- Thread Author
- #1
I have got a couple of BSOD in the past couple of days. Can you please tell me what's going on?
Attached are the last 2 dmp files.
* Bugcheck Analysis *
BugCheck D1, {fffffa8008bfd000, 2, 0, fffff88007a0cb0a}
Unable to load image \??\C:\Windows\system32\Drivers\pssdklbf.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for[B] pssdklbf.sys[/B]
*** ERROR: Module load completed but symbols could not be loaded for pssdklbf.sys
[B]Probably caused by : pssdklbf.sys[/B] ( pssdklbf+cb0a )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffffa8008bfd000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88007a0cb0a, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800038fe100
fffffa8008bfd000
CURRENT_IRQL: 2
FAULTING_IP:
pssdklbf+cb0a
fffff880`07a0cb0a 4c8b540af8 mov r10,qword ptr [rdx+rcx-8]
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffff88002d3b200 -- (.trap 0xfffff88002d3b200)
rax=fc707847e03f4c49 rbx=0000000000000000 rcx=fffff88009f64c68
rdx=000001fffec9839c rsi=0000000000000000 rdi=0000000000000000
rip=fffff88007a0cb0a rsp=fffff88002d3b398 rbp=0000000000000b47
r8=00000000000005d1 r9=0000000000000001 r10=a6c4498701964284
r11=fffff88009f646a4 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei ng nz na pe nc
pssdklbf+0xcb0a:
fffff880`07a0cb0a 4c8b540af8 mov r10,qword ptr [rdx+rcx-8] ds:3960:fffffa80`08bfcffc=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800036cb1e9 to fffff800036cbc40
STACK_TEXT:
fffff880`02d3b0b8 fffff800`036cb1e9 : 00000000`0000000a fffffa80`08bfd000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02d3b0c0 fffff800`036c9e60 : fffff880`02d3b710 00000000`00000000 fffff880`02d3b660 fffffa80`08bfca40 : nt!KiBugCheckDispatch+0x69
fffff880`02d3b200 fffff880`07a0cb0a : fffff880`07a0462f fffffa80`06e52770 fffff800`03841e80 fffffa80`06e527a8 : nt!KiPageFault+0x260
fffff880`02d3b398 fffff880`07a0462f : fffffa80`06e52770 fffff800`03841e80 fffffa80`06e527a8 fffffa80`07421ad0 : pssdklbf+0xcb0a
fffff880`02d3b3a0 fffffa80`06e52770 : fffff800`03841e80 fffffa80`06e527a8 fffffa80`07421ad0 00000000`00000000 : pssdklbf+0x462f
fffff880`02d3b3a8 fffff800`03841e80 : fffffa80`06e527a8 fffffa80`07421ad0 00000000`00000000 fffffa80`07ffee60 : 0xfffffa80`06e52770
fffff880`02d3b3b0 fffffa80`06e527a8 : fffffa80`07421ad0 00000000`00000000 fffffa80`07ffee60 fffffa80`06e527a8 : nt!KiInitialPCR+0x180
fffff880`02d3b3b8 fffffa80`07421ad0 : 00000000`00000000 fffffa80`07ffee60 fffffa80`06e527a8 00000000`00000011 : 0xfffffa80`06e527a8
fffff880`02d3b3c0 00000000`00000000 : fffffa80`07ffee60 fffffa80`06e527a8 00000000`00000011 fffffa80`044d7368 : 0xfffffa80`07421ad0
STACK_COMMAND: kb
FOLLOWUP_IP:
pssdklbf+cb0a
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: pssdklbf+cb0a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: pssdklbf
IMAGE_NAME: pssdklbf.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a408af2
FAILURE_BUCKET_ID: X64_0xD1_pssdklbf+cb0a
fffff880`04200000 fffff880`04243000 a72xj5gg a72xj5gg.SYS Fri Aug 07 14:30:20 2009 (4A7C2C6C)
fffff880`01000000 fffff880`01057000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03e12000 fffff880`03e9b000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`053e2000 fffff880`053f8000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00fcd000 fffff880`00fd8000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`07b46000 fffff880`07b51000 asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00f9a000 fffff880`00fa3000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fa3000 fffff880`00fcd000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`04cc8000 fffff880`052de000 atikmdag atikmdag.sys Mon Jun 15 03:41:39 2009 (4A35B4E3)
fffff880`01de2000 fffff880`01de9000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04480000 fffff880`0459f000 BHDrvx64 BHDrvx64.sys Thu Nov 10 00:00:00 2011 (4EBB1400)
fffff880`043cd000 fffff880`043de000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`039ad000 fffff880`039cb000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00630000 fffff960`00657000 cdd cdd.dll unavailable (00000000)
fffff880`061d5000 fffff880`061f2000 cdfs cdfs.sys Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`01a00000 fffff880`01a2a000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00ce0000 fffff880`00da0000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01d73000 fffff880`01da3000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c82000 fffff880`00ce0000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01655000 fffff880`016c7000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`053d2000 fffff880`053e2000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0467a000 fffff880`04688000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`043af000 fffff880`043cd000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`043a0000 fffff880`043af000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01d5d000 fffff880`01d73000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04798000 fffff880`047ba000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`045f6000 fffff880`045ff000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`047f4000 fffff880`04800000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01da3000 fffff880`01db6000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`061f2000 fffff880`061fe000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`052de000 fffff880`053d2000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04c00000 fffff880`04c46000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`04301000 fffff880`0437a000 eeCtrl64 eeCtrl64.sys Sat Oct 22 02:18:28 2011 (4EA219E4)
fffff880`07b51000 fffff880`07b71000 ENG64 ENG64.SYS Fri Jul 29 14:17:51 2011 (4E32B2FF)
fffff880`0437a000 fffff880`043a0000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Sat Oct 22 02:18:29 2011 (4EA219E5)
fffff880`07400000 fffff880`075f8000 EX64 EX64.SYS Fri Jul 29 14:15:11 2011 (4E32B25F)
fffff880`06e00000 fffff880`06e36000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`012de000 fffff880`012f2000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00da0000 fffff880`00dec000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`016d8000 fffff880`016e2000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01d23000 fffff880`01d5d000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c30000 fffff880`01c7a000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`04cc1000 fffff880`04cc7b80 GEARAspiWDM GEARAspiWDM.sys Mon May 16 21:56:05 2011 (4DD18F65)
fffff800`03606000 fffff800`0364f000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04c46000 fffff880`04c6a000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`046ff000 fffff880`0475b000 HdAudio HdAudio.sys Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`047c0000 fffff880`047d9000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0601e000 fffff880`06026080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06010000 fffff880`0601e000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`038e4000 fffff880`039ad000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d1a000 fffff880`01d23000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`07b71000 fffff880`07bee000 IDSvia64 IDSvia64.sys Wed Jul 20 14:19:46 2011 (4E26D5F2)
fffff880`045c5000 fffff880`045db000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01986000 fffff880`019b3000 Ironx64 Ironx64.SYS Fri Nov 12 23:06:50 2010 (4CDDC88A)
fffff880`045e7000 fffff880`045f6000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`047e6000 fffff880`047f4000 kbdhid kbdhid.sys Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bbe000 fffff800`00bc8000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`01600000 fffff880`01643000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015a3000 fffff880`015be000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`018c9000 fffff880`018f4000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`047ba000 fffff880`047bf200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`015be000 fffff880`015d3000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`01db6000 fffff880`01dd9000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c1f000 fffff880`00c6e000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`06000000 fffff880`0600e000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04272000 fffff880`04281000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`047d9000 fffff880`047e6000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00f80000 fffff880`00f9a000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`039cb000 fffff880`039e3000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`03800000 fffff880`0382d000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`064a3000 fffff880`064f1000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`064f1000 fffff880`06515000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`0193b000 fffff880`01946000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01057000 fffff880`01061000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01200000 fffff880`0125e000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`01851000 fffff880`0185c000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01d08000 fffff880`01d1a000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`016e2000 fffff880`017d5000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`045db000 fffff880`045e7000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`038b9000 fffff880`038cc000 ndisuio ndisuio.sys Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04243000 fffff880`04272000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`046ea000 fffff880`046ff000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03f0f000 fffff880`03f1e000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03e9b000 fffff880`03ee0000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01869000 fffff880`018c9000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01946000 fffff880`01957000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03e00000 fffff880`03e0c000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0364f000 fffff800`03c38000 nt ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01400000 fffff880`015a3000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01dd9000 fffff880`01de2000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`03866000 fffff880`038b9000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03ee9000 fffff880`03f0f000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`0106e000 fffff880`01083000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00ee1000 fffff880`00f14000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`011f8000 fffff880`011ff000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00f70000 fffff880`00f80000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`016c7000 fffff880`016d8000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06515000 fffff880`065bb000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0475b000 fffff880`04798000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c6e000 fffff880`00c82000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`07bee000 fffff880`07bff000 pssdk42 pssdk42.sys Tue Jun 23 13:11:57 2009 (4A40C68D)
fffff880`07a00000 fffff880`07a14000 pssdklbf pssdklbf.sys Tue Jun 23 08:57:38 2009 (4A408AF2)
fffff880`013d6000 fffff880`013e1700 PxHlpa64 PxHlpa64.sys Wed Oct 17 19:25:02 2007 (4716537E)
fffff880`04456000 fffff880`0447a000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`043de000 fffff880`043f9000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`019b3000 fffff880`019d4000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`019d4000 fffff880`019ee000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`01800000 fffff880`01851000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01df7000 fffff880`01e00000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01929000 fffff880`01932000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01932000 fffff880`0193b000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01cce000 fffff880`01d08000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`038cc000 fffff880`038e4000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04c88000 fffff880`04cc1000 Rt64win7 Rt64win7.sys Fri May 22 15:52:30 2009 (4A16BC2E)
fffff880`06028000 fffff880`061d4900 RTKVHD64 RTKVHD64.sys Fri May 22 19:04:20 2009 (4A16E924)
fffff880`011c9000 fffff880`011f8000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`065bb000 fffff880`065c6000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01cc6000 fffff880`01cce000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0109a000 fffff880`011c0000 sptd sptd.sys Sun Oct 11 21:55:14 2009 (4AD24632)
fffff880`06f0d000 fffff880`06fcd000 SRTSP64 SRTSP64.SYS Wed Mar 30 03:46:12 2011 (4D929974)
fffff880`03fea000 fffff880`04000000 SRTSPX64 SRTSPX64.SYS Wed Mar 30 03:46:18 2011 (4D92997A)
fffff880`06e75000 fffff880`06f0d000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06412000 fffff880`0647b000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`065c6000 fffff880`065f7000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`053f8000 fffff880`053f9480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0126d000 fffff880`012de000 SYMDS64 SYMDS64.SYS Wed Dec 08 00:16:58 2010 (4CFECE7A)
fffff880`012f2000 fffff880`013d6000 SYMEFA64 SYMEFA64.SYS Mon Mar 14 03:20:58 2011 (4D7D899A)
fffff880`03fb4000 fffff880`03fea000 SYMEVENT64x86 SYMEVENT64x86.SYS Thu Mar 24 23:02:36 2011 (4D8BCD8C)
fffff880`03f4d000 fffff880`03fb4000 SYMNETS SYMNETS.SYS Tue Apr 19 23:33:31 2011 (4DAE0DBB)
fffff880`01a2c000 fffff880`01c30000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`06400000 fffff880`06412000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01979000 fffff880`01986000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01957000 fffff880`01979000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03f39000 fffff880`03f4d000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00530000 fffff960`0053a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`0459f000 fffff880`045c5000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`019ee000 fffff880`01a00000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0465d000 fffff880`0467a000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0600e000 fffff880`0600ff00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04c77000 fffff880`04c88000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04690000 fffff880`046ea000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04400000 fffff880`04456000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`07a6c000 fffff880`07a87000 USBSTOR USBSTOR.SYS Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`04c6a000 fffff880`04c77000 usbuhci usbuhci.sys Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`01061000 fffff880`0106e000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01de9000 fffff880`01df7000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`018f4000 fffff880`01919000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01083000 fffff880`01098000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f14000 fffff880`00f70000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01c7a000 fffff880`01cc6000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`03f1e000 fffff880`03f39000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01919000 fffff880`01929000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e2e000 fffff880`00ed2000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ed2000 fffff880`00ee1000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03ee0000 fffff880`03ee9000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04600000 fffff880`0465d000 wg111v2 wg111v2.sys Wed Dec 26 02:46:26 2007 (4771C082)
fffff960`00090000 fffff960`003a4000 win32k win32k.sys unavailable (00000000)
fffff880`011c0000 fffff880`011c9000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`017d5000 fffff880`017f6000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`07a87000 fffff880`07ab8000 WUDFRd WUDFRd.sys Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`07ad0000 fffff880`07adc000 pcdsrvc_x64.
Checksum: 00000000
ImageSize: 0000C000
fffff880`07ac4000 fffff880`07ad0000 pcdsrvc_x64.
Checksum: 00000000
ImageSize: 0000C000
fffff880`07ab8000 fffff880`07ac4000 pcdsrvc_x64.
Checksum: 00000000
ImageSize: 0000C000
fffff880`07a60000 fffff880`07a6c000 pcdsrvc_x64.
Checksum: 00000000
ImageSize: 0000C000
fffff880`07a2f000 fffff880`07a60000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
fffff880`07a14000 fffff880`07a2f000 USBSTOR.SYS
Checksum: 00000000
ImageSize: 0001B000
fffff880`04284000 fffff880`04301000 IDSvia64.sys
Checksum: 00000000
ImageSize: 0007D000
fffff880`06fcd000 fffff880`06fed000 ENG64.SYS
Checksum: 00000000
ImageSize: 00020000
fffff880`07407000 fffff880`075ff000 EX64.SYS
Checksum: 00000000
ImageSize: 001F8000
fffff880`07ad5000 fffff880`07b46000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`01da3000 fffff880`01db1000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01db1000 fffff880`01dbd000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`01dbd000 fffff880`01dc6000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01dc6000 fffff880`01dd9000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Your latest dump file lists pssdklbf.sys as the probable cause.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
pssdklbf.sys Tue Jun 23 08:57:38 2009 Packet Sniffer SDK Update or uninstall this pre Win 7 software.
And definitely sort out that Packet Sniffer. That was what most likely caused both crashes (dumps had same stop errors etc.).
HTH.
If you r-click the actual driver(s), look under the details tab which will give actual Mmanufacture date.The pssdklbf.sys remains under the Drivers folder in windows but shows that it was last modified today. Does it need to be deleted?.
You could try with (both) the sniffer drivers from June 2009 to rename them and see if NetWoerx, errr, Worx!!![]()
