Microsoft (R) Windows Debugger Version 6.2.9200.16384 X86
Loading Dump File [C:\Windows\Minidump\082912-34320-01.dmp]
Symbol search path is:
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17835.amd64fre.win7sp1_gdr.120503-2030
Machine Name:
Kernel base = 0xfffff800`02e5e000 PsLoadedModuleList = 0xfffff800`030a2670
Debug session time: Wed Aug 29 20:32:44.825 2012 (UTC - 5:00)
System Uptime: 0 days 4:47:30.776
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 3B, {c0000005, fffff80002f50964, fffff88007c1ff90, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3f962 )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002f50964, Address of the instruction which caused the bugcheck
Arg3: fffff88007c1ff90, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`02f50964 488b00 mov rax,qword ptr [rax]
CONTEXT: fffff88007c1ff90 -- (.cxr 0xfffff88007c1ff90)
rax=f7fffa8009044970 rbx=fffffa80087ced90 rcx=0000000000000001
rdx=f7fffa8009044970 rsi=0000000000000000 rdi=fffffa80090448d0
rip=fffff80002f50964 rsp=fffff88007c20970 rbp=fffffa80090448d0
r8=0000000000000002 r9=fffff88007c20ac0 r10=fffff80002e5e000
r11=fffff88007c209c8 r12=fffffa8009044968 r13=fffffa8008928e40
r14=fffffa8009044970 r15=fffff8000304fe80
iopl=0 nv up ei ng nz na po cy
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010287
nt! ?? ::FNODOBFM::`string'+0x3f962:
fffff800`02f50964 488b00 mov rax,qword ptr [rax] ds:002b:f7fffa80`09044970=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: chrome.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff80002f50964
STACK_TEXT:
fffff880`07c20970 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x3f962
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+3f962
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4fa390f3
STACK_COMMAND: .cxr 0xfffff88007c1ff90 ; kb
FAILURE_BUCKET_ID: X64_0x3B_nt!_??_::FNODOBFM::_string_+3f962
This is my latest minidump file from a BSOD.
