Windows 7 BSOD Problem
nevica
Hello,
I have a dump file attached. Could someone please look at this.
Thanks,
NevicaLink Removed due to 404 Error
While not conclusive the single dump file that you have posted would seem to point at Abyssus.sys 10/29/2009 which would seem to be a driver for a specific USB optical mouse. You should try updating that driver and see if blue screens persist.
* Bugcheck Analysis *
BugCheck 1E, {0, 0, 0, 0}
Unable to load image [COLOR=#b22222]Abyssus.sys[/COLOR], Win32 error 0n2
*** WARNING: Unable to verify timestamp for [COLOR=#b22222]Abyssus.sys
[/COLOR]*** ERROR: Module load completed but symbols could not be loaded for Abyssus.sys
Probably caused by ...
Probably caused by : [COLOR=#b22222]Abyssus.sys[/COLOR] ( Abyssus+6af )
Followup: MachineOwner
0: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - The operation completed successfully.
FAULTING_IP:
+3231323165653330
00000000`00000000 ?? ???
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000000
ERROR_CODE: (NTSTATUS) 0 - STATUS_WAIT_0
BUGCHECK_STR: 0x1E_0
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff800030796be to fffff80003081cd0
STACK_TEXT:
fffff800`00b9bb48 fffff800`030796be : fffffa80`093325b0 fffff880`0f4943c8 fffff800`00b9c350 fffff800`030ad890 : nt!KeBugCheck
fffff800`00b9bb50 fffff800`030ad55d : fffff800`03288968 fffff800`031c5cbc fffff800`03002000 fffff800`00b9c2b0 : nt!KiKernelCalloutExceptionHandler+0xe
fffff800`00b9bb80 fffff800`030ac335 : fffff800`031c90fc fffff800`00b9bbf8 fffff800`00b9c2b0 fffff800`03002000 : nt!RtlpExecuteHandlerForException+0xd
fffff800`00b9bbb0 fffff800`030af632 : fffff800`00b9c2b0 fffff800`00b9c350 fffffa80`00000001 fffff880`00000005 : nt!RtlDispatchException+0x415
fffff800`00b9c290 fffff800`0303c6ea : 00000000`00000000 fffffa80`08751a18 fffffa80`087511a0 fffff880`04072783 : nt!RtlRaiseStatus+0x4e
fffff800`00b9c830 fffff880`05b5d6af : fffffa80`087ae800 fffffa80`00000000 fffffa80`094c9701 fffffa80`08ed0c00 : nt! ?? ::FNODOBFM::`string'+0xf5a9
fffff800`00b9c8b0 fffffa80`087ae800 : fffffa80`00000000 fffffa80`094c9701 fffffa80`08ed0c00 fffffa80`09f0d010 : [COLOR=#b22222]Abyssus[/COLOR]+0x6af
fffff800`00b9c8b8 fffffa80`00000000 : fffffa80`094c9701 fffffa80`08ed0c00 fffffa80`09f0d010 00000000`00000000 : 0xfffffa80`087ae800
fffff800`00b9c8c0 fffffa80`094c9701 : fffffa80`08ed0c00 fffffa80`09f0d010 00000000`00000000 fffffa80`09456400 : 0xfffffa80`00000000
fffff800`00b9c8c8 fffffa80`08ed0c00 : fffffa80`09f0d010 00000000`00000000 fffffa80`09456400 fffffa80`094c9760 : 0xfffffa80`094c9701
fffff800`00b9c8d0 fffffa80`09f0d010 : 00000000`00000000 fffffa80`09456400 fffffa80`094c9760 fffffa80`087ae8c0 : 0xfffffa80`08ed0c00
fffff800`00b9c8d8 00000000`00000000 : fffffa80`09456400 fffffa80`094c9760 fffffa80`087ae8c0 fffff800`03085091 : 0xfffffa80`09f0d010
STACK_COMMAND: kb
FOLLOWUP_IP:
[COLOR=#b22222]Abyssus[/COLOR]+6af
fffff880`05b5d6af ?? ???
SYMBOL_STACK_INDEX: 6
SYMBOL_NAME: [COLOR=#b22222]Abyssus[/COLOR]+6af
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: [COLOR=#b22222]Abyssus[/COLOR]
IMAGE_NAME: [COLOR=#b22222]Abyssus.sys[/COLOR]
DEBUG_FLR_IMAGE_TIMESTAMP: 4aea553c
FAILURE_BUCKET_ID: X64_0x1E_0_[COLOR=#b22222]Abyssus[/COLOR]+6af
Hello,
I tried running the SF Diagnostic Tool but it crashed when:
System.IO.FileNotFoundException: Could not find file ' C:\msinfo32.nfo'.
I have uploaded what I can run. ie the text file.
Nevica
you need to right click the SF Diagnostic Tool and choose run as administrator from the context menu. And update the driver I mentioned above.
Hi There,
I think by re-installing Abyssus software it has solved the problem............................ So-far.................
Thanks,
Nevica
