BSOD Problem on Shutdown or hibernation
I have HP DV7 laptop and until recently no issues but over the last month I have BSOD issues.
DRIVER_POWER_STATE_FAILURE with umbus.sys.
I have attached a copy of the latest dump file.
I have updated the drivers for the video card and the webcam and updated the BIOS. It appears to be temporarily fixed and then the USB stops working as well as the webcam.
Any ideas would be appreciated.
Hi.
This HP filter driver is causing the issues:
hpdskflt hpdskflt.sys Fri Feb 26 11:11:52 2010
I'd look into updating that.
Here are other drivers that are old and need updating or removal:
iaStorV  iaStorV.sys  Wed Apr 08 12:54:58 2009  <<< Intel storage driver
adp94xx  adp94xx.sys  Fri Dec 05 18:59:55 2008
adpahci  adpahci.sys  Tue May 01 13:29:26 2007
adpu320  adpu320.sys  Tue Feb 27 19:03:08 2007
arc      arc.sys      Thu May 24 17:31:06 2007
iirsp    iirsp.sys    Tue Dec 13 16:48:01 2005
lsi_fc   lsi_fc.sys   Tue Dec 09 17:28:47 2008
nfrd960  nfrd960.sys  Tue Jun 06 17:12:15 2006
PxHelp20 PxHelp20.sys Mon Dec 10 18:48:39 2007
djsvs    djsvs.sys    Tue Apr 11 20:20:11 2006
lmimirr  lmimirr.sys  Tue Apr 10 18:32:11 2007
HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:46:51 2009
RaInfo   RaInfo.sys   Fri Jan 04 13:57:12 2008
adfs     adfs.SYS     Thu Aug 14 10:57:15 2008
LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 12:26:22 2008
000      000.fcl      Fri Sep 26 09:11:12 2008
You could also look into removing Avast! with the special tool found here to see if it alleviates the problem, after giving attention to the above:
AV Uninstallers - Windows 7 Forums
