BSOD when running in regluar mode
hello,
i have a problem (again) i run the computer in regluar mode, then there's a BSOD within 2 minutes
Elmer
Hi lozzy123456,
Without the Minidump files there is little we can do to help you.
To ensure minidumps are enabled:
Go to Start, in the Search Box type: sysdm.cpl, press Enter.
Under the Advanced tab, click on the Startup and Recovery Settings... button.
Ensure that Automatically restart is unchecked.
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
OK your way out.
Reboot if changes have been made.
The .dmp files are located at C:\Windows\Minidump. Until a .dmp file is generated, the Minidump folder may not exist.
Go to your C:\Windows\Minidump folder. Copy the .dmp files to a new folder on your desktop. Zip up that folder and attach to a post
As soon as you can keep your PC open long enough, Take some screenshots as the instructions below:
Important! Every thread starter please see.
If you're having problems keeping the PC running, try Safe Mode with Networking.
HTH
Update Realtek HD Audio:
RTKVHD64.sys Tue Sep 15 07:02:10 2009
Check NVIDIA downloads for nForce updates:
nvmf6264.sys Thu Jul 30 19:48:18 2009
Check for Virtual Box and for VMWare updates too.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\013011-20560-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 UP Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`01e1a000 PsLoadedModuleList = 0xfffff800`02057e50
Debug session time: Sun Jan 30 11:46:18.404 2011 (UTC - 5:00)
System Uptime: 0 days 0:01:50.982
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {ffffffffc0000096, fffff80001e660fa, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!KeStackAttachProcess+1ba )
Followup: MachineOwner
kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000096, The exception code that was not handled
Arg2: fffff80001e660fa, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000096 - {EXCEPTION}  Privileged instruction.
FAULTING_IP:
fffff800`01e660fa 0f22d8          mov     cr3,rax
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
ERROR_CODE: (NTSTATUS) 0xc0000096 - {EXCEPTION}  Privileged instruction.
BUGCHECK_STR:  0x1E_c0000096
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff880074433f8 -- (.exr 0xfffff880074433f8)
ExceptionAddress: fffff80001e660fa (nt!KeStackAttachProcess+0x00000000000001ba)
   ExceptionCode: c0000096
  ExceptionFlags: 00000000
NumberParameters: 0
TRAP_FRAME:  fffff880074434a0 -- (.trap 0xfffff880074434a0)
rax=fffffa80021c8780 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80001e660fa rsp=fffff88007443630 rbp=fffff880074437a0
 r8=0000000000000000  r9=fffffa8002154840 r10=0000000000000001
r11=fffff8000208ab60 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
nt!KeStackAttachProcess+0x1ba:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80001ec4a39 to fffff80001e8a740
STACK_TEXT:
fffff880`07442c28 fffff800`01ec4a39 : 00000000`0000001e ffffffff`c0000096 fffff800`01e660fa 00000000`00000000 : nt!KeBugCheckEx
fffff880`07442c30 fffff800`01e89d82 : fffff880`074433f8 fffffa80`05773b60 fffff880`074434a0 fffff880`080d0730 : nt!KiDispatchException+0x1b9
fffff880`074432c0 fffff800`01e8868a : fffff880`07443c00 fffffa80`02154840 fffffa80`0239c850 fffff8a0`02a1cc50 : nt!KiExceptionDispatch+0xc2
fffff880`074434a0 fffff800`01e660fa : fffff880`07443648 fffff880`07443a28 fffff880`074437b8 fffffa80`0327aac6 : nt!KiGeneralProtectionFault+0x10a
fffff880`07443630 fffffa80`03277a93 : fffff880`074437b0 00000000`00000204 00000000`00000000 fffffa80`00000000 : nt!KeStackAttachProcess+0x1ba
fffff880`074436b0 fffff880`074437b0 : 00000000`00000204 00000000`00000000 fffffa80`00000000 00000000`00000000 : 0xfffffa80`03277a93
fffff880`074436b8 00000000`00000204 : 00000000`00000000 fffffa80`00000000 00000000`00000000 00000000`00000204 : 0xfffff880`074437b0
fffff880`074436c0 00000000`00000000 : fffffa80`00000000 00000000`00000000 00000000`00000204 00000000`00000000 : 0x204
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  nt!KeStackAttachProcess+1ba
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x1E_c0000096_nt!KeStackAttachProcess+1ba
Drivers:
fffff880`00ed5000 fffff880`00f2c000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02654000 fffff880`026de000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03997000 fffff880`039ad000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`02abf000 fffff880`02bf0000   agrsm64  agrsm64.sys  Thu Aug 13 11:20:43 2009 (4A842F4B)
fffff880`02548000 fffff880`0255f000   amdk8    amdk8.sys    Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`01155000 fffff880`01160000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00fdb000 fffff880`00fe4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c5c000 fffff880`00c86000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00870000 fffff960`008d1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`0142a000 fffff880`01431000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02511000 fffff880`02522000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06cd6000 fffff880`06cf4000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00730000 fffff960`00757000   cdd      cdd.dll      unavailable (00000000)
fffff880`01400000 fffff880`0142a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d1a000 fffff880`00dda000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`015ba000 fffff880`015ea000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cbc000 fffff880`00d1a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0143a000 fffff880`014ad000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03987000 fffff880`03997000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03cd1000 fffff880`03cdf000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`024f3000 fffff880`02511000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`024e4000 fffff880`024f3000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`017ce000 fffff880`017e4000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03ca9000 fffff880`03ccb000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03cdf000 fffff880`03ce9000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
fffff880`03d28000 fffff880`03d3b000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`03ce9000 fffff880`03d28000   dump_nvstor64 dump_nvstor64.sys Tue Aug 04 20:31:07 2009 (4A78D2CB)
fffff880`03d3b000 fffff880`03d47000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03838000 fffff880`0392c000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`0392c000 fffff880`03972000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`011ac000 fffff880`011c0000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01160000 fffff880`011ac000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`014be000 fffff880`014c8000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`0163a000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`016d4000 fffff880`0171e000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`023f6000 fffff800`0243f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06daa000 fffff880`06db6000   hcmon    hcmon.sys    Tue Sep 21 03:56:08 2010 (4C986518)
fffff880`025d1000 fffff880`025f5000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`03d72000 fffff880`03d8b000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`03d8b000 fffff880`03d93080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`03d64000 fffff880`03d72000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`06c0e000 fffff880`06cd6000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017c5000 fffff880`017ce000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`00fa9000 fffff880`00fb1000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c2d000 fffff880`02c3c000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03d94000 fffff880`03da2000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00baa000 fffff800`00bad000   kdcom    kdcom.dll    Fri Oct 08 07:17:09 2010 (4CAEFDB5)
fffff880`02a0f000 fffff880`02a52000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013cd000 fffff880`013e7000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`016a9000 fffff880`016d4000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`03ccb000 fffff880`03cd0200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03c31000 fffff880`03c46000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03dc8000 fffff880`03deb000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c9b000 fffff880`00ca8000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`02a00000 fffff880`02a0f000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`03dba000 fffff880`03dc8000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`02c3c000 fffff880`02c4b000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`03dad000 fffff880`03dba000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fc1000 fffff880`00fdb000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`06cf4000 fffff880`06d0c000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06d0c000 fffff880`06d39000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`06d39000 fffff880`06d87000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`06d87000 fffff880`06daa000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`011c9000 fffff880`011d4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f35000 fffff880`00f3f000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`024d9000 fffff880`024e4000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017b3000 fffff880`017c5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014c8000 fffff880`015ba000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`039d1000 fffff880`039dd000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03800000 fffff880`0382f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`02c8e000 fffff880`02ca3000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02718000 fffff880`02727000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`0260f000 fffff880`02654000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01649000 fffff880`016a9000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`011d4000 fffff880`011e5000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`024cd000 fffff880`024d9000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`01e1a000 fffff800`023f6000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0122a000 fffff880`013cd000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0163a000 fffff880`01643000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`037a3000 fffff880`037a4180   nvBridge nvBridge.kmd Wed Jul 29 12:06:04 2009 (4A70736C)
fffff880`02ca5000 fffff880`037a2f80   nvlddmkm nvlddmkm.sys Wed Jul 29 12:29:12 2009 (4A7078D8)
fffff880`02400000 fffff880`02451500   nvmf6264 nvmf6264.sys Thu Jul 30 19:48:18 2009 (4A723142)
fffff880`010b4000 fffff880`010f3000   nvstor64 nvstor64.sys Tue Aug 04 20:31:07 2009 (4A78D2CB)
fffff880`026f2000 fffff880`02718000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f7f000 fffff880`00f94000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f3f000 fffff880`00f72000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fb1000 fffff880`00fc1000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`014ad000 fffff880`014be000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07000000 fffff880`070a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`03c6c000 fffff880`03ca9000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ca8000 fffff880`00cbc000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`039ad000 fffff880`039d1000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`039dd000 fffff880`039f8000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`037a5000 fffff880`037c6000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`037c6000 fffff880`037e0000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0247c000 fffff880`024cd000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02c22000 fffff880`02c2d000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01431000 fffff880`0143a000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`013f5000 fffff880`013fe000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`011c0000 fffff880`011c9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01779000 fffff880`017b3000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03c46000 fffff880`03c5e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03a00000 fffff880`03be7a80   RTKVHD64 RTKVHD64.sys Tue Sep 15 07:02:10 2009 (4AAF7432)
fffff880`070a6000 fffff880`070b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01772000 fffff880`01779000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`0176a000 fffff880`01772000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0768c000 fffff880`07722000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07625000 fffff880`0768c000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`071aa000 fffff880`071d7000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`010f3000 fffff880`01155000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`039f8000 fffff880`039f9480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`071d7000 fffff880`071e9000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`011e5000 fffff880`011f2000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`00e00000 fffff880`00e1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`027cb000 fffff880`027df000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004d0000 fffff960`004da000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02522000 fffff880`02548000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`02c72000 fffff880`02c84000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`03d47000 fffff880`03d64000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`02bf0000 fffff880`02bf1f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`025c0000 fffff880`025d1000   usbehci  usbehci.sys  Sat Oct 24 00:27:33 2009 (4AE28235)
fffff880`02a52000 fffff880`02aac000   usbhub   usbhub.sys   Sat Oct 24 00:28:24 2009 (4AE28268)
fffff880`0255f000 fffff880`0256a000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0256a000 fffff880`025c0000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0279b000 fffff880`027caf00   VBoxDrv  VBoxDrv.sys  Fri Oct 08 09:52:29 2010 (4CAF221D)
fffff880`02c00000 fffff880`02c21b80   VBoxNetAdp VBoxNetAdp.sys Fri Oct 08 09:52:34 2010 (4CAF2222)
fffff880`02c4b000 fffff880`02c717c0   VBoxNetFlt VBoxNetFlt.sys Fri Oct 08 09:52:29 2010 (4CAF221D)
fffff880`0278f000 fffff880`0279a8c0   VBoxUSBMon VBoxUSBMon.sys Fri Oct 08 09:52:34 2010 (4CAF2222)
fffff880`00f72000 fffff880`00f7f000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`013e7000 fffff880`013f5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01200000 fffff880`01225000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`06db6000 fffff880`06dce000   vmci     vmci.sys     Tue Sep 21 03:24:22 2010 (4C985DA6)
fffff880`03da2000 fffff880`03dad000   VMkbd    VMkbd.sys    Tue Sep 21 04:46:23 2010 (4C9870DF)
fffff880`02742000 fffff880`0278f000   vmm      vmm.sys      Tue Apr 07 09:25:54 2009 (49DB5462)
fffff880`02c84000 fffff880`02c8e000   VMNET    VMNET.SYS    Mon Aug 10 08:04:50 2009 (4A800CE2)
fffff880`0382f000 fffff880`03837000   vmnetadapter vmnetadapter.sys Mon Aug 10 08:04:53 2009 (4A800CE5)
fffff880`03c21000 fffff880`03c31000   vmnetbridge vmnetbridge.sys Mon Aug 10 08:05:58 2009 (4A800D26)
fffff880`03972000 fffff880`03987000   VMNetSrv VMNetSrv.sys Wed Jan 16 06:52:01 2008 (478DEFE1)
fffff880`071e9000 fffff880`071f3000   vmnetuserif vmnetuserif.sys Tue Sep 21 04:10:42 2010 (4C986882)
fffff880`070d4000 fffff880`071aa000   vmx86    vmx86.sys    Tue Sep 21 05:33:47 2010 (4C987BFB)
fffff880`00f94000 fffff880`00fa9000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0171e000 fffff880`0176a000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`071f3000 fffff880`071ff000   vstor2_ws60 vstor2-ws60.sys Thu Aug 19 16:28:39 2010 (4C6D93F7)
fffff880`02727000 fffff880`02742000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0109d000 fffff880`010ad000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e22000 fffff880`00ec6000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ec6000 fffff880`00ed5000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`026e9000 fffff880`026f2000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`00350000   win32k   win32k.sys   unavailable (00000000)
fffff880`00f2c000 fffff880`00f35000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`026de000 fffff880`026e9000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 20:10:33 2009 (4A5BCCF9)
fffff880`03c00000 fffff880`03c21000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`017e4000 fffff880`017f2000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`017f2000 fffff880`017fc000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0105e000 fffff880`0109d000   dump_nvstor6
    Checksum:  00000000
    ImageSize:  0003F000
fffff880`015ea000 fffff880`015fd000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
idk how to check for VMware player updates
