BSOD, what is wrong with my computer?
Hello everyone! I'm new here :)
Recently, my computer always had BSOD. It started with a freeze on my computer, cursors are not moving, suddenly the screen go blank and voila, BSOD! I have already attached the minidump file, can anyone tell me what causes blue screen on my computer?
I don't know if this is related, but a few days ago, I updated my display driver from optional updates from Windows Update, I think the BSODs start after this. Then, I tried to install the driver from ATI website, still had the blue screen, reinstall the display driver, still had it :(
Hope anyone can help me... :)
kaos
give me 10 mins and ill post back with suggestions for you,
kaos
ok after experience slight technical issues on my pc, i finally downloaded the file
this file is not recognised by my debugging tool therefor the file is either corrupted or false
Are you able to upload another?
Wow! What a fast reply! Thank you so much hehehehe
zigzag3143
Honorable Member
Microsoft MVP
This was a classic video timeout and reset caused by your video driver (possibly heat). Of course not rebooing in almost 2 days doesnt help. You should reboot at least once a day.
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Users\K\Desktop\071011-17472-01.dmp]
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols;srv*e:\symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`03403000 PsLoadedModuleList = 0xfffff800`03648650
Debug session time: Sun Jul 10 06:54:48.169 2011 (GMT-4)
[COLOR=#ff0000][B]System Uptime: 1 days 6:41:04.901[/B][/COLOR]
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 116, {fffffa80098522e0, fffff88001007a1c, 0, 2}
Unable to load image \SystemRoot\system32\DRIVERS\atikmpag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+7a1c )
Followup: MachineOwner
0: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
[COLOR=#ff0000][B]Attempt to reset the display driver and recover from timeout failed.[/B][/COLOR]
Arguments:
Arg1: fffffa80098522e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88001007a1c, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmpag+7a1c
fffff880`01007a1c 4883ec28        sub     rsp,28h
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`029bd9c8 fffff880`0486f000 : 00000000`00000116 fffffa80`098522e0 fffff880`01007a1c 00000000`00000000 : nt!KeBugCheckEx
fffff880`029bd9d0 fffff880`0486ed0a : fffff880`01007a1c fffffa80`098522e0 fffffa80`03a01d50 fffffa80`05547410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`029bda10 fffff880`04915f07 : fffffa80`098522e0 00000000`00000000 fffffa80`03a01d50 fffffa80`05547410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`029bda40 fffff880`0493fb75 : 00000000`ffffffff 00000000`006c0b78 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`029bdb20 fffff880`0493e2bb : 00000000`00000102 00000000`00000000 00000000`006c0b78 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`029bdb50 fffff880`049112c6 : ffffffff`ff676980 fffffa80`05547410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`029bdbf0 fffff880`0493de7a : 00000000`00000000 fffffa80`05783010 00000000`00000080 fffffa80`05547410 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`029bdd00 fffff800`0371f32e : 00000000`fffffc32 fffffa80`0530bb60 fffffa80`039f79e0 fffffa80`0530bb60 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`029bdd40 fffff800`03474666 : fffff800`035f5e80 fffffa80`0530bb60 fffff800`03603cc0 2f4b774a`6e37667a : nt!PspSystemThreadStartup+0x5a
fffff880`029bdd80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+7a1c
SYMBOL_NAME:  atikmpag+7a1c
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME:  atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ddc68a6
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_atikmpag.sys
"It's not a true crash, in the sense that the bluescreen was initiated only because the combination of video driver and video hardware was being unresponsive, and not because of any synchronous processing exception.
Since Vista, the "Timeout Detection and Recovery" (TDR) components of the OS video subsystem have been capable of doing some truly impressive things to try to recover from issues which would have caused earlier OSs like XP to crash.
As a last resort, the TDR subsystem sends the video driver a "please restart yourself now!" command and waits a few seconds.
If there's no response, the OS concludes that the video driver/hardware combo has truly collapsed in a heap, and it fires off that stop 0x116 BSOD.
If playing with video driver versions hasn't helped, make sure the box is not overheating.
Try removing a side panel and aiming a big mains fan straight at the motherboard and GPU.
Run it like that for a few hours or days - long enough to ascertain whether cooler temperatures make a difference.
If so, it might be as simple as dust buildup and subsequently inadequate cooling.
I would download cpu-z and gpu-z (both free) and keep an eye on the video temps Let us know if you need help STOP 0x116: VIDEO_TDR_ERROR troubleshooting - Windows 7 Forums
kaos
DRIVERS
To add my colleagues excellent post , i've added the Drivers and there dates for added analysis
fffff800`00bc5000 fffff800`00bcf000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`03403000 fffff800`039ec000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff800`039ec000 fffff800`03a35000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`00c00000 fffff880`00c10000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00c10000 fffff880`00c2a000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00c2a000 fffff880`00c66000   vmbus    vmbus.sys    Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`00c66000 fffff880`00c7a000   winhv    winhv.sys    Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`00c82000 fffff880`00cd1000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00cd1000 fffff880`00ce5000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00ce5000 fffff880`00d43000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d43000 fffff880`00d76000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00d76000 fffff880`00d8b000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d8b000 fffff880`00da0000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00da0000 fffff880`00dfc000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00e00000 fffff880`00e09000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00e09000 fffff880`00e13000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00e13000 fffff880`00e20000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00e20000 fffff880`00e27000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e27000 fffff880`00e30000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e30000 fffff880`00ef0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00ef0000 fffff880`00f94000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f94000 fffff880`00fa3000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00fa3000 fffff880`00ffa000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01000000 fffff880`01051000   atikmpag atikmpag.sys Wed May 25 03:25:42 2011 (4DDC68A6)
fffff880`01055000 fffff880`0107f000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0107f000 fffff880`0108a000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0108a000 fffff880`010d6000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`010d6000 fffff880`010ea000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010ea000 fffff880`01148000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`01148000 fffff880`011ba000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`011ba000 fffff880`011d4000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`011d4000 fffff880`011e3000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`011e3000 fffff880`011f1000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`0121b000 fffff880`0122c000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0122c000 fffff880`01236000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01236000 fffff880`01257000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0125c000 fffff880`013ff000   Ntfs     Ntfs.sys     Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0142b000 fffff880`0143a000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0143a000 fffff880`01457000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01457000 fffff880`01472000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01472000 fffff880`014a1000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`014aa000 fffff880`0159d000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0159d000 fffff880`015fd000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01600000 fffff880`01645000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01645000 fffff880`0164e000   klim6    klim6.sys    Thu Apr 22 16:07:24 2010 (4BD0662C)
fffff880`0164f000 fffff880`01853000   tcpip    tcpip.sys    Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`01853000 fffff880`0189d000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`0189d000 fffff880`018ad000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`018ad000 fffff880`018f9000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`018f9000 fffff880`01917000   US40fs64 US40fs64.sys Fri Mar 05 13:03:05 2010 (4B910109)
fffff880`01917000 fffff880`0191f000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0191f000 fffff880`01959000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01959000 fffff880`0196b000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0196b000 fffff880`01988000   usbccgp  usbccgp.sys  Sat Nov 20 10:44:03 2010 (4CE7A673)
fffff880`01993000 fffff880`019bd000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`019bd000 fffff880`019e3000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`019e3000 fffff880`019f9000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`01a00000 fffff880`01a3a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01a3a000 fffff880`01a50000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01a50000 fffff880`01a80000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`01a86000 fffff880`021e5000   kl1      kl1.sys      Wed Jun 09 14:34:19 2010 (4C0F985B)
fffff880`021e5000 fffff880`021ee000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`021ee000 fffff880`021fc000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03000000 fffff880`0301e000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`0301e000 fffff880`03036000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0304e000 fffff880`03071000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`03071000 fffff880`03092000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`03092000 fffff880`030a7000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`030a7000 fffff880`030fa000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`030fa000 fffff880`0310d000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0310d000 fffff880`03125000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03125000 fffff880`031ee000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`03400000 fffff880`03409000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03409000 fffff880`0341d000   vpcnfltr vpcnfltr.sys Sat Nov 20 11:35:20 2010 (4CE7B278)
fffff880`0341f000 fffff880`034b5000   klif     klif.sys     Fri Aug 06 18:14:46 2010 (4C5C4306)
fffff880`034b5000 fffff880`034be000   Null     Null.SYS     unavailable (00000000)
fffff880`034be000 fffff880`034c5000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`034c5000 fffff880`034d3000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`034d3000 fffff880`034f8000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`034f8000 fffff880`03508000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`03508000 fffff880`03511000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`03511000 fffff880`0351a000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0351a000 fffff880`03523000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`03523000 fffff880`0352e000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0352e000 fffff880`0353f000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0353f000 fffff880`03561000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03561000 fffff880`0356e000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0356e000 fffff880`03575000   kl2      kl2.sys      Wed Jun 09 14:24:47 2010 (4C0F961F)
fffff880`03575000 fffff880`035fe000   afd      afd.sys      Sat Nov 20 09:23:27 2010 (4CE7938F)
fffff880`04400000 fffff880`0441b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0441d000 fffff880`04473600   vpcvmm   vpcvmm.sys   Sat Nov 20 11:35:48 2010 (4CE7B294)
fffff880`04474000 fffff880`04488000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`04488000 fffff880`044d9000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`044d9000 fffff880`044e5000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`044e5000 fffff880`044f0000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`044f0000 fffff880`044ff000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`044ff000 fffff880`04582000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`04582000 fffff880`045a0000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`045a0000 fffff880`045b1000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`045b1000 fffff880`045d7000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`045d7000 fffff880`045ed000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`045ed000 fffff880`045fc000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04800000 fffff880`04810000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`04810000 fffff880`04811480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`04812000 fffff880`04906000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04906000 fffff880`0494c000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0494c000 fffff880`04970000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04970000 fffff880`0497d000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`0497d000 fffff880`049d3000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`049d3000 fffff880`049e4000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`049e4000 fffff880`049f1000   fdc      fdc.sys      unavailable (00000000)
fffff880`049f1000 fffff880`049fd000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`04a00000 fffff880`04a15000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`04a15000 fffff880`04a36000   AtihdW76 AtihdW76.sys Thu Mar 31 08:15:43 2011 (4D942A1F)
fffff880`04a36000 fffff880`04a73000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`04a73000 fffff880`04a95000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`04a95000 fffff880`04a9a200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`04a9b000 fffff880`04ab0000   LHidFilt LHidFilt.Sys Thu Mar 18 08:51:17 2010 (4BA1E985)
fffff880`04ab0000 fffff880`04ac4000   LMouFilt LMouFilt.Sys Thu Mar 18 08:51:24 2010 (4BA1E98C)
fffff880`04acb000 fffff880`04b0e000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`04b0e000 fffff880`04b20000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`04b20000 fffff880`04b3d000   vpcusb   vpcusb.sys   Sat Nov 20 11:35:31 2010 (4CE7B283)
fffff880`04b3d000 fffff880`04b4c000   usbrpm   usbrpm.sys   Sat Nov 20 11:37:19 2010 (4CE7B2EF)
fffff880`04b4c000 fffff880`04b4df00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04b4e000 fffff880`04b8a000   vpchbus  vpchbus.sys  Sat Nov 20 11:35:38 2010 (4CE7B28A)
fffff880`04b8a000 fffff880`04be4000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`04be4000 fffff880`04bef000   flpydisk flpydisk.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`04bef000 fffff880`04bf9000   klmouflt klmouflt.sys Mon Nov 02 16:26:06 2009 (4AEF081E)
fffff880`05000000 fffff880`05024000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`05024000 fffff880`05030000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`05030000 fffff880`05044080   pcouffin pcouffin.sys Fri Jun 30 14:40:29 2006 (44A529CD)
fffff880`05049000 fffff880`05988000   atikmdag atikmdag.sys Wed May 25 03:40:32 2011 (4DDC6C20)
fffff880`05988000 fffff880`059ba000   Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`059ba000 fffff880`059d7000   parport  parport.sys  Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`059d7000 fffff880`059ed000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`059ed000 fffff880`059f8000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`06800000 fffff880`06819000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06819000 fffff880`06821080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0682b000 fffff880`06991c00   RTKVHD64 RTKVHD64.sys Fri Jun 27 04:21:58 2008 (48645CD6)
fffff880`06992000 fffff880`069a0000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`069a0000 fffff880`069ac000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`069ac000 fffff880`069b5000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`069b5000 fffff880`069c8000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`069c8000 fffff880`069d4000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`069d4000 fffff880`069e4000   LUsbFilt LUsbFilt.Sys Thu Mar 18 08:51:28 2010 (4BA1E990)
fffff880`069e4000 fffff880`069f2000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`069f2000 fffff880`069ff000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`06a00000 fffff880`06aa6000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`06aa6000 fffff880`06ab1000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`06ab1000 fffff880`06ae2000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`06ae5000 fffff880`06b12000   mrxsmb   mrxsmb.sys   Wed Feb 23 04:56:22 2011 (4D649376)
fffff880`06b12000 fffff880`06b5f000   mrxsmb10 mrxsmb10.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`06b5f000 fffff880`06b83000   mrxsmb20 mrxsmb20.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`06b83000 fffff880`06b9b000   adfs     adfs.SYS     Thu Jun 26 21:52:37 2008 (48640195)
fffff880`06b9b000 fffff880`06bc3000   idmwfp   idmwfp.sys   Thu Mar 17 15:32:32 2011 (4D822990)
fffff880`06bc3000 fffff880`06bd5000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`07000000 fffff880`0702d280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`07032000 fffff880`07033a80   MSPQM    MSPQM.sys    Tue Jul 14 01:00:17 2009 (4A5BCA91)
fffff880`0704f000 fffff880`070b8000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`070b8000 fffff880`07150000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`07150000 fffff880`07158000   gdrv     gdrv.sys     Sat Oct 13 08:22:00 2007 (47107218)
fffff880`07158000 fffff880`07160000   TuneUpUtilitiesDriver64 TuneUpUtilitiesDriver64.sys Thu Sep 17 12:54:52 2009 (4AB2238C)
fffff880`07160000 fffff880`0718e000   rdpdr    rdpdr.sys    Sat Nov 20 11:06:41 2010 (4CE7ABC1)
fffff880`0718e000 fffff880`07199000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`07199000 fffff880`071a8000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`071a8000 fffff880`071e1000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`071e1000 fffff880`071ec000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`0a643000 fffff880`0a679000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff960`000a0000 fffff960`003b1000   win32k   win32k.sys   unavailable (00000000)
fffff960`004a0000 fffff960`004aa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
fffff960`008d0000 fffff960`00931000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`0a694000 fffff880`0a6a0000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0a6a0000 fffff880`0a6a9000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0a6a9000 fffff880`0a6bc000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a679000 fffff880`0a694000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`07034000 fffff880`0704f000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`071ec000 fffff880`071f8000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07034000 fffff880`0703d000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`06bd5000 fffff880`06be8000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`07042000 fffff880`0704e000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07034000 fffff880`07036000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07036000 fffff880`07042000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07000000 fffff880`0702e000   usbvideo.sys
    Checksum:  00000000
    ImageSize:  0002E000
fffff880`07030000 fffff880`07032000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0702e000 fffff880`07030000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`07027000 fffff880`07033000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07033000 fffff880`0703c000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0703c000 fffff880`0704f000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a065000 fffff880`0a096000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0703d000 fffff880`07049000   ccdcmbx64.sy
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07031000 fffff880`0703d000   pccsmcfdx64.
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`071e1000 fffff880`071ef000   ccdcmbox64.s
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07000000 fffff880`0700e000   usbser.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`071ef000 fffff880`071f9000   usbser_lower
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`07018000 fffff880`07027000   modem.sys
    Checksum:  00000000
    ImageSize:  0000F000
fffff880`0700e000 fffff880`07018000   usbser_lower
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0a096000 fffff880`0a107000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`07000000 fffff880`07031000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0703d000 fffff880`0704e000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00031000
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00031000
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00031000
fffff880`071e1000 fffff880`071f2000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0703a000 fffff880`07046000   pccsmcfdx64.
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0701f000 fffff880`0703a000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`07013000 fffff880`0701f000   pccsmcfdx64.
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`071e1000 fffff880`071ed000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`071ed000 fffff880`071f6000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`07000000 fffff880`07013000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`08e7f000 fffff880`08ef0000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`021ee000 fffff880`021fc000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0196b000 fffff880`01977000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01977000 fffff880`01980000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01980000 fffff880`01993000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
zigzag3143
Honorable Member
Microsoft MVP
#7
To add to my colleague's excellent post these are the ones that need it the most
pcouffin.sys    6/30/2006 9:40:29 AM        fffff880`05030000    fffff880`05044080    0x00014080    0x44a529cd
gdrv.sys    10/13/2007 3:22:00 AM        fffff880`07150000    fffff880`07158000    0x00008000    0x47107218
adfs.SYS    6/26/2008 4:52:37 PM        fffff880`06b83000    fffff880`06b9b000    0x00018000    0x48640195
RTKVHD64.sys    6/26/2008 11:21:58 PM        fffff880`0682b000    fffff880`06991c00    0x00166c00    0x48645cd6
Rt64win7.sys    2/26/2009 5:04:13 AM        fffff880`05988000    fffff880`059ba000    0x00032000    0x49a65b0d
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
#8
I don't run my computer more than six hours straight, but I do always hibernate my computer, maybe that makes the system uptime thinks it run for 1 day?
After my computer comes out from hibernate state, I will be able to use my computer for about less than a minute before the BSOD (sometimes the screen just go black and I need to restart it manually) occurred. Is this related to the error in the red text? After I restarted, there is no more BSOD or black screen anymore...
ZigZag3143,
What should I do with the list of drivers you gave me? Should I download it and replace the one in my computer?
pcouffin.sys
gdrv.sys
adfs.SYS
RTKVHD64.sys
Rt64win7.sys
And here's my CPU-Z and GPU-Z report in rar file as you requested :)
