nollijible
- Joined
- Oct 16, 2009
I don't know if MS sent a patch Tuesday or not, but this happened on the first reboot since then.
Win 7 Home - Cannot access the C: drive.
When I choose repair option and open a cmd window it shows the drive as X: I can change to D: (cddrive) but when I try to access C: it says "There is not enough space on the disk."
No other "repair my PC" options worked either.
The harddrive shows in the bios. I can start (and then cancel) a new install and it shows the drive.
Chkdsk runs clean, but not sure it is checking the C: drive when run from the X: promt even though I typed chkdsk C: /f
I have tried to run SFC, but to get to the CMD window I have to use the repair option and it sets up a flag I guess that won't let SFC run w/o reboot which just sends me in a loop.
I do not have a restore disk or sys image. (not my PC... my sons)
Any suggestions are welcome.
