BSOD problems
Hello there , just bought my computer about month or so. It worked fine for a week then i got BSOD's. been trying to fix it and checking things , but i cant seem to find the problem. Have run Memtest and no errors. Hope you guys could help me.
Heres the minidump files and screenshots :
SDP4.PNG SDP2.PNG Capture.PNG SDP1.PNG SDP3.PNG View attachment Minidump files.zip
RAM is set right and the Kingston sticks are matching.
The crash was caused by MS DirectX driver while playing Wow.exe:
021811-19702-01.dmp
BugCheck 3B, {c0000005, fffff88004f33c70, fffff8800ab00da0, 0}
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine
PROCESS_NAME: Wow.exe
Probably caused by : dxgmms1.sys ( dxgmms1!VidMmTerminateAllocation+154 )
Possible causers - faulty RAM or motherboard, drivers, or faulty video card. Let's get you updated first.
atikmdag.sys Tue Jan 04 21:48:52 2011
You might benefit if you update to Catalyst 11.2 with the use of Driver Sweeper:
Guru3D - Driver Sweeper
ATI Radeon
Update VIA Audio:
viahduaa.sys Tue Mar 02 06:30:18 2010
VIA Drivers Download - VIA Technologies, Inc.
Update Realtek LAN:
Rt64win7.sys Sun May 30 23:46:43 2010
ftp://WebUser:*****@208.70.202.219/cn/nic/Install_Win7_7037_01202011.zip
Realtek
Update motherboard driver for USB 3.0:
nusb3hub.sys Thu Apr 22 21:34:35 2010
ASUSTeK Computer Inc.-Support-
If bsods persist, uninstall F-Secure and replace it with MSE:
https://www.microsoft.com/security_essentials/
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021811-19702-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02c1d000 PsLoadedModuleList = 0xfffff800`02e5ae50
Debug session time: Fri Feb 18 11:01:23.958 2011 (UTC - 5:00)
System Uptime: 0 days 20:08:51.285
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
0: kd> !analyze -v
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88004f33c70, Address of the instruction which caused the bugcheck
Arg3: fffff8800ab00da0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff880`04f33c70 498b7d20        mov     rdi,qword ptr [r13+20h]
CONTEXT:  fffff8800ab00da0 -- (.cxr 0xfffff8800ab00da0)
rax=fffffa80047d1050 rbx=fffffa8005b6c000 rcx=fffffa8003eae3e0
rdx=0000000000000000 rsi=fffffa800408e360 rdi=fffff8a00e76fac8
rip=fffff88004f33c70 rsp=fffff8800ab01770 rbp=fffffa8006d47d50
 r8=0000000000000000  r9=0000000000000000 r10=fffff80002e08760
r11=fffff8800ab01740 r12=fffff8a00e76fba0 r13=000000000204001c
r14=0000000000000001 r15=0000000000000001
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
dxgmms1!VidMmTerminateAllocation+0x154:
fffff880`04f33c70 498b7d20        mov     rdi,qword ptr [r13+20h] ds:002b:00000000`0204003c=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff88004f33c70
STACK_TEXT:
fffff880`0ab01770 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VidMmTerminateAllocation+0x154
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgmms1!VidMmTerminateAllocation+154
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME:  dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d3fa174
STACK_COMMAND:  .cxr 0xfffff8800ab00da0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgmms1!VidMmTerminateAllocation+154
Drivers:
fffff880`00eb7000 fffff880`00f0e000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03a70000 fffff880`03afa000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`02b8e000 fffff880`02ba4000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`042d6000 fffff880`042ea000   amdiox64 amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
fffff880`04144000 fffff880`04159000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00e4d000 fffff880`00e58000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04ff7000 fffff880`04fff000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`04118000 fffff880`0411e000   AsIO     AsIO.sys     Thu Apr 22 07:18:03 2010 (4BD0306B)
fffff880`083e3000 fffff880`083ee000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04383000 fffff880`043a3000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`046fb000 fffff880`04f32000   atikmdag atikmdag.sys Tue Jan 04 21:48:52 2011 (4D23DC14)
fffff880`04159000 fffff880`041a6000   atikmpag atikmpag.sys Tue Jan 04 21:19:38 2011 (4D23D53A)
fffff880`015ef000 fffff880`015f7000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`02a9d000 fffff880`02aa4000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04107000 fffff880`04118000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`029b7000 fffff880`029d5000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00750000 fffff960`00777000   cdd      cdd.dll      unavailable (00000000)
fffff880`02a6a000 fffff880`02a94000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`011bd000 fffff880`011ed000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cec000 fffff880`00d4a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0114a000 fffff880`011bd000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03a58000 fffff880`03a68000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03c51000 fffff880`03c5a000   cpuz135_x64 cpuz135_x64.sys Mon Dec 27 08:35:24 2010 (4D18961C)
fffff880`06400000 fffff880`0640e000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04066000 fffff880`040e9000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`040e9000 fffff880`04107000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03a40000 fffff880`03a4f000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`010c0000 fffff880`010d6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04200000 fffff880`04222000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`0641a000 fffff880`06423000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0640e000 fffff880`0641a000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06423000 fffff880`06436000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06436000 fffff880`06442000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04600000 fffff880`046f4000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04f32000 fffff880`04f78000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010d8000 fffff880`010ec000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00e58000 fffff880`00ea4000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`03a13000 fffff880`03a28380   fsdfw    fsdfw.sys    Mon Jun 14 07:04:05 2010 (4C160CA5)
fffff880`03a29000 fffff880`03a323a0   fses     fses.sys     Tue Mar 09 06:37:48 2010 (4B96330C)
fffff880`0833e000 fffff880`08372000   fsgk     fsgk.sys     Tue Sep 21 06:51:16 2010 (4C988E24)
fffff880`03a33000 fffff880`03a3ff60   fshs     fshs.sys     Fri Jun 04 04:39:19 2010 (4C08BBB7)
fffff880`03a0b000 fffff880`03a13000   fsvista  fsvista.sys  Wed Jun 23 07:59:23 2010 (4C21F71B)
fffff880`01086000 fffff880`010c0000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04fce000 fffff880`04fdb000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`031fa000 fffff800`03243000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04f78000 fffff880`04f9c000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04236000 fffff880`0424f000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`0424f000 fffff880`04257080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`04228000 fffff880`04236000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`028ef000 fffff880`029b7000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`014ed000 fffff880`014f6000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04273000 fffff880`04282000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04265000 fffff880`04273000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00baf000 fffff800`00bb9000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04293000 fffff880`042d6000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`04222000 fffff880`04227200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`028c2000 fffff880`028d7000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0287e000 fffff880`028a1000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ccb000 fffff880`00cd8000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`01235000 fffff880`01243000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04282000 fffff880`04291000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04258000 fffff880`04265000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`029d5000 fffff880`029ed000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02800000 fffff880`0282d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0282d000 fffff880`0287b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03c2e000 fffff880`03c51000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02b02000 fffff880`02b0d000   Msfs     Msfs.SYS     unavailable (00000000)
fffff880`00f17000 fffff880`00f21000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010ec000 fffff880`0114a000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03a00000 fffff880`03a0b000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`013e7000 fffff880`013f9000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014fd000 fffff880`015ef000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`02bc8000 fffff880`02bd4000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02a00000 fffff880`02a2f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0436e000 fffff880`04383000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03b29000 fffff880`03b38000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02b49000 fffff880`02b8e000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02b0d000 fffff880`02b1e000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03bef000 fffff880`03bfb000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c1d000 fffff800`031fa000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01244000 fffff880`013e7000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02a94000 fffff880`02a9d000   Null     Null.SYS     unavailable (00000000)
fffff880`042fc000 fffff880`04314000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`04f9c000 fffff880`04fcc000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`03b03000 fffff880`03b29000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f61000 fffff880`00f76000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f21000 fffff880`00f54000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fe7000 fffff880`00fee000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`03c5a000 fffff880`03d00000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`043a3000 fffff880`043e0000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cd8000 fffff880`00cec000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`02ba4000 fffff880`02bc8000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`02a2f000 fffff880`02a4a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`02bd4000 fffff880`02bf5000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`02a4a000 fffff880`02a64000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03b9e000 fffff880`03bef000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02bf5000 fffff880`02c00000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02ae7000 fffff880`02af0000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02af0000 fffff880`02af9000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02af9000 fffff880`02b02000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`028d7000 fffff880`028ef000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0400c000 fffff880`0405f000   Rt64win7 Rt64win7.sys Sun May 30 23:46:43 2010 (4C033123)
fffff880`03b84000 fffff880`03b9e000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`03d00000 fffff880`03d0b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04000000 fffff880`0400c000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03b38000 fffff880`03b55000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`014e5000 fffff880`014ed000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`082a8000 fffff880`0833e000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03d4a000 fffff880`03db1000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`03d0b000 fffff880`03d38000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04291000 fffff880`04292480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`03d38000 fffff880`03d4a000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02b3c000 fffff880`02b49000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02b1e000 fffff880`02b3c000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03b70000 fffff880`03b84000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00400000 fffff960`0040a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0411e000 fffff880`04144000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`042ea000 fffff880`042fc000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`043e0000 fffff880`043fd000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04fcc000 fffff880`04fcdf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04fe6000 fffff880`04ff7000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04314000 fffff880`0436e000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04fdb000 fffff880`04fe6000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`041a6000 fffff880`041fc000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00f54000 fffff880`00f61000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02aa4000 fffff880`02ab2000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06447000 fffff880`065f8000   viahduaa viahduaa.sys Tue Mar 02 06:30:18 2010 (4B8CF6CA)
fffff880`02ab2000 fffff880`02ad7000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`00f76000 fffff880`00f8b000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f8b000 fffff880`00fe7000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03b55000 fffff880`03b70000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02ad7000 fffff880`02ae7000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00d4a000 fffff880`00dee000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00dee000 fffff880`00dfd000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03afa000 fffff880`03b03000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000f0000 fffff960`00400000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`03a4f000 fffff880`03a58000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f0e000 fffff880`00f17000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`028a1000 fffff880`028c2000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`08271000 fffff880`0827d000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0827d000 fffff880`08286000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`08286000 fffff880`08299000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08200000 fffff880`08271000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`08372000 fffff880`083e3000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01235000 fffff880`01243000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`011ed000 fffff880`011f9000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`015f7000 fffff880`01600000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`00ea4000 fffff880`00eb7000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
thanks , will try and update and see what happens.
couldnt find the Lan driver in realtek page , but the motherboard page has the Lan driver , is it the same?
No, Realtek site has it newer, and the driver is there:
Realtek
(this file --> ftp://WebUser:*****@208.70.202.219/cn/nic/Install_Win7_7037_01202011.zip)
----> Realtek > Downloads > Communications Network ICs > Network Interface Controllers > 10/100/1000M Gigabit Ethernet > PCI > Software
#7
Will remove the f-secure and download that MSE if it helps.
Yes, I recommend.
#9
Same crash again:
022311-19858-01.dmp
BugCheck C2, {b, fffffa8003cf16b0, 3, fffffa8003cf21c0}
BAD_POOL_CALLER (c2)
The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
Process : Wow.exe
FAULTING_IP:
dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275
fffff880`043125fd 33d2 xor edx,edx
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275 )
Looks like it crashes mainly when you play WOW.
1. Start > Accessories > Command Prompt > sfc /scannow
2. Memtest86+ - Advanced Memory Diagnostic Tool 10 passes overnight
3. Run these video tests to see if you're getting blue screens under the load:
OCCT 3.1 Available With an Improved GPU Stress Test - 3D Tech News, Pixel Hacking, Data Visualization and 3D Programming - Geeks3D.com
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\022311-19858-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c14000 PsLoadedModuleList = 0xfffff800`02e51e50
Debug session time: Wed Feb 23 03:37:59.629 2011 (UTC - 5:00)
System Uptime: 0 days 12:33:19.580
1: kd> !analyze -v
Arguments:
Arg1: 000000000000000b, type of pool violation the caller is guilty of.
Arg2: fffffa8003cf16b0
Arg3: 0000000000000003
Arg4: fffffa8003cf21c0
Debugging Details:
FAULTING_IP:
BUGCHECK_STR:  0xc2_b
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002db76b8 to fffff80002c84740
STACK_TEXT:
fffff880`0c1d4268 fffff800`02db76b8 : 00000000`000000c2 00000000`0000000b fffffa80`03cf16b0 00000000`00000003 : nt!KeBugCheckEx
fffff880`0c1d4270 fffff880`043125fd : 00000000`00000000 00000000`00000001 fffff8a0`6d4d6956 00000000`00000174 : nt!ExDeferredFreePool+0x12a9
fffff880`0c1d4320 fffff880`042f8ecc : fffffa80`00000000 fffffa80`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+0x275
fffff880`0c1d43f0 fffff880`0423accc : 00000000`00000000 fffff8a0`01dc7000 fffff8a0`01dc7000 00000000`00000001 : dxgmms1!VidMmCloseAllocation+0x44
fffff880`0c1d4420 fffff880`0423a65f : fffff8a0`01dc7000 fffff8a0`01dc8300 fffff8a0`00000000 00000a00`00000799 : dxgkrnl!DXGDEVICE::DestroyAllocations+0x248
fffff880`0c1d4510 fffff880`0426874f : fffff8a0`0b7c6160 fffff8a0`01fb1f40 fffff8a0`0b7c6160 fffff880`0c1d4930 : dxgkrnl!DXGDEVICE::ProcessTerminationList+0xa3
fffff880`0c1d4560 fffff880`04267e7b : fffff8a0`00000799 fffff8a0`0b7c6160 fffff880`0c1d48c0 fffff880`0c1d48f0 : dxgkrnl!DXGCONTEXT::Present+0x2cb
fffff880`0c1d4880 fffff960`0025c9b4 : fffffa80`04296b60 00000000`7efdb000 fffff8a0`0357ea60 00000000`00000010 : dxgkrnl!DxgkPresent+0x543
fffff880`0c1d4bf0 fffff800`02c83993 : fffffa80`04296b60 00000000`000025c8 fffff880`0c1d4bf8 fffffa80`043ee4c0 : win32k!NtGdiDdDDIPresent+0x18
fffff880`0c1d4c20 00000000`738313ca : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`00d4d908 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x738313ca
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275
FAILURE_BUCKET_ID:  X64_0xc2_b_dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+275
Drivers:
fffff880`00e49000 fffff880`00ea0000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03e12000 fffff880`03e9c000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`043e9000 fffff880`043ff000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`02bb2000 fffff880`02bc6000   amdiox64 amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
fffff880`0410f000 fffff880`04124000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fdd000 fffff880`00fe8000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`043c8000 fffff880`043d0000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`040e3000 fffff880`040e9000   AsIO     AsIO.sys     Thu Apr 22 07:18:03 2010 (4BD0306B)
fffff880`00faa000 fffff880`00fb3000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fb3000 fffff880`00fdd000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`054ef000 fffff880`0550f000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`0467e000 fffff880`04f7a000   atikmdag atikmdag.sys Wed Jan 26 17:48:28 2011 (4D40A4BC)
fffff880`04124000 fffff880`04172000   atikmpag atikmpag.sys Wed Jan 26 17:13:33 2011 (4D409C8D)
fffff880`0124b000 fffff880`01253000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`02ac1000 fffff880`02ac8000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040d2000 fffff880`040e3000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03704000 fffff880`03722000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00680000 fffff960`006a7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`02a5d000 fffff880`02a87000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e00000 fffff880`00e30000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cf0000 fffff880`00d4e000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0113a000 fffff880`011ad000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`043d9000 fffff880`043e9000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`037e8000 fffff880`037f1000   cpuz135_x64 cpuz135_x64.sys Mon Dec 27 08:35:24 2010 (4D18961C)
fffff880`067df000 fffff880`067ed000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04031000 fffff880`040b4000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`040b4000 fffff880`040d2000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03fa8000 fffff880`03fb7000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01235000 fffff880`0124b000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0554c000 fffff880`0556e000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06600000 fffff880`06609000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`067ed000 fffff880`067f9000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06609000 fffff880`0661c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`067d3000 fffff880`067df000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04203000 fffff880`042f7000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`042f7000 fffff880`0433d000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010c8000 fffff880`010dc000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0107c000 fffff880`010c8000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0103a000 fffff880`01074000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0157d000 fffff880`015c7000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04393000 fffff880`043a0000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`031f1000 fffff800`0323a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0433d000 fffff880`04361000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0559f000 fffff880`055b8000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`055b8000 fffff880`055c0080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`05591000 fffff880`0559f000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0363c000 fffff880`03704000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015f1000 fffff880`015fa000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04000000 fffff880`0400f000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`055c1000 fffff880`055cf000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b99000 fffff800`00ba3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`03fb7000 fffff880`03ffa000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01552000 fffff880`0157d000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0556e000 fffff880`05573200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`05444000 fffff880`05459000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05400000 fffff880`05423000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ccf000 fffff880`00cdc000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`055dc000 fffff880`055ea000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0400f000 fffff880`0401e000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`055cf000 fffff880`055dc000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00f90000 fffff880`00faa000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02a87000 fffff880`02ab8000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`037d8000 fffff880`037e8000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`03722000 fffff880`0373a000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0373a000 fffff880`03767000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03767000 fffff880`037b5000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`037b5000 fffff880`037d8000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02b26000 fffff880`02b31000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ea9000 fffff880`00eb3000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010dc000 fffff880`0113a000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03f9d000 fffff880`03fa8000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015df000 fffff880`015f1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01400000 fffff880`014f2000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04ff4000 fffff880`05000000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04172000 fffff880`041a1000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`054da000 fffff880`054ef000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03ecb000 fffff880`03eda000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02b6d000 fffff880`02bb2000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`014f2000 fffff880`01552000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`03600000 fffff880`03615000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`02b31000 fffff880`02b42000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03f91000 fffff880`03f9d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c14000 fffff800`031f1000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0125b000 fffff880`013fe000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02ab8000 fffff880`02ac1000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02bc6000 fffff880`02bde000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`04361000 fffff880`04391000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`03ea5000 fffff880`03ecb000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00ef3000 fffff880`00f08000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00eb3000 fffff880`00ee6000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00f79000 fffff880`00f80000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00f80000 fffff880`00f90000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`08802000 fffff880`088a8000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0550f000 fffff880`0554c000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cdc000 fffff880`00cf0000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04fd0000 fffff880`04ff4000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041a1000 fffff880`041bc000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`041bc000 fffff880`041dd000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`041dd000 fffff880`041f7000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03f40000 fffff880`03f91000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04667000 fffff880`04672000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02b0b000 fffff880`02b14000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b14000 fffff880`02b1d000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b1d000 fffff880`02b26000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05459000 fffff880`05471000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04600000 fffff880`04667000   Rt64win7 Rt64win7.sys Wed Dec 29 06:44:36 2010 (4D1B1F24)
fffff880`03f26000 fffff880`03f40000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`088a8000 fffff880`088b3000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`043bc000 fffff880`043c8000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03eda000 fffff880`03ef7000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015d7000 fffff880`015df000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08959000 fffff880`089ef000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`088f2000 fffff880`08959000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`088b3000 fffff880`088e0000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04200000 fffff880`04201480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`088e0000 fffff880`088f2000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02b60000 fffff880`02b6d000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02b42000 fffff880`02b60000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03f12000 fffff880`03f26000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`040e9000 fffff880`0410f000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0401e000 fffff880`04030000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05574000 fffff880`05591000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04391000 fffff880`04392f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`043ab000 fffff880`043bc000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05480000 fffff880`054da000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`043a0000 fffff880`043ab000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04f7a000 fffff880`04fd0000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00ee6000 fffff880`00ef3000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02ac8000 fffff880`02ad6000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06622000 fffff880`067d3000   viahduaa viahduaa.sys Tue Mar 02 06:30:18 2010 (4B8CF6CA)
fffff880`02ad6000 fffff880`02afb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015c7000 fffff880`015d7000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00f08000 fffff880`00f1d000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f1d000 fffff880`00f79000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`011ad000 fffff880`011f9000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03ef7000 fffff880`03f12000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02afb000 fffff880`02b0b000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00d4e000 fffff880`00df2000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00cc0000 fffff880`00ccf000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03e9c000 fffff880`03ea5000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000d0000 fffff960`003e0000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`043d0000 fffff880`043d9000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00ea0000 fffff880`00ea9000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05423000 fffff880`05444000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0e8c7000 fffff880`0e938000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`00e30000 fffff880`00e3e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`00fe8000 fffff880`00ff4000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00ff4000 fffff880`00ffd000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`02a4a000 fffff880`02a5d000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Did the memtest over 10 passes and no errors. Didnt get any bluescreen while running the test either. sfc scan found some error that couldnt be fixed.
#11
Does it bsod only when you play World Of Warcraft?
#12
thinking again , yes , or the game is on when i tab out for windows.
#13
dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::CloseOneAllocation )
dxgmms1.sys ( dxgmms1!VidMmTerminateAllocation}
1. I don't see your dxdiag report, what is your videocard? Now you have the latest Catalyst, but I'm thinking is it actually the best version for your card?
2. Test the video memory too |MG| Video Memory Stress Test 1.7.116 Download.
3. Ram looks right and the sticks are matching. Is the voltage set right, I'm asking because there is no way I could see your voltage. Sometimes RAM makers put a note about the voltage needing to be set manually, because the motherboard can default it to low.
Give me PassMark RAMMon - Identify RAM type, speed & memory timings.
#15
2 Kingston sticks 99U5471-001.A00LF rated DDR1333 9-9-9-24, right?
And your motherboard does have support for DDR1333, correct?
#16
2 Kingston sticks 99U5471-001.A00LF rated DDR1333 9-9-9-24, right? yeah
yes the motherboard support DDR1333
#17
Ok, RAM is set right, is matched and supported by the motherboard. Memtest shows 0 errors. sfc /scannow shows some things that can't be corrected. Have reinstalled the videocard driver with the latest version. Still crashes when Alt-Tab'ing to desktop. Videotests as Furmark pass without a glitch. Latest Catalysts is what you've tried and what you need for Radeon 6850.
1. Run this video memory test |MG| Video Memory Stress Test 1.7.116 Download
2. Disable the videocard in windows device manager, reboot and try out the system for BSOD's with the card disabled.
3. Consider upgrading bios to the latest version
4. System reinstall might be worth a try, but in 90% of the cases it fixes nothing.
