Loading Dump File [F:\a\Minidump\D M P\DMP\021811-10623-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`0304e000 PsLoadedModuleList = 0xfffff800`0328be50
Debug session time: Fri Feb 18 07:05:03.016 2011 (UTC - 5:00)
System Uptime: 0 days 2:35:40.499
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 119, {7000000, fffffa800a8d9410, fffffa80072646b0, fffffa800700a760}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiCheckConditionDeviceCommand+8c )
Followup: MachineOwner
3: kd> !analyze -v
VIDEO_SCHEDULER_INTERNAL_ERROR (119)
The video scheduler has detected that fatal violation has occurred. This resulted
in a condition that video scheduler can no longer progress. Any other values after
parameter 1 must be individually examined according to the subtype.
Arguments:
Arg1: 0000000007000000, The subtype of the bugcheck:
Arg2: fffffa800a8d9410
Arg3: fffffa80072646b0
Arg4: fffffa800700a760
Debugging Details:
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x119
PROCESS_NAME: CurseClient.ex
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff8800455822f to fffff800030be740
STACK_TEXT:
fffff880`009cc988 fffff880`0455822f : 00000000`00000119 00000000`07000000 fffffa80`0a8d9410 fffffa80`072646b0 : nt!KeBugCheckEx
fffff880`009cc990 fffff880`1020e318 : fffffa80`06bb1010 00000000`00000000 00000000`00000000 fffffa80`07264710 : watchdog!WdLogEvent5+0x11b
fffff880`009cc9e0 fffff880`1020e37a : fffffa80`0000378e fffffa80`07264710 00000000`00000000 fffffa80`0a8d9410 : dxgmms1!VidSchiCheckConditionDeviceCommand+0x8c
fffff880`009cca10 fffff880`1020a360 : fffffa80`071ed9c0 fffffa80`072646b0 fffffa80`0a88c000 fffffa80`0a88c000 : dxgmms1!VidSchiCheckPendingDeviceCommand+0x3e
fffff880`009cca50 fffff880`102097da : fffffa80`00000000 fffffa80`00000000 00000000`00000002 00000000`00000000 : dxgmms1!VidSchiProcessCompletedQueuePacketInternal+0x438
fffff880`009ccb10 fffff880`10208e00 : 00000000`00000000 fffffa80`0a8d9410 00000000`00000000 fffffa80`0a679b60 : dxgmms1!VidSchiProcessDpcCompletedPacket+0x3b6
fffff880`009ccbb0 fffff880`10208c4c : fffff880`10e5a080 fffffa80`0a8d9410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchDdiNotifyDpcWorker+0x198
fffff880`009ccc00 fffff880`10eca1cf : fffffa80`09d7f480 00000000`00000000 00000000`00000022 00000000`00000000 : dxgmms1!VidSchDdiNotifyDpc+0x94
fffff880`009ccc50 fffff880`1031fa88 : fffffa80`09dc8000 fffffa80`09dc8000 00000000`00000000 00000000`00000000 : dxgkrnl!DxgNotifyDpcCB+0x77
fffff880`009ccc80 fffffa80`09dc8000 : fffffa80`09dc8000 00000000`00000000 00000000`00000000 fffff880`1031fa1b : nvlddmkm+0xb5a88
fffff880`009ccc88 fffffa80`09dc8000 : 00000000`00000000 00000000`00000000 fffff880`1031fa1b fffffa80`09dc8000 : 0xfffffa80`09dc8000
fffff880`009ccc90 00000000`00000000 : 00000000`00000000 fffff880`1031fa1b fffffa80`09dc8000 00000000`00000000 : 0xfffffa80`09dc8000
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff880`1020e318 c744243071c8ffff mov dword ptr [rsp+30h],0FFFFC871h
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: dxgmms1!VidSchiCheckConditionDeviceCommand+8c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME: dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4d3fa174
FAILURE_BUCKET_ID: X64_0x119_dxgmms1!VidSchiCheckConditionDeviceCommand+8c
3: kd> !analyze -v
Arguments:
Debugging Details:
BUGCHECK_STR: 0x119
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
