BSOD Troubles...thanks in advance for any help.
My computer is having a variety of performance issues that usually culminate in a BSOD. I ran the W7F Diagnostic tool to get some info and have attached it below. If anyone can offer any insight into how I might address this problem it would be much appreciated. Thanks in advance. Oh and the computer is a Toshiba Satellite L755 with an Intel Core i3-2310M @ 2.10 GHz. Thanks again. View attachment W7F_25-10-2012.zip
GeneralHiningII
Honorable Member
Will post an analysis soon, depends (probably a few hours)
usasma
Fantastic Member
avast! Network Shield Support ROOT\LEGACY_ASWTDI\0000 This device is not present, is not working properly, or does not have all its drivers installed.
SBRE ROOT\LEGACY_SBRE\0000 This device is not present, is not working properly, or does not have all its drivers installed.
Security Processor Loader Driver ROOT\LEGACY_SPLDR\0000 This device is not present, is not working properly, or does not have all its drivers installed.
You should only have 1 antivirus and 1 firewall running on your system. Please un-install both the Avast and the Sunbelt Antimalware as they are both having problems. Then please install a free antivirus for protection while we're troubleshooting: Free AntiVirus
The Security Processor Loader Driver is usually present due to either a current malware infection - or damage caused by an infections that was subsequently removed. Regardless of which, please run several of these free scans to ensure that your system is clean of viruses: Free Online AntiMalware Resources
Please also un-install SpyBot Search & Destroy TeaTimer.
GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
CD-ROM Class Filter Driver by Gear Software Also comes with iTunes
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
QIOMem.sys Mon Jun 15 01:58:48 2009 (4A35E318)
TOSHIBA Generic IO & Memory Access
http://www.carrona.org/drivers/driver.php?id=QIOMem.sys
TVALZFL.sys Fri Jun 19 06:05:44 2009 (4A3B62F8)
TVALZ Filter Driver - Toshiba
http://www.carrona.org/drivers/driver.php?id=TVALZFL.sys
tos_sps64.sys Wed Jun 24 01:31:09 2009 (4A41BA1D)
Toshiba tos_sps64 Service
http://www.carrona.org/drivers/driver.php?id=tos_sps64.sys
TVALZ_O.SYS Mon Jul 13 22:19:26 2009 (4A5BEB2E)
TOSHIBA ACPI-Based Value Added Logical and General Purpose Device Driver
http://www.carrona.org/drivers/driver.php?id=TVALZ_O.SYS
tdcmdpst.sys Thu Jul 30 04:39:35 2009 (4A715C47)
Toshiba ODD Writing Driver (CD/DVD)
http://www.carrona.org/drivers/driver.php?id=tdcmdpst.sys
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Thu Oct 25 11:18:58.000 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102512-25568-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:50:14.296[/B]
BugCheck Code: [B]BugCheck A, {0, 2, 0, fffff80002e9b442}[/B]
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidMmiProcessTerminationCommand+5f )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002e9b442, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_dxgmms1!VidMmiProcessTerminationCommand+5f[/B]
**************************Thu Oct 25 10:24:43.395 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102512-14367-01.dmp]
System Uptime:[B]0 days 0:06:01.691[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800031cc6ea, 1, 18}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObpCreateHandle+29a )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800031cc6ea, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 0000000000000018, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME: [B]TecoService.ex[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!ObpCreateHandle+29a[/B]
**************************Sun Oct 21 14:57:42.168 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102112-39483-01.dmp]
System Uptime:[B]0 days 0:23:29.073[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff80002eba7ef, 0, 7efa0000}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlImageNtHeaderEx+3f )[/B]
Arguments:
Arg2: fffff80002eba7ef, The address that the exception occurred at
Arg4: 000000007efa0000, Parameter 1 of the exception
PROCESS_NAME: [B]cmd.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!RtlImageNtHeaderEx+3f[/B]
**************************Sat Oct 20 20:51:17.794 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102012-22666-01.dmp]
System Uptime:[B]0 days 0:11:20.699[/B]
BugCheck Code: [B]BugCheck A, {26000000dc, 2, 1, fffff80002efe405}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeStackAttachProcess+115 )[/B]
Arguments:
Arg1: 00000026000000dc, memory referenced
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002efe405, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KeStackAttachProcess+115[/B]
**************************Wed Oct 17 21:51:08.051 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101712-18782-01.dmp]
System Uptime:[B]0 days 5:16:37.957[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800031906ea, 1, 18}[/B]
Arguments:
Arg2: fffff800031906ea, The address that the exception occurred at
PROCESS_NAME: [B]GoogleUpdate.e[/B]
**************************Sun Oct 14 18:06:04.538 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-41979-01.dmp]
System Uptime:[B]0 days 4:34:34.833[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800031ca6ea, 1, 18}[/B]
Arguments:
Arg2: fffff800031ca6ea, The address that the exception occurred at
PROCESS_NAME: [B]igfxsrvc.exe[/B]
**************************Sun Oct 14 12:04:42.691 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-59124-01.dmp]
System Uptime:[B]0 days 0:07:15.158[/B]
Arguments:
PROCESS_NAME: [B]WerFault.exe[/B]
**************************Sun Oct 14 11:26:18.753 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-51651-01.dmp]
System Uptime:[B]0 days 0:04:15.049[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800031d86ea, 1, 18}[/B]
Arguments:
Arg2: fffff800031d86ea, The address that the exception occurred at
PROCESS_NAME: [B]chrome.exe[/B]
**************************Sun Oct 14 11:21:42.729 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-56378-01.dmp]
System Uptime:[B]0 days 0:03:27.634[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff800031826ea, 1, 18}[/B]
Arguments:
Arg2: fffff800031826ea, The address that the exception occurred at
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]QIOMem.sys                  Mon Jun 15 01:58:48 2009 (4A35E318)[/B][/COLOR]
[COLOR=RED][B]TVALZFL.sys                 Fri Jun 19 06:05:44 2009 (4A3B62F8)[/B][/COLOR]
[COLOR=RED][B]tos_sps64.sys               Wed Jun 24 01:31:09 2009 (4A41BA1D)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]TVALZ_O.SYS                 Mon Jul 13 22:19:26 2009 (4A5BEB2E)[/B][/COLOR]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
L1C62x64.sys                Mon Sep 27 02:36:23 2010 (4CA03B67)
IntcDAud.sys                Fri Oct 15 04:28:17 2010 (4CB810A1)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
rtl8192Ce.sys               Tue Jan  4 11:50:10 2011 (4D234FC2)
iaStor.sys                  Wed Jan 12 20:50:12 2011 (4D2E5A54)
pgeffect.sys                Sun Jan 16 21:09:10 2011 (4D33A4C6)
SynTP.sys                   Thu Feb  3 21:59:28 2011 (4D4B6B90)
CHDRT64.sys                 Thu Jul  7 03:02:12 2011 (4E1559F4)
igdkmd64.sys                Wed Aug 31 15:53:13 2011 (4E5E9129)
aswFsBlk.SYS                Tue Aug 21 05:04:55 2012 (50334F37)
aswMonFlt.sys               Tue Aug 21 05:05:00 2012 (50334F3C)
aswTdi.SYS                  Tue Aug 21 05:05:01 2012 (50334F3D)
aswrdr2.sys                 Tue Aug 21 05:05:16 2012 (50334F4C)
aswSP.SYS                   Tue Aug 21 05:05:54 2012 (50334F72)
aswSnx.SYS                  Tue Aug 21 05:05:56 2012 (50334F74)
SBREdrv.sys                 Wed Oct 26 12:41:21 2011 (4EA83831)
sbapifs.sys                 Mon Nov 28 21:18:16 2011 (4ED440E8)
avgtpx64.sys                Thu Jul 19 10:07:13 2012 (50081491)
avgloga.sys                 Thu Aug  9 07:45:25 2012 (5023A2D5)
avgrkx64.sys                Thu Aug  9 22:33:54 2012 (50247312)
avgidsdrivera.sys           Mon Aug 13 10:28:50 2012 (50290F22)
avgldx64.sys                Wed Sep 12 05:35:55 2012 (5050577B)
avgtdia.sys                 Wed Sep 12 05:37:36 2012 (505057E0)
avgmfx64.sys                Thu Sep 13 23:14:31 2012 (5052A117)
avgidsha.sys                Mon Sep 17 12:46:31 2012 (505753E7)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=L1C62x64.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=rtl8192Ce.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=pgeffect.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=CHDRT64.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=aswFsBlk.SYS
http://www.carrona.org/drivers/driver.php?id=aswMonFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswTdi.SYS
http://www.carrona.org/drivers/driver.php?id=aswrdr2.sys
http://www.carrona.org/drivers/driver.php?id=aswSP.SYS
http://www.carrona.org/drivers/driver.php?id=aswSnx.SYS
http://www.carrona.org/drivers/driver.php?id=SBREdrv.sys
http://www.carrona.org/drivers/driver.php?id=sbapifs.sys
http://www.carrona.org/drivers/driver.php?id=avgtpx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgtdia.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
