BSOD random crash few times
Discussion in 'Windows 7 Blue Screen of Death (BSOD)' started by Kanjuro, Dec 3, 2010.
  1. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Past 2 days I would get a few BSOD after starting up my computer when I wake up. After a couple of BSOD everything starts running smoothly again or so it seems. So I just want ask for help to make sure this doesn't happen the next time I turn on my computer. Here is the dump files.View attachment Dump Copy.rar
  2. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
    Hey there, welcome.
    1) You can install my attachment to update this old driver:
    ASACPI ASACPI.sys Sun Mar 27 22:30:36 2005
    2) Update Realtek lan driver:
    Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009
    RTL8111
    3) If issues persist, uninstall Avast with its removal tool, in safe mode. Reboot and install MSE.
    Then also, post a screen shot of CPU-Z spd and memory tabs.
    #2 TorrentG, Dec 3, 2010
  3. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Thanks for the quick reply, I will inform if anything happens again.
  4. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Just happen again, didn't get a bsod while playing LOL but it did freeze. Then when I restarted I got the BSOD and here is the file.View attachment Dump.zip
    Also how do I do the screen shot not sure what to do for that.
  5. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
  6. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
  7. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
  8. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
  9. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
    Check again. No need for any more crash dumps. Only what I've asked for.
  10. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Okay here it is.
  11. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
    Luckily this is not baseball...3 strikes and you'd be out lol....check yet again.
  12. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Uh, I guess i just got struck out cause my computer crash and made one long beep with two short ones just a few minutes ago.
  13. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Is the only way to fix my computer right now to get new mem sticks or can I fix it by bios. This has happen to me in the past with windows xp on this computer so I am thinking I should just replace the sticks. Any suggestion on what I should get to replace it?
  14. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Sorry seems I did not add in the spd tab cause I saw nothing until I notice a scroll down tab in it with 4 slots. So here is the rest. Thank you for the help again.
  15. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
    Cool....run Memtest86+ overnight, 8-10 passes. If errors show, replace the RAM.
  16. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Never done this before, do I need to burn this into a cd?
  17. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Hi again G, I finally was able to run the test and all 9 passes. So now I am at a complete lost. I do not mind reformatting my computer as I only had it for 2 months with no real important info in it. However, that would still be last resort if you are able to come up with why I am still getting a bsod.
    #17 Kanjuro, Dec 6, 2010
  18. TorrentG
    TorrentG Banned
    May 31, 2010
    7,814
    372
    I already did come up with why. The memory is defective or there is a bios settings wrong for your setup.
    Test the modules one at a time, and make sure it's 8-10 passes each. If bios is well, you'll surely find the errors, even in fit takes time.
    Uninstall all motherboard utilities and in the bios, disable any CPU throttling, like Speedstep, Cool N Quiet or EIST.
    #18 TorrentG, Dec 6, 2010
  19. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    By test modules, do you mean use each stick one at a time in each slot?
    #19 Kanjuro, Dec 6, 2010
  20. Kanjuro
    Kanjuro New Member
    Dec 3, 2010
    26
    0
    Also not sure at all what to do about the uninstall part and disable CPU throttling. Sorry for being real computer illiterate.
Share This Page
Loading...
