First, thank you very much for looking at this. Ok, a lot to do.
Removed the NDIS Protocol Driver.
Had AMD Overdrive turned on, but hadn't really done much with it. Turned it off for now.
Un-installed EasyTune6, but could not find EasySaver. (found it later)
Not sure which AMD Special Tools you are refering to. I am using Revo Uninstaller. I see AMD Catalyst Install Manager (my video driver) and AMD GPU Clock Tool. I guess you could be talking about the clock tool. Let me know if that is what I should remove.
I do not see Gigabyte On/Off charge driver in Revo either. Please advise how to remove it.
As far as all the drivers, I have tried to update or remove any I could find. Comments below:
For the AMD driver, I updated it, but have had issues in the past with sound dropping and have had to revert to an older driver to correct it. I have been hestitant to upgrade for a while. If I have issues again, I will need to go back to the old, stable driver.
Pure Networks, Inc. Network Magic NDIS Relay Driver and Pure Networks, Inc. Network Magic Address Resolution Protocol Driver - This is an old Linksys wifi router. They don't appear to have a newer version, but I do not want to uninstall it as it is still in use.
Removed Blackberry software.
Gigabyte Easy Saver - mobo power utility driver - Uninstalled.
Removed DirecTV to PC.
Intel Storage drivers - I downloaded and installed these, but there was an error when writing to the registry and it says it cancelled. System rebooted fine.
NEC Electronics USB 3.0 Host Controller Driver & NEC Electronics USB 3.0 Host Controller Driver - Installed new driver from DriverGuide.
GIGABYTE On/Off Charge driver - Don't see this program. Went through startup and deleted all Gygabyte apps.
Did all this around four hours ago and have been in and out of FF since this with no BSOD's.
Attaching new info in case you see anything else:
