Hi, recently I changed my motherboard and graphics card. Since then, I have been getting BSOD's and they have become more frequent. I have read possible solutions to driver sweep and reinstall/update drivers. Though after several updates, the problem still persists !!
Before the BSOD appears, the screen freezes. This is then followed by the computer attempting to reset itself but is unable to reboot because of resetting before the computer is even able to turn on. The only way to avoid the reset loop is to manually shut it down then turning it back on after a few minutes.
My computer specifications:
Motherboard: Gigabyte P35-DS3L (revision 2)
CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66Ghz
Graphics Card: Radeon HD 4870
Below you will find a copy of my dump file, hopefully someone is able to shed some light on the problem
Link Removed due to 404 Error
