Hi Hannah90 and Welcome to The Forum.
You're getting a
stop0x124, which means blame the hardware.
Stop 0x124 Checks - Ensure that none of the hardware is being over-clocked.
- Ensure that the machine is adequately cooled. Chase out those dust bunnies!
- Make sure all hardware related drivers are up to date.
- Possibly update the motherboard BIOS according to the manufacturer's instructions.
- Always keep The Windows system itself up to date.
See this post by
H2S04 for additional pointers:
Stop 0x124 - what to try. Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority: AVG is known to be a cause of BSOD's on Windows 7 systems. Suggest that you uninstall it. Download the correct
AVG Remover for your system
(32 or 64 bit).
If you have AVG ID protection installed, download the
AVGID Protection Remover from the above link as well
(it wouldn't hurt to download and run it anyway). Download BSOD friendly
Link Removed due to 404 Error as AVG's replacement.
Uninstall AVG through the Control Panel. Re-boot to Safe Mode and run the
AVG Removal tool
(s). Re-boot to normal mode and
install MSE. Make sure your Windows firewall is enabled! After your blue screens have been resolved, feel free to re-try AVG.
Some hardware tests you should be prepared to run: Bugcheck Analysis: Code:
* Bugcheck Analysis *
BugCheck 124, {0, fffffa8004d59028, b2000000, 30005}
Probably caused by : hardware
Followup: MachineOwner
Drivers: Code:
fffff880`00f66000 fffff880`00fbd000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01139000 fffff880`011c2000 afd afd.sys Wed Dec 28 03:59:20 2011 (4EFA9418)
fffff880`00e7f000 fffff880`00e95000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0149c000 fffff880`014a7000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`01507000 fffff880`01514000 AsDsm AsDsm.sys Fri Feb 13 06:14:26 2009 (49950FC2)
fffff880`0274c000 fffff880`02754000 ASMMAP64 ASMMAP64.sys Thu Jul 02 10:13:26 2009 (4A4C7A36)
fffff880`0145e000 fffff880`01467000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01467000 fffff880`01491000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`04261000 fffff880`043ea000 athrx athrx.sys Wed Mar 03 00:45:21 2010 (4B8DB121)
fffff880`057f6000 fffff880`057fe000 ATK64AMD ATK64AMD.sys Wed May 13 02:04:54 2009 (4A0A1CB6)
fffff880`02412000 fffff880`0243d000 AVGIDSDriver AVGIDSDriver.Sys Sun Jul 10 23:36:37 2011 (4E1A2975)
fffff880`01d9c000 fffff880`01da6000 AVGIDSEH AVGIDSEH.Sys Sun Jul 10 23:36:50 2011 (4E1A2982)
fffff880`04bed000 fffff880`04bf8000 AVGIDSFilter AVGIDSFilter.Sys Sun Jul 10 23:37:05 2011 (4E1A2991)
fffff880`01000000 fffff880`01049000 avgldx64 avgldx64.sys Fri Oct 07 04:55:41 2011 (4E8E783D)
fffff880`04737000 fffff880`04747000 avgmfx64 avgmfx64.sys Mon Aug 08 04:41:46 2011 (4E3F5AFA)
fffff880`01d90000 fffff880`01d9c000 avgrkx64 avgrkx64.sys Tue Sep 13 05:02:34 2011 (4E6ED5DA)
fffff880`04400000 fffff880`04460000 avgtdia avgtdia.sys Sun Jul 10 23:46:53 2011 (4E1A2BDD)
fffff880`00e5e000 fffff880`00e6a000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`04750000 fffff880`04757000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`018b8000 fffff880`018c9000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04b18000 fffff880`04b36000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`007a0000 fffff960`007c7000 cdd cdd.dll Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff880`0470d000 fffff880`04737000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`0494b000 fffff880`049fe000 CHDRT64 CHDRT64.sys Mon Jan 18 20:52:28 2010 (4B54CA0C)
fffff880`00ce7000 fffff880`00da7000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01d60000 fffff880`01d90000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c89000 fffff880`00ce7000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`043f7000 fffff880`043fb500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0157b000 fffff880`015ed000 cng cng.sys Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`00e55000 fffff880`00e5e000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`0108d000 fffff880`0109d000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05faf000 fffff880`05fbd000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0189a000 fffff880`018b8000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0188b000 fffff880`0189a000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01d4a000 fffff880`01d60000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0483d000 fffff880`0485f000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0265b000 fffff880`0266e000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`02451000 fffff880`0265b000 dump_iaStor dump_iaStor.sys Tue Jun 08 18:33:03 2010 (4C0E7ECF)
fffff880`05f50000 fffff880`05f5c000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`056ab000 fffff880`0579f000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0579f000 fffff880`057e5000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`01068000 fffff880`0108d000 ETD ETD.sys Tue Apr 13 11:13:18 2010 (4BC443BE)
fffff880`06b67000 fffff880`06b9d000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`014f3000 fffff880`01507000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`014a7000 fffff880`014f3000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01611000 fffff880`0161b000 Fs_Rec Fs_Rec.sys Thu Mar 01 03:41:06 2012 (4F4EEFD2)
fffff880`01d10000 fffff880`01d4a000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c18000 fffff880`01c62000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`02c19000 fffff800`02c62000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04c67000 fffff880`04c8b000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`057e5000 fffff880`057f6000 HECIx64 HECIx64.sys Thu Sep 17 20:54:16 2009 (4AB293E8)
fffff880`05f2e000 fffff880`05f47000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05f47000 fffff880`05f4f080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05f20000 fffff880`05f2e000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`04a45000 fffff880`04b0e000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d07000 fffff880`01d10000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`0161b000 fffff880`01639000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01254000 fffff880`0145e000 iaStor iaStor.sys Tue Jun 08 18:33:03 2010 (4C0E7ECF)
fffff880`04c8c000 fffff880`056aab60 igdkmd64 igdkmd64.sys Wed Aug 25 20:35:58 2010 (4C75709E)
fffff880`011c2000 fffff880`011e8d00 Impcd Impcd.sys Fri Feb 26 23:32:11 2010 (4B8859FB)
fffff880`05ea0000 fffff880`05ee7000 IntcDAud IntcDAud.sys Wed Feb 03 13:38:31 2010 (4B697C57)
fffff880`011e9000 fffff880`011ff000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`04200000 fffff880`04227000 jmcr jmcr.sys Tue Aug 18 09:23:06 2009 (4A8A64EA)
fffff880`01049000 fffff880`01068000 JME JME.sys Thu Feb 25 03:26:53 2010 (4B85EDFD)
fffff880`015ed000 fffff880`015fc000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04256000 fffff880`0425e000 kbfiltr kbfiltr.sys Mon Jul 20 10:21:42 2009 (4A643726)
fffff800`00bcb000 fffff800`00bd5000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04887000 fffff880`048ca000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`017dc000 fffff880`017f7000 ksecdd ksecdd.sys Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01860000 fffff880`0188b000 ksecpkg ksecpkg.sys Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`0485f000 fffff880`04864200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`026b2000 fffff880`026c7000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0266e000 fffff880`02691000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`01514000 fffff880`0151d000 lullaby lullaby.sys Thu Jun 18 03:45:32 2009 (4A39AA4C)
fffff880`00c26000 fffff880`00c75000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`05fa1000 fffff880`05faf000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`018c9000 fffff880`018d8000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05f94000 fffff880`05fa1000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`0111f000 fffff880`01139000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`04b36000 fffff880`04b4e000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`04b4e000 fffff880`04b7b000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`04b7b000 fffff880`04bc9000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`04bc9000 fffff880`04bed000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01491000 fffff880`0149c000 msahci msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`047b5000 fffff880`047c0000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fc6000 fffff880`00fd0000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0151d000 fffff880`0157b000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`01a00000 fffff880`01a0b000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01cf5000 fffff880`01d07000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`018da000 fffff880`019cd000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`019f3000 fffff880`019ff000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0271a000 fffff880`0272d000 ndisuio ndisuio.sys Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`00da7000 fffff880`00dd6000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04936000 fffff880`0494b000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`01db4000 fffff880`01dc3000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04460000 fffff880`044a5000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01800000 fffff880`01860000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`047c0000 fffff880`047d1000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01df2000 fffff880`01dfe000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c62000 fffff800`0324a000 nt ntkrnlmp.exe Tue Mar 06 03:58:13 2012 (4F558B55)
fffff880`01639000 fffff880`017dc000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`04747000 fffff880`04750000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`01cf0000 fffff880`01cf4600 nvpciflt nvpciflt.sys Mon Jul 12 14:52:56 2010 (4C3B1E38)
fffff880`026c7000 fffff880`0271a000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`044ae000 fffff880`044d4000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00e40000 fffff880`00e55000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00e00000 fffff880`00e33000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`01108000 fffff880`0110f000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`0110f000 fffff880`0111f000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01600000 fffff880`01611000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`02754000 fffff880`027fa000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04800000 fffff880`0483d000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c75000 fffff880`00c89000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00fd0000 fffff880`00ff4000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`00e95000 fffff880`00eb0000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`00dd6000 fffff880`00df7000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`00c00000 fffff880`00c1a000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`01200000 fffff880`01251000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0479a000 fffff880`047a3000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`047a3000 fffff880`047ac000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`047ac000 fffff880`047b5000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01cb6000 fffff880`01cf0000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`0272d000 fffff880`02745000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04227000 fffff880`04256000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`04a00000 fffff880`04a0b000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`05f17000 fffff880`05f1fa80 sncduvc sncduvc.SYS Mon Dec 29 09:14:26 2008 (495894F2)
fffff880`044ea000 fffff880`046a1600 snp2uvc snp2uvc.sys Wed May 20 09:11:05 2009 (4A13BB19)
fffff880`01cae000 fffff880`01cb6000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`06a9e000 fffff880`06b36000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`05e00000 fffff880`05e69000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`04a0b000 fffff880`04a3c000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`05f06000 fffff880`05f16d00 STREAM STREAM.SYS Tue Jul 14 01:06:18 2009 (4A5BCBFA)
fffff880`043fc000 fffff880`043fd480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01a14000 fffff880`01c18000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`02400000 fffff880`02412000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`047f3000 fffff880`04800000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`047d1000 fffff880`047f3000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`01dde000 fffff880`01df2000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`004c0000 fffff960`004ca000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`019cd000 fffff880`019f3000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`02745000 fffff880`0274c000 TurboB TurboB.sys Thu Aug 06 22:17:31 2009 (4A7B486B)
fffff880`048ca000 fffff880`048dc000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05ee7000 fffff880`05f04000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`05f04000 fffff880`05f05f00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04c00000 fffff880`04c11000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`048dc000 fffff880`04936000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04c11000 fffff880`04c67000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`05f6d000 fffff880`05f79000 usbprint usbprint.sys Tue Jul 14 01:38:18 2009 (4A5BD37A)
fffff880`05f5c000 fffff880`05f6d000 usbscan usbscan.sys Tue Jul 14 01:35:32 2009 (4A5BD2D4)
fffff880`05f79000 fffff880`05f94000 USBSTOR USBSTOR.SYS Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`00e33000 fffff880`00e40000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`04757000 fffff880`04765000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`04765000 fffff880`0478a000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e6a000 fffff880`00e7f000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`010ac000 fffff880`01108000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01c62000 fffff880`01cae000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`043ea000 fffff880`043f7000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`044d4000 fffff880`044ea000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`04b0e000 fffff880`04b18000 vwifimp vwifimp.sys Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`01dc3000 fffff880`01dde000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`0478a000 fffff880`0479a000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00eb3000 fffff880`00f57000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f57000 fffff880`00f66000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`044a5000 fffff880`044ae000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00335000 win32k win32k.sys Fri Feb 03 04:34:05 2012 (4F2B63BD)
fffff880`00fbd000 fffff880`00fc6000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02691000 fffff880`026b2000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`06b36000 fffff880`06b67000 WUDFRd WUDFRd.sys Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`01da6000 fffff880`01db4000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`044f0000 fffff880`046fa000 dump_iaStor.
Checksum: 00000000
ImageSize: 0020A000
fffff880`046fa000 fffff880`0470d000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
P.S. I'd update: "
Computer Skill Level Average Ability" in your user profile, you followed 99.9% of helpful instructions. That makes you an expert!
