
Mysticmaus
Well-Known Member
Hi!
We have a serious BSOD problem here on a computer here at work >
Anyone that can help us?:frown:
BlueScreen
6.1.7601.2.1.0.256.48
1043
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF80002A88F86
BCP3: FFFFF88007053730
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
C:\Windows\Minidump\051912-16567-01.dmp
C:\Users\Supervisor\AppData\Local\Temp\WER-22058-0.sysdata.xml
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here Link Removed
Do your best to...
Then:
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area Link Removed .
Good luck
Randy
